RTEMS 6.1
bestcomm_api_mem.h
1#ifndef __TASK_API_BESTCOMM_API_MEM_H
2#define __TASK_API_BESTCOMM_API_MEM_H 1
3
4/******************************************************************************
5*
6* Copyright (c) 2004 Freescale Semiconductor, Inc.
7*
8* Permission is hereby granted, free of charge, to any person obtaining a
9* copy of this software and associated documentation files (the "Software"),
10* to deal in the Software without restriction, including without limitation
11* the rights to use, copy, modify, merge, publish, distribute, sublicense,
12* and/or sell copies of the Software, and to permit persons to whom the
13* Software is furnished to do so, subject to the following conditions:
14*
15* The above copyright notice and this permission notice shall be included
16* in all copies or substantial portions of the Software.
17*
18* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
19* IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
20* FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
21* THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR
22* OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE,
23* ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR
24* OTHER DEALINGS IN THE SOFTWARE.
25*
26******************************************************************************/
27
28#include "../include/mgt5200/mgt5200.h"
29
30/*
31 * An extern global variable is used here for the MBAR since it must
32 * be passed into the API for processes that use virtual memory.
33 */
34extern uint8 *MBarGlobal;
35
36#define SDMA_TASK_BAR (MBarGlobal+MBAR_SDMA+0x000)
37#define SDMA_INT_PEND (MBarGlobal+MBAR_SDMA+0x014)
38#define SDMA_INT_MASK (MBarGlobal+MBAR_SDMA+0x018)
39#define SDMA_TCR (MBarGlobal+MBAR_SDMA+0x01C)
40#define SDMA_TASK_SIZE (MBarGlobal+MBAR_SDMA+0x060)
41
42#define PCI_TX_PKT_SIZE (MBarGlobal+MBAR_SCPCI+0x000)
43#define PCI_TX_NTBIT (MBarGlobal+MBAR_SCPCI+0x01C)
44#define PCI_TX_FIFO (MBarGlobal+MBAR_SCPCI+0x040)
45#define PCI_TX_FIFO_STAT (MBarGlobal+MBAR_SCPCI+0x045)
46#define PCI_TX_FIFO_GRAN (MBarGlobal+MBAR_SCPCI+0x048)
47#define PCI_TX_FIFO_ALARM (MBarGlobal+MBAR_SCPCI+0x04E)
48
49#define PCI_RX_PKT_SIZE (MBarGlobal+MBAR_SCPCI+0x080)
50#define PCI_RX_NTBIT (MBarGlobal+MBAR_SCPCI+0x09C)
51#define PCI_RX_FIFO (MBarGlobal+MBAR_SCPCI+0x0C0)
52#define PCI_RX_FIFO_STAT (MBarGlobal+MBAR_SCPCI+0x0C5)
53#define PCI_RX_FIFO_GRAN (MBarGlobal+MBAR_SCPCI+0x0C8)
54#define PCI_RX_FIFO_ALARM (MBarGlobal+MBAR_SCPCI+0x0CE)
55
56
57#define FEC_RX_FIFO (MBarGlobal+MBAR_ETHERNET+0x184)
58#define FEC_RX_FIFO_STAT (MBarGlobal+MBAR_ETHERNET+0x188)
59#define FEC_RX_FIFO_GRAN (MBarGlobal+MBAR_ETHERNET+0x18C)
60#define FEC_RX_FIFO_ALARM (MBarGlobal+MBAR_ETHERNET+0x198)
61
62#define FEC_TX_FIFO (MBarGlobal+MBAR_ETHERNET+0x1A4)
63#define FEC_TX_FIFO_STAT (MBarGlobal+MBAR_ETHERNET+0x1A8)
64#define FEC_TX_FIFO_GRAN (MBarGlobal+MBAR_ETHERNET+0x1AC)
65#define FEC_TX_FIFO_ALARM (MBarGlobal+MBAR_ETHERNET+0x1B8)
66
67#endif /* __TASK_API_BESTCOMM_API_MEM_H */
