RTEMS 6.1
arm-a9mpcore-start.h
2
11/*
12 * Copyright (C) 2013, 2014 embedded brains GmbH & Co. KG
13 *
16 * are met:
22 *
34 */
35
36#ifndef LIBBSP_ARM_SHARED_ARM_A9MPCORE_START_H
37#define LIBBSP_ARM_SHARED_ARM_A9MPCORE_START_H
38
39#include <rtems/score/smpimpl.h>
40
41#include <libcpu/arm-cp15.h>
42
43#include <bsp.h>
44#include <bsp/start.h>
46#include <bsp/arm-cp15-start.h>
47#include <bsp/arm-errata.h>
48#include <dev/irq/arm-gic-irq.h>
49
50#ifdef __cplusplus
51extern "C" {
52#endif /* __cplusplus */
53
60BSP_START_TEXT_SECTION static inline void arm_a9mpcore_start_scu_invalidate(
61 volatile a9mpcore_scu *scu,
62 uint32_t cpu_id,
63 uint32_t ways
64)
65{
66 scu->invss = (ways & 0xf) << ((cpu_id & 0x3) * 4);
67}
68
69BSP_START_TEXT_SECTION static inline void
70arm_a9mpcore_start_errata_764369_handler(volatile a9mpcore_scu *scu)
71{
72 if (arm_errata_is_applicable_processor_errata_764369()) {
73 scu->diagn_ctrl |= A9MPCORE_SCU_DIAGN_CTRL_MIGRATORY_BIT_DISABLE;
74 }
75}
76
77BSP_START_TEXT_SECTION static inline void
78arm_a9mpcore_start_scu_enable(volatile a9mpcore_scu *scu)
79{
80 scu->ctrl |= A9MPCORE_SCU_CTRL_SCU_EN;
81 arm_a9mpcore_start_errata_764369_handler(scu);
82}
83
84#ifdef RTEMS_SMP
85BSP_START_TEXT_SECTION static inline void
86arm_a9mpcore_start_on_secondary_processor(void)
87{
88 uint32_t ctrl;
89
90 arm_gic_irq_initialize_secondary_cpu();
91
92 /* Change the VBAR from the start to the normal vector table */
93 arm_cp15_set_vector_base_address(bsp_vector_table_begin);
94
95 ctrl = arm_cp15_start_setup_mmu_and_cache(
96 0,
97 ARM_CP15_CTRL_AFE | ARM_CP15_CTRL_Z
98 );
99
100 arm_cp15_set_domain_access_control(
101 ARM_CP15_DAC_DOMAIN(ARM_MMU_DEFAULT_CLIENT_DOMAIN, ARM_CP15_DAC_CLIENT)
102 );
103
104 /* FIXME: Sharing the translation table between processors is brittle */
105 arm_cp15_set_translation_table_base(
106 (uint32_t *) bsp_translation_table_base
107 );
108
109 ctrl |= ARM_CP15_CTRL_I | ARM_CP15_CTRL_C | ARM_CP15_CTRL_M;
110 arm_cp15_set_control(ctrl);
111
112 _SMP_Start_multitasking_on_secondary_processor(_Per_CPU_Get());
113}
114
115BSP_START_TEXT_SECTION static inline void
116arm_a9mpcore_start_enable_smp_in_auxiliary_control(void)
117{
118 /*
119 * Enable cache coherency support and cache/MMU maintenance broadcasts for
120 * this processor.
121 */
122 uint32_t actlr = arm_cp15_get_auxiliary_control();
123 actlr |= ARM_CORTEX_A9_ACTL_SMP | ARM_CORTEX_A9_ACTL_FW;
124 arm_cp15_set_auxiliary_control(actlr);
125}
126
127BSP_START_TEXT_SECTION static inline void
128arm_a9mpcore_start_errata_794072_handler(void)
129{
130 uint32_t diag;
131
132 /*
133 * Workaround for Errata 794072: A short loop including a DMB instruction
134 * might cause a denial of service on another which executes a CP15 broadcast
135 * operation.
136 */
137 diag = arm_cp15_get_diagnostic_control();
138 diag |= 1U << 4;
139 arm_cp15_set_diagnostic_control(diag);
140}
141
142BSP_START_TEXT_SECTION static inline void
143arm_a9mpcore_start_errata_845369_handler(void)
144{
145 uint32_t diag;
146
147 /*
148 * Workaround for Errata 845369: Under Very Rare Timing Circumstances
149 * Transition into Streaming Mode Might Create Data Corruption.
150 */
151 diag = arm_cp15_get_diagnostic_control();
152 diag |= 1U << 22;
153 arm_cp15_set_diagnostic_control(diag);
154}
155#endif
156
157BSP_START_TEXT_SECTION static inline void arm_a9mpcore_start_hook_0(void)
158{
159 volatile a9mpcore_scu *scu =
160 (volatile a9mpcore_scu *) BSP_ARM_A9MPCORE_SCU_BASE;
161 uint32_t cpu_id = arm_cortex_a9_get_multiprocessor_cpu_id();
162
163 if (cpu_id == 0) {
164 arm_a9mpcore_start_scu_enable(scu);
165 }
166
167#ifdef RTEMS_SMP
168 arm_a9mpcore_start_errata_794072_handler();
169 arm_a9mpcore_start_errata_845369_handler();
170 arm_a9mpcore_start_enable_smp_in_auxiliary_control();
171#endif
172
173 arm_a9mpcore_start_scu_invalidate(scu, cpu_id, 0xf);
174
175#ifdef RTEMS_SMP
176 if (cpu_id != 0) {
177 arm_a9mpcore_start_on_secondary_processor();
178 }
179#endif
180}
181
182BSP_START_TEXT_SECTION static inline void arm_a9mpcore_start_global_timer(void)
183{
184 volatile a9mpcore_gt *gt = (volatile a9mpcore_gt *) BSP_ARM_A9MPCORE_GT_BASE;
185
186 gt->ctrl = 0;
187 gt->cntrlower = 0;
188 gt->cntrupper = 0;
189 gt->ctrl = A9MPCORE_GT_CTRL_TMR_EN;
190}
191
192BSP_START_TEXT_SECTION static inline void arm_a9mpcore_start_hook_1(void)
193{
194 arm_a9mpcore_start_global_timer();
195}
196
199#ifdef __cplusplus
200}
201#endif /* __cplusplus */
202
203#endif /* LIBBSP_ARM_SHARED_ARM_A9MPCORE_START_H */
This header file provides the interfaces of the Cortex-A9 MPCore Support.
Arm CP15 start.
ARM co-processor 15 (CP15) API.
Create #defines which state which erratas shall get applied.
This header file provides interfaces of the ARM Generic Interrupt Controller (GIC) support.
This header file provides interfaces of the SMP Support which are only used by the implementation.
Definition: arm-a9mpcore-regs.h:98
Definition: arm-a9mpcore-regs.h:51
