RTEMS
6.1
bsps
include
grlib
bspcommon.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
3
/* Common BSP/driver configuration routines.
4
5
* COPYRIGHT (c) 2015.
6
* Cobham Gaisler.
7
8
9
* modification, are permitted provided that the following conditions
10
* are met:
11
* 1. Redistributions of source code must retain the above copyright
12
* notice, this list of conditions and the following disclaimer.
13
* 2. Redistributions in binary form must reproduce the above copyright
14
* notice, this list of conditions and the following disclaimer in the
15
* documentation and/or other materials provided with the distribution.
16
17
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
18
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
19
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
20
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
21
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
22
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
23
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
24
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
25
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
26
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
27
* POSSIBILITY OF SUCH DAMAGE.
28
29
30
31
#ifndef __BSPCOMMON_H__
32
#define __BSPCOMMON_H__
33
34
drvmgr/drvmgr.h
35
36
#ifdef __cplusplus
37
extern
"C"
38
#endif
39
40
/* Count driver resource array length. Array must be terminated with a NULL */
41
int
get_resarray_count(
struct
drvmgr_bus_res
**array);
42
43
#ifdef __cplusplus
44
45
#endif
46
47
#endif
drvmgr.h
Driver Manager Interface.
drvmgr_bus_res
Definition:
drvmgr.h:238
