RTEMS 6.1
at91rm9200_mem.h File Reference
AT91RM9200 Memory Controller definitions. More...
#define EBI_CSA   0x00 /* Chip Select Assignment Register */
#define EBI_CFGR   0x04 /* Configuration Register */
#define EBI_CSA_CS4_CF   BIT4 /* 1 = CS4-6 are assigned to Compact Flash, 0 = Chip Selects */
#define EBI_CSA_CS3_SMM   BIT3 /* 1 = CS3 is assigned to SmartMedia, 0 = Chip Select */
#define EBI_CSA_CS1_SDRAM   BIT1 /* 1 = CS1 is assigned to SDRAM, 0 = Chip Select */
#define EBI_CSA_CS0_BF   BIT0 /* 1 = CS0 is assigned to Burst Flash, 0 = Chip Select */
#define EBI_CFGR_DBPU   BIT0 /* 1 = Disable D0-15 pullups */
#define SMC_CSR0   0x00 /* Chip Select Register 0 */
#define SMC_CSR1   0x04 /* Chip Select Register 1 */
#define SMC_CSR2   0x08 /* Chip Select Register 2 */
#define SMC_CSR3   0x0C /* Chip Select Register 3 */
#define SMC_CSR4   0x10 /* Chip Select Register 4 */
#define SMC_CSR5   0x14 /* Chip Select Register 5 */
#define SMC_CSR6   0x18 /* Chip Select Register 6 */
#define SMC_CSR7   0x1C /* Chip Select Register 7 */
#define SMC_CSR_RWHOLD(_x_)   ((_x_ & 0x3) << 28) /* Hold CS after R/W strobes */
#define SMC_CSR_RWSETUP(_x_)   ((_x_ & 0x3) << 24) /* Setup CS before R/W strobes */
#define SMC_CSR_ACSS_0   (0 << 16) /* Setup/Hold Address 0 clocks before/after CS */
#define SMC_CSR_ACSS_1   (1 << 16) /* Setup/Hold Address 1 clock before/after CS */
#define SMC_CSR_ACSS_2   (2 << 16) /* Setup/Hold Address 2 clocks before/after CS */
#define SMC_CSR_ACSS_3   (3 << 16) /* Setup/Hold Address 3 clocks before/after CS */
#define SMC_CSR_DRP_NORMAL   0 /* 0 = normal read protocol */
#define SMC_CSR_DRP_EARLY   BIT15 /* 1 = early read protocol */
#define SMC_CSR_DBW_16   (1 << 13) /* CS DataBus Width = 16-Bits */
#define SMC_CSR_DBW_8   (2 << 13) /* CS DataBus Width = 8 Bits */
#define SMC_CSR_BAT_16_1   0 /* Single 16-Bit device (when DBW is 16) */
#define SMC_CSR_BAT_16_2   BIT12 /* Dual 8-Bit devices (when DBW is 16) */
#define SMC_CSR_TDF(_x_)   ((_x_ & 0xf) << 8) /* Intercycle Data Float Time */
#define SMC_CSR_WSEN   BIT7 /* 1 = wait states are enabled */
#define SMC_CSR_NWS(_x_)   ((_x_ & 0x7f) << 0) /* Wait States + 1 */
#define SDRC_MR   0x00 /* Mode Register */
#define SDRC_TR   0x04 /* Refresh Timer Register */
#define SDRC_CR   0x08 /* Configuration Register */
#define SDRC_SRR   0x0C /* Self Refresh Register */
#define SDRC_LPR   0x10 /* Low Power Register */
#define SDRC_IER   0x14 /* Interrupt Enable Register */
#define SDRC_IDR   0x18 /* Interrupt Disable Register */
#define SDRC_IMR   0x1C /* Interrupt Mask Register */
#define SDRC_ISR   0x20 /* Interrupt Status Register */
#define SDRC_MR_DBW_16   BIT4 /* 1 = SDRAM is 16-bits wide, 0 = 32-bits */
#define SDRC_MR_NORM   (0 << 0) /* Normal Mode - All accesses to SDRAM are decoded normally */
#define SDRC_MR_NOP   (1 << 0) /* NOP Command is sent to SDRAM */
#define SDRC_MR_PRE   (2 << 0) /* Precharge All Command is sent to SDRAM */
#define SDRC_MR_MRS   (3 << 0) /* Mode Register Set Command is sent to SDRAM */
#define SDRC_MR_REF   (4 << 0) /* Refresh Command is sent to SDRAM */
#define SDRC_TR_COUNT(_x_)   ((_x_ & 0xfff) << 0)
#define SDRC_CR_TXSR(_x_)   ((_x_ & 0xf) << 27) /* CKE to ACT Time */
#define SDRC_CR_TRAS(_x_)   ((_x_ & 0xf) << 23) /* ACT to PRE Time */
#define SDRC_CR_TRCD(_x_)   ((_x_ & 0xf) << 19) /* RAS to CAS Time */
#define SDRC_CR_TRP(_x_)   ((_x_ & 0xf) << 15) /* PRE to ACT Time */
#define SDRC_CR_TRC(_x_)   ((_x_ & 0xf) << 11) /* REF to ACT Time */
#define SDRC_CR_TWR(_x_)   ((_x_ & 0xf) << 7) /* Write Recovery Time */
#define SDRC_CR_CAS_2   (2 << 5) /* Cas Delay = 2, this is the only supported value */
#define SDRC_CR_NB_2   0 /* 2 Banks per device */
#define SDRC_CR_NB_4   BIT4 /* 4 Banks per device */
#define SDRC_CR_NR_11   (0 << 2) /* Number of rows = 11 */
#define SDRC_CR_NR_12   (1 << 2) /* Number of rows = 12 */
#define SDRC_CR_NR_13   (2 << 2) /* Number of rows = 13 */
#define SDRC_CR_NC_8   (0 << 0) /* Number of columns = 8 */
#define SDRC_CR_NC_9   (1 << 0) /* Number of columns = 9 */
#define SDRC_CR_NC_10   (2 << 0) /* Number of columns = 10 */
#define SDRC_CR_NC_11   (3 << 0) /* Number of columns = 11 */
#define SDRC_SRR_SRCB   BIT0 /* 1 = Enter Self Refresh */
#define SDRC_LPR_LPCB   BIT0 /* 1 = De-assert CKE between accesses */
#define SDRC_INT_RES   BIT0 /* Refresh Error Status */
