RTEMS 6.1
ARM system low level start. More...
| #define | BSP_START_TEXT_SECTION __attribute__((section(".bsp_start_text"))) |
| #define | BSP_START_DATA_SECTION __attribute__((section(".bsp_start_data"))) |
| void | _start (void) |
| System start entry. | |
| void | bsp_start_hook_0 (void) |
| Start entry hook 0. | |
| void | bsp_start_hook_0_done (void) |
| Can be used by bsp_start_hook_0() to jump back to the start code instead of using the link register. | |
| void | bsp_start_hook_1 (void) |
| Start entry hook 1. | |
| void | bsp_start_memcpy (int *dest, const int *src, size_t n) |
| Similar to standard memcpy(). | |
| void | bsp_start_memcpy_arm (int *dest, const int *src, size_t n) |
| ARM entry point to bsp_start_memcpy(). | |
