RTEMS 6.1
am29lv160.h
1/*
2 * RTEMS Project (http://www.rtems.org/)
3 *
4 * Copyright 2007 Chris Johns (chrisj@rtems.org)
5 */
6
14#if !defined (_RTEMS_AM29LV160_H_)
15#define _RTEMS_AM29LV160_H_
16
17#include <rtems/flashdisk.h>
18
22#define rtems_am29lv160t_segment_count (4)
23extern const rtems_fdisk_segment_desc rtems_am29lv160t_segments[4];
24
28#define rtems_am29lv160b_segment_count (4)
29extern const rtems_fdisk_segment_desc rtems_am29lv160b_segments[4];
30
34extern const rtems_fdisk_driver_handlers rtems_am29lv160_handlers;
35
40{
41 int bus_8bit;
42 void* base;
44
48extern const rtems_am29lv160_config rtems_am29lv160_configuration[];
49
53extern uint32_t rtems_am29lv160_configuration_size;
54
55#endif
Interface to a Flash Disk Block Device.
Definition: am29lv160.h:40
Flash Low Level driver handlers.
Definition: flashdisk.h:220
Flash Segment Descriptor holds, number of continuous segments in the device of this type,...
Definition: flashdisk.h:194
