RTEMS 6.1
board_memories.h
6/* */
7/* All rights reserved. */
8/* */
11/* */
14/* */
17/* */
29
37#ifndef BOARD_MEMORIES_H
38#define BOARD_MEMORIES_H
39
40/*----------------------------------------------------------------------------
41 * Exported functions
42 *----------------------------------------------------------------------------*/
43
44#ifndef __rtems__
45extern void BOARD_ConfigureSdram(void);
46#else /* __rtems__ */
47extern void BOARD_ConfigureSdram(void) ATSAM_START_SRAM_SECTION;
48#endif /* __rtems__ */
49extern uint32_t BOARD_SdramValidation(uint32_t baseAddr, uint32_t size);
50
51#endif /* #ifndef BOARD_MEMORIES_H */
52
Configures the EBI for SDRAM (IS42S16100E-7B) access.
Definition: board_memories.c:152
