RTEMS 6.1
mmu.h
1
9/*
10 * Copyright (c) 2013 Alan Cudmore.
11 * based on work by:
12 * Copyright (c) 2009 embedded brains GmbH & Co. KG
13 *
14 * The license and distribution terms for this file may be
15 * found in the file LICENSE in this distribution or at
16 *
17 * http://www.rtems.org/license/LICENSE
18 *
19 */
20
21#ifndef LIBBSP_ARM_RASPBERRYPI_MMU_H
22#define LIBBSP_ARM_RASPBERRYPI_MMU_H
23
24#include <libcpu/arm-cp15.h>
25
26#ifdef __cplusplus
27extern "C" {
28#endif /* __cplusplus */
29
40#define RASPBERRYPI_MMU_CLIENT_DOMAIN 15U
41
42#define RASPBERRYPI_MMU_READ_ONLY \
43 ((RASPBERRYPI_MMU_CLIENT_DOMAIN << ARM_MMU_SECT_DOMAIN_SHIFT) \
44 | ARM_MMU_SECT_DEFAULT)
45
46#define RASPBERRYPI_MMU_READ_ONLY_CACHED \
47 (RASPBERRYPI_MMU_READ_ONLY | ARM_MMU_SECT_C | ARM_MMU_SECT_B)
48
49#define RASPBERRYPI_MMU_READ_WRITE \
50 ((RASPBERRYPI_MMU_CLIENT_DOMAIN << ARM_MMU_SECT_DOMAIN_SHIFT) \
51 | ARM_MMU_SECT_AP_0 \
52 | ARM_MMU_SECT_DEFAULT)
53
54#define RASPBERRYPI_MMU_READ_WRITE_CACHED \
55 (RASPBERRYPI_MMU_READ_WRITE | ARM_MMU_SECT_C | ARM_MMU_SECT_B)
56
59#ifdef __cplusplus
60}
61#endif /* __cplusplus */
62
63#endif /* LIBBSP_ARM_RASPBERRYPI_MMU_H */
ARM co-processor 15 (CP15) API.
