RTEMS 6.1
at91rm9200_gpio.h File Reference
AT91RM9200 GPIO definitions. More...
#include <bits.h>
#define PIO_PER   0x00 /* PIO Enable Register */
#define PIO_PDR   0x04 /* PIO Disable Register */
#define PIO_PSR   0x08 /* PIO Status Register */
#define PIO_OER   0x10 /* Output Enable Register */
#define PIO_ODR   0x14 /* Output Disable Registerr */
#define PIO_OSR   0x18 /* Output Status Register */
#define PIO_IFER   0x20 /* Input Filter Enable Register */
#define PIO_IFDR   0x24 /* Input Filter Disable Register */
#define PIO_IFSR   0x28 /* Input Filter Status Register */
#define PIO_SODR   0x30 /* Set Output Data Register */
#define PIO_CODR   0x34 /* Clear Output Data Register */
#define PIO_ODSR   0x38 /* Output Data Status Register */
#define PIO_PDSR   0x3c /* Pin Data Status Register */
#define PIO_IER   0x40 /* Interrupt Enable Register */
#define PIO_IDR   0x44 /* Interrupt Disable Register */
#define PIO_IMR   0x48 /* Interrupt Mask Register */
#define PIO_ISR   0x4c /* Interrupt Status Register */
#define PIO_MDER   0x50 /* Multi-driver Enable Register */
#define PIO_MDDR   0x54 /* Multi-driver Disable Register */
#define PIO_MDSR   0x58 /* Multi-driver Status Register */
#define PIO_PUDR   0x60 /* Pull-up Disable Register */
#define PIO_PUER   0x64 /* Pull-up Enable Register */
#define PIO_PUSR   0x68 /* Pad Pull-up Status Register */
#define PIO_ASR   0x70 /* Select A Register */
#define PIO_BSR   0x74 /* Select B Register */
#define PIO_ABSR   0x78 /* AB Select Status Register */
#define PIO_OWER   0xA0 /* Output Write Enable Register */
#define PIO_OWDR   0xA4 /* Output Write Disable Register */
#define PIO_OWSR   0xA8 /* Output Write Status Register */
#define GPIO_0   BIT0
#define GPIO_1   BIT1
#define GPIO_2   BIT2
#define GPIO_3   BIT3
#define GPIO_4   BIT4
#define GPIO_5   BIT5
#define GPIO_6   BIT6
#define GPIO_7   BIT7
#define GPIO_8   BIT8
#define GPIO_9   BIT9
#define GPIO_10   BIT10
#define GPIO_11   BIT11
#define GPIO_12   BIT12
#define GPIO_13   BIT13
#define GPIO_14   BIT14
#define GPIO_15   BIT15
#define GPIO_16   BIT16
#define GPIO_17   BIT17
#define GPIO_18   BIT18
#define GPIO_19   BIT19
#define GPIO_20   BIT20
#define GPIO_21   BIT21
#define GPIO_22   BIT22
#define GPIO_23   BIT23
#define GPIO_24   BIT24
#define GPIO_25   BIT25
#define GPIO_26   BIT26
#define GPIO_27   BIT27
#define GPIO_28   BIT28
#define GPIO_29   BIT29
#define GPIO_30   BIT30
#define GPIO_31   BIT31
#define GPIO_32   BIT0
#define GPIO_33   BIT1
#define GPIO_34   BIT2
#define GPIO_35   BIT3
#define GPIO_36   BIT4
#define GPIO_37   BIT5
#define GPIO_38   BIT6
#define GPIO_39   BIT7
#define GPIO_40   BIT8
#define GPIO_41   BIT9
#define GPIO_42   BIT10
#define GPIO_43   BIT11
#define GPIO_44   BIT12
#define GPIO_45   BIT13
#define GPIO_46   BIT14
#define GPIO_47   BIT15
#define GPIO_48   BIT16
#define GPIO_49   BIT17
#define GPIO_50   BIT18
#define GPIO_51   BIT19
#define GPIO_52   BIT20
#define GPIO_53   BIT21
#define GPIO_54   BIT22
#define GPIO_55   BIT23
#define GPIO_56   BIT24
#define GPIO_57   BIT25
#define GPIO_58   BIT26
#define GPIO_59   BIT27
#define GPIO_60   BIT28
#define GPIO_61   BIT29
#define GPIO_62   BIT30
#define GPIO_63   BIT31
#define GPIO_64   BIT0
#define GPIO_65   BIT1
#define GPIO_66   BIT2
#define GPIO_67   BIT3
#define GPIO_68   BIT4
#define GPIO_69   BIT5
#define GPIO_70   BIT6
#define GPIO_71   BIT7
#define GPIO_72   BIT8
#define GPIO_73   BIT9
#define GPIO_74   BIT10
#define GPIO_75   BIT11
#define GPIO_76   BIT12
#define GPIO_77   BIT13
#define GPIO_78   BIT14
#define GPIO_79   BIT15
#define GPIO_80   BIT16
#define GPIO_81   BIT17
#define GPIO_82   BIT18
#define GPIO_83   BIT19
#define GPIO_84   BIT20
#define GPIO_85   BIT21
#define GPIO_86   BIT22
#define GPIO_87   BIT23
#define GPIO_88   BIT24
#define GPIO_89   BIT25
#define GPIO_90   BIT26
#define GPIO_91   BIT27
#define GPIO_92   BIT28
#define GPIO_93   BIT29
#define GPIO_94   BIT30
#define GPIO_95   BIT31
#define GPIO_96   BIT0
#define GPIO_97   BIT1
#define GPIO_98   BIT2
#define GPIO_99   BIT3
#define GPIO_100   BIT4
#define GPIO_101   BIT5
#define GPIO_102   BIT6
#define GPIO_103   BIT7
#define GPIO_104   BIT8
#define GPIO_105   BIT9
#define GPIO_106   BIT10
#define GPIO_107   BIT11
#define GPIO_108   BIT12
#define GPIO_109   BIT13
#define GPIO_110   BIT14
#define GPIO_111   BIT15
#define GPIO_112   BIT16
#define GPIO_113   BIT17
#define GPIO_114   BIT18
#define GPIO_115   BIT19
#define GPIO_116   BIT20
#define GPIO_117   BIT21
#define GPIO_118   BIT22
#define GPIO_119   BIT23
#define GPIO_120   BIT24
#define GPIO_121   BIT25
#define GPIO_122   BIT26
#define GPIO_123   BIT27
#define GPIO_124   BIT28
#define GPIO_125   BIT29
#define GPIO_126   BIT30
#define GPIO_127   BIT31
#define PIOA_ASR_MISO   BIT0 /* SPI Master In (RX), Slave out */
#define PIOA_ASR_MOSI   BIT1 /* SPI Master Out (TX), Slave In */
#define PIOA_ASR_SPCK   BIT2 /* SPI Clock */
#define PIOA_ASR_NPCS0   BIT3 /* SPI Chip Select 0 */
#define PIOA_ASR_NPCS1   BIT4 /* SPI Chip Select 1 */
#define PIOA_ASR_NPCS2   BIT5 /* SPI Chip Select 2 */
#define PIOA_ASR_NPCS3   BIT6 /* SPI Chip Select 3 */
#define PIOA_ASR_ETXCK   BIT7 /* EMAC TX Clock */
#define PIOA_ASR_ETXEN   BIT8 /* EMAC TXEN */
#define PIOA_ASR_ETX0   BIT9 /* EMAC TXD0 */
#define PIOA_ASR_ETX1   BIT10 /* EMAC TXD1 */
#define PIOA_ASR_ECRS   BIT11 /* EMAC CRS */
#define PIOA_ASR_ERX0   BIT12 /* EMAC RXD0 */
#define PIOA_ASR_ERX1   BIT13 /* EMAC RXD1 */
#define PIOA_ASR_ERXER   BIT14 /* EMAC RXER */
#define PIOA_ASR_EMDC   BIT15 /* EMAC MDC */
#define PIOA_ASR_EMDIO   BIT16 /* EMAC MDIO */
#define PIOA_ASR_TXD0   BIT17 /* USART 0 Receive */
#define PIOA_ASR_RXD0   BIT18 /* USART 0 Transmit */
#define PIOA_ASR_SCK0   BIT19 /* USART 0 Clock */
#define PIOA_ASR_CTS0   BIT20 /* USART 0 CTS */
#define PIOA_ASR_RTS0   BIT21 /* USART 0 RTS */
#define PIOA_ASR_RXD2   BIT22 /* USART 2 Receive */
#define PIOA_ASR_TXD2   BIT23 /* USART 2 Transmit */
#define PIOA_ASR_SCK2   BIT24 /* USART 2 Clock */
#define PIOA_ASR_TWD   BIT25 /* Two-Wire (I2C) Data */
#define PIOA_ASR_TWCK   BIT26 /* Two-Wire (I2C) Clock */
#define PIOA_ASR_MCCK   BIT27 /* MMC/SD Card Clock */
#define PIOA_ASR_MCCDA   BIT28 /* MMC/SD Card A Command */
#define PIOA_ASR_MCDA0   BIT29 /* MMC/SD Card A Data 0 */
#define PIOA_ASR_DRXD   BIT30 /* Debug Uart Receive */
#define PIOA_ASR_DTXD   BIT31 /* Debug Uart Transmit */
#define PIOA_BSR_PCK3   BIT0 /* Peripheral Clock 3 */
#define PIOA_BSR_PCK0   BIT1 /* Peripheral Clock 0 */
#define PIOA_BSR_IRQ4   BIT2 /* IRQ4 */
#define PIOA_BSR_IRQ5   BIT3 /* IRQ5 */
#define PIOA_BSR_TXD3   BIT5 /* USART 3 Transmit */
#define PIOA_BSR_RXD3   BIT6 /* USART 3 Receive */
#define PIOA_BSR_PCK2   BIT7 /* Peripheral Clock 2 */
#define PIOA_BSR_MCCDB   BIT8 /* MMC/SD Card B Command */
#define PIOA_BSR_MCDB0   BIT9 /* MMC/SD Card B Data 0 */
#define PIOA_BSR_MCDB1   BIT10 /* MMC/SD Card B Data 1 */
#define PIOA_BSR_MCDB2   BIT11 /* MMC/SD Card B Data 2 */
#define PIOA_BSR_MCDB3   BIT12 /* MMC/SD C ard B Data 3 */
#define PIOA_BSR_TCLK0   BIT13 /* Timer 0 Clock */
#define PIOA_BSR_TCLK1   BIT14 /* Timer 1 Clck */
#define PIOA_BSR_TCLK2   BIT15 /* Timer 2 Clock */
#define PIOA_BSR_IRQ6   BIT16 /* IRQ6 */
#define PIOA_BSR_TIOA0   BIT17 /* Timer 0 I/O A */
#define PIOA_BSR_TIOB0   BIT18 /* Timer 0 I/O B */
#define PIOA_BSR_TIOA1   BIT19 /* Timer 1 I/O A */
#define PIOA_BSR_TIOB1   BIT20 /* Timer 1 I/O B */
#define PIOA_BSR_TIOA2   BIT21 /* Timer 2 I/O A */
#define PIOA_BSR_TIOB2   BIT22 /* Timer 2 I/O B */
#define PIOA_BSR_IRQ3   BIT23 /* IRQ3 */
#define PIOA_BSR_PCK1   BIT24 /* Peripheral Clock 1 */
#define PIOA_BSR_IRQ2   BIT25 /* IRQ2 */
#define PIOA_BSR_IRQ1   BIT26 /* IRQ1 */
#define PIOA_BSR_TCLK3   BIT27 /* Timer Block Clock 3 (docs only show 0-2?) */
#define PIOA_BSR_TCLK4   BIT28 /* Timer Block Clock 4 */
#define PIOA_BSR_TCLK5   BIT29 /* Timer Block Clock 5 */
#define PIOA_BSR_CTS2   BIT30 /* USART 2 CTS */
#define PIOA_BSR_RTS2   BIT31 /* USART 2 RTS */
#define PIOB_ASR_TF0   BIT0 /* AC'97/I2S 0 Transmit Frame */
#define PIOB_ASR_TK0   BIT1 /* AC'97/I2S 0 Transmit Clock */
#define PIOB_ASR_TD0   BIT2 /* AC'97/I2S 0 Transmit Data */
#define PIOB_ASR_RD0   BIT3 /* AC'97/I2S 0 Receive Data */
#define PIOB_ASR_RK0   BIT4 /* AC'97/I2S 0 Receive Clock */
#define PIOB_ASR_RF0   BIT5 /* AC'97/I2S 0 Receive Frame */
#define PIOB_ASR_TF1   BIT6 /* AC'97/I2S 1 Transmit Frame */
#define PIOB_ASR_TK1   BIT7 /* AC'97/I2S 1 Transmit Clock */
#define PIOB_ASR_TD1   BIT8 /* AC'97/I2S 1 Transmit Data */
#define PIOB_ASR_RD1   BIT9 /* AC'97/I2S 1 Receive Data */
#define PIOB_ASR_RK1   BIT10 /* AC'97/I2S 1 Receive Clock */
#define PIOB_ASR_RF1   BIT11 /* AC'97/I2S 1 Receive Frame */
#define PIOB_ASR_TF2   BIT12 /* AC'97/I2S 1 Transmit Frame */
#define PIOB_ASR_TK2   BIT13 /* AC'97/I2S 1 Transmit Clock */
#define PIOB_ASR_TD2   BIT14 /* AC'97/I2S 1 Transmit Data */
#define PIOB_ASR_RD2   BIT15 /* AC'97/I2S 1 Receive Data */
#define PIOB_ASR_RK2   BIT16 /* AC'97/I2S 1 Receive Clock */
#define PIOB_ASR_RF2   BIT17 /* AC'97/I2S 1 Receive Frame */
#define PIOB_ASR_RI1   BIT18 /* USART 1 RI */
#define PIOB_ASR_DTR1   BIT19 /* USART 1 DTR */
#define PIOB_ASR_TXD1   BIT20 /* USART 1 TXD */
#define PIOB_ASR_RXD1   BIT21 /* USART 1 RXD */
#define PIOB_ASR_SCK1   BIT22 /* USART 1 SCK */
#define PIOB_ASR_DCD1   BIT23 /* USART 1 DCD */
#define PIOB_ASR_CTS1   BIT24 /* USART 1 CTS */
#define PIOB_ASR_DSR1   BIT25 /* USART 1 DSR */
#define PIOB_ASR_RTS1   BIT26 /* USART 1 RTS */
#define PIOB_ASR_PCK0   BIT27 /* Peripheral Clock 0 */
#define PIOB_ASR_FIQ   BIT28 /* FIQ */
#define PIOB_ASR_IRQ0   BIT29 /* IRQ0 */
#define PIOB_BSR_RTS3   BIT0 /* USART 3 */
#define PIOB_BSR_CTS3   BIT1 /* USART 3 */
#define PIOB_BSR_SCK3   BIT2 /* USART 3 */
#define PIOB_BSR_MCDA1   BIT3 /* MMC/SD Card A, Data 1 */
#define PIOB_BSR_MCDA2   BIT4 /* MMC/SD Card A, Data 2 */
#define PIOB_BSR_MCDA3   BIT5 /* MMC/SD Card A, Data 3 */
#define PIOB_BSR_TIOA3   BIT6 /* Timer 3 IO A */
#define PIOB_BSR_TIOB3   BIT7 /* Timer 3 IO B */
#define PIOB_BSR_TIOA4   BIT8 /* Timer 4 IO A */
#define PIOB_BSR_TIOB4   BIT9 /* Timer 4 IO B */
#define PIOB_BSR_TIOA5   BIT10 /* Timer 5 IO A */
#define PIOB_BSR_TIOB5   BIT11 /* Timer 5 IO B */
#define PIOB_BSR_ETX2   BIT12 /* EMAC TXD2 */
#define PIOB_BSR_ETX3   BIT13 /* EMAC TXD3 */
#define PIOB_BSR_ETXER   BIT14 /* EMAC TXER */
#define PIOB_BSR_ERX2   BIT15 /* EMAC RXD2 */
#define PIOB_BSR_ERX3   BIT16 /* EMAC RXD3 */
#define PIOB_BSR_ERXDV   BIT17 /* EMAC RXDV */
#define PIOB_BSR_ECOL   BIT18 /* EMAC COL */
#define PIOB_BSR_ERXCK   BIT19 /* EMAC RX Clock */
#define PIOB_BSR_EF100   BIT25 /* EMAC Speed 100 (RMII Only) */
#define PIOC_ASR_BFCK   BIT0 /* Burst Flash Clock */
#define PIOC_ASR_BFRDY   BIT1 /* Burst Flash Ready or SMC Card OE */
#define PIOC_ASR_BFAVD   BIT2 /* Burst Flash Address Valid */
#define PIOC_ASR_BFBAA   BIT3 /* Burst Flash Address Advance or SMC Card WE */
#define PIOC_ASR_BFOE   BIT4 /* Burst Flash OE */
#define PIOC_ASR_BFWE   BIT5 /* Burst Flash WE */
#define PIOC_ASR_NWAIT   BIT6 /* WAIT Input */
#define PIOC_ASR_A23   BIT7 /* A23 */
#define PIOC_ASR_A24   BIT8 /* A24 */
#define PIOC_ASR_A25   BIT9 /* A25 or Compact Flash R/W */
#define PIOC_ASR_NCS4   BIT10 /* CS4 or Compact Flash CS */
#define PIOC_ASR_NCS5   BIT11 /* CS5 or Compact Flash CE1 */
#define PIOC_ASR_NCS6   BIT12 /* CS6 or Compact Flash CE2 */
#define PIOC_ASR_NCS7   BIT13 /* CS7 */
#define PIOC_ASR_D16   BIT16 /* Databus Bit 16 */
#define PIOC_ASR_D17   BIT17 /* Databus Bit 17 */
#define PIOC_ASR_D18   BIT18 /* Databus Bit 18 */
#define PIOC_ASR_D19   BIT19 /* Databus Bit 19 */
#define PIOC_ASR_D20   BIT20 /* Databus Bit 20 */
#define PIOC_ASR_D21   BIT21 /* Databus Bit 21 */
#define PIOC_ASR_D22   BIT22 /* Databus Bit 22 */
#define PIOC_ASR_D23   BIT23 /* Databus Bit 23 */
#define PIOC_ASR_D24   BIT24 /* Databus Bit 24 */
#define PIOC_ASR_D25   BIT25 /* Databus Bit 25 */
#define PIOC_ASR_D26   BIT26 /* Databus Bit 26 */
#define PIOC_ASR_D27   BIT27 /* Databus Bit 27 */
#define PIOC_ASR_D28   BIT28 /* Databus Bit 28 */
#define PIOC_ASR_D29   BIT29 /* Databus Bit 29 */
#define PIOC_ASR_D30   BIT30 /* Databus Bit 30 */
#define PIOC_ASR_D31   BIT31 /* Databus Bit 31 */
#define PIOD_ASR_ETX0   BIT0 /* EMAC TXD0 */
#define PIOD_ASR_ETX1   BIT1 /* EMAC TXD1 */
#define PIOD_ASR_ETX2   BIT2 /* EMAC TXD2 */
#define PIOD_ASR_ETX3   BIT3 /* EMAC TXD3 */
#define PIOD_ASR_ETXEN   BIT4 /* EMAC TXEN */
#define PIOD_ASR_ETXER   BIT5 /* EMAC TXER */
#define PIOD_ASR_DTXD   BIT6 /* Debug UART Transmit */
#define PIOD_ASR_PCK0   BIT7 /* Peripheral Clock 0 */
#define PIOD_ASR_PCK1   BIT8 /* Peripheral Clock 1 */
#define PIOD_ASR_PCK2   BIT9 /* Peripheral Clock 2 */
#define PIOD_ASR_PCK3   BIT10 /* Peripheral Clock 3 */
#define PIOD_ASR_TD0   BIT15 /* AC'97/I2S 0 Transmit Data */
#define PIOD_ASR_TD1   BIT16 /* AC'97/I2S 1 Transmit Data */
#define PIOD_ASR_TD2   BIT17 /* AC'97/I2S 2 Transmit Data */
#define PIOD_ASR_NPCS1   BIT18 /* SPI Chip Select 1 */
#define PIOD_ASR_NPCS2   BIT19 /* SPI Chip Select 2 */
#define PIOD_ASR_NPCS3   BIT20 /* SPI Chip Select 3 */
#define PIOD_ASR_RTS0   BIT21 /* USART 0 RTS */
#define PIOD_ASR_RTS1   BIT22 /* USART 1 RTS */
#define PIOD_ASR_RTS2   BIT23 /* USART 2 RTS */
#define PIOD_ASR_RTS3   BIT24 /* USART 3 RTS */
#define PIOD_ASR_DTR1   BIT25 /* USART 1 DTR */
#define PIOC_ASR_TSYNC   BIT7 /* ETM Sync */
#define PIOC_ASR_TCLK   BIT8 /* ETM Clock */
#define PIOC_ASR_TPS0   BIT9 /* ETM Processor Status 0 */
#define PIOC_ASR_TPS1   BIT10 /* ETM Processor Status 1 */
#define PIOC_ASR_TPS2   BIT11 /* ETM Processor Status 2 */
#define PIOC_ASR_TPK0   BIT12 /* ETM Packet Data 0 */
#define PIOC_ASR_TPK1   BIT13 /* ETM Packet Data 1 */
#define PIOC_ASR_TPK2   BIT14 /* ETM Packet Data 2 */
#define PIOC_ASR_TPK3   BIT15 /* ETM Packet Data 3 */
#define PIOC_ASR_TPK4   BIT16 /* ETM Packet Data 4 */
#define PIOC_ASR_TPK5   BIT17 /* ETM Packet Data 5 */
#define PIOC_ASR_TPK6   BIT18 /* ETM Packet Data 6 */
#define PIOC_ASR_TPK7   BIT19 /* ETM Packet Data 7 */
#define PIOC_ASR_TPK8   BIT20 /* ETM Packet Data 8 */
#define PIOC_ASR_TPK9   BIT21 /* ETM Packet Data 9 */
#define PIOC_ASR_TPK10   BIT22 /* ETM Packet Data 10 */
#define PIOC_ASR_TPK11   BIT23 /* ETM Packet Data 11 */
#define PIOC_ASR_TPK12   BIT24 /* ETM Packet Data 12 */
#define PIOC_ASR_TPK13   BIT25 /* ETM Packet Data 13 */
#define PIOC_ASR_TPK14   BIT26 /* ETM Packet Data 14 */
#define PIOC_ASR_TPK15   BIT27 /* ETM Packet Data 15 */
