RTEMS
6.1
bsps
include
grlib
ambapp_bus_grlib.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
3
/* LEON3 GRLIB AMBA Plug & Play bus driver interface.
4
5
* COPYRIGHT (c) 2008.
6
* Cobham Gaisler AB.
7
8
* This is driver is a wrapper for the general AMBA Plug & Play bus
9
* driver. This is the root bus driver for GRLIB systems.
10
11
12
* modification, are permitted provided that the following conditions
13
* are met:
14
* 1. Redistributions of source code must retain the above copyright
15
* notice, this list of conditions and the following disclaimer.
16
* 2. Redistributions in binary form must reproduce the above copyright
17
* notice, this list of conditions and the following disclaimer in the
18
* documentation and/or other materials provided with the distribution.
19
20
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
21
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
22
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
23
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
24
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
25
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
26
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
27
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
28
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
29
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
30
* POSSIBILITY OF SUCH DAMAGE.
31
32
33
#ifndef __AMBAPP_BUS_GRLIB_H__
34
#define __AMBAPP_BUS_GRLIB_H__
35
36
#ifdef __cplusplus
37
extern
"C"
38
#endif
39
40
struct
grlib_config
41
struct
ambapp_bus
*abus;
42
struct
drvmgr_bus_res
*resources;
43
44
45
/* Register GRLIB AMBA PnP Bus as root bus at driver manager */
46
extern
int
ambapp_grlib_root_register(
struct
grlib_config
config
47
48
/* Register bus driver to Driver Manager */
49
void
ambapp_grlib_register(
void
50
51
#ifdef __cplusplus
52
53
#endif
54
55
#endif
ambapp_bus
Definition:
ambapp.h:133
config_s
Definition:
deflate.c:114
drvmgr_bus_res
Definition:
drvmgr.h:238
grlib_config
Definition:
ambapp_bus_grlib.h:40
