RTEMS 6.1
bbb-pwm.h
1
9/*
10 * SPDX-License-Identifier: BSD-2-Clause
11 *
12 * Copyright (c) 2016 Punit Vara <punitvara@gmail.com>
13 *
16 * are met:
22 *
34 */
35
36
41#ifndef LIBBSP_ARM_BEAGLE_BBB_PWM_H
42#define LIBBSP_ARM_BEAGLE_BBB_PWM_H
43
44#ifdef __cplusplus
45extern "C" {
46#endif /* __cplusplus */
47
51#define BBB_CONTROL_CONF_GPMC_AD(n) (0x800 + (n * 4))
52#define BBB_CONTROL_CONF_LCD_DATA(n) (0x8a0 + (n * 4))
53
54
55typedef enum{
56 BBB_P8_13_2B = 3,
57 BBB_P8_19_2A,
58 BBB_P8_45_2A,
59 BBB_P8_46_2B,
60 BBB_P8_34_1B,
61 BBB_P8_36_1A,
62 BBB_P9_14_1A,
63 BBB_P9_16_1B,
64 BBB_P9_21_0B,
65 BBB_P9_22_0A,
66 BBB_P9_29_0B,
67 BBB_P9_31_0A
68}bbb_pwm_pin_t;
69
70#define BBB_P8_13_MUX_PWM 4
71#define BBB_P8_19_MUX_PWM 4
72#define BBB_P8_45_MUX_PWM 3
73#define BBB_P8_46_MUX_PWM 3
74#define BBB_P8_34_MUX_PWM 2
75#define BBB_P8_36_MUX_PWM 2
76#define BBB_P9_14_MUX_PWM 6
77#define BBB_P9_16_MUX_PWM 6
78#define BBB_P9_21_MUX_PWM 3
79#define BBB_P9_22_MUX_PWM 3
80#define BBB_P9_29_MUX_PWM 1
81#define BBB_P9_31_MUX_PWM 1
82#define BBB_PWM_FREQ_THRESHOLD 0.5f
83
98
99/* PWMSS setting
100 * set pulse argument of epwm module
101 *
102 * @param pwm_id : EPWMSS number , 0~2
103 * @param pwm_freq : frequency to be generated
104 * @param dutyA : Duty Cycle(in percentage) in PWM channel A
105 * @param dutyB : Duty Cycle(in percentage) in PWM channel B
106 *
107 * @return : 1 for success
108 * @return : 0 for failed
109 *
110 * @example : beagle_pwm_configure(0 , 50.0f , 50.0f , 25.0f); // Generate 50HZ pwm in PWM0 ,
111 * // duty cycle is 50% for ePWM0A , 25% for ePWM0B
112 *
113 * @Note :
114 * find an number nearst 65535 for TBPRD , to improve duty precision,
115 *
116 * Using big TBPRD can increase the range of CMPA and CMPB ,
117 * and it means we can get better precision on duty cycle.
118 *
119 * EX : 20.25% duty cycle
120 * on TBPRD = 62500 , CMPA = 12656.25 ( .25 rejection) , real duty : 20.2496% (12656 /62500)
121 * on TBPRD = 6250 , CMPA = 1265.625 ( .625 rejection), real duty : 20.24% (1265 6250)
122 * on TBPRD = 500 , CMPA = 101.25 ( .25 rejection) , real duty : 20.2% (101/500)
123 *
124 * Divisor = CLKDIV * HSPCLKDIV
125 * 1 TBPRD : 10 ns (default)
126 * 65535 TBPRD : 655350 ns
127 * 65535 TBPRD : 655350 * Divisor ns = X TBPRD : Cycle
128 *
129 * accrooding to that , we must find a Divisor value , let X nearest 65535 .
130 * so , Divisor must Nearest Cycle/655350
131 */
132int beagle_pwm_configure(BBB_PWMSS pwm_id, float pwm_freq, float duty_a, float duty_b);
133
144
155
168bool beagle_pwm_pinmux_setup(bbb_pwm_pin_t pin_no, BBB_PWMSS pwm_id);
169
180bool beagle_pwmss_is_running(unsigned int pwmss_id);
181
182
183#ifdef __cplusplus
184}
185#endif /* __cplusplus */
186
187#endif /* LIBBSP_ARM_BEAGLE_BBB_PWM_H */
bool beagle_pwm_disable(BBB_PWMSS pwmid)
This API disables the particular PWM module.
bool beagle_pwm_enable(BBB_PWMSS pwmid)
This API enables the particular PWM module.
This function determines whether PWMSS-wide clocks enabled or not.
bool beagle_pwm_init(BBB_PWMSS pwmss_id)
BeagleBone Black PWM API.
This function enables pinmuxing for PWM module.
BBB_PWMSS
The set of possible PWM subsystem module.
Definition: pwmss.h:58
