RTEMS
6.1
bsps
arm
lpc32xx
include
bsp
mmu.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
11
12
* Copyright (C) 2009, 2011 embedded brains GmbH & Co. KG
13
14
15
* modification, are permitted provided that the following conditions
16
* are met:
17
* 1. Redistributions of source code must retain the above copyright
18
* notice, this list of conditions and the following disclaimer.
19
* 2. Redistributions in binary form must reproduce the above copyright
20
* notice, this list of conditions and the following disclaimer in the
21
* documentation and/or other materials provided with the distribution.
22
23
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
24
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
25
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
26
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
27
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
28
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
29
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
30
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
31
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
32
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
33
* POSSIBILITY OF SUCH DAMAGE.
34
35
36
#ifndef LIBBSP_ARM_LPC32XX_MMU_H
37
#define LIBBSP_ARM_LPC32XX_MMU_H
38
39
libcpu/arm-cp15.h
40
41
#ifdef __cplusplus
42
extern
"C"
43
#endif
/* __cplusplus */
44
55
#define LPC32XX_MMU_CLIENT_DOMAIN 15U
56
57
#define LPC32XX_MMU_READ_ONLY \
58
((LPC32XX_MMU_CLIENT_DOMAIN << ARM_MMU_SECT_DOMAIN_SHIFT) \
59
| ARM_MMU_SECT_DEFAULT)
60
61
#define LPC32XX_MMU_READ_ONLY_CACHED \
62
(LPC32XX_MMU_READ_ONLY | ARM_MMU_SECT_C | ARM_MMU_SECT_B)
63
64
#define LPC32XX_MMU_READ_WRITE \
65
66
| ARM_MMU_SECT_AP_0 \
67
68
69
#define LPC32XX_MMU_READ_WRITE_CACHED \
70
(LPC32XX_MMU_READ_WRITE | ARM_MMU_SECT_C | ARM_MMU_SECT_B)
71
77
uint32_t
lpc32xx_set_translation_table_entries
78
const
void
*begin,
79
const
void
*end,
80
uint32_t section_flags
81
82
85
#ifdef __cplusplus
86
87
#endif
/* __cplusplus */
88
89
#endif
/* LIBBSP_ARM_LPC32XX_MMU_H */
arm-cp15.h
ARM co-processor 15 (CP15) API.
uint32_t lpc32xx_set_translation_table_entries(const void *begin, const void *end, uint32_t section_flags)
Sets the section_flags for the address range [begin, end).
Definition:
mmu.c:66
