RTEMS 6.1
This header file provides the interfaces of the Base64 Encoding and Decoding. More...
#include <rtems/dev/io.h>Go to the source code of this file.
| struct | Base64_Decode_control |
| Contains the base64 and base64url decoder control. More... | |
Enumerations | |
| enum | Base64_Decode_state { BASE64_DECODE_STATE_0 , BASE64_DECODE_STATE_1 , BASE64_DECODE_STATE_2 , BASE64_DECODE_STATE_3 } |
| Represents the base64 and base64url decoder state. | |
| enum | Base64_Decode_status { BASE64_DECODE_SUCCESS , BASE64_DECODE_OVERFLOW , BASE64_DECODE_INVALID_INPUT } |
| Represents the base64 and base64url decoder status. | |
| int | _Base64_Encode (IO_Put_char put_char, void *arg, const void *src, size_t len, const char *wordbreak, int wordlen) |
| Outputs the source buffer in base64 encoding. | |
| int | _Base64url_Encode (IO_Put_char put_char, void *arg, const void *src, size_t len, const char *wordbreak, int wordlen) |
| Outputs the source buffer in base64url encoding. | |
| void | _Base64_Decode_initialize (Base64_Decode_control *self, uint8_t *target, size_t target_size) |
| Initializes the base64 decoder. | |
| Base64_Decode_status | _Base64_Decode (Base64_Decode_control *self, char ch) |
| Decodes the character. | |
