RTEMS 6.1
arm-pl111-regs.h
2
11/*
12 * Copyright (c) 2013 embedded brains GmbH & Co. KG
13 *
16 * are met:
22 *
34 */
35
36#ifndef LIBBSP_ARM_SHARED_ARM_PL111_REGS_H
37#define LIBBSP_ARM_SHARED_ARM_PL111_REGS_H
38
39#include <bsp/utility.h>
40
41typedef struct {
42 uint32_t timing0;
43#define PL111_LCD_TIMING0_PPL(val) BSP_FLD32(val, 2, 7)
44#define PL111_LCD_TIMING0_PPL_GET(reg) BSP_FLD32GET(reg, 2, 7)
45#define PL111_LCD_TIMING0_PPL_SET(reg, val) BSP_FLD32SET(reg, val, 2, 7)
46#define PL111_LCD_TIMING0_HSW(val) BSP_FLD32(val, 8, 15)
47#define PL111_LCD_TIMING0_HSW_GET(reg) BSP_FLD32GET(reg, 8, 15)
48#define PL111_LCD_TIMING0_HSW_SET(reg, val) BSP_FLD32SET(reg, val, 8, 15)
49#define PL111_LCD_TIMING0_HFP(val) BSP_FLD32(val, 16, 23)
50#define PL111_LCD_TIMING0_HFP_GET(reg) BSP_FLD32GET(reg, 16, 23)
51#define PL111_LCD_TIMING0_HFP_SET(reg, val) BSP_FLD32SET(reg, val, 16, 23)
52#define PL111_LCD_TIMING0_HBP(val) BSP_FLD32(val, 24, 31)
53#define PL111_LCD_TIMING0_HBP_GET(reg) BSP_FLD32GET(reg, 24, 31)
54#define PL111_LCD_TIMING0_HBP_SET(reg, val) BSP_FLD32SET(reg, val, 24, 31)
55 uint32_t timing1;
56#define PL111_LCD_TIMING1_LPP(val) BSP_FLD32(val, 0, 9)
57#define PL111_LCD_TIMING1_LPP_GET(reg) BSP_FLD32GET(reg, 0, 9)
58#define PL111_LCD_TIMING1_LPP_SET(reg, val) BSP_FLD32SET(reg, val, 0, 9)
59#define PL111_LCD_TIMING1_VSW(val) BSP_FLD32(val, 10, 15)
60#define PL111_LCD_TIMING1_VSW_GET(reg) BSP_FLD32GET(reg, 10, 15)
61#define PL111_LCD_TIMING1_VSW_SET(reg, val) BSP_FLD32SET(reg, val, 10, 15)
62#define PL111_LCD_TIMING1_VFP(val) BSP_FLD32(val, 16, 23)
63#define PL111_LCD_TIMING1_VFP_GET(reg) BSP_FLD32GET(reg, 16, 23)
64#define PL111_LCD_TIMING1_VFP_SET(reg, val) BSP_FLD32SET(reg, val, 16, 23)
65#define PL111_LCD_TIMING1_VBP(val) BSP_FLD32(val, 24, 31)
66#define PL111_LCD_TIMING1_VBP_GET(reg) BSP_FLD32GET(reg, 24, 31)
67#define PL111_LCD_TIMING1_VBP_SET(reg, val) BSP_FLD32SET(reg, val, 24, 31)
68 uint32_t timing2;
69#define PL111_LCD_TIMING2_PCD_LO(val) BSP_FLD32(val, 0, 4)
70#define PL111_LCD_TIMING2_PCD_LO_GET(reg) BSP_FLD32GET(reg, 0, 4)
71#define PL111_LCD_TIMING2_PCD_LO_SET(reg, val) BSP_FLD32SET(reg, val, 0, 4)
72#define PL111_LCD_TIMING2_CLKSEL BSP_BIT32(5)
73#define PL111_LCD_TIMING2_ACB(val) BSP_FLD32(val, 6, 10)
74#define PL111_LCD_TIMING2_ACB_GET(reg) BSP_FLD32GET(reg, 6, 10)
75#define PL111_LCD_TIMING2_ACB_SET(reg, val) BSP_FLD32SET(reg, val, 6, 10)
76#define PL111_LCD_TIMING2_IVS BSP_BIT32(11)
77#define PL111_LCD_TIMING2_IHS BSP_BIT32(12)
78#define PL111_LCD_TIMING2_IPC BSP_BIT32(13)
79#define PL111_LCD_TIMING2_IOE BSP_BIT32(14)
80#define PL111_LCD_TIMING2_CPL(val) BSP_FLD32(val, 16, 25)
81#define PL111_LCD_TIMING2_CPL_GET(reg) BSP_FLD32GET(reg, 16, 25)
82#define PL111_LCD_TIMING2_CPL_SET(reg, val) BSP_FLD32SET(reg, val, 16, 25)
83#define PL111_LCD_TIMING2_BCD BSP_BIT32(26)
84#define PL111_LCD_TIMING2_PCD_HI(val) BSP_FLD32(val, 27, 31)
85#define PL111_LCD_TIMING2_PCD_HI_GET(reg) BSP_FLD32GET(reg, 27, 31)
86#define PL111_LCD_TIMING2_PCD_HI_SET(reg, val) BSP_FLD32SET(reg, val, 27, 31)
87 uint32_t timing3;
88#define PL111_LCD_TIMING3_LED(val) BSP_FLD32(val, 0, 6)
89#define PL111_LCD_TIMING3_LED_GET(reg) BSP_FLD32GET(reg, 0, 6)
90#define PL111_LCD_TIMING3_LED_SET(reg, val) BSP_FLD32SET(reg, val, 0, 6)
91#define PL111_LCD_TIMING3_LEE BSP_BIT32(16)
92 uint32_t upbase;
93 uint32_t lpbase;
94 uint32_t control;
95#define PL111_LCD_CONTROL_LCD_EN BSP_BIT32(0)
96#define PL111_LCD_CONTROL_LCD_BPP(val) BSP_FLD32(val, 1, 3)
97#define PL111_LCD_CONTROL_LCD_BPP_GET(reg) BSP_FLD32GET(reg, 1, 3)
98#define PL111_LCD_CONTROL_LCD_BPP_SET(reg, val) BSP_FLD32SET(reg, val, 1, 3)
99#define PL111_LCD_CONTROL_LCD_BPP_1 0x00U
100#define PL111_LCD_CONTROL_LCD_BPP_2 0x01U
101#define PL111_LCD_CONTROL_LCD_BPP_4 0x02U
102#define PL111_LCD_CONTROL_LCD_BPP_8 0x03U
103#define PL111_LCD_CONTROL_LCD_BPP_16 0x04U
104#define PL111_LCD_CONTROL_LCD_BPP_24 0x05U
105#define PL111_LCD_CONTROL_LCD_BPP_16_5_6_5 0x06U
106#define PL111_LCD_CONTROL_LCD_BPP_12 0x07U
107#define PL111_LCD_CONTROL_LCD_BW BSP_BIT32(4)
108#define PL111_LCD_CONTROL_LCD_TFT BSP_BIT32(5)
109#define PL111_LCD_CONTROL_LCD_MONO8 BSP_BIT32(6)
110#define PL111_LCD_CONTROL_LCD_DUAL BSP_BIT32(7)
111#define PL111_LCD_CONTROL_BGR BSP_BIT32(8)
112#define PL111_LCD_CONTROL_BEBO BSP_BIT32(9)
113#define PL111_LCD_CONTROL_BEPO BSP_BIT32(10)
114#define PL111_LCD_CONTROL_LCD_PWR BSP_BIT32(11)
115#define PL111_LCD_CONTROL_LCD_V_COMP(val) BSP_FLD32(val, 12, 13)
116#define PL111_LCD_CONTROL_LCD_V_COMP_GET(reg) BSP_FLD32GET(reg, 12, 13)
117#define PL111_LCD_CONTROL_LCD_V_COMP_SET(reg, val) BSP_FLD32SET(reg, val, 12, 13)
118#define PL111_LCD_CONTROL_WATERMARK BSP_BIT32(16)
119 uint32_t imsc;
120 uint32_t ris;
121 uint32_t mis;
122 uint32_t icr;
123#define PL111_LCD_I_FUF BSP_BIT32(1)
124#define PL111_LCD_I_LNBU BSP_BIT32(2)
125#define PL111_LCD_I_VCOMP BSP_BIT32(3)
126#define PL111_LCD_I_MBERROR BSP_BIT32(4)
127 uint32_t upcurr;
128 uint32_t lpcurr;
129 uint32_t reserved_34[115];
130 uint16_t pal[256];
131#define PL111_LCD_PAL_R(val) BSP_FLD16(val, 0, 4)
132#define PL111_LCD_PAL_R_GET(reg) BSP_FLD16GET(reg, 0, 4)
133#define PL111_LCD_PAL_R_SET(reg, val) BSP_FLD16SET(reg, val, 0, 4)
134#define PL111_LCD_PAL_G(val) BSP_FLD16(val, 5, 9)
135#define PL111_LCD_PAL_G_GET(reg) BSP_FLD16GET(reg, 5, 9)
136#define PL111_LCD_PAL_G_SET(reg, val) BSP_FLD16SET(reg, val, 5, 9)
137#define PL111_LCD_PAL_B(val) BSP_FLD16(val, 10, 14)
138#define PL111_LCD_PAL_B_GET(reg) BSP_FLD16GET(reg, 10, 14)
139#define PL111_LCD_PAL_B_SET(reg, val) BSP_FLD16SET(reg, val, 10, 14)
140#define PL111_LCD_PAL_I BSP_BIT16(15)
141} pl111_lcd;
142
143typedef struct {
144 uint8_t image[1024];
145 uint32_t ctrl;
146#define PL111_CRSR_CTRL_ON BSP_BIT32(0)
147#define PL111_CRSR_CTRL_NUMBER(val) BSP_FLD32(val, 4, 5)
148#define PL111_CRSR_CTRL_NUMBER_GET(reg) BSP_FLD32GET(reg, 4, 5)
149#define PL111_CRSR_CTRL_NUMBER_SET(reg, val) BSP_FLD32SET(reg, val, 4, 5)
150 uint32_t config;
151#define PL111_CRSR_CONFIG_SIZE BSP_BIT32(0)
152#define PL111_CRSR_CONFIG_FRAME_SYNC BSP_BIT32(1)
153 uint32_t palette0;
154 uint32_t palette1;
155#define PL111_CRSR_PALETTE_RED(val) BSP_FLD32(val, 0, 7)
156#define PL111_CRSR_PALETTE_RED_GET(reg) BSP_FLD32GET(reg, 0, 7)
157#define PL111_CRSR_PALETTE_RED_SET(reg, val) BSP_FLD32SET(reg, val, 0, 7)
158#define PL111_CRSR_PALETTE_GREEN(val) BSP_FLD32(val, 8, 15)
159#define PL111_CRSR_PALETTE_GREEN_GET(reg) BSP_FLD32GET(reg, 8, 15)
160#define PL111_CRSR_PALETTE_GREEN_SET(reg, val) BSP_FLD32SET(reg, val, 8, 15)
161#define PL111_CRSR_PALETTE_BLUE(val) BSP_FLD32(val, 16, 23)
162#define PL111_CRSR_PALETTE_BLUE_GET(reg) BSP_FLD32GET(reg, 16, 23)
163#define PL111_CRSR_PALETTE_BLUE_SET(reg, val) BSP_FLD32SET(reg, val, 16, 23)
164 uint32_t xy;
165#define PL111_CRSR_XY_X(val) BSP_FLD32(val, 0, 9)
166#define PL111_CRSR_XY_X_GET(reg) BSP_FLD32GET(reg, 0, 9)
167#define PL111_CRSR_XY_X_SET(reg, val) BSP_FLD32SET(reg, val, 0, 9)
168#define PL111_CRSR_XY_X_EXP(val) BSP_FLD32(val, 10, 11)
169#define PL111_CRSR_XY_X_EXP_GET(reg) BSP_FLD32GET(reg, 10, 11)
170#define PL111_CRSR_XY_X_EXP_SET(reg, val) BSP_FLD32SET(reg, val, 10, 11)
171#define PL111_CRSR_XY_Y(val) BSP_FLD32(val, 16, 25)
172#define PL111_CRSR_XY_Y_GET(reg) BSP_FLD32GET(reg, 16, 25)
173#define PL111_CRSR_XY_Y_SET(reg, val) BSP_FLD32SET(reg, val, 16, 25)
174#define PL111_CRSR_XY_Y_EXP(val) BSP_FLD32(val, 25, 27)
175#define PL111_CRSR_XY_Y_EXP_GET(reg) BSP_FLD32GET(reg, 25, 27)
176#define PL111_CRSR_XY_Y_EXP_SET(reg, val) BSP_FLD32SET(reg, val, 25, 27)
177 uint32_t clip;
178#define PL111_CRSR_CLIP_X(val) BSP_FLD32(val, 0, 5)
179#define PL111_CRSR_CLIP_X_GET(reg) BSP_FLD32GET(reg, 0, 5)
180#define PL111_CRSR_CLIP_X_SET(reg, val) BSP_FLD32SET(reg, val, 0, 5)
181#define PL111_CRSR_CLIP_Y(val) BSP_FLD32(val, 8, 13)
182#define PL111_CRSR_CLIP_Y_GET(reg) BSP_FLD32GET(reg, 8, 13)
183#define PL111_CRSR_CLIP_Y_SET(reg, val) BSP_FLD32SET(reg, val, 8, 13)
184 uint32_t imsc;
185 uint32_t icr;
186 uint32_t ris;
187 uint32_t mis;
188#define PL111_CRSR_I_CRSR BSP_BIT32(0)
189} pl111_crsr;
190
191typedef struct {
193 uint32_t reserved_400[256];
194 pl111_crsr crsr;
195} pl111;
196
197#endif /* LIBBSP_ARM_SHARED_ARM_PL111_REGS_H */
This header file provides utility macros for BSPs.
Definition: deflate.c:114
Definition: intercom.c:87
Definition: 8xx_immap.h:195
Definition: arm-pl111-regs.h:143
Definition: arm-pl111-regs.h:41
Definition: arm-pl111-regs.h:191
