RTEMS 6.1
alt_l3.h
1
7/*******************************************************************************
8* *
9* Copyright 2013 Altera Corporation. All Rights Reserved. *
10* *
11* Redistribution and use in source and binary forms, with or without *
12* modification, are permitted provided that the following conditions are met: *
13* *
14* 1. Redistributions of source code must retain the above copyright notice, *
15* this list of conditions and the following disclaimer. *
16* *
17* 2. Redistributions in binary form must reproduce the above copyright notice, *
18* this list of conditions and the following disclaimer in the documentation *
19* and/or other materials provided with the distribution. *
20* *
21* 3. The name of the author may not be used to endorse or promote products *
22* derived from this software without specific prior written permission. *
23* *
24* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDER "AS IS" AND ANY EXPRESS OR *
25* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF *
26* MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE, ARE DISCLAIMED. IN NO *
27* EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, *
28* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, *
29* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; *
30* OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, *
31* WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR *
32* OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF *
33* ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. *
34* *
35*******************************************************************************/
36
37/* Altera - ALT_L3 */
38
39#ifndef __ALTERA_ALT_L3_H__
40#define __ALTERA_ALT_L3_H__
41
42#ifdef __cplusplus
43extern "C"
44{
45#endif /* __cplusplus */
46
47/*
48 * Component : L3 (NIC-301) GPV Registers - ALT_L3
49 * L3 (NIC-301) GPV Registers
50 *
51 * Registers to control L3 interconnect settings
52 *
53 */
54/*
55 * Register : Remap - remap
56 *
57 * The L3 interconnect has separate address maps for the various L3 Masters.
58 * Generally, the addresses are the same for most masters. However, the sparse
59 * interconnect of the L3 switch causes some masters to have holes in their memory
60 * maps. The remap bits are not mutually exclusive. Each bit can be set
61 * independently and in combinations. Priority for the bits is determined by the
62 * bit offset: lower offset bits take precedence over higher offset bits.
63 *
64 * Register Layout
65 *
66 * Bits | Access | Reset | Description
67 * :-------|:-------|:------|:---------------------------------
68 * [0] | W | 0x0 | MPU at 0x0
69 * [1] | W | 0x0 | Non-MPU at 0x0
70 * [2] | ??? | 0x0 | *UNDEFINED*
71 * [3] | W | 0x0 | HPS2FPGA AXI Bridge Visibility
72 * [4] | W | 0x0 | LWHPS2FPGA AXI Bridge Visibility
73 * [31:5] | ??? | 0x0 | *UNDEFINED*
74 *
75 */
76/*
77 * Field : MPU at 0x0 - mpuzero
78 *
79 * Controls whether address 0x0 for the MPU L3 master is mapped to the Boot ROM or
80 * On-chip RAM. This field only has an effect on the MPU L3 master.
81 *
82 * Field Enumeration Values:
83 *
84 * Enum | Value | Description
85 * :-------------------------------|:------|:-------------------------------------------------
86 * ALT_L3_REMAP_MPUZERO_E_BOOTROM | 0x0 | Maps the Boot ROM to address 0x0 for the MPU L3
87 * : | | master. Note that the Boot ROM is also always
88 * : | | mapped to address 0xfffd_0000 for the MPU L3
89 * : | | master independent of this field's value.
90 * ALT_L3_REMAP_MPUZERO_E_OCRAM | 0x1 | Maps the On-chip RAM to address 0x0 for the MPU
91 * : | | L3 master. Note that the On-chip RAM is also
92 * : | | always mapped to address 0xffff_0000 for the MPU
93 * : | | L3 master independent of this field's value.
94 *
95 * Field Access Macros:
96 *
97 */
98/*
99 * Enumerated value for register field ALT_L3_REMAP_MPUZERO
100 *
101 * Maps the Boot ROM to address 0x0 for the MPU L3 master. Note that the Boot ROM
102 * is also always mapped to address 0xfffd_0000 for the MPU L3 master independent
103 * of this field's value.
104 */
105#define ALT_L3_REMAP_MPUZERO_E_BOOTROM 0x0
106/*
107 * Enumerated value for register field ALT_L3_REMAP_MPUZERO
108 *
109 * Maps the On-chip RAM to address 0x0 for the MPU L3 master. Note that the On-chip
110 * RAM is also always mapped to address 0xffff_0000 for the MPU L3 master
111 * independent of this field's value.
112 */
113#define ALT_L3_REMAP_MPUZERO_E_OCRAM 0x1
114
115/* The Least Significant Bit (LSB) position of the ALT_L3_REMAP_MPUZERO register field. */
116#define ALT_L3_REMAP_MPUZERO_LSB 0
117/* The Most Significant Bit (MSB) position of the ALT_L3_REMAP_MPUZERO register field. */
118#define ALT_L3_REMAP_MPUZERO_MSB 0
119/* The width in bits of the ALT_L3_REMAP_MPUZERO register field. */
120#define ALT_L3_REMAP_MPUZERO_WIDTH 1
121/* The mask used to set the ALT_L3_REMAP_MPUZERO register field value. */
122#define ALT_L3_REMAP_MPUZERO_SET_MSK 0x00000001
123/* The mask used to clear the ALT_L3_REMAP_MPUZERO register field value. */
124#define ALT_L3_REMAP_MPUZERO_CLR_MSK 0xfffffffe
125/* The reset value of the ALT_L3_REMAP_MPUZERO register field. */
126#define ALT_L3_REMAP_MPUZERO_RESET 0x0
127/* Extracts the ALT_L3_REMAP_MPUZERO field value from a register. */
128#define ALT_L3_REMAP_MPUZERO_GET(value) (((value) & 0x00000001) >> 0)
129/* Produces a ALT_L3_REMAP_MPUZERO register field value suitable for setting the register. */
130#define ALT_L3_REMAP_MPUZERO_SET(value) (((value) << 0) & 0x00000001)
131
132/*
133 * Field : Non-MPU at 0x0 - nonmpuzero
134 *
135 * Controls whether address 0x0 for the non-MPU L3 masters is mapped to the SDRAM
136 * or On-chip RAM. This field only has an effect on the non-MPU L3 masters. The
137 * non-MPU L3 masters are the DMA controllers (standalone and those built-in to
138 * peripherals), the FPGA2HPS AXI Bridge, and the DAP.
139 *
140 * Field Enumeration Values:
141 *
142 * Enum | Value | Description
143 * :--------------------------------|:------|:-------------------------------------------------
144 * ALT_L3_REMAP_NONMPUZERO_E_SDRAM | 0x0 | Maps the SDRAM to address 0x0 for the non-MPU L3
145 * : | | masters.
146 * ALT_L3_REMAP_NONMPUZERO_E_OCRAM | 0x1 | Maps the On-chip RAM to address 0x0 for the non-
147 * : | | MPU L3 masters. Note that the On-chip RAM is
148 * : | | also always mapped to address 0xffff_0000 for
149 * : | | the non-MPU L3 masters independent of this
150 * : | | field's value.
151 *
152 * Field Access Macros:
153 *
154 */
155/*
156 * Enumerated value for register field ALT_L3_REMAP_NONMPUZERO
157 *
158 * Maps the SDRAM to address 0x0 for the non-MPU L3 masters.
159 */
160#define ALT_L3_REMAP_NONMPUZERO_E_SDRAM 0x0
161/*
162 * Enumerated value for register field ALT_L3_REMAP_NONMPUZERO
163 *
164 * Maps the On-chip RAM to address 0x0 for the non-MPU L3 masters. Note that the
165 * On-chip RAM is also always mapped to address 0xffff_0000 for the non-MPU L3
166 * masters independent of this field's value.
167 */
168#define ALT_L3_REMAP_NONMPUZERO_E_OCRAM 0x1
169
170/* The Least Significant Bit (LSB) position of the ALT_L3_REMAP_NONMPUZERO register field. */
171#define ALT_L3_REMAP_NONMPUZERO_LSB 1
172/* The Most Significant Bit (MSB) position of the ALT_L3_REMAP_NONMPUZERO register field. */
173#define ALT_L3_REMAP_NONMPUZERO_MSB 1
174/* The width in bits of the ALT_L3_REMAP_NONMPUZERO register field. */
175#define ALT_L3_REMAP_NONMPUZERO_WIDTH 1
176/* The mask used to set the ALT_L3_REMAP_NONMPUZERO register field value. */
177#define ALT_L3_REMAP_NONMPUZERO_SET_MSK 0x00000002
178/* The mask used to clear the ALT_L3_REMAP_NONMPUZERO register field value. */
179#define ALT_L3_REMAP_NONMPUZERO_CLR_MSK 0xfffffffd
180/* The reset value of the ALT_L3_REMAP_NONMPUZERO register field. */
181#define ALT_L3_REMAP_NONMPUZERO_RESET 0x0
182/* Extracts the ALT_L3_REMAP_NONMPUZERO field value from a register. */
183#define ALT_L3_REMAP_NONMPUZERO_GET(value) (((value) & 0x00000002) >> 1)
184/* Produces a ALT_L3_REMAP_NONMPUZERO register field value suitable for setting the register. */
185#define ALT_L3_REMAP_NONMPUZERO_SET(value) (((value) << 1) & 0x00000002)
186
187/*
188 * Field : HPS2FPGA AXI Bridge Visibility - hps2fpga
189 *
190 * Controls whether the HPS2FPGA AXI Bridge is visible to L3 masters or not.
191 *
192 * Field Enumeration Values:
193 *
194 * Enum | Value | Description
195 * :-----------------------------|:------|:------------------------------------------------
196 * ALT_L3_REMAP_H2F_E_INVISIBLE | 0x0 | The HPS2FPGA AXI Bridge is not visible to L3
197 * : | | masters. Accesses to the associated address
198 * : | | range return an AXI decode error to the master.
199 * ALT_L3_REMAP_H2F_E_VISIBLE | 0x1 | The HPS2FPGA AXI Bridge is visible to L3
200 * : | | masters.
201 *
202 * Field Access Macros:
203 *
204 */
205/*
206 * Enumerated value for register field ALT_L3_REMAP_H2F
207 *
208 * The HPS2FPGA AXI Bridge is not visible to L3 masters. Accesses to the associated
209 * address range return an AXI decode error to the master.
210 */
211#define ALT_L3_REMAP_H2F_E_INVISIBLE 0x0
212/*
213 * Enumerated value for register field ALT_L3_REMAP_H2F
214 *
215 * The HPS2FPGA AXI Bridge is visible to L3 masters.
216 */
217#define ALT_L3_REMAP_H2F_E_VISIBLE 0x1
218
219/* The Least Significant Bit (LSB) position of the ALT_L3_REMAP_H2F register field. */
220#define ALT_L3_REMAP_H2F_LSB 3
221/* The Most Significant Bit (MSB) position of the ALT_L3_REMAP_H2F register field. */
222#define ALT_L3_REMAP_H2F_MSB 3
223/* The width in bits of the ALT_L3_REMAP_H2F register field. */
224#define ALT_L3_REMAP_H2F_WIDTH 1
225/* The mask used to set the ALT_L3_REMAP_H2F register field value. */
226#define ALT_L3_REMAP_H2F_SET_MSK 0x00000008
227/* The mask used to clear the ALT_L3_REMAP_H2F register field value. */
228#define ALT_L3_REMAP_H2F_CLR_MSK 0xfffffff7
229/* The reset value of the ALT_L3_REMAP_H2F register field. */
230#define ALT_L3_REMAP_H2F_RESET 0x0
231/* Extracts the ALT_L3_REMAP_H2F field value from a register. */
232#define ALT_L3_REMAP_H2F_GET(value) (((value) & 0x00000008) >> 3)
233/* Produces a ALT_L3_REMAP_H2F register field value suitable for setting the register. */
234#define ALT_L3_REMAP_H2F_SET(value) (((value) << 3) & 0x00000008)
235
236/*
237 * Field : LWHPS2FPGA AXI Bridge Visibility - lwhps2fpga
238 *
239 * Controls whether the Lightweight HPS2FPGA AXI Bridge is visible to L3 masters or
240 * not.
241 *
242 * Field Enumeration Values:
243 *
244 * Enum | Value | Description
245 * :-------------------------------|:------|:------------------------------------------------
246 * ALT_L3_REMAP_LWH2F_E_INVISIBLE | 0x0 | The LWHPS2FPGA AXI Bridge is not visible to L3
247 * : | | masters. Accesses to the associated address
248 * : | | range return an AXI decode error to the master.
249 * ALT_L3_REMAP_LWH2F_E_VISIBLE | 0x1 | The LWHPS2FPGA AXI Bridge is visible to L3
250 * : | | masters.
251 *
252 * Field Access Macros:
253 *
254 */
255/*
256 * Enumerated value for register field ALT_L3_REMAP_LWH2F
257 *
258 * The LWHPS2FPGA AXI Bridge is not visible to L3 masters. Accesses to the
259 * associated address range return an AXI decode error to the master.
260 */
261#define ALT_L3_REMAP_LWH2F_E_INVISIBLE 0x0
262/*
263 * Enumerated value for register field ALT_L3_REMAP_LWH2F
264 *
265 * The LWHPS2FPGA AXI Bridge is visible to L3 masters.
266 */
267#define ALT_L3_REMAP_LWH2F_E_VISIBLE 0x1
268
269/* The Least Significant Bit (LSB) position of the ALT_L3_REMAP_LWH2F register field. */
270#define ALT_L3_REMAP_LWH2F_LSB 4
271/* The Most Significant Bit (MSB) position of the ALT_L3_REMAP_LWH2F register field. */
272#define ALT_L3_REMAP_LWH2F_MSB 4
273/* The width in bits of the ALT_L3_REMAP_LWH2F register field. */
274#define ALT_L3_REMAP_LWH2F_WIDTH 1
275/* The mask used to set the ALT_L3_REMAP_LWH2F register field value. */
276#define ALT_L3_REMAP_LWH2F_SET_MSK 0x00000010
277/* The mask used to clear the ALT_L3_REMAP_LWH2F register field value. */
278#define ALT_L3_REMAP_LWH2F_CLR_MSK 0xffffffef
279/* The reset value of the ALT_L3_REMAP_LWH2F register field. */
280#define ALT_L3_REMAP_LWH2F_RESET 0x0
281/* Extracts the ALT_L3_REMAP_LWH2F field value from a register. */
282#define ALT_L3_REMAP_LWH2F_GET(value) (((value) & 0x00000010) >> 4)
283/* Produces a ALT_L3_REMAP_LWH2F register field value suitable for setting the register. */
284#define ALT_L3_REMAP_LWH2F_SET(value) (((value) << 4) & 0x00000010)
285
286#ifndef __ASSEMBLY__
287/*
288 * WARNING: The C register and register group struct declarations are provided for
289 * convenience and illustrative purposes. They should, however, be used with
290 * caution as the C language standard provides no guarantees about the alignment or
291 * atomicity of device memory accesses. The recommended practice for writing
292 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
293 * alt_write_word() functions.
294 *
295 * The struct declaration for register ALT_L3_REMAP.
296 */
298{
299 uint32_t mpuzero : 1; /* MPU at 0x0 */
300 uint32_t nonmpuzero : 1; /* Non-MPU at 0x0 */
301 uint32_t : 1; /* *UNDEFINED* */
302 uint32_t hps2fpga : 1; /* HPS2FPGA AXI Bridge Visibility */
303 uint32_t lwhps2fpga : 1; /* LWHPS2FPGA AXI Bridge Visibility */
304 uint32_t : 27; /* *UNDEFINED* */
305};
306
307/* The typedef declaration for register ALT_L3_REMAP. */
308typedef volatile struct ALT_L3_REMAP_s ALT_L3_REMAP_t;
309#endif /* __ASSEMBLY__ */
310
311/* The byte offset of the ALT_L3_REMAP register from the beginning of the component. */
312#define ALT_L3_REMAP_OFST 0x0
313
314/*
315 * Register Group : Security Register Group - ALT_L3_SECGRP
316 * Security Register Group
317 *
318 * Registers that control slave security.
319 *
320 */
321/*
322 * Register : L4 Main Peripherals Security - l4main
323 *
324 * Controls security settings for L4 Main peripherals.
325 *
326 * Register Layout
327 *
328 * Bits | Access | Reset | Description
329 * :-------|:-------|:------|:------------------------
330 * [0] | W | 0x0 | SPI Slave 0 Security
331 * [1] | W | 0x0 | SPI Slave 1 Security
332 * [2] | W | 0x0 | DMA Secure Security
333 * [3] | W | 0x0 | DMA Non-secure Security
334 * [31:4] | ??? | 0x0 | *UNDEFINED*
335 *
336 */
337/*
338 * Field : SPI Slave 0 Security - spis0
339 *
340 * Controls whether secure or non-secure masters can access the SPI Slave 0 slave.
341 *
342 * Field Enumeration Values:
343 *
344 * Enum | Value | Description
345 * :------------------------------------|:------|:----------------------------------------------
346 * ALT_L3_SEC_L4MAIN_SPIS0_E_SECURE | 0x0 | The slave can only be accessed by a secure
347 * : | | master.
348 * ALT_L3_SEC_L4MAIN_SPIS0_E_NONSECURE | 0x1 | The slave can only be accessed by a secure or
349 * : | | non-secure masters.
350 *
351 * Field Access Macros:
352 *
353 */
354/*
355 * Enumerated value for register field ALT_L3_SEC_L4MAIN_SPIS0
356 *
357 * The slave can only be accessed by a secure master.
358 */
359#define ALT_L3_SEC_L4MAIN_SPIS0_E_SECURE 0x0
360/*
361 * Enumerated value for register field ALT_L3_SEC_L4MAIN_SPIS0
362 *
363 * The slave can only be accessed by a secure or non-secure masters.
364 */
365#define ALT_L3_SEC_L4MAIN_SPIS0_E_NONSECURE 0x1
366
367/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4MAIN_SPIS0 register field. */
368#define ALT_L3_SEC_L4MAIN_SPIS0_LSB 0
369/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4MAIN_SPIS0 register field. */
370#define ALT_L3_SEC_L4MAIN_SPIS0_MSB 0
371/* The width in bits of the ALT_L3_SEC_L4MAIN_SPIS0 register field. */
372#define ALT_L3_SEC_L4MAIN_SPIS0_WIDTH 1
373/* The mask used to set the ALT_L3_SEC_L4MAIN_SPIS0 register field value. */
374#define ALT_L3_SEC_L4MAIN_SPIS0_SET_MSK 0x00000001
375/* The mask used to clear the ALT_L3_SEC_L4MAIN_SPIS0 register field value. */
376#define ALT_L3_SEC_L4MAIN_SPIS0_CLR_MSK 0xfffffffe
377/* The reset value of the ALT_L3_SEC_L4MAIN_SPIS0 register field. */
378#define ALT_L3_SEC_L4MAIN_SPIS0_RESET 0x0
379/* Extracts the ALT_L3_SEC_L4MAIN_SPIS0 field value from a register. */
380#define ALT_L3_SEC_L4MAIN_SPIS0_GET(value) (((value) & 0x00000001) >> 0)
381/* Produces a ALT_L3_SEC_L4MAIN_SPIS0 register field value suitable for setting the register. */
382#define ALT_L3_SEC_L4MAIN_SPIS0_SET(value) (((value) << 0) & 0x00000001)
383
384/*
385 * Field : SPI Slave 1 Security - spis1
386 *
387 * Controls whether secure or non-secure masters can access the SPI Slave 1 slave.
388 *
389 * Field Enumeration Values:
390 *
391 * Enum | Value | Description
392 * :------------------------------------|:------|:----------------------------------------------
393 * ALT_L3_SEC_L4MAIN_SPIS1_E_SECURE | 0x0 | The slave can only be accessed by a secure
394 * : | | master.
395 * ALT_L3_SEC_L4MAIN_SPIS1_E_NONSECURE | 0x1 | The slave can only be accessed by a secure or
396 * : | | non-secure masters.
397 *
398 * Field Access Macros:
399 *
400 */
401/*
402 * Enumerated value for register field ALT_L3_SEC_L4MAIN_SPIS1
403 *
404 * The slave can only be accessed by a secure master.
405 */
406#define ALT_L3_SEC_L4MAIN_SPIS1_E_SECURE 0x0
407/*
408 * Enumerated value for register field ALT_L3_SEC_L4MAIN_SPIS1
409 *
410 * The slave can only be accessed by a secure or non-secure masters.
411 */
412#define ALT_L3_SEC_L4MAIN_SPIS1_E_NONSECURE 0x1
413
414/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4MAIN_SPIS1 register field. */
415#define ALT_L3_SEC_L4MAIN_SPIS1_LSB 1
416/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4MAIN_SPIS1 register field. */
417#define ALT_L3_SEC_L4MAIN_SPIS1_MSB 1
418/* The width in bits of the ALT_L3_SEC_L4MAIN_SPIS1 register field. */
419#define ALT_L3_SEC_L4MAIN_SPIS1_WIDTH 1
420/* The mask used to set the ALT_L3_SEC_L4MAIN_SPIS1 register field value. */
421#define ALT_L3_SEC_L4MAIN_SPIS1_SET_MSK 0x00000002
422/* The mask used to clear the ALT_L3_SEC_L4MAIN_SPIS1 register field value. */
423#define ALT_L3_SEC_L4MAIN_SPIS1_CLR_MSK 0xfffffffd
424/* The reset value of the ALT_L3_SEC_L4MAIN_SPIS1 register field. */
425#define ALT_L3_SEC_L4MAIN_SPIS1_RESET 0x0
426/* Extracts the ALT_L3_SEC_L4MAIN_SPIS1 field value from a register. */
427#define ALT_L3_SEC_L4MAIN_SPIS1_GET(value) (((value) & 0x00000002) >> 1)
428/* Produces a ALT_L3_SEC_L4MAIN_SPIS1 register field value suitable for setting the register. */
429#define ALT_L3_SEC_L4MAIN_SPIS1_SET(value) (((value) << 1) & 0x00000002)
430
431/*
432 * Field : DMA Secure Security - dmasecure
433 *
434 * Controls whether secure or non-secure masters can access the DMA Secure slave.
435 *
436 * Field Enumeration Values:
437 *
438 * Enum | Value | Description
439 * :----------------------------------------|:------|:----------------------------------------------
440 * ALT_L3_SEC_L4MAIN_DMASECURE_E_SECURE | 0x0 | The slave can only be accessed by a secure
441 * : | | master.
442 * ALT_L3_SEC_L4MAIN_DMASECURE_E_NONSECURE | 0x1 | The slave can only be accessed by a secure or
443 * : | | non-secure masters.
444 *
445 * Field Access Macros:
446 *
447 */
448/*
449 * Enumerated value for register field ALT_L3_SEC_L4MAIN_DMASECURE
450 *
451 * The slave can only be accessed by a secure master.
452 */
453#define ALT_L3_SEC_L4MAIN_DMASECURE_E_SECURE 0x0
454/*
455 * Enumerated value for register field ALT_L3_SEC_L4MAIN_DMASECURE
456 *
457 * The slave can only be accessed by a secure or non-secure masters.
458 */
459#define ALT_L3_SEC_L4MAIN_DMASECURE_E_NONSECURE 0x1
460
461/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4MAIN_DMASECURE register field. */
462#define ALT_L3_SEC_L4MAIN_DMASECURE_LSB 2
463/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4MAIN_DMASECURE register field. */
464#define ALT_L3_SEC_L4MAIN_DMASECURE_MSB 2
465/* The width in bits of the ALT_L3_SEC_L4MAIN_DMASECURE register field. */
466#define ALT_L3_SEC_L4MAIN_DMASECURE_WIDTH 1
467/* The mask used to set the ALT_L3_SEC_L4MAIN_DMASECURE register field value. */
468#define ALT_L3_SEC_L4MAIN_DMASECURE_SET_MSK 0x00000004
469/* The mask used to clear the ALT_L3_SEC_L4MAIN_DMASECURE register field value. */
470#define ALT_L3_SEC_L4MAIN_DMASECURE_CLR_MSK 0xfffffffb
471/* The reset value of the ALT_L3_SEC_L4MAIN_DMASECURE register field. */
472#define ALT_L3_SEC_L4MAIN_DMASECURE_RESET 0x0
473/* Extracts the ALT_L3_SEC_L4MAIN_DMASECURE field value from a register. */
474#define ALT_L3_SEC_L4MAIN_DMASECURE_GET(value) (((value) & 0x00000004) >> 2)
475/* Produces a ALT_L3_SEC_L4MAIN_DMASECURE register field value suitable for setting the register. */
476#define ALT_L3_SEC_L4MAIN_DMASECURE_SET(value) (((value) << 2) & 0x00000004)
477
478/*
479 * Field : DMA Non-secure Security - dmanonsecure
480 *
481 * Controls whether secure or non-secure masters can access the DMA Non-secure
482 * slave.
483 *
484 * Field Enumeration Values:
485 *
486 * Enum | Value | Description
487 * :-------------------------------------------|:------|:----------------------------------------------
488 * ALT_L3_SEC_L4MAIN_DMANONSECURE_E_SECURE | 0x0 | The slave can only be accessed by a secure
489 * : | | master.
490 * ALT_L3_SEC_L4MAIN_DMANONSECURE_E_NONSECURE | 0x1 | The slave can only be accessed by a secure or
491 * : | | non-secure masters.
492 *
493 * Field Access Macros:
494 *
495 */
496/*
497 * Enumerated value for register field ALT_L3_SEC_L4MAIN_DMANONSECURE
498 *
499 * The slave can only be accessed by a secure master.
500 */
501#define ALT_L3_SEC_L4MAIN_DMANONSECURE_E_SECURE 0x0
502/*
503 * Enumerated value for register field ALT_L3_SEC_L4MAIN_DMANONSECURE
504 *
505 * The slave can only be accessed by a secure or non-secure masters.
506 */
507#define ALT_L3_SEC_L4MAIN_DMANONSECURE_E_NONSECURE 0x1
508
509/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4MAIN_DMANONSECURE register field. */
510#define ALT_L3_SEC_L4MAIN_DMANONSECURE_LSB 3
511/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4MAIN_DMANONSECURE register field. */
512#define ALT_L3_SEC_L4MAIN_DMANONSECURE_MSB 3
513/* The width in bits of the ALT_L3_SEC_L4MAIN_DMANONSECURE register field. */
514#define ALT_L3_SEC_L4MAIN_DMANONSECURE_WIDTH 1
515/* The mask used to set the ALT_L3_SEC_L4MAIN_DMANONSECURE register field value. */
516#define ALT_L3_SEC_L4MAIN_DMANONSECURE_SET_MSK 0x00000008
517/* The mask used to clear the ALT_L3_SEC_L4MAIN_DMANONSECURE register field value. */
518#define ALT_L3_SEC_L4MAIN_DMANONSECURE_CLR_MSK 0xfffffff7
519/* The reset value of the ALT_L3_SEC_L4MAIN_DMANONSECURE register field. */
520#define ALT_L3_SEC_L4MAIN_DMANONSECURE_RESET 0x0
521/* Extracts the ALT_L3_SEC_L4MAIN_DMANONSECURE field value from a register. */
522#define ALT_L3_SEC_L4MAIN_DMANONSECURE_GET(value) (((value) & 0x00000008) >> 3)
523/* Produces a ALT_L3_SEC_L4MAIN_DMANONSECURE register field value suitable for setting the register. */
524#define ALT_L3_SEC_L4MAIN_DMANONSECURE_SET(value) (((value) << 3) & 0x00000008)
525
526#ifndef __ASSEMBLY__
527/*
528 * WARNING: The C register and register group struct declarations are provided for
529 * convenience and illustrative purposes. They should, however, be used with
530 * caution as the C language standard provides no guarantees about the alignment or
531 * atomicity of device memory accesses. The recommended practice for writing
532 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
533 * alt_write_word() functions.
534 *
535 * The struct declaration for register ALT_L3_SEC_L4MAIN.
536 */
538{
539 uint32_t spis0 : 1; /* SPI Slave 0 Security */
540 uint32_t spis1 : 1; /* SPI Slave 1 Security */
541 uint32_t dmasecure : 1; /* DMA Secure Security */
542 uint32_t dmanonsecure : 1; /* DMA Non-secure Security */
543 uint32_t : 28; /* *UNDEFINED* */
544};
545
546/* The typedef declaration for register ALT_L3_SEC_L4MAIN. */
547typedef volatile struct ALT_L3_SEC_L4MAIN_s ALT_L3_SEC_L4MAIN_t;
548#endif /* __ASSEMBLY__ */
549
550/* The byte offset of the ALT_L3_SEC_L4MAIN register from the beginning of the component. */
551#define ALT_L3_SEC_L4MAIN_OFST 0x0
552
553/*
554 * Register : L4 SP Peripherals Security - l4sp
555 *
556 * Controls security settings for L4 SP peripherals.
557 *
558 * Register Layout
559 *
560 * Bits | Access | Reset | Description
561 * :--------|:-------|:------|:-------------------------
562 * [0] | W | 0x0 | SDRAM Registers Security
563 * [1] | W | 0x0 | SP Timer 0 Security
564 * [2] | W | 0x0 | I2C0 Security
565 * [3] | W | 0x0 | I2C1 Security
566 * [4] | W | 0x0 | I2C2 (EMAC 0) Security
567 * [5] | W | 0x0 | I2C3 (EMAC 1) Security
568 * [6] | W | 0x0 | UART 0 Security
569 * [7] | W | 0x0 | UART 1 Security
570 * [8] | W | 0x0 | CAN 0 Security
571 * [9] | W | 0x0 | CAN 1 Security
572 * [10] | W | 0x0 | SP Timer 1 Security
573 * [31:11] | ??? | 0x0 | *UNDEFINED*
574 *
575 */
576/*
577 * Field : SDRAM Registers Security - sdrregs
578 *
579 * Controls whether secure or non-secure masters can access the SDRAM Registers
580 * slave.
581 *
582 * Field Enumeration Values:
583 *
584 * Enum | Value | Description
585 * :------------------------------------|:------|:----------------------------------------------
586 * ALT_L3_SEC_L4SP_SDRREGS_E_SECURE | 0x0 | The slave can only be accessed by a secure
587 * : | | master.
588 * ALT_L3_SEC_L4SP_SDRREGS_E_NONSECURE | 0x1 | The slave can only be accessed by a secure or
589 * : | | non-secure masters.
590 *
591 * Field Access Macros:
592 *
593 */
594/*
595 * Enumerated value for register field ALT_L3_SEC_L4SP_SDRREGS
596 *
597 * The slave can only be accessed by a secure master.
598 */
599#define ALT_L3_SEC_L4SP_SDRREGS_E_SECURE 0x0
600/*
601 * Enumerated value for register field ALT_L3_SEC_L4SP_SDRREGS
602 *
603 * The slave can only be accessed by a secure or non-secure masters.
604 */
605#define ALT_L3_SEC_L4SP_SDRREGS_E_NONSECURE 0x1
606
607/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4SP_SDRREGS register field. */
608#define ALT_L3_SEC_L4SP_SDRREGS_LSB 0
609/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4SP_SDRREGS register field. */
610#define ALT_L3_SEC_L4SP_SDRREGS_MSB 0
611/* The width in bits of the ALT_L3_SEC_L4SP_SDRREGS register field. */
612#define ALT_L3_SEC_L4SP_SDRREGS_WIDTH 1
613/* The mask used to set the ALT_L3_SEC_L4SP_SDRREGS register field value. */
614#define ALT_L3_SEC_L4SP_SDRREGS_SET_MSK 0x00000001
615/* The mask used to clear the ALT_L3_SEC_L4SP_SDRREGS register field value. */
616#define ALT_L3_SEC_L4SP_SDRREGS_CLR_MSK 0xfffffffe
617/* The reset value of the ALT_L3_SEC_L4SP_SDRREGS register field. */
618#define ALT_L3_SEC_L4SP_SDRREGS_RESET 0x0
619/* Extracts the ALT_L3_SEC_L4SP_SDRREGS field value from a register. */
620#define ALT_L3_SEC_L4SP_SDRREGS_GET(value) (((value) & 0x00000001) >> 0)
621/* Produces a ALT_L3_SEC_L4SP_SDRREGS register field value suitable for setting the register. */
622#define ALT_L3_SEC_L4SP_SDRREGS_SET(value) (((value) << 0) & 0x00000001)
623
624/*
625 * Field : SP Timer 0 Security - sptimer0
626 *
627 * Controls whether secure or non-secure masters can access the SP Timer 0 slave.
628 *
629 * Field Enumeration Values:
630 *
631 * Enum | Value | Description
632 * :-----------------------------------|:------|:----------------------------------------------
633 * ALT_L3_SEC_L4SP_SPTMR0_E_SECURE | 0x0 | The slave can only be accessed by a secure
634 * : | | master.
635 * ALT_L3_SEC_L4SP_SPTMR0_E_NONSECURE | 0x1 | The slave can only be accessed by a secure or
636 * : | | non-secure masters.
637 *
638 * Field Access Macros:
639 *
640 */
641/*
642 * Enumerated value for register field ALT_L3_SEC_L4SP_SPTMR0
643 *
644 * The slave can only be accessed by a secure master.
645 */
646#define ALT_L3_SEC_L4SP_SPTMR0_E_SECURE 0x0
647/*
648 * Enumerated value for register field ALT_L3_SEC_L4SP_SPTMR0
649 *
650 * The slave can only be accessed by a secure or non-secure masters.
651 */
652#define ALT_L3_SEC_L4SP_SPTMR0_E_NONSECURE 0x1
653
654/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4SP_SPTMR0 register field. */
655#define ALT_L3_SEC_L4SP_SPTMR0_LSB 1
656/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4SP_SPTMR0 register field. */
657#define ALT_L3_SEC_L4SP_SPTMR0_MSB 1
658/* The width in bits of the ALT_L3_SEC_L4SP_SPTMR0 register field. */
659#define ALT_L3_SEC_L4SP_SPTMR0_WIDTH 1
660/* The mask used to set the ALT_L3_SEC_L4SP_SPTMR0 register field value. */
661#define ALT_L3_SEC_L4SP_SPTMR0_SET_MSK 0x00000002
662/* The mask used to clear the ALT_L3_SEC_L4SP_SPTMR0 register field value. */
663#define ALT_L3_SEC_L4SP_SPTMR0_CLR_MSK 0xfffffffd
664/* The reset value of the ALT_L3_SEC_L4SP_SPTMR0 register field. */
665#define ALT_L3_SEC_L4SP_SPTMR0_RESET 0x0
666/* Extracts the ALT_L3_SEC_L4SP_SPTMR0 field value from a register. */
667#define ALT_L3_SEC_L4SP_SPTMR0_GET(value) (((value) & 0x00000002) >> 1)
668/* Produces a ALT_L3_SEC_L4SP_SPTMR0 register field value suitable for setting the register. */
669#define ALT_L3_SEC_L4SP_SPTMR0_SET(value) (((value) << 1) & 0x00000002)
670
671/*
672 * Field : I2C0 Security - i2c0
673 *
674 * Controls whether secure or non-secure masters can access the I2C0 slave.
675 *
676 * Field Enumeration Values:
677 *
678 * Enum | Value | Description
679 * :---------------------------------|:------|:----------------------------------------------
680 * ALT_L3_SEC_L4SP_I2C0_E_SECURE | 0x0 | The slave can only be accessed by a secure
681 * : | | master.
682 * ALT_L3_SEC_L4SP_I2C0_E_NONSECURE | 0x1 | The slave can only be accessed by a secure or
683 * : | | non-secure masters.
684 *
685 * Field Access Macros:
686 *
687 */
688/*
689 * Enumerated value for register field ALT_L3_SEC_L4SP_I2C0
690 *
691 * The slave can only be accessed by a secure master.
692 */
693#define ALT_L3_SEC_L4SP_I2C0_E_SECURE 0x0
694/*
695 * Enumerated value for register field ALT_L3_SEC_L4SP_I2C0
696 *
697 * The slave can only be accessed by a secure or non-secure masters.
698 */
699#define ALT_L3_SEC_L4SP_I2C0_E_NONSECURE 0x1
700
701/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4SP_I2C0 register field. */
702#define ALT_L3_SEC_L4SP_I2C0_LSB 2
703/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4SP_I2C0 register field. */
704#define ALT_L3_SEC_L4SP_I2C0_MSB 2
705/* The width in bits of the ALT_L3_SEC_L4SP_I2C0 register field. */
706#define ALT_L3_SEC_L4SP_I2C0_WIDTH 1
707/* The mask used to set the ALT_L3_SEC_L4SP_I2C0 register field value. */
708#define ALT_L3_SEC_L4SP_I2C0_SET_MSK 0x00000004
709/* The mask used to clear the ALT_L3_SEC_L4SP_I2C0 register field value. */
710#define ALT_L3_SEC_L4SP_I2C0_CLR_MSK 0xfffffffb
711/* The reset value of the ALT_L3_SEC_L4SP_I2C0 register field. */
712#define ALT_L3_SEC_L4SP_I2C0_RESET 0x0
713/* Extracts the ALT_L3_SEC_L4SP_I2C0 field value from a register. */
714#define ALT_L3_SEC_L4SP_I2C0_GET(value) (((value) & 0x00000004) >> 2)
715/* Produces a ALT_L3_SEC_L4SP_I2C0 register field value suitable for setting the register. */
716#define ALT_L3_SEC_L4SP_I2C0_SET(value) (((value) << 2) & 0x00000004)
717
718/*
719 * Field : I2C1 Security - i2c1
720 *
721 * Controls whether secure or non-secure masters can access the I2C1 slave.
722 *
723 * Field Enumeration Values:
724 *
725 * Enum | Value | Description
726 * :---------------------------------|:------|:----------------------------------------------
727 * ALT_L3_SEC_L4SP_I2C1_E_SECURE | 0x0 | The slave can only be accessed by a secure
728 * : | | master.
729 * ALT_L3_SEC_L4SP_I2C1_E_NONSECURE | 0x1 | The slave can only be accessed by a secure or
730 * : | | non-secure masters.
731 *
732 * Field Access Macros:
733 *
734 */
735/*
736 * Enumerated value for register field ALT_L3_SEC_L4SP_I2C1
737 *
738 * The slave can only be accessed by a secure master.
739 */
740#define ALT_L3_SEC_L4SP_I2C1_E_SECURE 0x0
741/*
742 * Enumerated value for register field ALT_L3_SEC_L4SP_I2C1
743 *
744 * The slave can only be accessed by a secure or non-secure masters.
745 */
746#define ALT_L3_SEC_L4SP_I2C1_E_NONSECURE 0x1
747
748/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4SP_I2C1 register field. */
749#define ALT_L3_SEC_L4SP_I2C1_LSB 3
750/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4SP_I2C1 register field. */
751#define ALT_L3_SEC_L4SP_I2C1_MSB 3
752/* The width in bits of the ALT_L3_SEC_L4SP_I2C1 register field. */
753#define ALT_L3_SEC_L4SP_I2C1_WIDTH 1
754/* The mask used to set the ALT_L3_SEC_L4SP_I2C1 register field value. */
755#define ALT_L3_SEC_L4SP_I2C1_SET_MSK 0x00000008
756/* The mask used to clear the ALT_L3_SEC_L4SP_I2C1 register field value. */
757#define ALT_L3_SEC_L4SP_I2C1_CLR_MSK 0xfffffff7
758/* The reset value of the ALT_L3_SEC_L4SP_I2C1 register field. */
759#define ALT_L3_SEC_L4SP_I2C1_RESET 0x0
760/* Extracts the ALT_L3_SEC_L4SP_I2C1 field value from a register. */
761#define ALT_L3_SEC_L4SP_I2C1_GET(value) (((value) & 0x00000008) >> 3)
762/* Produces a ALT_L3_SEC_L4SP_I2C1 register field value suitable for setting the register. */
763#define ALT_L3_SEC_L4SP_I2C1_SET(value) (((value) << 3) & 0x00000008)
764
765/*
766 * Field : I2C2 (EMAC 0) Security - i2c2
767 *
768 * Controls whether secure or non-secure masters can access the I2C2 (EMAC 0)
769 * slave.
770 *
771 * Field Enumeration Values:
772 *
773 * Enum | Value | Description
774 * :---------------------------------|:------|:----------------------------------------------
775 * ALT_L3_SEC_L4SP_I2C2_E_SECURE | 0x0 | The slave can only be accessed by a secure
776 * : | | master.
777 * ALT_L3_SEC_L4SP_I2C2_E_NONSECURE | 0x1 | The slave can only be accessed by a secure or
778 * : | | non-secure masters.
779 *
780 * Field Access Macros:
781 *
782 */
783/*
784 * Enumerated value for register field ALT_L3_SEC_L4SP_I2C2
785 *
786 * The slave can only be accessed by a secure master.
787 */
788#define ALT_L3_SEC_L4SP_I2C2_E_SECURE 0x0
789/*
790 * Enumerated value for register field ALT_L3_SEC_L4SP_I2C2
791 *
792 * The slave can only be accessed by a secure or non-secure masters.
793 */
794#define ALT_L3_SEC_L4SP_I2C2_E_NONSECURE 0x1
795
796/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4SP_I2C2 register field. */
797#define ALT_L3_SEC_L4SP_I2C2_LSB 4
798/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4SP_I2C2 register field. */
799#define ALT_L3_SEC_L4SP_I2C2_MSB 4
800/* The width in bits of the ALT_L3_SEC_L4SP_I2C2 register field. */
801#define ALT_L3_SEC_L4SP_I2C2_WIDTH 1
802/* The mask used to set the ALT_L3_SEC_L4SP_I2C2 register field value. */
803#define ALT_L3_SEC_L4SP_I2C2_SET_MSK 0x00000010
804/* The mask used to clear the ALT_L3_SEC_L4SP_I2C2 register field value. */
805#define ALT_L3_SEC_L4SP_I2C2_CLR_MSK 0xffffffef
806/* The reset value of the ALT_L3_SEC_L4SP_I2C2 register field. */
807#define ALT_L3_SEC_L4SP_I2C2_RESET 0x0
808/* Extracts the ALT_L3_SEC_L4SP_I2C2 field value from a register. */
809#define ALT_L3_SEC_L4SP_I2C2_GET(value) (((value) & 0x00000010) >> 4)
810/* Produces a ALT_L3_SEC_L4SP_I2C2 register field value suitable for setting the register. */
811#define ALT_L3_SEC_L4SP_I2C2_SET(value) (((value) << 4) & 0x00000010)
812
813/*
814 * Field : I2C3 (EMAC 1) Security - i2c3
815 *
816 * Controls whether secure or non-secure masters can access the I2C3 (EMAC 1)
817 * slave.
818 *
819 * Field Enumeration Values:
820 *
821 * Enum | Value | Description
822 * :---------------------------------|:------|:----------------------------------------------
823 * ALT_L3_SEC_L4SP_I2C3_E_SECURE | 0x0 | The slave can only be accessed by a secure
824 * : | | master.
825 * ALT_L3_SEC_L4SP_I2C3_E_NONSECURE | 0x1 | The slave can only be accessed by a secure or
826 * : | | non-secure masters.
827 *
828 * Field Access Macros:
829 *
830 */
831/*
832 * Enumerated value for register field ALT_L3_SEC_L4SP_I2C3
833 *
834 * The slave can only be accessed by a secure master.
835 */
836#define ALT_L3_SEC_L4SP_I2C3_E_SECURE 0x0
837/*
838 * Enumerated value for register field ALT_L3_SEC_L4SP_I2C3
839 *
840 * The slave can only be accessed by a secure or non-secure masters.
841 */
842#define ALT_L3_SEC_L4SP_I2C3_E_NONSECURE 0x1
843
844/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4SP_I2C3 register field. */
845#define ALT_L3_SEC_L4SP_I2C3_LSB 5
846/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4SP_I2C3 register field. */
847#define ALT_L3_SEC_L4SP_I2C3_MSB 5
848/* The width in bits of the ALT_L3_SEC_L4SP_I2C3 register field. */
849#define ALT_L3_SEC_L4SP_I2C3_WIDTH 1
850/* The mask used to set the ALT_L3_SEC_L4SP_I2C3 register field value. */
851#define ALT_L3_SEC_L4SP_I2C3_SET_MSK 0x00000020
852/* The mask used to clear the ALT_L3_SEC_L4SP_I2C3 register field value. */
853#define ALT_L3_SEC_L4SP_I2C3_CLR_MSK 0xffffffdf
854/* The reset value of the ALT_L3_SEC_L4SP_I2C3 register field. */
855#define ALT_L3_SEC_L4SP_I2C3_RESET 0x0
856/* Extracts the ALT_L3_SEC_L4SP_I2C3 field value from a register. */
857#define ALT_L3_SEC_L4SP_I2C3_GET(value) (((value) & 0x00000020) >> 5)
858/* Produces a ALT_L3_SEC_L4SP_I2C3 register field value suitable for setting the register. */
859#define ALT_L3_SEC_L4SP_I2C3_SET(value) (((value) << 5) & 0x00000020)
860
861/*
862 * Field : UART 0 Security - uart0
863 *
864 * Controls whether secure or non-secure masters can access the UART 0 slave.
865 *
866 * Field Enumeration Values:
867 *
868 * Enum | Value | Description
869 * :----------------------------------|:------|:----------------------------------------------
870 * ALT_L3_SEC_L4SP_UART0_E_SECURE | 0x0 | The slave can only be accessed by a secure
871 * : | | master.
872 * ALT_L3_SEC_L4SP_UART0_E_NONSECURE | 0x1 | The slave can only be accessed by a secure or
873 * : | | non-secure masters.
874 *
875 * Field Access Macros:
876 *
877 */
878/*
879 * Enumerated value for register field ALT_L3_SEC_L4SP_UART0
880 *
881 * The slave can only be accessed by a secure master.
882 */
883#define ALT_L3_SEC_L4SP_UART0_E_SECURE 0x0
884/*
885 * Enumerated value for register field ALT_L3_SEC_L4SP_UART0
886 *
887 * The slave can only be accessed by a secure or non-secure masters.
888 */
889#define ALT_L3_SEC_L4SP_UART0_E_NONSECURE 0x1
890
891/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4SP_UART0 register field. */
892#define ALT_L3_SEC_L4SP_UART0_LSB 6
893/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4SP_UART0 register field. */
894#define ALT_L3_SEC_L4SP_UART0_MSB 6
895/* The width in bits of the ALT_L3_SEC_L4SP_UART0 register field. */
896#define ALT_L3_SEC_L4SP_UART0_WIDTH 1
897/* The mask used to set the ALT_L3_SEC_L4SP_UART0 register field value. */
898#define ALT_L3_SEC_L4SP_UART0_SET_MSK 0x00000040
899/* The mask used to clear the ALT_L3_SEC_L4SP_UART0 register field value. */
900#define ALT_L3_SEC_L4SP_UART0_CLR_MSK 0xffffffbf
901/* The reset value of the ALT_L3_SEC_L4SP_UART0 register field. */
902#define ALT_L3_SEC_L4SP_UART0_RESET 0x0
903/* Extracts the ALT_L3_SEC_L4SP_UART0 field value from a register. */
904#define ALT_L3_SEC_L4SP_UART0_GET(value) (((value) & 0x00000040) >> 6)
905/* Produces a ALT_L3_SEC_L4SP_UART0 register field value suitable for setting the register. */
906#define ALT_L3_SEC_L4SP_UART0_SET(value) (((value) << 6) & 0x00000040)
907
908/*
909 * Field : UART 1 Security - uart1
910 *
911 * Controls whether secure or non-secure masters can access the UART 1 slave.
912 *
913 * Field Enumeration Values:
914 *
915 * Enum | Value | Description
916 * :----------------------------------|:------|:----------------------------------------------
917 * ALT_L3_SEC_L4SP_UART1_E_SECURE | 0x0 | The slave can only be accessed by a secure
918 * : | | master.
919 * ALT_L3_SEC_L4SP_UART1_E_NONSECURE | 0x1 | The slave can only be accessed by a secure or
920 * : | | non-secure masters.
921 *
922 * Field Access Macros:
923 *
924 */
925/*
926 * Enumerated value for register field ALT_L3_SEC_L4SP_UART1
927 *
928 * The slave can only be accessed by a secure master.
929 */
930#define ALT_L3_SEC_L4SP_UART1_E_SECURE 0x0
931/*
932 * Enumerated value for register field ALT_L3_SEC_L4SP_UART1
933 *
934 * The slave can only be accessed by a secure or non-secure masters.
935 */
936#define ALT_L3_SEC_L4SP_UART1_E_NONSECURE 0x1
937
938/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4SP_UART1 register field. */
939#define ALT_L3_SEC_L4SP_UART1_LSB 7
940/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4SP_UART1 register field. */
941#define ALT_L3_SEC_L4SP_UART1_MSB 7
942/* The width in bits of the ALT_L3_SEC_L4SP_UART1 register field. */
943#define ALT_L3_SEC_L4SP_UART1_WIDTH 1
944/* The mask used to set the ALT_L3_SEC_L4SP_UART1 register field value. */
945#define ALT_L3_SEC_L4SP_UART1_SET_MSK 0x00000080
946/* The mask used to clear the ALT_L3_SEC_L4SP_UART1 register field value. */
947#define ALT_L3_SEC_L4SP_UART1_CLR_MSK 0xffffff7f
948/* The reset value of the ALT_L3_SEC_L4SP_UART1 register field. */
949#define ALT_L3_SEC_L4SP_UART1_RESET 0x0
950/* Extracts the ALT_L3_SEC_L4SP_UART1 field value from a register. */
951#define ALT_L3_SEC_L4SP_UART1_GET(value) (((value) & 0x00000080) >> 7)
952/* Produces a ALT_L3_SEC_L4SP_UART1 register field value suitable for setting the register. */
953#define ALT_L3_SEC_L4SP_UART1_SET(value) (((value) << 7) & 0x00000080)
954
955/*
956 * Field : CAN 0 Security - can0
957 *
958 * Controls whether secure or non-secure masters can access the CAN 0 slave.
959 *
960 * Field Enumeration Values:
961 *
962 * Enum | Value | Description
963 * :---------------------------------|:------|:----------------------------------------------
964 * ALT_L3_SEC_L4SP_CAN0_E_SECURE | 0x0 | The slave can only be accessed by a secure
965 * : | | master.
966 * ALT_L3_SEC_L4SP_CAN0_E_NONSECURE | 0x1 | The slave can only be accessed by a secure or
967 * : | | non-secure masters.
968 *
969 * Field Access Macros:
970 *
971 */
972/*
973 * Enumerated value for register field ALT_L3_SEC_L4SP_CAN0
974 *
975 * The slave can only be accessed by a secure master.
976 */
977#define ALT_L3_SEC_L4SP_CAN0_E_SECURE 0x0
978/*
979 * Enumerated value for register field ALT_L3_SEC_L4SP_CAN0
980 *
981 * The slave can only be accessed by a secure or non-secure masters.
982 */
983#define ALT_L3_SEC_L4SP_CAN0_E_NONSECURE 0x1
984
985/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4SP_CAN0 register field. */
986#define ALT_L3_SEC_L4SP_CAN0_LSB 8
987/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4SP_CAN0 register field. */
988#define ALT_L3_SEC_L4SP_CAN0_MSB 8
989/* The width in bits of the ALT_L3_SEC_L4SP_CAN0 register field. */
990#define ALT_L3_SEC_L4SP_CAN0_WIDTH 1
991/* The mask used to set the ALT_L3_SEC_L4SP_CAN0 register field value. */
992#define ALT_L3_SEC_L4SP_CAN0_SET_MSK 0x00000100
993/* The mask used to clear the ALT_L3_SEC_L4SP_CAN0 register field value. */
994#define ALT_L3_SEC_L4SP_CAN0_CLR_MSK 0xfffffeff
995/* The reset value of the ALT_L3_SEC_L4SP_CAN0 register field. */
996#define ALT_L3_SEC_L4SP_CAN0_RESET 0x0
997/* Extracts the ALT_L3_SEC_L4SP_CAN0 field value from a register. */
998#define ALT_L3_SEC_L4SP_CAN0_GET(value) (((value) & 0x00000100) >> 8)
999/* Produces a ALT_L3_SEC_L4SP_CAN0 register field value suitable for setting the register. */
1000#define ALT_L3_SEC_L4SP_CAN0_SET(value) (((value) << 8) & 0x00000100)
1001
1002/*
1003 * Field : CAN 1 Security - can1
1004 *
1005 * Controls whether secure or non-secure masters can access the CAN 1 slave.
1006 *
1007 * Field Enumeration Values:
1008 *
1009 * Enum | Value | Description
1010 * :---------------------------------|:------|:----------------------------------------------
1011 * ALT_L3_SEC_L4SP_CAN1_E_SECURE | 0x0 | The slave can only be accessed by a secure
1012 * : | | master.
1013 * ALT_L3_SEC_L4SP_CAN1_E_NONSECURE | 0x1 | The slave can only be accessed by a secure or
1014 * : | | non-secure masters.
1015 *
1016 * Field Access Macros:
1017 *
1018 */
1019/*
1020 * Enumerated value for register field ALT_L3_SEC_L4SP_CAN1
1021 *
1022 * The slave can only be accessed by a secure master.
1023 */
1024#define ALT_L3_SEC_L4SP_CAN1_E_SECURE 0x0
1025/*
1026 * Enumerated value for register field ALT_L3_SEC_L4SP_CAN1
1027 *
1028 * The slave can only be accessed by a secure or non-secure masters.
1029 */
1030#define ALT_L3_SEC_L4SP_CAN1_E_NONSECURE 0x1
1031
1032/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4SP_CAN1 register field. */
1033#define ALT_L3_SEC_L4SP_CAN1_LSB 9
1034/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4SP_CAN1 register field. */
1035#define ALT_L3_SEC_L4SP_CAN1_MSB 9
1036/* The width in bits of the ALT_L3_SEC_L4SP_CAN1 register field. */
1037#define ALT_L3_SEC_L4SP_CAN1_WIDTH 1
1038/* The mask used to set the ALT_L3_SEC_L4SP_CAN1 register field value. */
1039#define ALT_L3_SEC_L4SP_CAN1_SET_MSK 0x00000200
1040/* The mask used to clear the ALT_L3_SEC_L4SP_CAN1 register field value. */
1041#define ALT_L3_SEC_L4SP_CAN1_CLR_MSK 0xfffffdff
1042/* The reset value of the ALT_L3_SEC_L4SP_CAN1 register field. */
1043#define ALT_L3_SEC_L4SP_CAN1_RESET 0x0
1044/* Extracts the ALT_L3_SEC_L4SP_CAN1 field value from a register. */
1045#define ALT_L3_SEC_L4SP_CAN1_GET(value) (((value) & 0x00000200) >> 9)
1046/* Produces a ALT_L3_SEC_L4SP_CAN1 register field value suitable for setting the register. */
1047#define ALT_L3_SEC_L4SP_CAN1_SET(value) (((value) << 9) & 0x00000200)
1048
1049/*
1050 * Field : SP Timer 1 Security - sptimer1
1051 *
1052 * Controls whether secure or non-secure masters can access the SP Timer 1 slave.
1053 *
1054 * Field Enumeration Values:
1055 *
1056 * Enum | Value | Description
1057 * :-----------------------------------|:------|:----------------------------------------------
1058 * ALT_L3_SEC_L4SP_SPTMR1_E_SECURE | 0x0 | The slave can only be accessed by a secure
1059 * : | | master.
1060 * ALT_L3_SEC_L4SP_SPTMR1_E_NONSECURE | 0x1 | The slave can only be accessed by a secure or
1061 * : | | non-secure masters.
1062 *
1063 * Field Access Macros:
1064 *
1065 */
1066/*
1067 * Enumerated value for register field ALT_L3_SEC_L4SP_SPTMR1
1068 *
1069 * The slave can only be accessed by a secure master.
1070 */
1071#define ALT_L3_SEC_L4SP_SPTMR1_E_SECURE 0x0
1072/*
1073 * Enumerated value for register field ALT_L3_SEC_L4SP_SPTMR1
1074 *
1075 * The slave can only be accessed by a secure or non-secure masters.
1076 */
1077#define ALT_L3_SEC_L4SP_SPTMR1_E_NONSECURE 0x1
1078
1079/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4SP_SPTMR1 register field. */
1080#define ALT_L3_SEC_L4SP_SPTMR1_LSB 10
1081/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4SP_SPTMR1 register field. */
1082#define ALT_L3_SEC_L4SP_SPTMR1_MSB 10
1083/* The width in bits of the ALT_L3_SEC_L4SP_SPTMR1 register field. */
1084#define ALT_L3_SEC_L4SP_SPTMR1_WIDTH 1
1085/* The mask used to set the ALT_L3_SEC_L4SP_SPTMR1 register field value. */
1086#define ALT_L3_SEC_L4SP_SPTMR1_SET_MSK 0x00000400
1087/* The mask used to clear the ALT_L3_SEC_L4SP_SPTMR1 register field value. */
1088#define ALT_L3_SEC_L4SP_SPTMR1_CLR_MSK 0xfffffbff
1089/* The reset value of the ALT_L3_SEC_L4SP_SPTMR1 register field. */
1090#define ALT_L3_SEC_L4SP_SPTMR1_RESET 0x0
1091/* Extracts the ALT_L3_SEC_L4SP_SPTMR1 field value from a register. */
1092#define ALT_L3_SEC_L4SP_SPTMR1_GET(value) (((value) & 0x00000400) >> 10)
1093/* Produces a ALT_L3_SEC_L4SP_SPTMR1 register field value suitable for setting the register. */
1094#define ALT_L3_SEC_L4SP_SPTMR1_SET(value) (((value) << 10) & 0x00000400)
1095
1096#ifndef __ASSEMBLY__
1097/*
1098 * WARNING: The C register and register group struct declarations are provided for
1099 * convenience and illustrative purposes. They should, however, be used with
1100 * caution as the C language standard provides no guarantees about the alignment or
1101 * atomicity of device memory accesses. The recommended practice for writing
1102 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
1103 * alt_write_word() functions.
1104 *
1105 * The struct declaration for register ALT_L3_SEC_L4SP.
1106 */
1108{
1109 uint32_t sdrregs : 1; /* SDRAM Registers Security */
1110 uint32_t sptimer0 : 1; /* SP Timer 0 Security */
1111 uint32_t i2c0 : 1; /* I2C0 Security */
1112 uint32_t i2c1 : 1; /* I2C1 Security */
1113 uint32_t i2c2 : 1; /* I2C2 (EMAC 0) Security */
1114 uint32_t i2c3 : 1; /* I2C3 (EMAC 1) Security */
1115 uint32_t uart0 : 1; /* UART 0 Security */
1116 uint32_t uart1 : 1; /* UART 1 Security */
1117 uint32_t can0 : 1; /* CAN 0 Security */
1118 uint32_t can1 : 1; /* CAN 1 Security */
1119 uint32_t sptimer1 : 1; /* SP Timer 1 Security */
1120 uint32_t : 21; /* *UNDEFINED* */
1121};
1122
1123/* The typedef declaration for register ALT_L3_SEC_L4SP. */
1124typedef volatile struct ALT_L3_SEC_L4SP_s ALT_L3_SEC_L4SP_t;
1125#endif /* __ASSEMBLY__ */
1126
1127/* The byte offset of the ALT_L3_SEC_L4SP register from the beginning of the component. */
1128#define ALT_L3_SEC_L4SP_OFST 0x4
1129
1130/*
1131 * Register : L4 MP Peripherals Security - l4mp
1132 *
1133 * Controls security settings for L4 MP peripherals.
1134 *
1135 * Register Layout
1136 *
1137 * Bits | Access | Reset | Description
1138 * :--------|:-------|:------|:-------------------------------
1139 * [0] | W | 0x0 | FPGA Manager Register Security
1140 * [1] | W | 0x0 | DAP Security
1141 * [2] | W | 0x0 | QSPI Registers Security
1142 * [3] | W | 0x0 | SDMMC Security
1143 * [4] | W | 0x0 | EMAC 0 Security
1144 * [5] | W | 0x0 | EMAC 1 Security
1145 * [6] | W | 0x0 | ACP ID Mapper Security
1146 * [7] | W | 0x0 | GPIO 0 Security
1147 * [8] | W | 0x0 | GPIO 1 Security
1148 * [9] | W | 0x0 | GPIO 2 Security
1149 * [31:10] | ??? | 0x0 | *UNDEFINED*
1150 *
1151 */
1152/*
1153 * Field : FPGA Manager Register Security - fpgamgrregs
1154 *
1155 * Controls whether secure or non-secure masters can access the FPGA Manager
1156 * Register slave.
1157 *
1158 * Field Enumeration Values:
1159 *
1160 * Enum | Value | Description
1161 * :------------------------------------|:------|:----------------------------------------------
1162 * ALT_L3_SEC_L4MP_FPGAMGR_E_SECURE | 0x0 | The slave can only be accessed by a secure
1163 * : | | master.
1164 * ALT_L3_SEC_L4MP_FPGAMGR_E_NONSECURE | 0x1 | The slave can only be accessed by a secure or
1165 * : | | non-secure masters.
1166 *
1167 * Field Access Macros:
1168 *
1169 */
1170/*
1171 * Enumerated value for register field ALT_L3_SEC_L4MP_FPGAMGR
1172 *
1173 * The slave can only be accessed by a secure master.
1174 */
1175#define ALT_L3_SEC_L4MP_FPGAMGR_E_SECURE 0x0
1176/*
1177 * Enumerated value for register field ALT_L3_SEC_L4MP_FPGAMGR
1178 *
1179 * The slave can only be accessed by a secure or non-secure masters.
1180 */
1181#define ALT_L3_SEC_L4MP_FPGAMGR_E_NONSECURE 0x1
1182
1183/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4MP_FPGAMGR register field. */
1184#define ALT_L3_SEC_L4MP_FPGAMGR_LSB 0
1185/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4MP_FPGAMGR register field. */
1186#define ALT_L3_SEC_L4MP_FPGAMGR_MSB 0
1187/* The width in bits of the ALT_L3_SEC_L4MP_FPGAMGR register field. */
1188#define ALT_L3_SEC_L4MP_FPGAMGR_WIDTH 1
1189/* The mask used to set the ALT_L3_SEC_L4MP_FPGAMGR register field value. */
1190#define ALT_L3_SEC_L4MP_FPGAMGR_SET_MSK 0x00000001
1191/* The mask used to clear the ALT_L3_SEC_L4MP_FPGAMGR register field value. */
1192#define ALT_L3_SEC_L4MP_FPGAMGR_CLR_MSK 0xfffffffe
1193/* The reset value of the ALT_L3_SEC_L4MP_FPGAMGR register field. */
1194#define ALT_L3_SEC_L4MP_FPGAMGR_RESET 0x0
1195/* Extracts the ALT_L3_SEC_L4MP_FPGAMGR field value from a register. */
1196#define ALT_L3_SEC_L4MP_FPGAMGR_GET(value) (((value) & 0x00000001) >> 0)
1197/* Produces a ALT_L3_SEC_L4MP_FPGAMGR register field value suitable for setting the register. */
1198#define ALT_L3_SEC_L4MP_FPGAMGR_SET(value) (((value) << 0) & 0x00000001)
1199
1200/*
1201 * Field : DAP Security - dap
1202 *
1203 * Controls whether secure or non-secure masters can access the DAP slave.
1204 *
1205 * Field Enumeration Values:
1206 *
1207 * Enum | Value | Description
1208 * :--------------------------------|:------|:----------------------------------------------
1209 * ALT_L3_SEC_L4MP_DAP_E_SECURE | 0x0 | The slave can only be accessed by a secure
1210 * : | | master.
1211 * ALT_L3_SEC_L4MP_DAP_E_NONSECURE | 0x1 | The slave can only be accessed by a secure or
1212 * : | | non-secure masters.
1213 *
1214 * Field Access Macros:
1215 *
1216 */
1217/*
1218 * Enumerated value for register field ALT_L3_SEC_L4MP_DAP
1219 *
1220 * The slave can only be accessed by a secure master.
1221 */
1222#define ALT_L3_SEC_L4MP_DAP_E_SECURE 0x0
1223/*
1224 * Enumerated value for register field ALT_L3_SEC_L4MP_DAP
1225 *
1226 * The slave can only be accessed by a secure or non-secure masters.
1227 */
1228#define ALT_L3_SEC_L4MP_DAP_E_NONSECURE 0x1
1229
1230/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4MP_DAP register field. */
1231#define ALT_L3_SEC_L4MP_DAP_LSB 1
1232/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4MP_DAP register field. */
1233#define ALT_L3_SEC_L4MP_DAP_MSB 1
1234/* The width in bits of the ALT_L3_SEC_L4MP_DAP register field. */
1235#define ALT_L3_SEC_L4MP_DAP_WIDTH 1
1236/* The mask used to set the ALT_L3_SEC_L4MP_DAP register field value. */
1237#define ALT_L3_SEC_L4MP_DAP_SET_MSK 0x00000002
1238/* The mask used to clear the ALT_L3_SEC_L4MP_DAP register field value. */
1239#define ALT_L3_SEC_L4MP_DAP_CLR_MSK 0xfffffffd
1240/* The reset value of the ALT_L3_SEC_L4MP_DAP register field. */
1241#define ALT_L3_SEC_L4MP_DAP_RESET 0x0
1242/* Extracts the ALT_L3_SEC_L4MP_DAP field value from a register. */
1243#define ALT_L3_SEC_L4MP_DAP_GET(value) (((value) & 0x00000002) >> 1)
1244/* Produces a ALT_L3_SEC_L4MP_DAP register field value suitable for setting the register. */
1245#define ALT_L3_SEC_L4MP_DAP_SET(value) (((value) << 1) & 0x00000002)
1246
1247/*
1248 * Field : QSPI Registers Security - qspiregs
1249 *
1250 * Controls whether secure or non-secure masters can access the QSPI Registers
1251 * slave.
1252 *
1253 * Field Enumeration Values:
1254 *
1255 * Enum | Value | Description
1256 * :---------------------------------|:------|:----------------------------------------------
1257 * ALT_L3_SEC_L4MP_QSPI_E_SECURE | 0x0 | The slave can only be accessed by a secure
1258 * : | | master.
1259 * ALT_L3_SEC_L4MP_QSPI_E_NONSECURE | 0x1 | The slave can only be accessed by a secure or
1260 * : | | non-secure masters.
1261 *
1262 * Field Access Macros:
1263 *
1264 */
1265/*
1266 * Enumerated value for register field ALT_L3_SEC_L4MP_QSPI
1267 *
1268 * The slave can only be accessed by a secure master.
1269 */
1270#define ALT_L3_SEC_L4MP_QSPI_E_SECURE 0x0
1271/*
1272 * Enumerated value for register field ALT_L3_SEC_L4MP_QSPI
1273 *
1274 * The slave can only be accessed by a secure or non-secure masters.
1275 */
1276#define ALT_L3_SEC_L4MP_QSPI_E_NONSECURE 0x1
1277
1278/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4MP_QSPI register field. */
1279#define ALT_L3_SEC_L4MP_QSPI_LSB 2
1280/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4MP_QSPI register field. */
1281#define ALT_L3_SEC_L4MP_QSPI_MSB 2
1282/* The width in bits of the ALT_L3_SEC_L4MP_QSPI register field. */
1283#define ALT_L3_SEC_L4MP_QSPI_WIDTH 1
1284/* The mask used to set the ALT_L3_SEC_L4MP_QSPI register field value. */
1285#define ALT_L3_SEC_L4MP_QSPI_SET_MSK 0x00000004
1286/* The mask used to clear the ALT_L3_SEC_L4MP_QSPI register field value. */
1287#define ALT_L3_SEC_L4MP_QSPI_CLR_MSK 0xfffffffb
1288/* The reset value of the ALT_L3_SEC_L4MP_QSPI register field. */
1289#define ALT_L3_SEC_L4MP_QSPI_RESET 0x0
1290/* Extracts the ALT_L3_SEC_L4MP_QSPI field value from a register. */
1291#define ALT_L3_SEC_L4MP_QSPI_GET(value) (((value) & 0x00000004) >> 2)
1292/* Produces a ALT_L3_SEC_L4MP_QSPI register field value suitable for setting the register. */
1293#define ALT_L3_SEC_L4MP_QSPI_SET(value) (((value) << 2) & 0x00000004)
1294
1295/*
1296 * Field : SDMMC Security - sdmmc
1297 *
1298 * Controls whether secure or non-secure masters can access the SDMMC slave.
1299 *
1300 * Field Enumeration Values:
1301 *
1302 * Enum | Value | Description
1303 * :----------------------------------|:------|:----------------------------------------------
1304 * ALT_L3_SEC_L4MP_SDMMC_E_SECURE | 0x0 | The slave can only be accessed by a secure
1305 * : | | master.
1306 * ALT_L3_SEC_L4MP_SDMMC_E_NONSECURE | 0x1 | The slave can only be accessed by a secure or
1307 * : | | non-secure masters.
1308 *
1309 * Field Access Macros:
1310 *
1311 */
1312/*
1313 * Enumerated value for register field ALT_L3_SEC_L4MP_SDMMC
1314 *
1315 * The slave can only be accessed by a secure master.
1316 */
1317#define ALT_L3_SEC_L4MP_SDMMC_E_SECURE 0x0
1318/*
1319 * Enumerated value for register field ALT_L3_SEC_L4MP_SDMMC
1320 *
1321 * The slave can only be accessed by a secure or non-secure masters.
1322 */
1323#define ALT_L3_SEC_L4MP_SDMMC_E_NONSECURE 0x1
1324
1325/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4MP_SDMMC register field. */
1326#define ALT_L3_SEC_L4MP_SDMMC_LSB 3
1327/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4MP_SDMMC register field. */
1328#define ALT_L3_SEC_L4MP_SDMMC_MSB 3
1329/* The width in bits of the ALT_L3_SEC_L4MP_SDMMC register field. */
1330#define ALT_L3_SEC_L4MP_SDMMC_WIDTH 1
1331/* The mask used to set the ALT_L3_SEC_L4MP_SDMMC register field value. */
1332#define ALT_L3_SEC_L4MP_SDMMC_SET_MSK 0x00000008
1333/* The mask used to clear the ALT_L3_SEC_L4MP_SDMMC register field value. */
1334#define ALT_L3_SEC_L4MP_SDMMC_CLR_MSK 0xfffffff7
1335/* The reset value of the ALT_L3_SEC_L4MP_SDMMC register field. */
1336#define ALT_L3_SEC_L4MP_SDMMC_RESET 0x0
1337/* Extracts the ALT_L3_SEC_L4MP_SDMMC field value from a register. */
1338#define ALT_L3_SEC_L4MP_SDMMC_GET(value) (((value) & 0x00000008) >> 3)
1339/* Produces a ALT_L3_SEC_L4MP_SDMMC register field value suitable for setting the register. */
1340#define ALT_L3_SEC_L4MP_SDMMC_SET(value) (((value) << 3) & 0x00000008)
1341
1342/*
1343 * Field : EMAC 0 Security - emac0
1344 *
1345 * Controls whether secure or non-secure masters can access the EMAC 0 slave.
1346 *
1347 * Field Enumeration Values:
1348 *
1349 * Enum | Value | Description
1350 * :----------------------------------|:------|:----------------------------------------------
1351 * ALT_L3_SEC_L4MP_EMAC0_E_SECURE | 0x0 | The slave can only be accessed by a secure
1352 * : | | master.
1353 * ALT_L3_SEC_L4MP_EMAC0_E_NONSECURE | 0x1 | The slave can only be accessed by a secure or
1354 * : | | non-secure masters.
1355 *
1356 * Field Access Macros:
1357 *
1358 */
1359/*
1360 * Enumerated value for register field ALT_L3_SEC_L4MP_EMAC0
1361 *
1362 * The slave can only be accessed by a secure master.
1363 */
1364#define ALT_L3_SEC_L4MP_EMAC0_E_SECURE 0x0
1365/*
1366 * Enumerated value for register field ALT_L3_SEC_L4MP_EMAC0
1367 *
1368 * The slave can only be accessed by a secure or non-secure masters.
1369 */
1370#define ALT_L3_SEC_L4MP_EMAC0_E_NONSECURE 0x1
1371
1372/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4MP_EMAC0 register field. */
1373#define ALT_L3_SEC_L4MP_EMAC0_LSB 4
1374/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4MP_EMAC0 register field. */
1375#define ALT_L3_SEC_L4MP_EMAC0_MSB 4
1376/* The width in bits of the ALT_L3_SEC_L4MP_EMAC0 register field. */
1377#define ALT_L3_SEC_L4MP_EMAC0_WIDTH 1
1378/* The mask used to set the ALT_L3_SEC_L4MP_EMAC0 register field value. */
1379#define ALT_L3_SEC_L4MP_EMAC0_SET_MSK 0x00000010
1380/* The mask used to clear the ALT_L3_SEC_L4MP_EMAC0 register field value. */
1381#define ALT_L3_SEC_L4MP_EMAC0_CLR_MSK 0xffffffef
1382/* The reset value of the ALT_L3_SEC_L4MP_EMAC0 register field. */
1383#define ALT_L3_SEC_L4MP_EMAC0_RESET 0x0
1384/* Extracts the ALT_L3_SEC_L4MP_EMAC0 field value from a register. */
1385#define ALT_L3_SEC_L4MP_EMAC0_GET(value) (((value) & 0x00000010) >> 4)
1386/* Produces a ALT_L3_SEC_L4MP_EMAC0 register field value suitable for setting the register. */
1387#define ALT_L3_SEC_L4MP_EMAC0_SET(value) (((value) << 4) & 0x00000010)
1388
1389/*
1390 * Field : EMAC 1 Security - emac1
1391 *
1392 * Controls whether secure or non-secure masters can access the EMAC 1 slave.
1393 *
1394 * Field Enumeration Values:
1395 *
1396 * Enum | Value | Description
1397 * :----------------------------------|:------|:----------------------------------------------
1398 * ALT_L3_SEC_L4MP_EMAC1_E_SECURE | 0x0 | The slave can only be accessed by a secure
1399 * : | | master.
1400 * ALT_L3_SEC_L4MP_EMAC1_E_NONSECURE | 0x1 | The slave can only be accessed by a secure or
1401 * : | | non-secure masters.
1402 *
1403 * Field Access Macros:
1404 *
1405 */
1406/*
1407 * Enumerated value for register field ALT_L3_SEC_L4MP_EMAC1
1408 *
1409 * The slave can only be accessed by a secure master.
1410 */
1411#define ALT_L3_SEC_L4MP_EMAC1_E_SECURE 0x0
1412/*
1413 * Enumerated value for register field ALT_L3_SEC_L4MP_EMAC1
1414 *
1415 * The slave can only be accessed by a secure or non-secure masters.
1416 */
1417#define ALT_L3_SEC_L4MP_EMAC1_E_NONSECURE 0x1
1418
1419/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4MP_EMAC1 register field. */
1420#define ALT_L3_SEC_L4MP_EMAC1_LSB 5
1421/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4MP_EMAC1 register field. */
1422#define ALT_L3_SEC_L4MP_EMAC1_MSB 5
1423/* The width in bits of the ALT_L3_SEC_L4MP_EMAC1 register field. */
1424#define ALT_L3_SEC_L4MP_EMAC1_WIDTH 1
1425/* The mask used to set the ALT_L3_SEC_L4MP_EMAC1 register field value. */
1426#define ALT_L3_SEC_L4MP_EMAC1_SET_MSK 0x00000020
1427/* The mask used to clear the ALT_L3_SEC_L4MP_EMAC1 register field value. */
1428#define ALT_L3_SEC_L4MP_EMAC1_CLR_MSK 0xffffffdf
1429/* The reset value of the ALT_L3_SEC_L4MP_EMAC1 register field. */
1430#define ALT_L3_SEC_L4MP_EMAC1_RESET 0x0
1431/* Extracts the ALT_L3_SEC_L4MP_EMAC1 field value from a register. */
1432#define ALT_L3_SEC_L4MP_EMAC1_GET(value) (((value) & 0x00000020) >> 5)
1433/* Produces a ALT_L3_SEC_L4MP_EMAC1 register field value suitable for setting the register. */
1434#define ALT_L3_SEC_L4MP_EMAC1_SET(value) (((value) << 5) & 0x00000020)
1435
1436/*
1437 * Field : ACP ID Mapper Security - acpidmap
1438 *
1439 * Controls whether secure or non-secure masters can access the ACP ID Mapper
1440 * slave.
1441 *
1442 * Field Enumeration Values:
1443 *
1444 * Enum | Value | Description
1445 * :-------------------------------------|:------|:----------------------------------------------
1446 * ALT_L3_SEC_L4MP_ACPIDMAP_E_SECURE | 0x0 | The slave can only be accessed by a secure
1447 * : | | master.
1448 * ALT_L3_SEC_L4MP_ACPIDMAP_E_NONSECURE | 0x1 | The slave can only be accessed by a secure or
1449 * : | | non-secure masters.
1450 *
1451 * Field Access Macros:
1452 *
1453 */
1454/*
1455 * Enumerated value for register field ALT_L3_SEC_L4MP_ACPIDMAP
1456 *
1457 * The slave can only be accessed by a secure master.
1458 */
1459#define ALT_L3_SEC_L4MP_ACPIDMAP_E_SECURE 0x0
1460/*
1461 * Enumerated value for register field ALT_L3_SEC_L4MP_ACPIDMAP
1462 *
1463 * The slave can only be accessed by a secure or non-secure masters.
1464 */
1465#define ALT_L3_SEC_L4MP_ACPIDMAP_E_NONSECURE 0x1
1466
1467/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4MP_ACPIDMAP register field. */
1468#define ALT_L3_SEC_L4MP_ACPIDMAP_LSB 6
1469/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4MP_ACPIDMAP register field. */
1470#define ALT_L3_SEC_L4MP_ACPIDMAP_MSB 6
1471/* The width in bits of the ALT_L3_SEC_L4MP_ACPIDMAP register field. */
1472#define ALT_L3_SEC_L4MP_ACPIDMAP_WIDTH 1
1473/* The mask used to set the ALT_L3_SEC_L4MP_ACPIDMAP register field value. */
1474#define ALT_L3_SEC_L4MP_ACPIDMAP_SET_MSK 0x00000040
1475/* The mask used to clear the ALT_L3_SEC_L4MP_ACPIDMAP register field value. */
1476#define ALT_L3_SEC_L4MP_ACPIDMAP_CLR_MSK 0xffffffbf
1477/* The reset value of the ALT_L3_SEC_L4MP_ACPIDMAP register field. */
1478#define ALT_L3_SEC_L4MP_ACPIDMAP_RESET 0x0
1479/* Extracts the ALT_L3_SEC_L4MP_ACPIDMAP field value from a register. */
1480#define ALT_L3_SEC_L4MP_ACPIDMAP_GET(value) (((value) & 0x00000040) >> 6)
1481/* Produces a ALT_L3_SEC_L4MP_ACPIDMAP register field value suitable for setting the register. */
1482#define ALT_L3_SEC_L4MP_ACPIDMAP_SET(value) (((value) << 6) & 0x00000040)
1483
1484/*
1485 * Field : GPIO 0 Security - gpio0
1486 *
1487 * Controls whether secure or non-secure masters can access the GPIO 0 slave.
1488 *
1489 * Field Enumeration Values:
1490 *
1491 * Enum | Value | Description
1492 * :----------------------------------|:------|:----------------------------------------------
1493 * ALT_L3_SEC_L4MP_GPIO0_E_SECURE | 0x0 | The slave can only be accessed by a secure
1494 * : | | master.
1495 * ALT_L3_SEC_L4MP_GPIO0_E_NONSECURE | 0x1 | The slave can only be accessed by a secure or
1496 * : | | non-secure masters.
1497 *
1498 * Field Access Macros:
1499 *
1500 */
1501/*
1502 * Enumerated value for register field ALT_L3_SEC_L4MP_GPIO0
1503 *
1504 * The slave can only be accessed by a secure master.
1505 */
1506#define ALT_L3_SEC_L4MP_GPIO0_E_SECURE 0x0
1507/*
1508 * Enumerated value for register field ALT_L3_SEC_L4MP_GPIO0
1509 *
1510 * The slave can only be accessed by a secure or non-secure masters.
1511 */
1512#define ALT_L3_SEC_L4MP_GPIO0_E_NONSECURE 0x1
1513
1514/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4MP_GPIO0 register field. */
1515#define ALT_L3_SEC_L4MP_GPIO0_LSB 7
1516/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4MP_GPIO0 register field. */
1517#define ALT_L3_SEC_L4MP_GPIO0_MSB 7
1518/* The width in bits of the ALT_L3_SEC_L4MP_GPIO0 register field. */
1519#define ALT_L3_SEC_L4MP_GPIO0_WIDTH 1
1520/* The mask used to set the ALT_L3_SEC_L4MP_GPIO0 register field value. */
1521#define ALT_L3_SEC_L4MP_GPIO0_SET_MSK 0x00000080
1522/* The mask used to clear the ALT_L3_SEC_L4MP_GPIO0 register field value. */
1523#define ALT_L3_SEC_L4MP_GPIO0_CLR_MSK 0xffffff7f
1524/* The reset value of the ALT_L3_SEC_L4MP_GPIO0 register field. */
1525#define ALT_L3_SEC_L4MP_GPIO0_RESET 0x0
1526/* Extracts the ALT_L3_SEC_L4MP_GPIO0 field value from a register. */
1527#define ALT_L3_SEC_L4MP_GPIO0_GET(value) (((value) & 0x00000080) >> 7)
1528/* Produces a ALT_L3_SEC_L4MP_GPIO0 register field value suitable for setting the register. */
1529#define ALT_L3_SEC_L4MP_GPIO0_SET(value) (((value) << 7) & 0x00000080)
1530
1531/*
1532 * Field : GPIO 1 Security - gpio1
1533 *
1534 * Controls whether secure or non-secure masters can access the GPIO 1 slave.
1535 *
1536 * Field Enumeration Values:
1537 *
1538 * Enum | Value | Description
1539 * :----------------------------------|:------|:----------------------------------------------
1540 * ALT_L3_SEC_L4MP_GPIO1_E_SECURE | 0x0 | The slave can only be accessed by a secure
1541 * : | | master.
1542 * ALT_L3_SEC_L4MP_GPIO1_E_NONSECURE | 0x1 | The slave can only be accessed by a secure or
1543 * : | | non-secure masters.
1544 *
1545 * Field Access Macros:
1546 *
1547 */
1548/*
1549 * Enumerated value for register field ALT_L3_SEC_L4MP_GPIO1
1550 *
1551 * The slave can only be accessed by a secure master.
1552 */
1553#define ALT_L3_SEC_L4MP_GPIO1_E_SECURE 0x0
1554/*
1555 * Enumerated value for register field ALT_L3_SEC_L4MP_GPIO1
1556 *
1557 * The slave can only be accessed by a secure or non-secure masters.
1558 */
1559#define ALT_L3_SEC_L4MP_GPIO1_E_NONSECURE 0x1
1560
1561/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4MP_GPIO1 register field. */
1562#define ALT_L3_SEC_L4MP_GPIO1_LSB 8
1563/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4MP_GPIO1 register field. */
1564#define ALT_L3_SEC_L4MP_GPIO1_MSB 8
1565/* The width in bits of the ALT_L3_SEC_L4MP_GPIO1 register field. */
1566#define ALT_L3_SEC_L4MP_GPIO1_WIDTH 1
1567/* The mask used to set the ALT_L3_SEC_L4MP_GPIO1 register field value. */
1568#define ALT_L3_SEC_L4MP_GPIO1_SET_MSK 0x00000100
1569/* The mask used to clear the ALT_L3_SEC_L4MP_GPIO1 register field value. */
1570#define ALT_L3_SEC_L4MP_GPIO1_CLR_MSK 0xfffffeff
1571/* The reset value of the ALT_L3_SEC_L4MP_GPIO1 register field. */
1572#define ALT_L3_SEC_L4MP_GPIO1_RESET 0x0
1573/* Extracts the ALT_L3_SEC_L4MP_GPIO1 field value from a register. */
1574#define ALT_L3_SEC_L4MP_GPIO1_GET(value) (((value) & 0x00000100) >> 8)
1575/* Produces a ALT_L3_SEC_L4MP_GPIO1 register field value suitable for setting the register. */
1576#define ALT_L3_SEC_L4MP_GPIO1_SET(value) (((value) << 8) & 0x00000100)
1577
1578/*
1579 * Field : GPIO 2 Security - gpio2
1580 *
1581 * Controls whether secure or non-secure masters can access the GPIO 2 slave.
1582 *
1583 * Field Enumeration Values:
1584 *
1585 * Enum | Value | Description
1586 * :----------------------------------|:------|:----------------------------------------------
1587 * ALT_L3_SEC_L4MP_GPIO2_E_SECURE | 0x0 | The slave can only be accessed by a secure
1588 * : | | master.
1589 * ALT_L3_SEC_L4MP_GPIO2_E_NONSECURE | 0x1 | The slave can only be accessed by a secure or
1590 * : | | non-secure masters.
1591 *
1592 * Field Access Macros:
1593 *
1594 */
1595/*
1596 * Enumerated value for register field ALT_L3_SEC_L4MP_GPIO2
1597 *
1598 * The slave can only be accessed by a secure master.
1599 */
1600#define ALT_L3_SEC_L4MP_GPIO2_E_SECURE 0x0
1601/*
1602 * Enumerated value for register field ALT_L3_SEC_L4MP_GPIO2
1603 *
1604 * The slave can only be accessed by a secure or non-secure masters.
1605 */
1606#define ALT_L3_SEC_L4MP_GPIO2_E_NONSECURE 0x1
1607
1608/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4MP_GPIO2 register field. */
1609#define ALT_L3_SEC_L4MP_GPIO2_LSB 9
1610/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4MP_GPIO2 register field. */
1611#define ALT_L3_SEC_L4MP_GPIO2_MSB 9
1612/* The width in bits of the ALT_L3_SEC_L4MP_GPIO2 register field. */
1613#define ALT_L3_SEC_L4MP_GPIO2_WIDTH 1
1614/* The mask used to set the ALT_L3_SEC_L4MP_GPIO2 register field value. */
1615#define ALT_L3_SEC_L4MP_GPIO2_SET_MSK 0x00000200
1616/* The mask used to clear the ALT_L3_SEC_L4MP_GPIO2 register field value. */
1617#define ALT_L3_SEC_L4MP_GPIO2_CLR_MSK 0xfffffdff
1618/* The reset value of the ALT_L3_SEC_L4MP_GPIO2 register field. */
1619#define ALT_L3_SEC_L4MP_GPIO2_RESET 0x0
1620/* Extracts the ALT_L3_SEC_L4MP_GPIO2 field value from a register. */
1621#define ALT_L3_SEC_L4MP_GPIO2_GET(value) (((value) & 0x00000200) >> 9)
1622/* Produces a ALT_L3_SEC_L4MP_GPIO2 register field value suitable for setting the register. */
1623#define ALT_L3_SEC_L4MP_GPIO2_SET(value) (((value) << 9) & 0x00000200)
1624
1625#ifndef __ASSEMBLY__
1626/*
1627 * WARNING: The C register and register group struct declarations are provided for
1628 * convenience and illustrative purposes. They should, however, be used with
1629 * caution as the C language standard provides no guarantees about the alignment or
1630 * atomicity of device memory accesses. The recommended practice for writing
1631 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
1632 * alt_write_word() functions.
1633 *
1634 * The struct declaration for register ALT_L3_SEC_L4MP.
1635 */
1637{
1638 uint32_t fpgamgrregs : 1; /* FPGA Manager Register Security */
1639 uint32_t dap : 1; /* DAP Security */
1640 uint32_t qspiregs : 1; /* QSPI Registers Security */
1641 uint32_t sdmmc : 1; /* SDMMC Security */
1642 uint32_t emac0 : 1; /* EMAC 0 Security */
1643 uint32_t emac1 : 1; /* EMAC 1 Security */
1644 uint32_t acpidmap : 1; /* ACP ID Mapper Security */
1645 uint32_t gpio0 : 1; /* GPIO 0 Security */
1646 uint32_t gpio1 : 1; /* GPIO 1 Security */
1647 uint32_t gpio2 : 1; /* GPIO 2 Security */
1648 uint32_t : 22; /* *UNDEFINED* */
1649};
1650
1651/* The typedef declaration for register ALT_L3_SEC_L4MP. */
1652typedef volatile struct ALT_L3_SEC_L4MP_s ALT_L3_SEC_L4MP_t;
1653#endif /* __ASSEMBLY__ */
1654
1655/* The byte offset of the ALT_L3_SEC_L4MP register from the beginning of the component. */
1656#define ALT_L3_SEC_L4MP_OFST 0x8
1657
1658/*
1659 * Register : L4 OSC1 Peripherals Security - l4osc1
1660 *
1661 * Controls security settings for L4 OSC1 peripherals.
1662 *
1663 * Register Layout
1664 *
1665 * Bits | Access | Reset | Description
1666 * :-------|:-------|:------|:-----------------------------
1667 * [0] | W | 0x0 | L4 Watchdog Timer 0 Security
1668 * [1] | W | 0x0 | L4 Watchdog Timer 0 Security
1669 * [2] | W | 0x0 | Clock Manager Security
1670 * [3] | W | 0x0 | Reset Manager Security
1671 * [4] | W | 0x0 | System Manager Security
1672 * [5] | W | 0x0 | OSC1 Timer 0 Security
1673 * [6] | W | 0x0 | OSC1 Timer 1 Security
1674 * [31:7] | ??? | 0x0 | *UNDEFINED*
1675 *
1676 */
1677/*
1678 * Field : L4 Watchdog Timer 0 Security - l4wd0
1679 *
1680 * Controls whether secure or non-secure masters can access the L4 Watchdog Timer 0
1681 * slave.
1682 *
1683 * Field Enumeration Values:
1684 *
1685 * Enum | Value | Description
1686 * :------------------------------------|:------|:----------------------------------------------
1687 * ALT_L3_SEC_L4OSC1_L4WD0_E_SECURE | 0x0 | The slave can only be accessed by a secure
1688 * : | | master.
1689 * ALT_L3_SEC_L4OSC1_L4WD0_E_NONSECURE | 0x1 | The slave can only be accessed by a secure or
1690 * : | | non-secure masters.
1691 *
1692 * Field Access Macros:
1693 *
1694 */
1695/*
1696 * Enumerated value for register field ALT_L3_SEC_L4OSC1_L4WD0
1697 *
1698 * The slave can only be accessed by a secure master.
1699 */
1700#define ALT_L3_SEC_L4OSC1_L4WD0_E_SECURE 0x0
1701/*
1702 * Enumerated value for register field ALT_L3_SEC_L4OSC1_L4WD0
1703 *
1704 * The slave can only be accessed by a secure or non-secure masters.
1705 */
1706#define ALT_L3_SEC_L4OSC1_L4WD0_E_NONSECURE 0x1
1707
1708/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4OSC1_L4WD0 register field. */
1709#define ALT_L3_SEC_L4OSC1_L4WD0_LSB 0
1710/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4OSC1_L4WD0 register field. */
1711#define ALT_L3_SEC_L4OSC1_L4WD0_MSB 0
1712/* The width in bits of the ALT_L3_SEC_L4OSC1_L4WD0 register field. */
1713#define ALT_L3_SEC_L4OSC1_L4WD0_WIDTH 1
1714/* The mask used to set the ALT_L3_SEC_L4OSC1_L4WD0 register field value. */
1715#define ALT_L3_SEC_L4OSC1_L4WD0_SET_MSK 0x00000001
1716/* The mask used to clear the ALT_L3_SEC_L4OSC1_L4WD0 register field value. */
1717#define ALT_L3_SEC_L4OSC1_L4WD0_CLR_MSK 0xfffffffe
1718/* The reset value of the ALT_L3_SEC_L4OSC1_L4WD0 register field. */
1719#define ALT_L3_SEC_L4OSC1_L4WD0_RESET 0x0
1720/* Extracts the ALT_L3_SEC_L4OSC1_L4WD0 field value from a register. */
1721#define ALT_L3_SEC_L4OSC1_L4WD0_GET(value) (((value) & 0x00000001) >> 0)
1722/* Produces a ALT_L3_SEC_L4OSC1_L4WD0 register field value suitable for setting the register. */
1723#define ALT_L3_SEC_L4OSC1_L4WD0_SET(value) (((value) << 0) & 0x00000001)
1724
1725/*
1726 * Field : L4 Watchdog Timer 0 Security - l4wd1
1727 *
1728 * Controls whether secure or non-secure masters can access the L4 Watchdog Timer 0
1729 * slave.
1730 *
1731 * Field Enumeration Values:
1732 *
1733 * Enum | Value | Description
1734 * :------------------------------------|:------|:----------------------------------------------
1735 * ALT_L3_SEC_L4OSC1_L4WD1_E_SECURE | 0x0 | The slave can only be accessed by a secure
1736 * : | | master.
1737 * ALT_L3_SEC_L4OSC1_L4WD1_E_NONSECURE | 0x1 | The slave can only be accessed by a secure or
1738 * : | | non-secure masters.
1739 *
1740 * Field Access Macros:
1741 *
1742 */
1743/*
1744 * Enumerated value for register field ALT_L3_SEC_L4OSC1_L4WD1
1745 *
1746 * The slave can only be accessed by a secure master.
1747 */
1748#define ALT_L3_SEC_L4OSC1_L4WD1_E_SECURE 0x0
1749/*
1750 * Enumerated value for register field ALT_L3_SEC_L4OSC1_L4WD1
1751 *
1752 * The slave can only be accessed by a secure or non-secure masters.
1753 */
1754#define ALT_L3_SEC_L4OSC1_L4WD1_E_NONSECURE 0x1
1755
1756/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4OSC1_L4WD1 register field. */
1757#define ALT_L3_SEC_L4OSC1_L4WD1_LSB 1
1758/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4OSC1_L4WD1 register field. */
1759#define ALT_L3_SEC_L4OSC1_L4WD1_MSB 1
1760/* The width in bits of the ALT_L3_SEC_L4OSC1_L4WD1 register field. */
1761#define ALT_L3_SEC_L4OSC1_L4WD1_WIDTH 1
1762/* The mask used to set the ALT_L3_SEC_L4OSC1_L4WD1 register field value. */
1763#define ALT_L3_SEC_L4OSC1_L4WD1_SET_MSK 0x00000002
1764/* The mask used to clear the ALT_L3_SEC_L4OSC1_L4WD1 register field value. */
1765#define ALT_L3_SEC_L4OSC1_L4WD1_CLR_MSK 0xfffffffd
1766/* The reset value of the ALT_L3_SEC_L4OSC1_L4WD1 register field. */
1767#define ALT_L3_SEC_L4OSC1_L4WD1_RESET 0x0
1768/* Extracts the ALT_L3_SEC_L4OSC1_L4WD1 field value from a register. */
1769#define ALT_L3_SEC_L4OSC1_L4WD1_GET(value) (((value) & 0x00000002) >> 1)
1770/* Produces a ALT_L3_SEC_L4OSC1_L4WD1 register field value suitable for setting the register. */
1771#define ALT_L3_SEC_L4OSC1_L4WD1_SET(value) (((value) << 1) & 0x00000002)
1772
1773/*
1774 * Field : Clock Manager Security - clkmgr
1775 *
1776 * Controls whether secure or non-secure masters can access the Clock Manager
1777 * slave.
1778 *
1779 * Field Enumeration Values:
1780 *
1781 * Enum | Value | Description
1782 * :-------------------------------------|:------|:----------------------------------------------
1783 * ALT_L3_SEC_L4OSC1_CLKMGR_E_SECURE | 0x0 | The slave can only be accessed by a secure
1784 * : | | master.
1785 * ALT_L3_SEC_L4OSC1_CLKMGR_E_NONSECURE | 0x1 | The slave can only be accessed by a secure or
1786 * : | | non-secure masters.
1787 *
1788 * Field Access Macros:
1789 *
1790 */
1791/*
1792 * Enumerated value for register field ALT_L3_SEC_L4OSC1_CLKMGR
1793 *
1794 * The slave can only be accessed by a secure master.
1795 */
1796#define ALT_L3_SEC_L4OSC1_CLKMGR_E_SECURE 0x0
1797/*
1798 * Enumerated value for register field ALT_L3_SEC_L4OSC1_CLKMGR
1799 *
1800 * The slave can only be accessed by a secure or non-secure masters.
1801 */
1802#define ALT_L3_SEC_L4OSC1_CLKMGR_E_NONSECURE 0x1
1803
1804/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4OSC1_CLKMGR register field. */
1805#define ALT_L3_SEC_L4OSC1_CLKMGR_LSB 2
1806/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4OSC1_CLKMGR register field. */
1807#define ALT_L3_SEC_L4OSC1_CLKMGR_MSB 2
1808/* The width in bits of the ALT_L3_SEC_L4OSC1_CLKMGR register field. */
1809#define ALT_L3_SEC_L4OSC1_CLKMGR_WIDTH 1
1810/* The mask used to set the ALT_L3_SEC_L4OSC1_CLKMGR register field value. */
1811#define ALT_L3_SEC_L4OSC1_CLKMGR_SET_MSK 0x00000004
1812/* The mask used to clear the ALT_L3_SEC_L4OSC1_CLKMGR register field value. */
1813#define ALT_L3_SEC_L4OSC1_CLKMGR_CLR_MSK 0xfffffffb
1814/* The reset value of the ALT_L3_SEC_L4OSC1_CLKMGR register field. */
1815#define ALT_L3_SEC_L4OSC1_CLKMGR_RESET 0x0
1816/* Extracts the ALT_L3_SEC_L4OSC1_CLKMGR field value from a register. */
1817#define ALT_L3_SEC_L4OSC1_CLKMGR_GET(value) (((value) & 0x00000004) >> 2)
1818/* Produces a ALT_L3_SEC_L4OSC1_CLKMGR register field value suitable for setting the register. */
1819#define ALT_L3_SEC_L4OSC1_CLKMGR_SET(value) (((value) << 2) & 0x00000004)
1820
1821/*
1822 * Field : Reset Manager Security - rstmgr
1823 *
1824 * Controls whether secure or non-secure masters can access the Reset Manager
1825 * slave.
1826 *
1827 * Field Enumeration Values:
1828 *
1829 * Enum | Value | Description
1830 * :-------------------------------------|:------|:----------------------------------------------
1831 * ALT_L3_SEC_L4OSC1_RSTMGR_E_SECURE | 0x0 | The slave can only be accessed by a secure
1832 * : | | master.
1833 * ALT_L3_SEC_L4OSC1_RSTMGR_E_NONSECURE | 0x1 | The slave can only be accessed by a secure or
1834 * : | | non-secure masters.
1835 *
1836 * Field Access Macros:
1837 *
1838 */
1839/*
1840 * Enumerated value for register field ALT_L3_SEC_L4OSC1_RSTMGR
1841 *
1842 * The slave can only be accessed by a secure master.
1843 */
1844#define ALT_L3_SEC_L4OSC1_RSTMGR_E_SECURE 0x0
1845/*
1846 * Enumerated value for register field ALT_L3_SEC_L4OSC1_RSTMGR
1847 *
1848 * The slave can only be accessed by a secure or non-secure masters.
1849 */
1850#define ALT_L3_SEC_L4OSC1_RSTMGR_E_NONSECURE 0x1
1851
1852/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4OSC1_RSTMGR register field. */
1853#define ALT_L3_SEC_L4OSC1_RSTMGR_LSB 3
1854/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4OSC1_RSTMGR register field. */
1855#define ALT_L3_SEC_L4OSC1_RSTMGR_MSB 3
1856/* The width in bits of the ALT_L3_SEC_L4OSC1_RSTMGR register field. */
1857#define ALT_L3_SEC_L4OSC1_RSTMGR_WIDTH 1
1858/* The mask used to set the ALT_L3_SEC_L4OSC1_RSTMGR register field value. */
1859#define ALT_L3_SEC_L4OSC1_RSTMGR_SET_MSK 0x00000008
1860/* The mask used to clear the ALT_L3_SEC_L4OSC1_RSTMGR register field value. */
1861#define ALT_L3_SEC_L4OSC1_RSTMGR_CLR_MSK 0xfffffff7
1862/* The reset value of the ALT_L3_SEC_L4OSC1_RSTMGR register field. */
1863#define ALT_L3_SEC_L4OSC1_RSTMGR_RESET 0x0
1864/* Extracts the ALT_L3_SEC_L4OSC1_RSTMGR field value from a register. */
1865#define ALT_L3_SEC_L4OSC1_RSTMGR_GET(value) (((value) & 0x00000008) >> 3)
1866/* Produces a ALT_L3_SEC_L4OSC1_RSTMGR register field value suitable for setting the register. */
1867#define ALT_L3_SEC_L4OSC1_RSTMGR_SET(value) (((value) << 3) & 0x00000008)
1868
1869/*
1870 * Field : System Manager Security - sysmgr
1871 *
1872 * Controls whether secure or non-secure masters can access the System Manager
1873 * slave.
1874 *
1875 * Field Enumeration Values:
1876 *
1877 * Enum | Value | Description
1878 * :-------------------------------------|:------|:----------------------------------------------
1879 * ALT_L3_SEC_L4OSC1_SYSMGR_E_SECURE | 0x0 | The slave can only be accessed by a secure
1880 * : | | master.
1881 * ALT_L3_SEC_L4OSC1_SYSMGR_E_NONSECURE | 0x1 | The slave can only be accessed by a secure or
1882 * : | | non-secure masters.
1883 *
1884 * Field Access Macros:
1885 *
1886 */
1887/*
1888 * Enumerated value for register field ALT_L3_SEC_L4OSC1_SYSMGR
1889 *
1890 * The slave can only be accessed by a secure master.
1891 */
1892#define ALT_L3_SEC_L4OSC1_SYSMGR_E_SECURE 0x0
1893/*
1894 * Enumerated value for register field ALT_L3_SEC_L4OSC1_SYSMGR
1895 *
1896 * The slave can only be accessed by a secure or non-secure masters.
1897 */
1898#define ALT_L3_SEC_L4OSC1_SYSMGR_E_NONSECURE 0x1
1899
1900/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4OSC1_SYSMGR register field. */
1901#define ALT_L3_SEC_L4OSC1_SYSMGR_LSB 4
1902/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4OSC1_SYSMGR register field. */
1903#define ALT_L3_SEC_L4OSC1_SYSMGR_MSB 4
1904/* The width in bits of the ALT_L3_SEC_L4OSC1_SYSMGR register field. */
1905#define ALT_L3_SEC_L4OSC1_SYSMGR_WIDTH 1
1906/* The mask used to set the ALT_L3_SEC_L4OSC1_SYSMGR register field value. */
1907#define ALT_L3_SEC_L4OSC1_SYSMGR_SET_MSK 0x00000010
1908/* The mask used to clear the ALT_L3_SEC_L4OSC1_SYSMGR register field value. */
1909#define ALT_L3_SEC_L4OSC1_SYSMGR_CLR_MSK 0xffffffef
1910/* The reset value of the ALT_L3_SEC_L4OSC1_SYSMGR register field. */
1911#define ALT_L3_SEC_L4OSC1_SYSMGR_RESET 0x0
1912/* Extracts the ALT_L3_SEC_L4OSC1_SYSMGR field value from a register. */
1913#define ALT_L3_SEC_L4OSC1_SYSMGR_GET(value) (((value) & 0x00000010) >> 4)
1914/* Produces a ALT_L3_SEC_L4OSC1_SYSMGR register field value suitable for setting the register. */
1915#define ALT_L3_SEC_L4OSC1_SYSMGR_SET(value) (((value) << 4) & 0x00000010)
1916
1917/*
1918 * Field : OSC1 Timer 0 Security - osc1timer0
1919 *
1920 * Controls whether secure or non-secure masters can access the OSC1 Timer 0 slave.
1921 *
1922 * Field Enumeration Values:
1923 *
1924 * Enum | Value | Description
1925 * :---------------------------------------|:------|:----------------------------------------------
1926 * ALT_L3_SEC_L4OSC1_OSC1TMR0_E_SECURE | 0x0 | The slave can only be accessed by a secure
1927 * : | | master.
1928 * ALT_L3_SEC_L4OSC1_OSC1TMR0_E_NONSECURE | 0x1 | The slave can only be accessed by a secure or
1929 * : | | non-secure masters.
1930 *
1931 * Field Access Macros:
1932 *
1933 */
1934/*
1935 * Enumerated value for register field ALT_L3_SEC_L4OSC1_OSC1TMR0
1936 *
1937 * The slave can only be accessed by a secure master.
1938 */
1939#define ALT_L3_SEC_L4OSC1_OSC1TMR0_E_SECURE 0x0
1940/*
1941 * Enumerated value for register field ALT_L3_SEC_L4OSC1_OSC1TMR0
1942 *
1943 * The slave can only be accessed by a secure or non-secure masters.
1944 */
1945#define ALT_L3_SEC_L4OSC1_OSC1TMR0_E_NONSECURE 0x1
1946
1947/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4OSC1_OSC1TMR0 register field. */
1948#define ALT_L3_SEC_L4OSC1_OSC1TMR0_LSB 5
1949/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4OSC1_OSC1TMR0 register field. */
1950#define ALT_L3_SEC_L4OSC1_OSC1TMR0_MSB 5
1951/* The width in bits of the ALT_L3_SEC_L4OSC1_OSC1TMR0 register field. */
1952#define ALT_L3_SEC_L4OSC1_OSC1TMR0_WIDTH 1
1953/* The mask used to set the ALT_L3_SEC_L4OSC1_OSC1TMR0 register field value. */
1954#define ALT_L3_SEC_L4OSC1_OSC1TMR0_SET_MSK 0x00000020
1955/* The mask used to clear the ALT_L3_SEC_L4OSC1_OSC1TMR0 register field value. */
1956#define ALT_L3_SEC_L4OSC1_OSC1TMR0_CLR_MSK 0xffffffdf
1957/* The reset value of the ALT_L3_SEC_L4OSC1_OSC1TMR0 register field. */
1958#define ALT_L3_SEC_L4OSC1_OSC1TMR0_RESET 0x0
1959/* Extracts the ALT_L3_SEC_L4OSC1_OSC1TMR0 field value from a register. */
1960#define ALT_L3_SEC_L4OSC1_OSC1TMR0_GET(value) (((value) & 0x00000020) >> 5)
1961/* Produces a ALT_L3_SEC_L4OSC1_OSC1TMR0 register field value suitable for setting the register. */
1962#define ALT_L3_SEC_L4OSC1_OSC1TMR0_SET(value) (((value) << 5) & 0x00000020)
1963
1964/*
1965 * Field : OSC1 Timer 1 Security - osc1timer1
1966 *
1967 * Controls whether secure or non-secure masters can access the OSC1 Timer 1 slave.
1968 *
1969 * Field Enumeration Values:
1970 *
1971 * Enum | Value | Description
1972 * :---------------------------------------|:------|:----------------------------------------------
1973 * ALT_L3_SEC_L4OSC1_OSC1TMR1_E_SECURE | 0x0 | The slave can only be accessed by a secure
1974 * : | | master.
1975 * ALT_L3_SEC_L4OSC1_OSC1TMR1_E_NONSECURE | 0x1 | The slave can only be accessed by a secure or
1976 * : | | non-secure masters.
1977 *
1978 * Field Access Macros:
1979 *
1980 */
1981/*
1982 * Enumerated value for register field ALT_L3_SEC_L4OSC1_OSC1TMR1
1983 *
1984 * The slave can only be accessed by a secure master.
1985 */
1986#define ALT_L3_SEC_L4OSC1_OSC1TMR1_E_SECURE 0x0
1987/*
1988 * Enumerated value for register field ALT_L3_SEC_L4OSC1_OSC1TMR1
1989 *
1990 * The slave can only be accessed by a secure or non-secure masters.
1991 */
1992#define ALT_L3_SEC_L4OSC1_OSC1TMR1_E_NONSECURE 0x1
1993
1994/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4OSC1_OSC1TMR1 register field. */
1995#define ALT_L3_SEC_L4OSC1_OSC1TMR1_LSB 6
1996/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4OSC1_OSC1TMR1 register field. */
1997#define ALT_L3_SEC_L4OSC1_OSC1TMR1_MSB 6
1998/* The width in bits of the ALT_L3_SEC_L4OSC1_OSC1TMR1 register field. */
1999#define ALT_L3_SEC_L4OSC1_OSC1TMR1_WIDTH 1
2000/* The mask used to set the ALT_L3_SEC_L4OSC1_OSC1TMR1 register field value. */
2001#define ALT_L3_SEC_L4OSC1_OSC1TMR1_SET_MSK 0x00000040
2002/* The mask used to clear the ALT_L3_SEC_L4OSC1_OSC1TMR1 register field value. */
2003#define ALT_L3_SEC_L4OSC1_OSC1TMR1_CLR_MSK 0xffffffbf
2004/* The reset value of the ALT_L3_SEC_L4OSC1_OSC1TMR1 register field. */
2005#define ALT_L3_SEC_L4OSC1_OSC1TMR1_RESET 0x0
2006/* Extracts the ALT_L3_SEC_L4OSC1_OSC1TMR1 field value from a register. */
2007#define ALT_L3_SEC_L4OSC1_OSC1TMR1_GET(value) (((value) & 0x00000040) >> 6)
2008/* Produces a ALT_L3_SEC_L4OSC1_OSC1TMR1 register field value suitable for setting the register. */
2009#define ALT_L3_SEC_L4OSC1_OSC1TMR1_SET(value) (((value) << 6) & 0x00000040)
2010
2011#ifndef __ASSEMBLY__
2012/*
2013 * WARNING: The C register and register group struct declarations are provided for
2014 * convenience and illustrative purposes. They should, however, be used with
2015 * caution as the C language standard provides no guarantees about the alignment or
2016 * atomicity of device memory accesses. The recommended practice for writing
2017 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
2018 * alt_write_word() functions.
2019 *
2020 * The struct declaration for register ALT_L3_SEC_L4OSC1.
2021 */
2023{
2024 uint32_t l4wd0 : 1; /* L4 Watchdog Timer 0 Security */
2025 uint32_t l4wd1 : 1; /* L4 Watchdog Timer 0 Security */
2026 uint32_t clkmgr : 1; /* Clock Manager Security */
2027 uint32_t rstmgr : 1; /* Reset Manager Security */
2028 uint32_t sysmgr : 1; /* System Manager Security */
2029 uint32_t osc1timer0 : 1; /* OSC1 Timer 0 Security */
2030 uint32_t osc1timer1 : 1; /* OSC1 Timer 1 Security */
2031 uint32_t : 25; /* *UNDEFINED* */
2032};
2033
2034/* The typedef declaration for register ALT_L3_SEC_L4OSC1. */
2035typedef volatile struct ALT_L3_SEC_L4OSC1_s ALT_L3_SEC_L4OSC1_t;
2036#endif /* __ASSEMBLY__ */
2037
2038/* The byte offset of the ALT_L3_SEC_L4OSC1 register from the beginning of the component. */
2039#define ALT_L3_SEC_L4OSC1_OFST 0xc
2040
2041/*
2042 * Register : L4 SPIM Peripherals Security - l4spim
2043 *
2044 * Controls security settings for L4 SPIM peripherals.
2045 *
2046 * Register Layout
2047 *
2048 * Bits | Access | Reset | Description
2049 * :-------|:-------|:------|:----------------------
2050 * [0] | W | 0x0 | SPI Master 0 Security
2051 * [1] | W | 0x0 | SPI Master 1 Security
2052 * [2] | W | 0x0 | Scan Manager Security
2053 * [31:3] | ??? | 0x0 | *UNDEFINED*
2054 *
2055 */
2056/*
2057 * Field : SPI Master 0 Security - spim0
2058 *
2059 * Controls whether secure or non-secure masters can access the SPI Master 0 slave.
2060 *
2061 * Field Enumeration Values:
2062 *
2063 * Enum | Value | Description
2064 * :------------------------------------|:------|:----------------------------------------------
2065 * ALT_L3_SEC_L4SPIM_SPIM0_E_SECURE | 0x0 | The slave can only be accessed by a secure
2066 * : | | master.
2067 * ALT_L3_SEC_L4SPIM_SPIM0_E_NONSECURE | 0x1 | The slave can only be accessed by a secure or
2068 * : | | non-secure masters.
2069 *
2070 * Field Access Macros:
2071 *
2072 */
2073/*
2074 * Enumerated value for register field ALT_L3_SEC_L4SPIM_SPIM0
2075 *
2076 * The slave can only be accessed by a secure master.
2077 */
2078#define ALT_L3_SEC_L4SPIM_SPIM0_E_SECURE 0x0
2079/*
2080 * Enumerated value for register field ALT_L3_SEC_L4SPIM_SPIM0
2081 *
2082 * The slave can only be accessed by a secure or non-secure masters.
2083 */
2084#define ALT_L3_SEC_L4SPIM_SPIM0_E_NONSECURE 0x1
2085
2086/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4SPIM_SPIM0 register field. */
2087#define ALT_L3_SEC_L4SPIM_SPIM0_LSB 0
2088/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4SPIM_SPIM0 register field. */
2089#define ALT_L3_SEC_L4SPIM_SPIM0_MSB 0
2090/* The width in bits of the ALT_L3_SEC_L4SPIM_SPIM0 register field. */
2091#define ALT_L3_SEC_L4SPIM_SPIM0_WIDTH 1
2092/* The mask used to set the ALT_L3_SEC_L4SPIM_SPIM0 register field value. */
2093#define ALT_L3_SEC_L4SPIM_SPIM0_SET_MSK 0x00000001
2094/* The mask used to clear the ALT_L3_SEC_L4SPIM_SPIM0 register field value. */
2095#define ALT_L3_SEC_L4SPIM_SPIM0_CLR_MSK 0xfffffffe
2096/* The reset value of the ALT_L3_SEC_L4SPIM_SPIM0 register field. */
2097#define ALT_L3_SEC_L4SPIM_SPIM0_RESET 0x0
2098/* Extracts the ALT_L3_SEC_L4SPIM_SPIM0 field value from a register. */
2099#define ALT_L3_SEC_L4SPIM_SPIM0_GET(value) (((value) & 0x00000001) >> 0)
2100/* Produces a ALT_L3_SEC_L4SPIM_SPIM0 register field value suitable for setting the register. */
2101#define ALT_L3_SEC_L4SPIM_SPIM0_SET(value) (((value) << 0) & 0x00000001)
2102
2103/*
2104 * Field : SPI Master 1 Security - spim1
2105 *
2106 * Controls whether secure or non-secure masters can access the SPI Master 1 slave.
2107 *
2108 * Field Enumeration Values:
2109 *
2110 * Enum | Value | Description
2111 * :------------------------------------|:------|:----------------------------------------------
2112 * ALT_L3_SEC_L4SPIM_SPIM1_E_SECURE | 0x0 | The slave can only be accessed by a secure
2113 * : | | master.
2114 * ALT_L3_SEC_L4SPIM_SPIM1_E_NONSECURE | 0x1 | The slave can only be accessed by a secure or
2115 * : | | non-secure masters.
2116 *
2117 * Field Access Macros:
2118 *
2119 */
2120/*
2121 * Enumerated value for register field ALT_L3_SEC_L4SPIM_SPIM1
2122 *
2123 * The slave can only be accessed by a secure master.
2124 */
2125#define ALT_L3_SEC_L4SPIM_SPIM1_E_SECURE 0x0
2126/*
2127 * Enumerated value for register field ALT_L3_SEC_L4SPIM_SPIM1
2128 *
2129 * The slave can only be accessed by a secure or non-secure masters.
2130 */
2131#define ALT_L3_SEC_L4SPIM_SPIM1_E_NONSECURE 0x1
2132
2133/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4SPIM_SPIM1 register field. */
2134#define ALT_L3_SEC_L4SPIM_SPIM1_LSB 1
2135/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4SPIM_SPIM1 register field. */
2136#define ALT_L3_SEC_L4SPIM_SPIM1_MSB 1
2137/* The width in bits of the ALT_L3_SEC_L4SPIM_SPIM1 register field. */
2138#define ALT_L3_SEC_L4SPIM_SPIM1_WIDTH 1
2139/* The mask used to set the ALT_L3_SEC_L4SPIM_SPIM1 register field value. */
2140#define ALT_L3_SEC_L4SPIM_SPIM1_SET_MSK 0x00000002
2141/* The mask used to clear the ALT_L3_SEC_L4SPIM_SPIM1 register field value. */
2142#define ALT_L3_SEC_L4SPIM_SPIM1_CLR_MSK 0xfffffffd
2143/* The reset value of the ALT_L3_SEC_L4SPIM_SPIM1 register field. */
2144#define ALT_L3_SEC_L4SPIM_SPIM1_RESET 0x0
2145/* Extracts the ALT_L3_SEC_L4SPIM_SPIM1 field value from a register. */
2146#define ALT_L3_SEC_L4SPIM_SPIM1_GET(value) (((value) & 0x00000002) >> 1)
2147/* Produces a ALT_L3_SEC_L4SPIM_SPIM1 register field value suitable for setting the register. */
2148#define ALT_L3_SEC_L4SPIM_SPIM1_SET(value) (((value) << 1) & 0x00000002)
2149
2150/*
2151 * Field : Scan Manager Security - scanmgr
2152 *
2153 * Controls whether secure or non-secure masters can access the Scan Manager slave.
2154 *
2155 * Field Enumeration Values:
2156 *
2157 * Enum | Value | Description
2158 * :--------------------------------------|:------|:----------------------------------------------
2159 * ALT_L3_SEC_L4SPIM_SCANMGR_E_SECURE | 0x0 | The slave can only be accessed by a secure
2160 * : | | master.
2161 * ALT_L3_SEC_L4SPIM_SCANMGR_E_NONSECURE | 0x1 | The slave can only be accessed by a secure or
2162 * : | | non-secure masters.
2163 *
2164 * Field Access Macros:
2165 *
2166 */
2167/*
2168 * Enumerated value for register field ALT_L3_SEC_L4SPIM_SCANMGR
2169 *
2170 * The slave can only be accessed by a secure master.
2171 */
2172#define ALT_L3_SEC_L4SPIM_SCANMGR_E_SECURE 0x0
2173/*
2174 * Enumerated value for register field ALT_L3_SEC_L4SPIM_SCANMGR
2175 *
2176 * The slave can only be accessed by a secure or non-secure masters.
2177 */
2178#define ALT_L3_SEC_L4SPIM_SCANMGR_E_NONSECURE 0x1
2179
2180/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_L4SPIM_SCANMGR register field. */
2181#define ALT_L3_SEC_L4SPIM_SCANMGR_LSB 2
2182/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_L4SPIM_SCANMGR register field. */
2183#define ALT_L3_SEC_L4SPIM_SCANMGR_MSB 2
2184/* The width in bits of the ALT_L3_SEC_L4SPIM_SCANMGR register field. */
2185#define ALT_L3_SEC_L4SPIM_SCANMGR_WIDTH 1
2186/* The mask used to set the ALT_L3_SEC_L4SPIM_SCANMGR register field value. */
2187#define ALT_L3_SEC_L4SPIM_SCANMGR_SET_MSK 0x00000004
2188/* The mask used to clear the ALT_L3_SEC_L4SPIM_SCANMGR register field value. */
2189#define ALT_L3_SEC_L4SPIM_SCANMGR_CLR_MSK 0xfffffffb
2190/* The reset value of the ALT_L3_SEC_L4SPIM_SCANMGR register field. */
2191#define ALT_L3_SEC_L4SPIM_SCANMGR_RESET 0x0
2192/* Extracts the ALT_L3_SEC_L4SPIM_SCANMGR field value from a register. */
2193#define ALT_L3_SEC_L4SPIM_SCANMGR_GET(value) (((value) & 0x00000004) >> 2)
2194/* Produces a ALT_L3_SEC_L4SPIM_SCANMGR register field value suitable for setting the register. */
2195#define ALT_L3_SEC_L4SPIM_SCANMGR_SET(value) (((value) << 2) & 0x00000004)
2196
2197#ifndef __ASSEMBLY__
2198/*
2199 * WARNING: The C register and register group struct declarations are provided for
2200 * convenience and illustrative purposes. They should, however, be used with
2201 * caution as the C language standard provides no guarantees about the alignment or
2202 * atomicity of device memory accesses. The recommended practice for writing
2203 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
2204 * alt_write_word() functions.
2205 *
2206 * The struct declaration for register ALT_L3_SEC_L4SPIM.
2207 */
2209{
2210 uint32_t spim0 : 1; /* SPI Master 0 Security */
2211 uint32_t spim1 : 1; /* SPI Master 1 Security */
2212 uint32_t scanmgr : 1; /* Scan Manager Security */
2213 uint32_t : 29; /* *UNDEFINED* */
2214};
2215
2216/* The typedef declaration for register ALT_L3_SEC_L4SPIM. */
2217typedef volatile struct ALT_L3_SEC_L4SPIM_s ALT_L3_SEC_L4SPIM_t;
2218#endif /* __ASSEMBLY__ */
2219
2220/* The byte offset of the ALT_L3_SEC_L4SPIM register from the beginning of the component. */
2221#define ALT_L3_SEC_L4SPIM_OFST 0x10
2222
2223/*
2224 * Register : STM Peripheral Security - stm
2225 *
2226 * Controls security settings for STM peripheral.
2227 *
2228 * Register Layout
2229 *
2230 * Bits | Access | Reset | Description
2231 * :-------|:-------|:------|:-------------
2232 * [0] | W | 0x0 | STM Security
2233 * [31:1] | ??? | 0x0 | *UNDEFINED*
2234 *
2235 */
2236/*
2237 * Field : STM Security - s
2238 *
2239 * Controls whether secure or non-secure masters can access the STM slave.
2240 *
2241 * Field Enumeration Values:
2242 *
2243 * Enum | Value | Description
2244 * :-----------------------------|:------|:----------------------------------------------
2245 * ALT_L3_SEC_STM_S_E_SECURE | 0x0 | The slave can only be accessed by a secure
2246 * : | | master.
2247 * ALT_L3_SEC_STM_S_E_NONSECURE | 0x1 | The slave can only be accessed by a secure or
2248 * : | | non-secure masters.
2249 *
2250 * Field Access Macros:
2251 *
2252 */
2253/*
2254 * Enumerated value for register field ALT_L3_SEC_STM_S
2255 *
2256 * The slave can only be accessed by a secure master.
2257 */
2258#define ALT_L3_SEC_STM_S_E_SECURE 0x0
2259/*
2260 * Enumerated value for register field ALT_L3_SEC_STM_S
2261 *
2262 * The slave can only be accessed by a secure or non-secure masters.
2263 */
2264#define ALT_L3_SEC_STM_S_E_NONSECURE 0x1
2265
2266/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_STM_S register field. */
2267#define ALT_L3_SEC_STM_S_LSB 0
2268/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_STM_S register field. */
2269#define ALT_L3_SEC_STM_S_MSB 0
2270/* The width in bits of the ALT_L3_SEC_STM_S register field. */
2271#define ALT_L3_SEC_STM_S_WIDTH 1
2272/* The mask used to set the ALT_L3_SEC_STM_S register field value. */
2273#define ALT_L3_SEC_STM_S_SET_MSK 0x00000001
2274/* The mask used to clear the ALT_L3_SEC_STM_S register field value. */
2275#define ALT_L3_SEC_STM_S_CLR_MSK 0xfffffffe
2276/* The reset value of the ALT_L3_SEC_STM_S register field. */
2277#define ALT_L3_SEC_STM_S_RESET 0x0
2278/* Extracts the ALT_L3_SEC_STM_S field value from a register. */
2279#define ALT_L3_SEC_STM_S_GET(value) (((value) & 0x00000001) >> 0)
2280/* Produces a ALT_L3_SEC_STM_S register field value suitable for setting the register. */
2281#define ALT_L3_SEC_STM_S_SET(value) (((value) << 0) & 0x00000001)
2282
2283#ifndef __ASSEMBLY__
2284/*
2285 * WARNING: The C register and register group struct declarations are provided for
2286 * convenience and illustrative purposes. They should, however, be used with
2287 * caution as the C language standard provides no guarantees about the alignment or
2288 * atomicity of device memory accesses. The recommended practice for writing
2289 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
2290 * alt_write_word() functions.
2291 *
2292 * The struct declaration for register ALT_L3_SEC_STM.
2293 */
2295{
2296 uint32_t s : 1; /* STM Security */
2297 uint32_t : 31; /* *UNDEFINED* */
2298};
2299
2300/* The typedef declaration for register ALT_L3_SEC_STM. */
2301typedef volatile struct ALT_L3_SEC_STM_s ALT_L3_SEC_STM_t;
2302#endif /* __ASSEMBLY__ */
2303
2304/* The byte offset of the ALT_L3_SEC_STM register from the beginning of the component. */
2305#define ALT_L3_SEC_STM_OFST 0x14
2306
2307/*
2308 * Register : LWHPS2FPGA AXI Bridge Registers Peripheral Security - lwhps2fpgaregs
2309 *
2310 * Controls security settings for LWHPS2FPGA AXI Bridge Registers peripheral.
2311 *
2312 * Register Layout
2313 *
2314 * Bits | Access | Reset | Description
2315 * :-------|:-------|:------|:-----------------------------------------
2316 * [0] | W | 0x0 | LWHPS2FPGA AXI Bridge Registers Security
2317 * [31:1] | ??? | 0x0 | *UNDEFINED*
2318 *
2319 */
2320/*
2321 * Field : LWHPS2FPGA AXI Bridge Registers Security - s
2322 *
2323 * Controls whether secure or non-secure masters can access the LWHPS2FPGA AXI
2324 * Bridge Registers slave.
2325 *
2326 * Field Enumeration Values:
2327 *
2328 * Enum | Value | Description
2329 * :-------------------------------|:------|:----------------------------------------------
2330 * ALT_L3_SEC_LWH2F_S_E_SECURE | 0x0 | The slave can only be accessed by a secure
2331 * : | | master.
2332 * ALT_L3_SEC_LWH2F_S_E_NONSECURE | 0x1 | The slave can only be accessed by a secure or
2333 * : | | non-secure masters.
2334 *
2335 * Field Access Macros:
2336 *
2337 */
2338/*
2339 * Enumerated value for register field ALT_L3_SEC_LWH2F_S
2340 *
2341 * The slave can only be accessed by a secure master.
2342 */
2343#define ALT_L3_SEC_LWH2F_S_E_SECURE 0x0
2344/*
2345 * Enumerated value for register field ALT_L3_SEC_LWH2F_S
2346 *
2347 * The slave can only be accessed by a secure or non-secure masters.
2348 */
2349#define ALT_L3_SEC_LWH2F_S_E_NONSECURE 0x1
2350
2351/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_LWH2F_S register field. */
2352#define ALT_L3_SEC_LWH2F_S_LSB 0
2353/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_LWH2F_S register field. */
2354#define ALT_L3_SEC_LWH2F_S_MSB 0
2355/* The width in bits of the ALT_L3_SEC_LWH2F_S register field. */
2356#define ALT_L3_SEC_LWH2F_S_WIDTH 1
2357/* The mask used to set the ALT_L3_SEC_LWH2F_S register field value. */
2358#define ALT_L3_SEC_LWH2F_S_SET_MSK 0x00000001
2359/* The mask used to clear the ALT_L3_SEC_LWH2F_S register field value. */
2360#define ALT_L3_SEC_LWH2F_S_CLR_MSK 0xfffffffe
2361/* The reset value of the ALT_L3_SEC_LWH2F_S register field. */
2362#define ALT_L3_SEC_LWH2F_S_RESET 0x0
2363/* Extracts the ALT_L3_SEC_LWH2F_S field value from a register. */
2364#define ALT_L3_SEC_LWH2F_S_GET(value) (((value) & 0x00000001) >> 0)
2365/* Produces a ALT_L3_SEC_LWH2F_S register field value suitable for setting the register. */
2366#define ALT_L3_SEC_LWH2F_S_SET(value) (((value) << 0) & 0x00000001)
2367
2368#ifndef __ASSEMBLY__
2369/*
2370 * WARNING: The C register and register group struct declarations are provided for
2371 * convenience and illustrative purposes. They should, however, be used with
2372 * caution as the C language standard provides no guarantees about the alignment or
2373 * atomicity of device memory accesses. The recommended practice for writing
2374 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
2375 * alt_write_word() functions.
2376 *
2377 * The struct declaration for register ALT_L3_SEC_LWH2F.
2378 */
2380{
2381 uint32_t s : 1; /* LWHPS2FPGA AXI Bridge Registers Security */
2382 uint32_t : 31; /* *UNDEFINED* */
2383};
2384
2385/* The typedef declaration for register ALT_L3_SEC_LWH2F. */
2386typedef volatile struct ALT_L3_SEC_LWH2F_s ALT_L3_SEC_LWH2F_t;
2387#endif /* __ASSEMBLY__ */
2388
2389/* The byte offset of the ALT_L3_SEC_LWH2F register from the beginning of the component. */
2390#define ALT_L3_SEC_LWH2F_OFST 0x18
2391
2392/*
2393 * Register : USB1 Registers Peripheral Security - usb1
2394 *
2395 * Controls security settings for USB1 Registers peripheral.
2396 *
2397 * Register Layout
2398 *
2399 * Bits | Access | Reset | Description
2400 * :-------|:-------|:------|:------------------------
2401 * [0] | W | 0x0 | USB1 Registers Security
2402 * [31:1] | ??? | 0x0 | *UNDEFINED*
2403 *
2404 */
2405/*
2406 * Field : USB1 Registers Security - s
2407 *
2408 * Controls whether secure or non-secure masters can access the USB1 Registers
2409 * slave.
2410 *
2411 * Field Enumeration Values:
2412 *
2413 * Enum | Value | Description
2414 * :------------------------------|:------|:----------------------------------------------
2415 * ALT_L3_SEC_USB1_S_E_SECURE | 0x0 | The slave can only be accessed by a secure
2416 * : | | master.
2417 * ALT_L3_SEC_USB1_S_E_NONSECURE | 0x1 | The slave can only be accessed by a secure or
2418 * : | | non-secure masters.
2419 *
2420 * Field Access Macros:
2421 *
2422 */
2423/*
2424 * Enumerated value for register field ALT_L3_SEC_USB1_S
2425 *
2426 * The slave can only be accessed by a secure master.
2427 */
2428#define ALT_L3_SEC_USB1_S_E_SECURE 0x0
2429/*
2430 * Enumerated value for register field ALT_L3_SEC_USB1_S
2431 *
2432 * The slave can only be accessed by a secure or non-secure masters.
2433 */
2434#define ALT_L3_SEC_USB1_S_E_NONSECURE 0x1
2435
2436/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_USB1_S register field. */
2437#define ALT_L3_SEC_USB1_S_LSB 0
2438/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_USB1_S register field. */
2439#define ALT_L3_SEC_USB1_S_MSB 0
2440/* The width in bits of the ALT_L3_SEC_USB1_S register field. */
2441#define ALT_L3_SEC_USB1_S_WIDTH 1
2442/* The mask used to set the ALT_L3_SEC_USB1_S register field value. */
2443#define ALT_L3_SEC_USB1_S_SET_MSK 0x00000001
2444/* The mask used to clear the ALT_L3_SEC_USB1_S register field value. */
2445#define ALT_L3_SEC_USB1_S_CLR_MSK 0xfffffffe
2446/* The reset value of the ALT_L3_SEC_USB1_S register field. */
2447#define ALT_L3_SEC_USB1_S_RESET 0x0
2448/* Extracts the ALT_L3_SEC_USB1_S field value from a register. */
2449#define ALT_L3_SEC_USB1_S_GET(value) (((value) & 0x00000001) >> 0)
2450/* Produces a ALT_L3_SEC_USB1_S register field value suitable for setting the register. */
2451#define ALT_L3_SEC_USB1_S_SET(value) (((value) << 0) & 0x00000001)
2452
2453#ifndef __ASSEMBLY__
2454/*
2455 * WARNING: The C register and register group struct declarations are provided for
2456 * convenience and illustrative purposes. They should, however, be used with
2457 * caution as the C language standard provides no guarantees about the alignment or
2458 * atomicity of device memory accesses. The recommended practice for writing
2459 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
2460 * alt_write_word() functions.
2461 *
2462 * The struct declaration for register ALT_L3_SEC_USB1.
2463 */
2465{
2466 uint32_t s : 1; /* USB1 Registers Security */
2467 uint32_t : 31; /* *UNDEFINED* */
2468};
2469
2470/* The typedef declaration for register ALT_L3_SEC_USB1. */
2471typedef volatile struct ALT_L3_SEC_USB1_s ALT_L3_SEC_USB1_t;
2472#endif /* __ASSEMBLY__ */
2473
2474/* The byte offset of the ALT_L3_SEC_USB1 register from the beginning of the component. */
2475#define ALT_L3_SEC_USB1_OFST 0x20
2476
2477/*
2478 * Register : NAND Flash Controller Data Peripheral Security - nanddata
2479 *
2480 * Controls security settings for NAND Flash Controller Data peripheral.
2481 *
2482 * Register Layout
2483 *
2484 * Bits | Access | Reset | Description
2485 * :-------|:-------|:------|:------------------------------------
2486 * [0] | W | 0x0 | NAND Flash Controller Data Security
2487 * [31:1] | ??? | 0x0 | *UNDEFINED*
2488 *
2489 */
2490/*
2491 * Field : NAND Flash Controller Data Security - s
2492 *
2493 * Controls whether secure or non-secure masters can access the NAND Flash
2494 * Controller Data slave.
2495 *
2496 * Field Enumeration Values:
2497 *
2498 * Enum | Value | Description
2499 * :----------------------------------|:------|:----------------------------------------------
2500 * ALT_L3_SEC_NANDDATA_S_E_SECURE | 0x0 | The slave can only be accessed by a secure
2501 * : | | master.
2502 * ALT_L3_SEC_NANDDATA_S_E_NONSECURE | 0x1 | The slave can only be accessed by a secure or
2503 * : | | non-secure masters.
2504 *
2505 * Field Access Macros:
2506 *
2507 */
2508/*
2509 * Enumerated value for register field ALT_L3_SEC_NANDDATA_S
2510 *
2511 * The slave can only be accessed by a secure master.
2512 */
2513#define ALT_L3_SEC_NANDDATA_S_E_SECURE 0x0
2514/*
2515 * Enumerated value for register field ALT_L3_SEC_NANDDATA_S
2516 *
2517 * The slave can only be accessed by a secure or non-secure masters.
2518 */
2519#define ALT_L3_SEC_NANDDATA_S_E_NONSECURE 0x1
2520
2521/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_NANDDATA_S register field. */
2522#define ALT_L3_SEC_NANDDATA_S_LSB 0
2523/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_NANDDATA_S register field. */
2524#define ALT_L3_SEC_NANDDATA_S_MSB 0
2525/* The width in bits of the ALT_L3_SEC_NANDDATA_S register field. */
2526#define ALT_L3_SEC_NANDDATA_S_WIDTH 1
2527/* The mask used to set the ALT_L3_SEC_NANDDATA_S register field value. */
2528#define ALT_L3_SEC_NANDDATA_S_SET_MSK 0x00000001
2529/* The mask used to clear the ALT_L3_SEC_NANDDATA_S register field value. */
2530#define ALT_L3_SEC_NANDDATA_S_CLR_MSK 0xfffffffe
2531/* The reset value of the ALT_L3_SEC_NANDDATA_S register field. */
2532#define ALT_L3_SEC_NANDDATA_S_RESET 0x0
2533/* Extracts the ALT_L3_SEC_NANDDATA_S field value from a register. */
2534#define ALT_L3_SEC_NANDDATA_S_GET(value) (((value) & 0x00000001) >> 0)
2535/* Produces a ALT_L3_SEC_NANDDATA_S register field value suitable for setting the register. */
2536#define ALT_L3_SEC_NANDDATA_S_SET(value) (((value) << 0) & 0x00000001)
2537
2538#ifndef __ASSEMBLY__
2539/*
2540 * WARNING: The C register and register group struct declarations are provided for
2541 * convenience and illustrative purposes. They should, however, be used with
2542 * caution as the C language standard provides no guarantees about the alignment or
2543 * atomicity of device memory accesses. The recommended practice for writing
2544 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
2545 * alt_write_word() functions.
2546 *
2547 * The struct declaration for register ALT_L3_SEC_NANDDATA.
2548 */
2550{
2551 uint32_t s : 1; /* NAND Flash Controller Data Security */
2552 uint32_t : 31; /* *UNDEFINED* */
2553};
2554
2555/* The typedef declaration for register ALT_L3_SEC_NANDDATA. */
2556typedef volatile struct ALT_L3_SEC_NANDDATA_s ALT_L3_SEC_NANDDATA_t;
2557#endif /* __ASSEMBLY__ */
2558
2559/* The byte offset of the ALT_L3_SEC_NANDDATA register from the beginning of the component. */
2560#define ALT_L3_SEC_NANDDATA_OFST 0x24
2561
2562/*
2563 * Register : USB0 Registers Peripheral Security - usb0
2564 *
2565 * Controls security settings for USB0 Registers peripheral.
2566 *
2567 * Register Layout
2568 *
2569 * Bits | Access | Reset | Description
2570 * :-------|:-------|:------|:------------------------
2571 * [0] | W | 0x0 | USB0 Registers Security
2572 * [31:1] | ??? | 0x0 | *UNDEFINED*
2573 *
2574 */
2575/*
2576 * Field : USB0 Registers Security - s
2577 *
2578 * Controls whether secure or non-secure masters can access the USB0 Registers
2579 * slave.
2580 *
2581 * Field Enumeration Values:
2582 *
2583 * Enum | Value | Description
2584 * :------------------------------|:------|:----------------------------------------------
2585 * ALT_L3_SEC_USB0_S_E_SECURE | 0x0 | The slave can only be accessed by a secure
2586 * : | | master.
2587 * ALT_L3_SEC_USB0_S_E_NONSECURE | 0x1 | The slave can only be accessed by a secure or
2588 * : | | non-secure masters.
2589 *
2590 * Field Access Macros:
2591 *
2592 */
2593/*
2594 * Enumerated value for register field ALT_L3_SEC_USB0_S
2595 *
2596 * The slave can only be accessed by a secure master.
2597 */
2598#define ALT_L3_SEC_USB0_S_E_SECURE 0x0
2599/*
2600 * Enumerated value for register field ALT_L3_SEC_USB0_S
2601 *
2602 * The slave can only be accessed by a secure or non-secure masters.
2603 */
2604#define ALT_L3_SEC_USB0_S_E_NONSECURE 0x1
2605
2606/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_USB0_S register field. */
2607#define ALT_L3_SEC_USB0_S_LSB 0
2608/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_USB0_S register field. */
2609#define ALT_L3_SEC_USB0_S_MSB 0
2610/* The width in bits of the ALT_L3_SEC_USB0_S register field. */
2611#define ALT_L3_SEC_USB0_S_WIDTH 1
2612/* The mask used to set the ALT_L3_SEC_USB0_S register field value. */
2613#define ALT_L3_SEC_USB0_S_SET_MSK 0x00000001
2614/* The mask used to clear the ALT_L3_SEC_USB0_S register field value. */
2615#define ALT_L3_SEC_USB0_S_CLR_MSK 0xfffffffe
2616/* The reset value of the ALT_L3_SEC_USB0_S register field. */
2617#define ALT_L3_SEC_USB0_S_RESET 0x0
2618/* Extracts the ALT_L3_SEC_USB0_S field value from a register. */
2619#define ALT_L3_SEC_USB0_S_GET(value) (((value) & 0x00000001) >> 0)
2620/* Produces a ALT_L3_SEC_USB0_S register field value suitable for setting the register. */
2621#define ALT_L3_SEC_USB0_S_SET(value) (((value) << 0) & 0x00000001)
2622
2623#ifndef __ASSEMBLY__
2624/*
2625 * WARNING: The C register and register group struct declarations are provided for
2626 * convenience and illustrative purposes. They should, however, be used with
2627 * caution as the C language standard provides no guarantees about the alignment or
2628 * atomicity of device memory accesses. The recommended practice for writing
2629 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
2630 * alt_write_word() functions.
2631 *
2632 * The struct declaration for register ALT_L3_SEC_USB0.
2633 */
2635{
2636 uint32_t s : 1; /* USB0 Registers Security */
2637 uint32_t : 31; /* *UNDEFINED* */
2638};
2639
2640/* The typedef declaration for register ALT_L3_SEC_USB0. */
2641typedef volatile struct ALT_L3_SEC_USB0_s ALT_L3_SEC_USB0_t;
2642#endif /* __ASSEMBLY__ */
2643
2644/* The byte offset of the ALT_L3_SEC_USB0 register from the beginning of the component. */
2645#define ALT_L3_SEC_USB0_OFST 0x78
2646
2647/*
2648 * Register : NAND Flash Controller Registers Peripheral Security - nandregs
2649 *
2650 * Controls security settings for NAND Flash Controller Registers peripheral.
2651 *
2652 * Register Layout
2653 *
2654 * Bits | Access | Reset | Description
2655 * :-------|:-------|:------|:-----------------------------------------
2656 * [0] | W | 0x0 | NAND Flash Controller Registers Security
2657 * [31:1] | ??? | 0x0 | *UNDEFINED*
2658 *
2659 */
2660/*
2661 * Field : NAND Flash Controller Registers Security - s
2662 *
2663 * Controls whether secure or non-secure masters can access the NAND Flash
2664 * Controller Registers slave.
2665 *
2666 * Field Enumeration Values:
2667 *
2668 * Enum | Value | Description
2669 * :------------------------------|:------|:----------------------------------------------
2670 * ALT_L3_SEC_NAND_S_E_SECURE | 0x0 | The slave can only be accessed by a secure
2671 * : | | master.
2672 * ALT_L3_SEC_NAND_S_E_NONSECURE | 0x1 | The slave can only be accessed by a secure or
2673 * : | | non-secure masters.
2674 *
2675 * Field Access Macros:
2676 *
2677 */
2678/*
2679 * Enumerated value for register field ALT_L3_SEC_NAND_S
2680 *
2681 * The slave can only be accessed by a secure master.
2682 */
2683#define ALT_L3_SEC_NAND_S_E_SECURE 0x0
2684/*
2685 * Enumerated value for register field ALT_L3_SEC_NAND_S
2686 *
2687 * The slave can only be accessed by a secure or non-secure masters.
2688 */
2689#define ALT_L3_SEC_NAND_S_E_NONSECURE 0x1
2690
2691/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_NAND_S register field. */
2692#define ALT_L3_SEC_NAND_S_LSB 0
2693/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_NAND_S register field. */
2694#define ALT_L3_SEC_NAND_S_MSB 0
2695/* The width in bits of the ALT_L3_SEC_NAND_S register field. */
2696#define ALT_L3_SEC_NAND_S_WIDTH 1
2697/* The mask used to set the ALT_L3_SEC_NAND_S register field value. */
2698#define ALT_L3_SEC_NAND_S_SET_MSK 0x00000001
2699/* The mask used to clear the ALT_L3_SEC_NAND_S register field value. */
2700#define ALT_L3_SEC_NAND_S_CLR_MSK 0xfffffffe
2701/* The reset value of the ALT_L3_SEC_NAND_S register field. */
2702#define ALT_L3_SEC_NAND_S_RESET 0x0
2703/* Extracts the ALT_L3_SEC_NAND_S field value from a register. */
2704#define ALT_L3_SEC_NAND_S_GET(value) (((value) & 0x00000001) >> 0)
2705/* Produces a ALT_L3_SEC_NAND_S register field value suitable for setting the register. */
2706#define ALT_L3_SEC_NAND_S_SET(value) (((value) << 0) & 0x00000001)
2707
2708#ifndef __ASSEMBLY__
2709/*
2710 * WARNING: The C register and register group struct declarations are provided for
2711 * convenience and illustrative purposes. They should, however, be used with
2712 * caution as the C language standard provides no guarantees about the alignment or
2713 * atomicity of device memory accesses. The recommended practice for writing
2714 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
2715 * alt_write_word() functions.
2716 *
2717 * The struct declaration for register ALT_L3_SEC_NAND.
2718 */
2720{
2721 uint32_t s : 1; /* NAND Flash Controller Registers Security */
2722 uint32_t : 31; /* *UNDEFINED* */
2723};
2724
2725/* The typedef declaration for register ALT_L3_SEC_NAND. */
2726typedef volatile struct ALT_L3_SEC_NAND_s ALT_L3_SEC_NAND_t;
2727#endif /* __ASSEMBLY__ */
2728
2729/* The byte offset of the ALT_L3_SEC_NAND register from the beginning of the component. */
2730#define ALT_L3_SEC_NAND_OFST 0x7c
2731
2732/*
2733 * Register : QSPI Flash Controller Data Peripheral Security - qspidata
2734 *
2735 * Controls security settings for QSPI Flash Controller Data peripheral.
2736 *
2737 * Register Layout
2738 *
2739 * Bits | Access | Reset | Description
2740 * :-------|:-------|:------|:------------------------------------
2741 * [0] | W | 0x0 | QSPI Flash Controller Data Security
2742 * [31:1] | ??? | 0x0 | *UNDEFINED*
2743 *
2744 */
2745/*
2746 * Field : QSPI Flash Controller Data Security - s
2747 *
2748 * Controls whether secure or non-secure masters can access the QSPI Flash
2749 * Controller Data slave.
2750 *
2751 * Field Enumeration Values:
2752 *
2753 * Enum | Value | Description
2754 * :----------------------------------|:------|:----------------------------------------------
2755 * ALT_L3_SEC_QSPIDATA_S_E_SECURE | 0x0 | The slave can only be accessed by a secure
2756 * : | | master.
2757 * ALT_L3_SEC_QSPIDATA_S_E_NONSECURE | 0x1 | The slave can only be accessed by a secure or
2758 * : | | non-secure masters.
2759 *
2760 * Field Access Macros:
2761 *
2762 */
2763/*
2764 * Enumerated value for register field ALT_L3_SEC_QSPIDATA_S
2765 *
2766 * The slave can only be accessed by a secure master.
2767 */
2768#define ALT_L3_SEC_QSPIDATA_S_E_SECURE 0x0
2769/*
2770 * Enumerated value for register field ALT_L3_SEC_QSPIDATA_S
2771 *
2772 * The slave can only be accessed by a secure or non-secure masters.
2773 */
2774#define ALT_L3_SEC_QSPIDATA_S_E_NONSECURE 0x1
2775
2776/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_QSPIDATA_S register field. */
2777#define ALT_L3_SEC_QSPIDATA_S_LSB 0
2778/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_QSPIDATA_S register field. */
2779#define ALT_L3_SEC_QSPIDATA_S_MSB 0
2780/* The width in bits of the ALT_L3_SEC_QSPIDATA_S register field. */
2781#define ALT_L3_SEC_QSPIDATA_S_WIDTH 1
2782/* The mask used to set the ALT_L3_SEC_QSPIDATA_S register field value. */
2783#define ALT_L3_SEC_QSPIDATA_S_SET_MSK 0x00000001
2784/* The mask used to clear the ALT_L3_SEC_QSPIDATA_S register field value. */
2785#define ALT_L3_SEC_QSPIDATA_S_CLR_MSK 0xfffffffe
2786/* The reset value of the ALT_L3_SEC_QSPIDATA_S register field. */
2787#define ALT_L3_SEC_QSPIDATA_S_RESET 0x0
2788/* Extracts the ALT_L3_SEC_QSPIDATA_S field value from a register. */
2789#define ALT_L3_SEC_QSPIDATA_S_GET(value) (((value) & 0x00000001) >> 0)
2790/* Produces a ALT_L3_SEC_QSPIDATA_S register field value suitable for setting the register. */
2791#define ALT_L3_SEC_QSPIDATA_S_SET(value) (((value) << 0) & 0x00000001)
2792
2793#ifndef __ASSEMBLY__
2794/*
2795 * WARNING: The C register and register group struct declarations are provided for
2796 * convenience and illustrative purposes. They should, however, be used with
2797 * caution as the C language standard provides no guarantees about the alignment or
2798 * atomicity of device memory accesses. The recommended practice for writing
2799 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
2800 * alt_write_word() functions.
2801 *
2802 * The struct declaration for register ALT_L3_SEC_QSPIDATA.
2803 */
2805{
2806 uint32_t s : 1; /* QSPI Flash Controller Data Security */
2807 uint32_t : 31; /* *UNDEFINED* */
2808};
2809
2810/* The typedef declaration for register ALT_L3_SEC_QSPIDATA. */
2811typedef volatile struct ALT_L3_SEC_QSPIDATA_s ALT_L3_SEC_QSPIDATA_t;
2812#endif /* __ASSEMBLY__ */
2813
2814/* The byte offset of the ALT_L3_SEC_QSPIDATA register from the beginning of the component. */
2815#define ALT_L3_SEC_QSPIDATA_OFST 0x80
2816
2817/*
2818 * Register : FPGA Manager Data Peripheral Security - fpgamgrdata
2819 *
2820 * Controls security settings for FPGA Manager Data peripheral.
2821 *
2822 * Register Layout
2823 *
2824 * Bits | Access | Reset | Description
2825 * :-------|:-------|:------|:---------------------------
2826 * [0] | W | 0x0 | FPGA Manager Data Security
2827 * [31:1] | ??? | 0x0 | *UNDEFINED*
2828 *
2829 */
2830/*
2831 * Field : FPGA Manager Data Security - s
2832 *
2833 * Controls whether secure or non-secure masters can access the FPGA Manager Data
2834 * slave.
2835 *
2836 * Field Enumeration Values:
2837 *
2838 * Enum | Value | Description
2839 * :-------------------------------------|:------|:----------------------------------------------
2840 * ALT_L3_SEC_FPGAMGRDATA_S_E_SECURE | 0x0 | The slave can only be accessed by a secure
2841 * : | | master.
2842 * ALT_L3_SEC_FPGAMGRDATA_S_E_NONSECURE | 0x1 | The slave can only be accessed by a secure or
2843 * : | | non-secure masters.
2844 *
2845 * Field Access Macros:
2846 *
2847 */
2848/*
2849 * Enumerated value for register field ALT_L3_SEC_FPGAMGRDATA_S
2850 *
2851 * The slave can only be accessed by a secure master.
2852 */
2853#define ALT_L3_SEC_FPGAMGRDATA_S_E_SECURE 0x0
2854/*
2855 * Enumerated value for register field ALT_L3_SEC_FPGAMGRDATA_S
2856 *
2857 * The slave can only be accessed by a secure or non-secure masters.
2858 */
2859#define ALT_L3_SEC_FPGAMGRDATA_S_E_NONSECURE 0x1
2860
2861/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_FPGAMGRDATA_S register field. */
2862#define ALT_L3_SEC_FPGAMGRDATA_S_LSB 0
2863/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_FPGAMGRDATA_S register field. */
2864#define ALT_L3_SEC_FPGAMGRDATA_S_MSB 0
2865/* The width in bits of the ALT_L3_SEC_FPGAMGRDATA_S register field. */
2866#define ALT_L3_SEC_FPGAMGRDATA_S_WIDTH 1
2867/* The mask used to set the ALT_L3_SEC_FPGAMGRDATA_S register field value. */
2868#define ALT_L3_SEC_FPGAMGRDATA_S_SET_MSK 0x00000001
2869/* The mask used to clear the ALT_L3_SEC_FPGAMGRDATA_S register field value. */
2870#define ALT_L3_SEC_FPGAMGRDATA_S_CLR_MSK 0xfffffffe
2871/* The reset value of the ALT_L3_SEC_FPGAMGRDATA_S register field. */
2872#define ALT_L3_SEC_FPGAMGRDATA_S_RESET 0x0
2873/* Extracts the ALT_L3_SEC_FPGAMGRDATA_S field value from a register. */
2874#define ALT_L3_SEC_FPGAMGRDATA_S_GET(value) (((value) & 0x00000001) >> 0)
2875/* Produces a ALT_L3_SEC_FPGAMGRDATA_S register field value suitable for setting the register. */
2876#define ALT_L3_SEC_FPGAMGRDATA_S_SET(value) (((value) << 0) & 0x00000001)
2877
2878#ifndef __ASSEMBLY__
2879/*
2880 * WARNING: The C register and register group struct declarations are provided for
2881 * convenience and illustrative purposes. They should, however, be used with
2882 * caution as the C language standard provides no guarantees about the alignment or
2883 * atomicity of device memory accesses. The recommended practice for writing
2884 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
2885 * alt_write_word() functions.
2886 *
2887 * The struct declaration for register ALT_L3_SEC_FPGAMGRDATA.
2888 */
2890{
2891 uint32_t s : 1; /* FPGA Manager Data Security */
2892 uint32_t : 31; /* *UNDEFINED* */
2893};
2894
2895/* The typedef declaration for register ALT_L3_SEC_FPGAMGRDATA. */
2897#endif /* __ASSEMBLY__ */
2898
2899/* The byte offset of the ALT_L3_SEC_FPGAMGRDATA register from the beginning of the component. */
2900#define ALT_L3_SEC_FPGAMGRDATA_OFST 0x84
2901
2902/*
2903 * Register : HPS2FPGA AXI Bridge Registers Peripheral Security - hps2fpgaregs
2904 *
2905 * Controls security settings for HPS2FPGA AXI Bridge Registers peripheral.
2906 *
2907 * Register Layout
2908 *
2909 * Bits | Access | Reset | Description
2910 * :-------|:-------|:------|:---------------------------------------
2911 * [0] | W | 0x0 | HPS2FPGA AXI Bridge Registers Security
2912 * [31:1] | ??? | 0x0 | *UNDEFINED*
2913 *
2914 */
2915/*
2916 * Field : HPS2FPGA AXI Bridge Registers Security - s
2917 *
2918 * Controls whether secure or non-secure masters can access the HPS2FPGA AXI Bridge
2919 * Registers slave.
2920 *
2921 * Field Enumeration Values:
2922 *
2923 * Enum | Value | Description
2924 * :-----------------------------|:------|:----------------------------------------------
2925 * ALT_L3_SEC_H2F_S_E_SECURE | 0x0 | The slave can only be accessed by a secure
2926 * : | | master.
2927 * ALT_L3_SEC_H2F_S_E_NONSECURE | 0x1 | The slave can only be accessed by a secure or
2928 * : | | non-secure masters.
2929 *
2930 * Field Access Macros:
2931 *
2932 */
2933/*
2934 * Enumerated value for register field ALT_L3_SEC_H2F_S
2935 *
2936 * The slave can only be accessed by a secure master.
2937 */
2938#define ALT_L3_SEC_H2F_S_E_SECURE 0x0
2939/*
2940 * Enumerated value for register field ALT_L3_SEC_H2F_S
2941 *
2942 * The slave can only be accessed by a secure or non-secure masters.
2943 */
2944#define ALT_L3_SEC_H2F_S_E_NONSECURE 0x1
2945
2946/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_H2F_S register field. */
2947#define ALT_L3_SEC_H2F_S_LSB 0
2948/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_H2F_S register field. */
2949#define ALT_L3_SEC_H2F_S_MSB 0
2950/* The width in bits of the ALT_L3_SEC_H2F_S register field. */
2951#define ALT_L3_SEC_H2F_S_WIDTH 1
2952/* The mask used to set the ALT_L3_SEC_H2F_S register field value. */
2953#define ALT_L3_SEC_H2F_S_SET_MSK 0x00000001
2954/* The mask used to clear the ALT_L3_SEC_H2F_S register field value. */
2955#define ALT_L3_SEC_H2F_S_CLR_MSK 0xfffffffe
2956/* The reset value of the ALT_L3_SEC_H2F_S register field. */
2957#define ALT_L3_SEC_H2F_S_RESET 0x0
2958/* Extracts the ALT_L3_SEC_H2F_S field value from a register. */
2959#define ALT_L3_SEC_H2F_S_GET(value) (((value) & 0x00000001) >> 0)
2960/* Produces a ALT_L3_SEC_H2F_S register field value suitable for setting the register. */
2961#define ALT_L3_SEC_H2F_S_SET(value) (((value) << 0) & 0x00000001)
2962
2963#ifndef __ASSEMBLY__
2964/*
2965 * WARNING: The C register and register group struct declarations are provided for
2966 * convenience and illustrative purposes. They should, however, be used with
2967 * caution as the C language standard provides no guarantees about the alignment or
2968 * atomicity of device memory accesses. The recommended practice for writing
2969 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
2970 * alt_write_word() functions.
2971 *
2972 * The struct declaration for register ALT_L3_SEC_H2F.
2973 */
2975{
2976 uint32_t s : 1; /* HPS2FPGA AXI Bridge Registers Security */
2977 uint32_t : 31; /* *UNDEFINED* */
2978};
2979
2980/* The typedef declaration for register ALT_L3_SEC_H2F. */
2981typedef volatile struct ALT_L3_SEC_H2F_s ALT_L3_SEC_H2F_t;
2982#endif /* __ASSEMBLY__ */
2983
2984/* The byte offset of the ALT_L3_SEC_H2F register from the beginning of the component. */
2985#define ALT_L3_SEC_H2F_OFST 0x88
2986
2987/*
2988 * Register : MPU ACP Peripheral Security - acp
2989 *
2990 * Controls security settings for MPU ACP peripheral.
2991 *
2992 * Register Layout
2993 *
2994 * Bits | Access | Reset | Description
2995 * :-------|:-------|:------|:-----------------
2996 * [0] | W | 0x0 | MPU ACP Security
2997 * [31:1] | ??? | 0x0 | *UNDEFINED*
2998 *
2999 */
3000/*
3001 * Field : MPU ACP Security - s
3002 *
3003 * Controls whether secure or non-secure masters can access the MPU ACP slave.
3004 *
3005 * Field Enumeration Values:
3006 *
3007 * Enum | Value | Description
3008 * :-----------------------------|:------|:----------------------------------------------
3009 * ALT_L3_SEC_ACP_S_E_SECURE | 0x0 | The slave can only be accessed by a secure
3010 * : | | master.
3011 * ALT_L3_SEC_ACP_S_E_NONSECURE | 0x1 | The slave can only be accessed by a secure or
3012 * : | | non-secure masters.
3013 *
3014 * Field Access Macros:
3015 *
3016 */
3017/*
3018 * Enumerated value for register field ALT_L3_SEC_ACP_S
3019 *
3020 * The slave can only be accessed by a secure master.
3021 */
3022#define ALT_L3_SEC_ACP_S_E_SECURE 0x0
3023/*
3024 * Enumerated value for register field ALT_L3_SEC_ACP_S
3025 *
3026 * The slave can only be accessed by a secure or non-secure masters.
3027 */
3028#define ALT_L3_SEC_ACP_S_E_NONSECURE 0x1
3029
3030/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_ACP_S register field. */
3031#define ALT_L3_SEC_ACP_S_LSB 0
3032/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_ACP_S register field. */
3033#define ALT_L3_SEC_ACP_S_MSB 0
3034/* The width in bits of the ALT_L3_SEC_ACP_S register field. */
3035#define ALT_L3_SEC_ACP_S_WIDTH 1
3036/* The mask used to set the ALT_L3_SEC_ACP_S register field value. */
3037#define ALT_L3_SEC_ACP_S_SET_MSK 0x00000001
3038/* The mask used to clear the ALT_L3_SEC_ACP_S register field value. */
3039#define ALT_L3_SEC_ACP_S_CLR_MSK 0xfffffffe
3040/* The reset value of the ALT_L3_SEC_ACP_S register field. */
3041#define ALT_L3_SEC_ACP_S_RESET 0x0
3042/* Extracts the ALT_L3_SEC_ACP_S field value from a register. */
3043#define ALT_L3_SEC_ACP_S_GET(value) (((value) & 0x00000001) >> 0)
3044/* Produces a ALT_L3_SEC_ACP_S register field value suitable for setting the register. */
3045#define ALT_L3_SEC_ACP_S_SET(value) (((value) << 0) & 0x00000001)
3046
3047#ifndef __ASSEMBLY__
3048/*
3049 * WARNING: The C register and register group struct declarations are provided for
3050 * convenience and illustrative purposes. They should, however, be used with
3051 * caution as the C language standard provides no guarantees about the alignment or
3052 * atomicity of device memory accesses. The recommended practice for writing
3053 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
3054 * alt_write_word() functions.
3055 *
3056 * The struct declaration for register ALT_L3_SEC_ACP.
3057 */
3059{
3060 uint32_t s : 1; /* MPU ACP Security */
3061 uint32_t : 31; /* *UNDEFINED* */
3062};
3063
3064/* The typedef declaration for register ALT_L3_SEC_ACP. */
3065typedef volatile struct ALT_L3_SEC_ACP_s ALT_L3_SEC_ACP_t;
3066#endif /* __ASSEMBLY__ */
3067
3068/* The byte offset of the ALT_L3_SEC_ACP register from the beginning of the component. */
3069#define ALT_L3_SEC_ACP_OFST 0x8c
3070
3071/*
3072 * Register : ROM Peripheral Security - rom
3073 *
3074 * Controls security settings for ROM peripheral.
3075 *
3076 * Register Layout
3077 *
3078 * Bits | Access | Reset | Description
3079 * :-------|:-------|:------|:-------------
3080 * [0] | W | 0x0 | ROM Security
3081 * [31:1] | ??? | 0x0 | *UNDEFINED*
3082 *
3083 */
3084/*
3085 * Field : ROM Security - s
3086 *
3087 * Controls whether secure or non-secure masters can access the ROM slave.
3088 *
3089 * Field Enumeration Values:
3090 *
3091 * Enum | Value | Description
3092 * :-----------------------------|:------|:----------------------------------------------
3093 * ALT_L3_SEC_ROM_S_E_SECURE | 0x0 | The slave can only be accessed by a secure
3094 * : | | master.
3095 * ALT_L3_SEC_ROM_S_E_NONSECURE | 0x1 | The slave can only be accessed by a secure or
3096 * : | | non-secure masters.
3097 *
3098 * Field Access Macros:
3099 *
3100 */
3101/*
3102 * Enumerated value for register field ALT_L3_SEC_ROM_S
3103 *
3104 * The slave can only be accessed by a secure master.
3105 */
3106#define ALT_L3_SEC_ROM_S_E_SECURE 0x0
3107/*
3108 * Enumerated value for register field ALT_L3_SEC_ROM_S
3109 *
3110 * The slave can only be accessed by a secure or non-secure masters.
3111 */
3112#define ALT_L3_SEC_ROM_S_E_NONSECURE 0x1
3113
3114/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_ROM_S register field. */
3115#define ALT_L3_SEC_ROM_S_LSB 0
3116/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_ROM_S register field. */
3117#define ALT_L3_SEC_ROM_S_MSB 0
3118/* The width in bits of the ALT_L3_SEC_ROM_S register field. */
3119#define ALT_L3_SEC_ROM_S_WIDTH 1
3120/* The mask used to set the ALT_L3_SEC_ROM_S register field value. */
3121#define ALT_L3_SEC_ROM_S_SET_MSK 0x00000001
3122/* The mask used to clear the ALT_L3_SEC_ROM_S register field value. */
3123#define ALT_L3_SEC_ROM_S_CLR_MSK 0xfffffffe
3124/* The reset value of the ALT_L3_SEC_ROM_S register field. */
3125#define ALT_L3_SEC_ROM_S_RESET 0x0
3126/* Extracts the ALT_L3_SEC_ROM_S field value from a register. */
3127#define ALT_L3_SEC_ROM_S_GET(value) (((value) & 0x00000001) >> 0)
3128/* Produces a ALT_L3_SEC_ROM_S register field value suitable for setting the register. */
3129#define ALT_L3_SEC_ROM_S_SET(value) (((value) << 0) & 0x00000001)
3130
3131#ifndef __ASSEMBLY__
3132/*
3133 * WARNING: The C register and register group struct declarations are provided for
3134 * convenience and illustrative purposes. They should, however, be used with
3135 * caution as the C language standard provides no guarantees about the alignment or
3136 * atomicity of device memory accesses. The recommended practice for writing
3137 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
3138 * alt_write_word() functions.
3139 *
3140 * The struct declaration for register ALT_L3_SEC_ROM.
3141 */
3143{
3144 uint32_t s : 1; /* ROM Security */
3145 uint32_t : 31; /* *UNDEFINED* */
3146};
3147
3148/* The typedef declaration for register ALT_L3_SEC_ROM. */
3149typedef volatile struct ALT_L3_SEC_ROM_s ALT_L3_SEC_ROM_t;
3150#endif /* __ASSEMBLY__ */
3151
3152/* The byte offset of the ALT_L3_SEC_ROM register from the beginning of the component. */
3153#define ALT_L3_SEC_ROM_OFST 0x90
3154
3155/*
3156 * Register : On-chip RAM Peripheral Security - ocram
3157 *
3158 * Controls security settings for On-chip RAM peripheral.
3159 *
3160 * Register Layout
3161 *
3162 * Bits | Access | Reset | Description
3163 * :-------|:-------|:------|:---------------------
3164 * [0] | W | 0x0 | On-chip RAM Security
3165 * [31:1] | ??? | 0x0 | *UNDEFINED*
3166 *
3167 */
3168/*
3169 * Field : On-chip RAM Security - s
3170 *
3171 * Controls whether secure or non-secure masters can access the On-chip RAM slave.
3172 *
3173 * Field Enumeration Values:
3174 *
3175 * Enum | Value | Description
3176 * :-------------------------------|:------|:----------------------------------------------
3177 * ALT_L3_SEC_OCRAM_S_E_SECURE | 0x0 | The slave can only be accessed by a secure
3178 * : | | master.
3179 * ALT_L3_SEC_OCRAM_S_E_NONSECURE | 0x1 | The slave can only be accessed by a secure or
3180 * : | | non-secure masters.
3181 *
3182 * Field Access Macros:
3183 *
3184 */
3185/*
3186 * Enumerated value for register field ALT_L3_SEC_OCRAM_S
3187 *
3188 * The slave can only be accessed by a secure master.
3189 */
3190#define ALT_L3_SEC_OCRAM_S_E_SECURE 0x0
3191/*
3192 * Enumerated value for register field ALT_L3_SEC_OCRAM_S
3193 *
3194 * The slave can only be accessed by a secure or non-secure masters.
3195 */
3196#define ALT_L3_SEC_OCRAM_S_E_NONSECURE 0x1
3197
3198/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_OCRAM_S register field. */
3199#define ALT_L3_SEC_OCRAM_S_LSB 0
3200/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_OCRAM_S register field. */
3201#define ALT_L3_SEC_OCRAM_S_MSB 0
3202/* The width in bits of the ALT_L3_SEC_OCRAM_S register field. */
3203#define ALT_L3_SEC_OCRAM_S_WIDTH 1
3204/* The mask used to set the ALT_L3_SEC_OCRAM_S register field value. */
3205#define ALT_L3_SEC_OCRAM_S_SET_MSK 0x00000001
3206/* The mask used to clear the ALT_L3_SEC_OCRAM_S register field value. */
3207#define ALT_L3_SEC_OCRAM_S_CLR_MSK 0xfffffffe
3208/* The reset value of the ALT_L3_SEC_OCRAM_S register field. */
3209#define ALT_L3_SEC_OCRAM_S_RESET 0x0
3210/* Extracts the ALT_L3_SEC_OCRAM_S field value from a register. */
3211#define ALT_L3_SEC_OCRAM_S_GET(value) (((value) & 0x00000001) >> 0)
3212/* Produces a ALT_L3_SEC_OCRAM_S register field value suitable for setting the register. */
3213#define ALT_L3_SEC_OCRAM_S_SET(value) (((value) << 0) & 0x00000001)
3214
3215#ifndef __ASSEMBLY__
3216/*
3217 * WARNING: The C register and register group struct declarations are provided for
3218 * convenience and illustrative purposes. They should, however, be used with
3219 * caution as the C language standard provides no guarantees about the alignment or
3220 * atomicity of device memory accesses. The recommended practice for writing
3221 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
3222 * alt_write_word() functions.
3223 *
3224 * The struct declaration for register ALT_L3_SEC_OCRAM.
3225 */
3227{
3228 uint32_t s : 1; /* On-chip RAM Security */
3229 uint32_t : 31; /* *UNDEFINED* */
3230};
3231
3232/* The typedef declaration for register ALT_L3_SEC_OCRAM. */
3233typedef volatile struct ALT_L3_SEC_OCRAM_s ALT_L3_SEC_OCRAM_t;
3234#endif /* __ASSEMBLY__ */
3235
3236/* The byte offset of the ALT_L3_SEC_OCRAM register from the beginning of the component. */
3237#define ALT_L3_SEC_OCRAM_OFST 0x94
3238
3239/*
3240 * Register : SDRAM Data Peripheral Security - sdrdata
3241 *
3242 * Controls security settings for SDRAM Data peripheral.
3243 *
3244 * Register Layout
3245 *
3246 * Bits | Access | Reset | Description
3247 * :-------|:-------|:------|:--------------------
3248 * [0] | W | 0x0 | SDRAM Data Security
3249 * [31:1] | ??? | 0x0 | *UNDEFINED*
3250 *
3251 */
3252/*
3253 * Field : SDRAM Data Security - s
3254 *
3255 * Controls whether secure or non-secure masters can access the SDRAM Data slave.
3256 *
3257 * Field Enumeration Values:
3258 *
3259 * Enum | Value | Description
3260 * :---------------------------------|:------|:----------------------------------------------
3261 * ALT_L3_SEC_SDRDATA_S_E_SECURE | 0x0 | The slave can only be accessed by a secure
3262 * : | | master.
3263 * ALT_L3_SEC_SDRDATA_S_E_NONSECURE | 0x1 | The slave can only be accessed by a secure or
3264 * : | | non-secure masters.
3265 *
3266 * Field Access Macros:
3267 *
3268 */
3269/*
3270 * Enumerated value for register field ALT_L3_SEC_SDRDATA_S
3271 *
3272 * The slave can only be accessed by a secure master.
3273 */
3274#define ALT_L3_SEC_SDRDATA_S_E_SECURE 0x0
3275/*
3276 * Enumerated value for register field ALT_L3_SEC_SDRDATA_S
3277 *
3278 * The slave can only be accessed by a secure or non-secure masters.
3279 */
3280#define ALT_L3_SEC_SDRDATA_S_E_NONSECURE 0x1
3281
3282/* The Least Significant Bit (LSB) position of the ALT_L3_SEC_SDRDATA_S register field. */
3283#define ALT_L3_SEC_SDRDATA_S_LSB 0
3284/* The Most Significant Bit (MSB) position of the ALT_L3_SEC_SDRDATA_S register field. */
3285#define ALT_L3_SEC_SDRDATA_S_MSB 0
3286/* The width in bits of the ALT_L3_SEC_SDRDATA_S register field. */
3287#define ALT_L3_SEC_SDRDATA_S_WIDTH 1
3288/* The mask used to set the ALT_L3_SEC_SDRDATA_S register field value. */
3289#define ALT_L3_SEC_SDRDATA_S_SET_MSK 0x00000001
3290/* The mask used to clear the ALT_L3_SEC_SDRDATA_S register field value. */
3291#define ALT_L3_SEC_SDRDATA_S_CLR_MSK 0xfffffffe
3292/* The reset value of the ALT_L3_SEC_SDRDATA_S register field. */
3293#define ALT_L3_SEC_SDRDATA_S_RESET 0x0
3294/* Extracts the ALT_L3_SEC_SDRDATA_S field value from a register. */
3295#define ALT_L3_SEC_SDRDATA_S_GET(value) (((value) & 0x00000001) >> 0)
3296/* Produces a ALT_L3_SEC_SDRDATA_S register field value suitable for setting the register. */
3297#define ALT_L3_SEC_SDRDATA_S_SET(value) (((value) << 0) & 0x00000001)
3298
3299#ifndef __ASSEMBLY__
3300/*
3301 * WARNING: The C register and register group struct declarations are provided for
3302 * convenience and illustrative purposes. They should, however, be used with
3303 * caution as the C language standard provides no guarantees about the alignment or
3304 * atomicity of device memory accesses. The recommended practice for writing
3305 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
3306 * alt_write_word() functions.
3307 *
3308 * The struct declaration for register ALT_L3_SEC_SDRDATA.
3309 */
3311{
3312 uint32_t s : 1; /* SDRAM Data Security */
3313 uint32_t : 31; /* *UNDEFINED* */
3314};
3315
3316/* The typedef declaration for register ALT_L3_SEC_SDRDATA. */
3317typedef volatile struct ALT_L3_SEC_SDRDATA_s ALT_L3_SEC_SDRDATA_t;
3318#endif /* __ASSEMBLY__ */
3319
3320/* The byte offset of the ALT_L3_SEC_SDRDATA register from the beginning of the component. */
3321#define ALT_L3_SEC_SDRDATA_OFST 0x98
3322
3323#ifndef __ASSEMBLY__
3324/*
3325 * WARNING: The C register and register group struct declarations are provided for
3326 * convenience and illustrative purposes. They should, however, be used with
3327 * caution as the C language standard provides no guarantees about the alignment or
3328 * atomicity of device memory accesses. The recommended practice for writing
3329 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
3330 * alt_write_word() functions.
3331 *
3332 * The struct declaration for register group ALT_L3_SECGRP.
3333 */
3335{
3336 volatile ALT_L3_SEC_L4MAIN_t l4main; /* ALT_L3_SEC_L4MAIN */
3337 volatile ALT_L3_SEC_L4SP_t l4sp; /* ALT_L3_SEC_L4SP */
3338 volatile ALT_L3_SEC_L4MP_t l4mp; /* ALT_L3_SEC_L4MP */
3339 volatile ALT_L3_SEC_L4OSC1_t l4osc1; /* ALT_L3_SEC_L4OSC1 */
3340 volatile ALT_L3_SEC_L4SPIM_t l4spim; /* ALT_L3_SEC_L4SPIM */
3341 volatile ALT_L3_SEC_STM_t stm; /* ALT_L3_SEC_STM */
3342 volatile ALT_L3_SEC_LWH2F_t lwhps2fpgaregs; /* ALT_L3_SEC_LWH2F */
3343 volatile uint32_t _pad_0x1c_0x1f; /* *UNDEFINED* */
3344 volatile ALT_L3_SEC_USB1_t usb1; /* ALT_L3_SEC_USB1 */
3345 volatile ALT_L3_SEC_NANDDATA_t nanddata; /* ALT_L3_SEC_NANDDATA */
3346 volatile uint32_t _pad_0x28_0x77[20]; /* *UNDEFINED* */
3347 volatile ALT_L3_SEC_USB0_t usb0; /* ALT_L3_SEC_USB0 */
3348 volatile ALT_L3_SEC_NAND_t nandregs; /* ALT_L3_SEC_NAND */
3349 volatile ALT_L3_SEC_QSPIDATA_t qspidata; /* ALT_L3_SEC_QSPIDATA */
3350 volatile ALT_L3_SEC_FPGAMGRDATA_t fpgamgrdata; /* ALT_L3_SEC_FPGAMGRDATA */
3351 volatile ALT_L3_SEC_H2F_t hps2fpgaregs; /* ALT_L3_SEC_H2F */
3352 volatile ALT_L3_SEC_ACP_t acp; /* ALT_L3_SEC_ACP */
3353 volatile ALT_L3_SEC_ROM_t rom; /* ALT_L3_SEC_ROM */
3354 volatile ALT_L3_SEC_OCRAM_t ocram; /* ALT_L3_SEC_OCRAM */
3355 volatile ALT_L3_SEC_SDRDATA_t sdrdata; /* ALT_L3_SEC_SDRDATA */
3356};
3357
3358/* The typedef declaration for register group ALT_L3_SECGRP. */
3359typedef volatile struct ALT_L3_SECGRP_s ALT_L3_SECGRP_t;
3360/* The struct declaration for the raw register contents of register group ALT_L3_SECGRP. */
3362{
3363 volatile uint32_t l4main; /* ALT_L3_SEC_L4MAIN */
3364 volatile uint32_t l4sp; /* ALT_L3_SEC_L4SP */
3365 volatile uint32_t l4mp; /* ALT_L3_SEC_L4MP */
3366 volatile uint32_t l4osc1; /* ALT_L3_SEC_L4OSC1 */
3367 volatile uint32_t l4spim; /* ALT_L3_SEC_L4SPIM */
3368 volatile uint32_t stm; /* ALT_L3_SEC_STM */
3369 volatile uint32_t lwhps2fpgaregs; /* ALT_L3_SEC_LWH2F */
3370 volatile uint32_t _pad_0x1c_0x1f; /* *UNDEFINED* */
3371 volatile uint32_t usb1; /* ALT_L3_SEC_USB1 */
3372 volatile uint32_t nanddata; /* ALT_L3_SEC_NANDDATA */
3373 volatile uint32_t _pad_0x28_0x77[20]; /* *UNDEFINED* */
3374 volatile uint32_t usb0; /* ALT_L3_SEC_USB0 */
3375 volatile uint32_t nandregs; /* ALT_L3_SEC_NAND */
3376 volatile uint32_t qspidata; /* ALT_L3_SEC_QSPIDATA */
3377 volatile uint32_t fpgamgrdata; /* ALT_L3_SEC_FPGAMGRDATA */
3378 volatile uint32_t hps2fpgaregs; /* ALT_L3_SEC_H2F */
3379 volatile uint32_t acp; /* ALT_L3_SEC_ACP */
3380 volatile uint32_t rom; /* ALT_L3_SEC_ROM */
3381 volatile uint32_t ocram; /* ALT_L3_SEC_OCRAM */
3382 volatile uint32_t sdrdata; /* ALT_L3_SEC_SDRDATA */
3383};
3384
3385/* The typedef declaration for the raw register contents of register group ALT_L3_SECGRP. */
3386typedef volatile struct ALT_L3_SECGRP_raw_s ALT_L3_SECGRP_raw_t;
3387#endif /* __ASSEMBLY__ */
3388
3389
3390/*
3391 * Register Group : ID Register Group - ALT_L3_IDGRP
3392 * ID Register Group
3393 *
3394 * Contains registers that identify the ARM NIC-301 IP Core.
3395 *
3396 */
3397/*
3398 * Register : Peripheral ID4 Register - periph_id_4
3399 *
3400 * JEP106 continuation code
3401 *
3402 * Register Layout
3403 *
3404 * Bits | Access | Reset | Description
3405 * :-------|:-------|:------|:---------------
3406 * [7:0] | R | 0x4 | Peripheral ID4
3407 * [31:8] | ??? | 0x0 | *UNDEFINED*
3408 *
3409 */
3410/*
3411 * Field : Peripheral ID4 - periph_id_4
3412 *
3413 * JEP106 continuation code
3414 *
3415 * Field Access Macros:
3416 *
3417 */
3418/* The Least Significant Bit (LSB) position of the ALT_L3_ID_PERIPH_ID_4_PERIPH_ID_4 register field. */
3419#define ALT_L3_ID_PERIPH_ID_4_PERIPH_ID_4_LSB 0
3420/* The Most Significant Bit (MSB) position of the ALT_L3_ID_PERIPH_ID_4_PERIPH_ID_4 register field. */
3421#define ALT_L3_ID_PERIPH_ID_4_PERIPH_ID_4_MSB 7
3422/* The width in bits of the ALT_L3_ID_PERIPH_ID_4_PERIPH_ID_4 register field. */
3423#define ALT_L3_ID_PERIPH_ID_4_PERIPH_ID_4_WIDTH 8
3424/* The mask used to set the ALT_L3_ID_PERIPH_ID_4_PERIPH_ID_4 register field value. */
3425#define ALT_L3_ID_PERIPH_ID_4_PERIPH_ID_4_SET_MSK 0x000000ff
3426/* The mask used to clear the ALT_L3_ID_PERIPH_ID_4_PERIPH_ID_4 register field value. */
3427#define ALT_L3_ID_PERIPH_ID_4_PERIPH_ID_4_CLR_MSK 0xffffff00
3428/* The reset value of the ALT_L3_ID_PERIPH_ID_4_PERIPH_ID_4 register field. */
3429#define ALT_L3_ID_PERIPH_ID_4_PERIPH_ID_4_RESET 0x4
3430/* Extracts the ALT_L3_ID_PERIPH_ID_4_PERIPH_ID_4 field value from a register. */
3431#define ALT_L3_ID_PERIPH_ID_4_PERIPH_ID_4_GET(value) (((value) & 0x000000ff) >> 0)
3432/* Produces a ALT_L3_ID_PERIPH_ID_4_PERIPH_ID_4 register field value suitable for setting the register. */
3433#define ALT_L3_ID_PERIPH_ID_4_PERIPH_ID_4_SET(value) (((value) << 0) & 0x000000ff)
3434
3435#ifndef __ASSEMBLY__
3436/*
3437 * WARNING: The C register and register group struct declarations are provided for
3438 * convenience and illustrative purposes. They should, however, be used with
3439 * caution as the C language standard provides no guarantees about the alignment or
3440 * atomicity of device memory accesses. The recommended practice for writing
3441 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
3442 * alt_write_word() functions.
3443 *
3444 * The struct declaration for register ALT_L3_ID_PERIPH_ID_4.
3445 */
3447{
3448 const uint32_t periph_id_4 : 8; /* Peripheral ID4 */
3449 uint32_t : 24; /* *UNDEFINED* */
3450};
3451
3452/* The typedef declaration for register ALT_L3_ID_PERIPH_ID_4. */
3453typedef volatile struct ALT_L3_ID_PERIPH_ID_4_s ALT_L3_ID_PERIPH_ID_4_t;
3454#endif /* __ASSEMBLY__ */
3455
3456/* The byte offset of the ALT_L3_ID_PERIPH_ID_4 register from the beginning of the component. */
3457#define ALT_L3_ID_PERIPH_ID_4_OFST 0xfd0
3458
3459/*
3460 * Register : Peripheral ID0 Register - periph_id_0
3461 *
3462 * Peripheral ID0
3463 *
3464 * Register Layout
3465 *
3466 * Bits | Access | Reset | Description
3467 * :-------|:-------|:------|:------------------
3468 * [7:0] | R | 0x1 | Part Number [7:0]
3469 * [31:8] | ??? | 0x0 | *UNDEFINED*
3470 *
3471 */
3472/*
3473 * Field : Part Number [7:0] - pn7to0
3474 *
3475 * Part Number [7:0]
3476 *
3477 * Field Access Macros:
3478 *
3479 */
3480/* The Least Significant Bit (LSB) position of the ALT_L3_ID_PERIPH_ID_0_PN7TO0 register field. */
3481#define ALT_L3_ID_PERIPH_ID_0_PN7TO0_LSB 0
3482/* The Most Significant Bit (MSB) position of the ALT_L3_ID_PERIPH_ID_0_PN7TO0 register field. */
3483#define ALT_L3_ID_PERIPH_ID_0_PN7TO0_MSB 7
3484/* The width in bits of the ALT_L3_ID_PERIPH_ID_0_PN7TO0 register field. */
3485#define ALT_L3_ID_PERIPH_ID_0_PN7TO0_WIDTH 8
3486/* The mask used to set the ALT_L3_ID_PERIPH_ID_0_PN7TO0 register field value. */
3487#define ALT_L3_ID_PERIPH_ID_0_PN7TO0_SET_MSK 0x000000ff
3488/* The mask used to clear the ALT_L3_ID_PERIPH_ID_0_PN7TO0 register field value. */
3489#define ALT_L3_ID_PERIPH_ID_0_PN7TO0_CLR_MSK 0xffffff00
3490/* The reset value of the ALT_L3_ID_PERIPH_ID_0_PN7TO0 register field. */
3491#define ALT_L3_ID_PERIPH_ID_0_PN7TO0_RESET 0x1
3492/* Extracts the ALT_L3_ID_PERIPH_ID_0_PN7TO0 field value from a register. */
3493#define ALT_L3_ID_PERIPH_ID_0_PN7TO0_GET(value) (((value) & 0x000000ff) >> 0)
3494/* Produces a ALT_L3_ID_PERIPH_ID_0_PN7TO0 register field value suitable for setting the register. */
3495#define ALT_L3_ID_PERIPH_ID_0_PN7TO0_SET(value) (((value) << 0) & 0x000000ff)
3496
3497#ifndef __ASSEMBLY__
3498/*
3499 * WARNING: The C register and register group struct declarations are provided for
3500 * convenience and illustrative purposes. They should, however, be used with
3501 * caution as the C language standard provides no guarantees about the alignment or
3502 * atomicity of device memory accesses. The recommended practice for writing
3503 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
3504 * alt_write_word() functions.
3505 *
3506 * The struct declaration for register ALT_L3_ID_PERIPH_ID_0.
3507 */
3509{
3510 const uint32_t pn7to0 : 8; /* Part Number [7:0] */
3511 uint32_t : 24; /* *UNDEFINED* */
3512};
3513
3514/* The typedef declaration for register ALT_L3_ID_PERIPH_ID_0. */
3515typedef volatile struct ALT_L3_ID_PERIPH_ID_0_s ALT_L3_ID_PERIPH_ID_0_t;
3516#endif /* __ASSEMBLY__ */
3517
3518/* The byte offset of the ALT_L3_ID_PERIPH_ID_0 register from the beginning of the component. */
3519#define ALT_L3_ID_PERIPH_ID_0_OFST 0xfe0
3520
3521/*
3522 * Register : Peripheral ID1 Register - periph_id_1
3523 *
3524 * Peripheral ID1
3525 *
3526 * Register Layout
3527 *
3528 * Bits | Access | Reset | Description
3529 * :-------|:-------|:------|:--------------------------------
3530 * [7:0] | R | 0xb3 | JEP106[3:0], Part Number [11:8]
3531 * [31:8] | ??? | 0x0 | *UNDEFINED*
3532 *
3533 */
3534/*
3535 * Field : JEP106[3:0], Part Number [11:8] - jep3to0_pn11to8
3536 *
3537 * JEP106[3:0], Part Number [11:8]
3538 *
3539 * Field Access Macros:
3540 *
3541 */
3542/* The Least Significant Bit (LSB) position of the ALT_L3_ID_PERIPH_ID_1_JEP3TO0_PN11TO8 register field. */
3543#define ALT_L3_ID_PERIPH_ID_1_JEP3TO0_PN11TO8_LSB 0
3544/* The Most Significant Bit (MSB) position of the ALT_L3_ID_PERIPH_ID_1_JEP3TO0_PN11TO8 register field. */
3545#define ALT_L3_ID_PERIPH_ID_1_JEP3TO0_PN11TO8_MSB 7
3546/* The width in bits of the ALT_L3_ID_PERIPH_ID_1_JEP3TO0_PN11TO8 register field. */
3547#define ALT_L3_ID_PERIPH_ID_1_JEP3TO0_PN11TO8_WIDTH 8
3548/* The mask used to set the ALT_L3_ID_PERIPH_ID_1_JEP3TO0_PN11TO8 register field value. */
3549#define ALT_L3_ID_PERIPH_ID_1_JEP3TO0_PN11TO8_SET_MSK 0x000000ff
3550/* The mask used to clear the ALT_L3_ID_PERIPH_ID_1_JEP3TO0_PN11TO8 register field value. */
3551#define ALT_L3_ID_PERIPH_ID_1_JEP3TO0_PN11TO8_CLR_MSK 0xffffff00
3552/* The reset value of the ALT_L3_ID_PERIPH_ID_1_JEP3TO0_PN11TO8 register field. */
3553#define ALT_L3_ID_PERIPH_ID_1_JEP3TO0_PN11TO8_RESET 0xb3
3554/* Extracts the ALT_L3_ID_PERIPH_ID_1_JEP3TO0_PN11TO8 field value from a register. */
3555#define ALT_L3_ID_PERIPH_ID_1_JEP3TO0_PN11TO8_GET(value) (((value) & 0x000000ff) >> 0)
3556/* Produces a ALT_L3_ID_PERIPH_ID_1_JEP3TO0_PN11TO8 register field value suitable for setting the register. */
3557#define ALT_L3_ID_PERIPH_ID_1_JEP3TO0_PN11TO8_SET(value) (((value) << 0) & 0x000000ff)
3558
3559#ifndef __ASSEMBLY__
3560/*
3561 * WARNING: The C register and register group struct declarations are provided for
3562 * convenience and illustrative purposes. They should, however, be used with
3563 * caution as the C language standard provides no guarantees about the alignment or
3564 * atomicity of device memory accesses. The recommended practice for writing
3565 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
3566 * alt_write_word() functions.
3567 *
3568 * The struct declaration for register ALT_L3_ID_PERIPH_ID_1.
3569 */
3571{
3572 const uint32_t jep3to0_pn11to8 : 8; /* JEP106[3:0], Part Number [11:8] */
3573 uint32_t : 24; /* *UNDEFINED* */
3574};
3575
3576/* The typedef declaration for register ALT_L3_ID_PERIPH_ID_1. */
3577typedef volatile struct ALT_L3_ID_PERIPH_ID_1_s ALT_L3_ID_PERIPH_ID_1_t;
3578#endif /* __ASSEMBLY__ */
3579
3580/* The byte offset of the ALT_L3_ID_PERIPH_ID_1 register from the beginning of the component. */
3581#define ALT_L3_ID_PERIPH_ID_1_OFST 0xfe4
3582
3583/*
3584 * Register : Peripheral ID2 Register - periph_id_2
3585 *
3586 * Peripheral ID2
3587 *
3588 * Register Layout
3589 *
3590 * Bits | Access | Reset | Description
3591 * :-------|:-------|:------|:----------------------------------------
3592 * [7:0] | R | 0x6b | Revision, JEP106 code flag, JEP106[6:4]
3593 * [31:8] | ??? | 0x0 | *UNDEFINED*
3594 *
3595 */
3596/*
3597 * Field : Revision, JEP106 code flag, JEP106[6:4] - rev_jepcode_jep6to4
3598 *
3599 * Revision, JEP106 code flag, JEP106[6:4]
3600 *
3601 * Field Access Macros:
3602 *
3603 */
3604/* The Least Significant Bit (LSB) position of the ALT_L3_ID_PERIPH_ID_2_REV_JEPCODE_JEP6TO4 register field. */
3605#define ALT_L3_ID_PERIPH_ID_2_REV_JEPCODE_JEP6TO4_LSB 0
3606/* The Most Significant Bit (MSB) position of the ALT_L3_ID_PERIPH_ID_2_REV_JEPCODE_JEP6TO4 register field. */
3607#define ALT_L3_ID_PERIPH_ID_2_REV_JEPCODE_JEP6TO4_MSB 7
3608/* The width in bits of the ALT_L3_ID_PERIPH_ID_2_REV_JEPCODE_JEP6TO4 register field. */
3609#define ALT_L3_ID_PERIPH_ID_2_REV_JEPCODE_JEP6TO4_WIDTH 8
3610/* The mask used to set the ALT_L3_ID_PERIPH_ID_2_REV_JEPCODE_JEP6TO4 register field value. */
3611#define ALT_L3_ID_PERIPH_ID_2_REV_JEPCODE_JEP6TO4_SET_MSK 0x000000ff
3612/* The mask used to clear the ALT_L3_ID_PERIPH_ID_2_REV_JEPCODE_JEP6TO4 register field value. */
3613#define ALT_L3_ID_PERIPH_ID_2_REV_JEPCODE_JEP6TO4_CLR_MSK 0xffffff00
3614/* The reset value of the ALT_L3_ID_PERIPH_ID_2_REV_JEPCODE_JEP6TO4 register field. */
3615#define ALT_L3_ID_PERIPH_ID_2_REV_JEPCODE_JEP6TO4_RESET 0x6b
3616/* Extracts the ALT_L3_ID_PERIPH_ID_2_REV_JEPCODE_JEP6TO4 field value from a register. */
3617#define ALT_L3_ID_PERIPH_ID_2_REV_JEPCODE_JEP6TO4_GET(value) (((value) & 0x000000ff) >> 0)
3618/* Produces a ALT_L3_ID_PERIPH_ID_2_REV_JEPCODE_JEP6TO4 register field value suitable for setting the register. */
3619#define ALT_L3_ID_PERIPH_ID_2_REV_JEPCODE_JEP6TO4_SET(value) (((value) << 0) & 0x000000ff)
3620
3621#ifndef __ASSEMBLY__
3622/*
3623 * WARNING: The C register and register group struct declarations are provided for
3624 * convenience and illustrative purposes. They should, however, be used with
3625 * caution as the C language standard provides no guarantees about the alignment or
3626 * atomicity of device memory accesses. The recommended practice for writing
3627 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
3628 * alt_write_word() functions.
3629 *
3630 * The struct declaration for register ALT_L3_ID_PERIPH_ID_2.
3631 */
3633{
3634 const uint32_t rev_jepcode_jep6to4 : 8; /* Revision, JEP106 code flag, JEP106[6:4] */
3635 uint32_t : 24; /* *UNDEFINED* */
3636};
3637
3638/* The typedef declaration for register ALT_L3_ID_PERIPH_ID_2. */
3639typedef volatile struct ALT_L3_ID_PERIPH_ID_2_s ALT_L3_ID_PERIPH_ID_2_t;
3640#endif /* __ASSEMBLY__ */
3641
3642/* The byte offset of the ALT_L3_ID_PERIPH_ID_2 register from the beginning of the component. */
3643#define ALT_L3_ID_PERIPH_ID_2_OFST 0xfe8
3644
3645/*
3646 * Register : Peripheral ID3 Register - periph_id_3
3647 *
3648 * Peripheral ID3
3649 *
3650 * Register Layout
3651 *
3652 * Bits | Access | Reset | Description
3653 * :-------|:-------|:------|:----------------------
3654 * [3:0] | R | 0x0 | Customer Model Number
3655 * [7:4] | R | 0x0 | Revision
3656 * [31:8] | ??? | 0x0 | *UNDEFINED*
3657 *
3658 */
3659/*
3660 * Field : Customer Model Number - cust_mod_num
3661 *
3662 * Customer Model Number
3663 *
3664 * Field Access Macros:
3665 *
3666 */
3667/* The Least Significant Bit (LSB) position of the ALT_L3_ID_PERIPH_ID_3_CUST_MOD_NUM register field. */
3668#define ALT_L3_ID_PERIPH_ID_3_CUST_MOD_NUM_LSB 0
3669/* The Most Significant Bit (MSB) position of the ALT_L3_ID_PERIPH_ID_3_CUST_MOD_NUM register field. */
3670#define ALT_L3_ID_PERIPH_ID_3_CUST_MOD_NUM_MSB 3
3671/* The width in bits of the ALT_L3_ID_PERIPH_ID_3_CUST_MOD_NUM register field. */
3672#define ALT_L3_ID_PERIPH_ID_3_CUST_MOD_NUM_WIDTH 4
3673/* The mask used to set the ALT_L3_ID_PERIPH_ID_3_CUST_MOD_NUM register field value. */
3674#define ALT_L3_ID_PERIPH_ID_3_CUST_MOD_NUM_SET_MSK 0x0000000f
3675/* The mask used to clear the ALT_L3_ID_PERIPH_ID_3_CUST_MOD_NUM register field value. */
3676#define ALT_L3_ID_PERIPH_ID_3_CUST_MOD_NUM_CLR_MSK 0xfffffff0
3677/* The reset value of the ALT_L3_ID_PERIPH_ID_3_CUST_MOD_NUM register field. */
3678#define ALT_L3_ID_PERIPH_ID_3_CUST_MOD_NUM_RESET 0x0
3679/* Extracts the ALT_L3_ID_PERIPH_ID_3_CUST_MOD_NUM field value from a register. */
3680#define ALT_L3_ID_PERIPH_ID_3_CUST_MOD_NUM_GET(value) (((value) & 0x0000000f) >> 0)
3681/* Produces a ALT_L3_ID_PERIPH_ID_3_CUST_MOD_NUM register field value suitable for setting the register. */
3682#define ALT_L3_ID_PERIPH_ID_3_CUST_MOD_NUM_SET(value) (((value) << 0) & 0x0000000f)
3683
3684/*
3685 * Field : Revision - rev_and
3686 *
3687 * Revision
3688 *
3689 * Field Access Macros:
3690 *
3691 */
3692/* The Least Significant Bit (LSB) position of the ALT_L3_ID_PERIPH_ID_3_REV_AND register field. */
3693#define ALT_L3_ID_PERIPH_ID_3_REV_AND_LSB 4
3694/* The Most Significant Bit (MSB) position of the ALT_L3_ID_PERIPH_ID_3_REV_AND register field. */
3695#define ALT_L3_ID_PERIPH_ID_3_REV_AND_MSB 7
3696/* The width in bits of the ALT_L3_ID_PERIPH_ID_3_REV_AND register field. */
3697#define ALT_L3_ID_PERIPH_ID_3_REV_AND_WIDTH 4
3698/* The mask used to set the ALT_L3_ID_PERIPH_ID_3_REV_AND register field value. */
3699#define ALT_L3_ID_PERIPH_ID_3_REV_AND_SET_MSK 0x000000f0
3700/* The mask used to clear the ALT_L3_ID_PERIPH_ID_3_REV_AND register field value. */
3701#define ALT_L3_ID_PERIPH_ID_3_REV_AND_CLR_MSK 0xffffff0f
3702/* The reset value of the ALT_L3_ID_PERIPH_ID_3_REV_AND register field. */
3703#define ALT_L3_ID_PERIPH_ID_3_REV_AND_RESET 0x0
3704/* Extracts the ALT_L3_ID_PERIPH_ID_3_REV_AND field value from a register. */
3705#define ALT_L3_ID_PERIPH_ID_3_REV_AND_GET(value) (((value) & 0x000000f0) >> 4)
3706/* Produces a ALT_L3_ID_PERIPH_ID_3_REV_AND register field value suitable for setting the register. */
3707#define ALT_L3_ID_PERIPH_ID_3_REV_AND_SET(value) (((value) << 4) & 0x000000f0)
3708
3709#ifndef __ASSEMBLY__
3710/*
3711 * WARNING: The C register and register group struct declarations are provided for
3712 * convenience and illustrative purposes. They should, however, be used with
3713 * caution as the C language standard provides no guarantees about the alignment or
3714 * atomicity of device memory accesses. The recommended practice for writing
3715 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
3716 * alt_write_word() functions.
3717 *
3718 * The struct declaration for register ALT_L3_ID_PERIPH_ID_3.
3719 */
3721{
3722 const uint32_t cust_mod_num : 4; /* Customer Model Number */
3723 const uint32_t rev_and : 4; /* Revision */
3724 uint32_t : 24; /* *UNDEFINED* */
3725};
3726
3727/* The typedef declaration for register ALT_L3_ID_PERIPH_ID_3. */
3728typedef volatile struct ALT_L3_ID_PERIPH_ID_3_s ALT_L3_ID_PERIPH_ID_3_t;
3729#endif /* __ASSEMBLY__ */
3730
3731/* The byte offset of the ALT_L3_ID_PERIPH_ID_3 register from the beginning of the component. */
3732#define ALT_L3_ID_PERIPH_ID_3_OFST 0xfec
3733
3734/*
3735 * Register : Component ID0 Register - comp_id_0
3736 *
3737 * Component ID0
3738 *
3739 * Register Layout
3740 *
3741 * Bits | Access | Reset | Description
3742 * :-------|:-------|:------|:------------
3743 * [7:0] | R | 0xd | Preamble
3744 * [31:8] | ??? | 0x0 | *UNDEFINED*
3745 *
3746 */
3747/*
3748 * Field : Preamble - preamble
3749 *
3750 * Preamble
3751 *
3752 * Field Access Macros:
3753 *
3754 */
3755/* The Least Significant Bit (LSB) position of the ALT_L3_ID_COMP_ID_0_PREAMBLE register field. */
3756#define ALT_L3_ID_COMP_ID_0_PREAMBLE_LSB 0
3757/* The Most Significant Bit (MSB) position of the ALT_L3_ID_COMP_ID_0_PREAMBLE register field. */
3758#define ALT_L3_ID_COMP_ID_0_PREAMBLE_MSB 7
3759/* The width in bits of the ALT_L3_ID_COMP_ID_0_PREAMBLE register field. */
3760#define ALT_L3_ID_COMP_ID_0_PREAMBLE_WIDTH 8
3761/* The mask used to set the ALT_L3_ID_COMP_ID_0_PREAMBLE register field value. */
3762#define ALT_L3_ID_COMP_ID_0_PREAMBLE_SET_MSK 0x000000ff
3763/* The mask used to clear the ALT_L3_ID_COMP_ID_0_PREAMBLE register field value. */
3764#define ALT_L3_ID_COMP_ID_0_PREAMBLE_CLR_MSK 0xffffff00
3765/* The reset value of the ALT_L3_ID_COMP_ID_0_PREAMBLE register field. */
3766#define ALT_L3_ID_COMP_ID_0_PREAMBLE_RESET 0xd
3767/* Extracts the ALT_L3_ID_COMP_ID_0_PREAMBLE field value from a register. */
3768#define ALT_L3_ID_COMP_ID_0_PREAMBLE_GET(value) (((value) & 0x000000ff) >> 0)
3769/* Produces a ALT_L3_ID_COMP_ID_0_PREAMBLE register field value suitable for setting the register. */
3770#define ALT_L3_ID_COMP_ID_0_PREAMBLE_SET(value) (((value) << 0) & 0x000000ff)
3771
3772#ifndef __ASSEMBLY__
3773/*
3774 * WARNING: The C register and register group struct declarations are provided for
3775 * convenience and illustrative purposes. They should, however, be used with
3776 * caution as the C language standard provides no guarantees about the alignment or
3777 * atomicity of device memory accesses. The recommended practice for writing
3778 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
3779 * alt_write_word() functions.
3780 *
3781 * The struct declaration for register ALT_L3_ID_COMP_ID_0.
3782 */
3784{
3785 const uint32_t preamble : 8; /* Preamble */
3786 uint32_t : 24; /* *UNDEFINED* */
3787};
3788
3789/* The typedef declaration for register ALT_L3_ID_COMP_ID_0. */
3790typedef volatile struct ALT_L3_ID_COMP_ID_0_s ALT_L3_ID_COMP_ID_0_t;
3791#endif /* __ASSEMBLY__ */
3792
3793/* The byte offset of the ALT_L3_ID_COMP_ID_0 register from the beginning of the component. */
3794#define ALT_L3_ID_COMP_ID_0_OFST 0xff0
3795
3796/*
3797 * Register : Component ID1 Register - comp_id_1
3798 *
3799 * Component ID1
3800 *
3801 * Register Layout
3802 *
3803 * Bits | Access | Reset | Description
3804 * :-------|:-------|:------|:-------------------------------------
3805 * [7:0] | R | 0xf0 | Generic IP component class, Preamble
3806 * [31:8] | ??? | 0x0 | *UNDEFINED*
3807 *
3808 */
3809/*
3810 * Field : Generic IP component class, Preamble - genipcompcls_preamble
3811 *
3812 * Generic IP component class, Preamble
3813 *
3814 * Field Access Macros:
3815 *
3816 */
3817/* The Least Significant Bit (LSB) position of the ALT_L3_ID_COMP_ID_1_GENIPCOMPCLS_PREAMBLE register field. */
3818#define ALT_L3_ID_COMP_ID_1_GENIPCOMPCLS_PREAMBLE_LSB 0
3819/* The Most Significant Bit (MSB) position of the ALT_L3_ID_COMP_ID_1_GENIPCOMPCLS_PREAMBLE register field. */
3820#define ALT_L3_ID_COMP_ID_1_GENIPCOMPCLS_PREAMBLE_MSB 7
3821/* The width in bits of the ALT_L3_ID_COMP_ID_1_GENIPCOMPCLS_PREAMBLE register field. */
3822#define ALT_L3_ID_COMP_ID_1_GENIPCOMPCLS_PREAMBLE_WIDTH 8
3823/* The mask used to set the ALT_L3_ID_COMP_ID_1_GENIPCOMPCLS_PREAMBLE register field value. */
3824#define ALT_L3_ID_COMP_ID_1_GENIPCOMPCLS_PREAMBLE_SET_MSK 0x000000ff
3825/* The mask used to clear the ALT_L3_ID_COMP_ID_1_GENIPCOMPCLS_PREAMBLE register field value. */
3826#define ALT_L3_ID_COMP_ID_1_GENIPCOMPCLS_PREAMBLE_CLR_MSK 0xffffff00
3827/* The reset value of the ALT_L3_ID_COMP_ID_1_GENIPCOMPCLS_PREAMBLE register field. */
3828#define ALT_L3_ID_COMP_ID_1_GENIPCOMPCLS_PREAMBLE_RESET 0xf0
3829/* Extracts the ALT_L3_ID_COMP_ID_1_GENIPCOMPCLS_PREAMBLE field value from a register. */
3830#define ALT_L3_ID_COMP_ID_1_GENIPCOMPCLS_PREAMBLE_GET(value) (((value) & 0x000000ff) >> 0)
3831/* Produces a ALT_L3_ID_COMP_ID_1_GENIPCOMPCLS_PREAMBLE register field value suitable for setting the register. */
3832#define ALT_L3_ID_COMP_ID_1_GENIPCOMPCLS_PREAMBLE_SET(value) (((value) << 0) & 0x000000ff)
3833
3834#ifndef __ASSEMBLY__
3835/*
3836 * WARNING: The C register and register group struct declarations are provided for
3837 * convenience and illustrative purposes. They should, however, be used with
3838 * caution as the C language standard provides no guarantees about the alignment or
3839 * atomicity of device memory accesses. The recommended practice for writing
3840 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
3841 * alt_write_word() functions.
3842 *
3843 * The struct declaration for register ALT_L3_ID_COMP_ID_1.
3844 */
3846{
3847 const uint32_t genipcompcls_preamble : 8; /* Generic IP component class, Preamble */
3848 uint32_t : 24; /* *UNDEFINED* */
3849};
3850
3851/* The typedef declaration for register ALT_L3_ID_COMP_ID_1. */
3852typedef volatile struct ALT_L3_ID_COMP_ID_1_s ALT_L3_ID_COMP_ID_1_t;
3853#endif /* __ASSEMBLY__ */
3854
3855/* The byte offset of the ALT_L3_ID_COMP_ID_1 register from the beginning of the component. */
3856#define ALT_L3_ID_COMP_ID_1_OFST 0xff4
3857
3858/*
3859 * Register : Component ID2 Register - comp_id_2
3860 *
3861 * Component ID2
3862 *
3863 * Register Layout
3864 *
3865 * Bits | Access | Reset | Description
3866 * :-------|:-------|:------|:------------
3867 * [7:0] | R | 0x5 | Preamble
3868 * [31:8] | ??? | 0x0 | *UNDEFINED*
3869 *
3870 */
3871/*
3872 * Field : Preamble - preamble
3873 *
3874 * Preamble
3875 *
3876 * Field Access Macros:
3877 *
3878 */
3879/* The Least Significant Bit (LSB) position of the ALT_L3_ID_COMP_ID_2_PREAMBLE register field. */
3880#define ALT_L3_ID_COMP_ID_2_PREAMBLE_LSB 0
3881/* The Most Significant Bit (MSB) position of the ALT_L3_ID_COMP_ID_2_PREAMBLE register field. */
3882#define ALT_L3_ID_COMP_ID_2_PREAMBLE_MSB 7
3883/* The width in bits of the ALT_L3_ID_COMP_ID_2_PREAMBLE register field. */
3884#define ALT_L3_ID_COMP_ID_2_PREAMBLE_WIDTH 8
3885/* The mask used to set the ALT_L3_ID_COMP_ID_2_PREAMBLE register field value. */
3886#define ALT_L3_ID_COMP_ID_2_PREAMBLE_SET_MSK 0x000000ff
3887/* The mask used to clear the ALT_L3_ID_COMP_ID_2_PREAMBLE register field value. */
3888#define ALT_L3_ID_COMP_ID_2_PREAMBLE_CLR_MSK 0xffffff00
3889/* The reset value of the ALT_L3_ID_COMP_ID_2_PREAMBLE register field. */
3890#define ALT_L3_ID_COMP_ID_2_PREAMBLE_RESET 0x5
3891/* Extracts the ALT_L3_ID_COMP_ID_2_PREAMBLE field value from a register. */
3892#define ALT_L3_ID_COMP_ID_2_PREAMBLE_GET(value) (((value) & 0x000000ff) >> 0)
3893/* Produces a ALT_L3_ID_COMP_ID_2_PREAMBLE register field value suitable for setting the register. */
3894#define ALT_L3_ID_COMP_ID_2_PREAMBLE_SET(value) (((value) << 0) & 0x000000ff)
3895
3896#ifndef __ASSEMBLY__
3897/*
3898 * WARNING: The C register and register group struct declarations are provided for
3899 * convenience and illustrative purposes. They should, however, be used with
3900 * caution as the C language standard provides no guarantees about the alignment or
3901 * atomicity of device memory accesses. The recommended practice for writing
3902 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
3903 * alt_write_word() functions.
3904 *
3905 * The struct declaration for register ALT_L3_ID_COMP_ID_2.
3906 */
3908{
3909 const uint32_t preamble : 8; /* Preamble */
3910 uint32_t : 24; /* *UNDEFINED* */
3911};
3912
3913/* The typedef declaration for register ALT_L3_ID_COMP_ID_2. */
3914typedef volatile struct ALT_L3_ID_COMP_ID_2_s ALT_L3_ID_COMP_ID_2_t;
3915#endif /* __ASSEMBLY__ */
3916
3917/* The byte offset of the ALT_L3_ID_COMP_ID_2 register from the beginning of the component. */
3918#define ALT_L3_ID_COMP_ID_2_OFST 0xff8
3919
3920/*
3921 * Register : Component ID3 Register - comp_id_3
3922 *
3923 * Component ID3
3924 *
3925 * Register Layout
3926 *
3927 * Bits | Access | Reset | Description
3928 * :-------|:-------|:------|:------------
3929 * [7:0] | R | 0xb1 | Preamble
3930 * [31:8] | ??? | 0x0 | *UNDEFINED*
3931 *
3932 */
3933/*
3934 * Field : Preamble - preamble
3935 *
3936 * Preamble
3937 *
3938 * Field Access Macros:
3939 *
3940 */
3941/* The Least Significant Bit (LSB) position of the ALT_L3_ID_COMP_ID_3_PREAMBLE register field. */
3942#define ALT_L3_ID_COMP_ID_3_PREAMBLE_LSB 0
3943/* The Most Significant Bit (MSB) position of the ALT_L3_ID_COMP_ID_3_PREAMBLE register field. */
3944#define ALT_L3_ID_COMP_ID_3_PREAMBLE_MSB 7
3945/* The width in bits of the ALT_L3_ID_COMP_ID_3_PREAMBLE register field. */
3946#define ALT_L3_ID_COMP_ID_3_PREAMBLE_WIDTH 8
3947/* The mask used to set the ALT_L3_ID_COMP_ID_3_PREAMBLE register field value. */
3948#define ALT_L3_ID_COMP_ID_3_PREAMBLE_SET_MSK 0x000000ff
3949/* The mask used to clear the ALT_L3_ID_COMP_ID_3_PREAMBLE register field value. */
3950#define ALT_L3_ID_COMP_ID_3_PREAMBLE_CLR_MSK 0xffffff00
3951/* The reset value of the ALT_L3_ID_COMP_ID_3_PREAMBLE register field. */
3952#define ALT_L3_ID_COMP_ID_3_PREAMBLE_RESET 0xb1
3953/* Extracts the ALT_L3_ID_COMP_ID_3_PREAMBLE field value from a register. */
3954#define ALT_L3_ID_COMP_ID_3_PREAMBLE_GET(value) (((value) & 0x000000ff) >> 0)
3955/* Produces a ALT_L3_ID_COMP_ID_3_PREAMBLE register field value suitable for setting the register. */
3956#define ALT_L3_ID_COMP_ID_3_PREAMBLE_SET(value) (((value) << 0) & 0x000000ff)
3957
3958#ifndef __ASSEMBLY__
3959/*
3960 * WARNING: The C register and register group struct declarations are provided for
3961 * convenience and illustrative purposes. They should, however, be used with
3962 * caution as the C language standard provides no guarantees about the alignment or
3963 * atomicity of device memory accesses. The recommended practice for writing
3964 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
3965 * alt_write_word() functions.
3966 *
3967 * The struct declaration for register ALT_L3_ID_COMP_ID_3.
3968 */
3970{
3971 const uint32_t preamble : 8; /* Preamble */
3972 uint32_t : 24; /* *UNDEFINED* */
3973};
3974
3975/* The typedef declaration for register ALT_L3_ID_COMP_ID_3. */
3976typedef volatile struct ALT_L3_ID_COMP_ID_3_s ALT_L3_ID_COMP_ID_3_t;
3977#endif /* __ASSEMBLY__ */
3978
3979/* The byte offset of the ALT_L3_ID_COMP_ID_3 register from the beginning of the component. */
3980#define ALT_L3_ID_COMP_ID_3_OFST 0xffc
3981
3982#ifndef __ASSEMBLY__
3983/*
3984 * WARNING: The C register and register group struct declarations are provided for
3985 * convenience and illustrative purposes. They should, however, be used with
3986 * caution as the C language standard provides no guarantees about the alignment or
3987 * atomicity of device memory accesses. The recommended practice for writing
3988 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
3989 * alt_write_word() functions.
3990 *
3991 * The struct declaration for register group ALT_L3_IDGRP.
3992 */
3994{
3995 volatile uint32_t _pad_0x0_0xfcf[1012]; /* *UNDEFINED* */
3996 volatile ALT_L3_ID_PERIPH_ID_4_t periph_id_4; /* ALT_L3_ID_PERIPH_ID_4 */
3997 volatile uint32_t _pad_0xfd4_0xfdf[3]; /* *UNDEFINED* */
3998 volatile ALT_L3_ID_PERIPH_ID_0_t periph_id_0; /* ALT_L3_ID_PERIPH_ID_0 */
3999 volatile ALT_L3_ID_PERIPH_ID_1_t periph_id_1; /* ALT_L3_ID_PERIPH_ID_1 */
4000 volatile ALT_L3_ID_PERIPH_ID_2_t periph_id_2; /* ALT_L3_ID_PERIPH_ID_2 */
4001 volatile ALT_L3_ID_PERIPH_ID_3_t periph_id_3; /* ALT_L3_ID_PERIPH_ID_3 */
4002 volatile ALT_L3_ID_COMP_ID_0_t comp_id_0; /* ALT_L3_ID_COMP_ID_0 */
4003 volatile ALT_L3_ID_COMP_ID_1_t comp_id_1; /* ALT_L3_ID_COMP_ID_1 */
4004 volatile ALT_L3_ID_COMP_ID_2_t comp_id_2; /* ALT_L3_ID_COMP_ID_2 */
4005 volatile ALT_L3_ID_COMP_ID_3_t comp_id_3; /* ALT_L3_ID_COMP_ID_3 */
4006};
4007
4008/* The typedef declaration for register group ALT_L3_IDGRP. */
4009typedef volatile struct ALT_L3_IDGRP_s ALT_L3_IDGRP_t;
4010/* The struct declaration for the raw register contents of register group ALT_L3_IDGRP. */
4012{
4013 volatile uint32_t _pad_0x0_0xfcf[1012]; /* *UNDEFINED* */
4014 volatile uint32_t periph_id_4; /* ALT_L3_ID_PERIPH_ID_4 */
4015 volatile uint32_t _pad_0xfd4_0xfdf[3]; /* *UNDEFINED* */
4016 volatile uint32_t periph_id_0; /* ALT_L3_ID_PERIPH_ID_0 */
4017 volatile uint32_t periph_id_1; /* ALT_L3_ID_PERIPH_ID_1 */
4018 volatile uint32_t periph_id_2; /* ALT_L3_ID_PERIPH_ID_2 */
4019 volatile uint32_t periph_id_3; /* ALT_L3_ID_PERIPH_ID_3 */
4020 volatile uint32_t comp_id_0; /* ALT_L3_ID_COMP_ID_0 */
4021 volatile uint32_t comp_id_1; /* ALT_L3_ID_COMP_ID_1 */
4022 volatile uint32_t comp_id_2; /* ALT_L3_ID_COMP_ID_2 */
4023 volatile uint32_t comp_id_3; /* ALT_L3_ID_COMP_ID_3 */
4024};
4025
4026/* The typedef declaration for the raw register contents of register group ALT_L3_IDGRP. */
4027typedef volatile struct ALT_L3_IDGRP_raw_s ALT_L3_IDGRP_raw_t;
4028#endif /* __ASSEMBLY__ */
4029
4030
4031/*
4032 * Register Group : Master Register Group - ALT_L3_MSTGRP
4033 * Master Register Group
4034 *
4035 * Registers associated with master interfaces in the L3 Interconnect. Note that a
4036 * master in the L3 Interconnect connects to a slave in a module.
4037 *
4038 */
4039/*
4040 * Register Group : L4 MAIN - ALT_L3_MST_L4MAIN
4041 * L4 MAIN
4042 *
4043 * Registers associated with the L4 MAIN master. This master is used to access the
4044 * APB slaves on the L4 MAIN bus.
4045 *
4046 */
4047/*
4048 * Register : Bus Matrix Issuing Functionality Modification Register - fn_mod_bm_iss
4049 *
4050 * Sets the issuing capability of the preceding switch arbitration scheme to
4051 * multiple or single outstanding transactions.
4052 *
4053 * Register Layout
4054 *
4055 * Bits | Access | Reset | Description
4056 * :-------|:-------|:------|:------------------------
4057 * [0] | RW | 0x0 | ALT_L3_FN_MOD_BM_ISS_RD
4058 * [1] | RW | 0x0 | ALT_L3_FN_MOD_BM_ISS_WR
4059 * [31:2] | ??? | 0x0 | *UNDEFINED*
4060 *
4061 */
4062/*
4063 * Field : rd
4064 *
4065 * Field Enumeration Values:
4066 *
4067 * Enum | Value | Description
4068 * :---------------------------------|:------|:-------------------------------------------
4069 * ALT_L3_FN_MOD_BM_ISS_RD_E_MULT | 0x0 | Multiple outstanding read transactions
4070 * ALT_L3_FN_MOD_BM_ISS_RD_E_SINGLE | 0x1 | Only a single outstanding read transaction
4071 *
4072 * Field Access Macros:
4073 *
4074 */
4075/*
4076 * Enumerated value for register field ALT_L3_FN_MOD_BM_ISS_RD
4077 *
4078 * Multiple outstanding read transactions
4079 */
4080#define ALT_L3_FN_MOD_BM_ISS_RD_E_MULT 0x0
4081/*
4082 * Enumerated value for register field ALT_L3_FN_MOD_BM_ISS_RD
4083 *
4084 * Only a single outstanding read transaction
4085 */
4086#define ALT_L3_FN_MOD_BM_ISS_RD_E_SINGLE 0x1
4087
4088/* The Least Significant Bit (LSB) position of the ALT_L3_FN_MOD_BM_ISS_RD register field. */
4089#define ALT_L3_FN_MOD_BM_ISS_RD_LSB 0
4090/* The Most Significant Bit (MSB) position of the ALT_L3_FN_MOD_BM_ISS_RD register field. */
4091#define ALT_L3_FN_MOD_BM_ISS_RD_MSB 0
4092/* The width in bits of the ALT_L3_FN_MOD_BM_ISS_RD register field. */
4093#define ALT_L3_FN_MOD_BM_ISS_RD_WIDTH 1
4094/* The mask used to set the ALT_L3_FN_MOD_BM_ISS_RD register field value. */
4095#define ALT_L3_FN_MOD_BM_ISS_RD_SET_MSK 0x00000001
4096/* The mask used to clear the ALT_L3_FN_MOD_BM_ISS_RD register field value. */
4097#define ALT_L3_FN_MOD_BM_ISS_RD_CLR_MSK 0xfffffffe
4098/* The reset value of the ALT_L3_FN_MOD_BM_ISS_RD register field. */
4099#define ALT_L3_FN_MOD_BM_ISS_RD_RESET 0x0
4100/* Extracts the ALT_L3_FN_MOD_BM_ISS_RD field value from a register. */
4101#define ALT_L3_FN_MOD_BM_ISS_RD_GET(value) (((value) & 0x00000001) >> 0)
4102/* Produces a ALT_L3_FN_MOD_BM_ISS_RD register field value suitable for setting the register. */
4103#define ALT_L3_FN_MOD_BM_ISS_RD_SET(value) (((value) << 0) & 0x00000001)
4104
4105/*
4106 * Field : wr
4107 *
4108 * Field Enumeration Values:
4109 *
4110 * Enum | Value | Description
4111 * :---------------------------------|:------|:--------------------------------------------
4112 * ALT_L3_FN_MOD_BM_ISS_WR_E_MULT | 0x0 | Multiple outstanding write transactions
4113 * ALT_L3_FN_MOD_BM_ISS_WR_E_SINGLE | 0x1 | Only a single outstanding write transaction
4114 *
4115 * Field Access Macros:
4116 *
4117 */
4118/*
4119 * Enumerated value for register field ALT_L3_FN_MOD_BM_ISS_WR
4120 *
4121 * Multiple outstanding write transactions
4122 */
4123#define ALT_L3_FN_MOD_BM_ISS_WR_E_MULT 0x0
4124/*
4125 * Enumerated value for register field ALT_L3_FN_MOD_BM_ISS_WR
4126 *
4127 * Only a single outstanding write transaction
4128 */
4129#define ALT_L3_FN_MOD_BM_ISS_WR_E_SINGLE 0x1
4130
4131/* The Least Significant Bit (LSB) position of the ALT_L3_FN_MOD_BM_ISS_WR register field. */
4132#define ALT_L3_FN_MOD_BM_ISS_WR_LSB 1
4133/* The Most Significant Bit (MSB) position of the ALT_L3_FN_MOD_BM_ISS_WR register field. */
4134#define ALT_L3_FN_MOD_BM_ISS_WR_MSB 1
4135/* The width in bits of the ALT_L3_FN_MOD_BM_ISS_WR register field. */
4136#define ALT_L3_FN_MOD_BM_ISS_WR_WIDTH 1
4137/* The mask used to set the ALT_L3_FN_MOD_BM_ISS_WR register field value. */
4138#define ALT_L3_FN_MOD_BM_ISS_WR_SET_MSK 0x00000002
4139/* The mask used to clear the ALT_L3_FN_MOD_BM_ISS_WR register field value. */
4140#define ALT_L3_FN_MOD_BM_ISS_WR_CLR_MSK 0xfffffffd
4141/* The reset value of the ALT_L3_FN_MOD_BM_ISS_WR register field. */
4142#define ALT_L3_FN_MOD_BM_ISS_WR_RESET 0x0
4143/* Extracts the ALT_L3_FN_MOD_BM_ISS_WR field value from a register. */
4144#define ALT_L3_FN_MOD_BM_ISS_WR_GET(value) (((value) & 0x00000002) >> 1)
4145/* Produces a ALT_L3_FN_MOD_BM_ISS_WR register field value suitable for setting the register. */
4146#define ALT_L3_FN_MOD_BM_ISS_WR_SET(value) (((value) << 1) & 0x00000002)
4147
4148#ifndef __ASSEMBLY__
4149/*
4150 * WARNING: The C register and register group struct declarations are provided for
4151 * convenience and illustrative purposes. They should, however, be used with
4152 * caution as the C language standard provides no guarantees about the alignment or
4153 * atomicity of device memory accesses. The recommended practice for writing
4154 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
4155 * alt_write_word() functions.
4156 *
4157 * The struct declaration for register ALT_L3_FN_MOD_BM_ISS.
4158 */
4160{
4161 uint32_t rd : 1; /* ALT_L3_FN_MOD_BM_ISS_RD */
4162 uint32_t wr : 1; /* ALT_L3_FN_MOD_BM_ISS_WR */
4163 uint32_t : 30; /* *UNDEFINED* */
4164};
4165
4166/* The typedef declaration for register ALT_L3_FN_MOD_BM_ISS. */
4167typedef volatile struct ALT_L3_FN_MOD_BM_ISS_s ALT_L3_FN_MOD_BM_ISS_t;
4168#endif /* __ASSEMBLY__ */
4169
4170/* The byte offset of the ALT_L3_FN_MOD_BM_ISS register from the beginning of the component. */
4171#define ALT_L3_FN_MOD_BM_ISS_OFST 0x8
4172/* The address of the ALT_L3_FN_MOD_BM_ISS register. */
4173#define ALT_L3_FN_MOD_BM_ISS_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_L3_FN_MOD_BM_ISS_OFST))
4174
4175#ifndef __ASSEMBLY__
4176/*
4177 * WARNING: The C register and register group struct declarations are provided for
4178 * convenience and illustrative purposes. They should, however, be used with
4179 * caution as the C language standard provides no guarantees about the alignment or
4180 * atomicity of device memory accesses. The recommended practice for writing
4181 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
4182 * alt_write_word() functions.
4183 *
4184 * The struct declaration for register group ALT_L3_MST_L4MAIN.
4185 */
4187{
4188 volatile uint32_t _pad_0x0_0x7[2]; /* *UNDEFINED* */
4189 volatile ALT_L3_FN_MOD_BM_ISS_t fn_mod_bm_iss; /* ALT_L3_FN_MOD_BM_ISS */
4190};
4191
4192/* The typedef declaration for register group ALT_L3_MST_L4MAIN. */
4193typedef volatile struct ALT_L3_MST_L4MAIN_s ALT_L3_MST_L4MAIN_t;
4194/* The struct declaration for the raw register contents of register group ALT_L3_MST_L4MAIN. */
4196{
4197 volatile uint32_t _pad_0x0_0x7[2]; /* *UNDEFINED* */
4198 volatile uint32_t fn_mod_bm_iss; /* ALT_L3_FN_MOD_BM_ISS */
4199};
4200
4201/* The typedef declaration for the raw register contents of register group ALT_L3_MST_L4MAIN. */
4202typedef volatile struct ALT_L3_MST_L4MAIN_raw_s ALT_L3_MST_L4MAIN_raw_t;
4203#endif /* __ASSEMBLY__ */
4204
4205
4206/*
4207 * Register Group : L4 SP - ALT_L3_MST_L4SP
4208 * L4 SP
4209 *
4210 * Registers associated with the L4 SP master. This master is used to access the
4211 * APB slaves on the L4 SP bus.
4212 *
4213 */
4214#ifndef __ASSEMBLY__
4215/*
4216 * WARNING: The C register and register group struct declarations are provided for
4217 * convenience and illustrative purposes. They should, however, be used with
4218 * caution as the C language standard provides no guarantees about the alignment or
4219 * atomicity of device memory accesses. The recommended practice for writing
4220 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
4221 * alt_write_word() functions.
4222 *
4223 * The struct declaration for register group ALT_L3_MST_L4SP.
4224 */
4226{
4227 volatile uint32_t _pad_0x0_0x7[2]; /* *UNDEFINED* */
4228 volatile ALT_L3_FN_MOD_BM_ISS_t fn_mod_bm_iss; /* ALT_L3_FN_MOD_BM_ISS */
4229};
4230
4231/* The typedef declaration for register group ALT_L3_MST_L4SP. */
4232typedef volatile struct ALT_L3_MST_L4SP_s ALT_L3_MST_L4SP_t;
4233/* The struct declaration for the raw register contents of register group ALT_L3_MST_L4SP. */
4235{
4236 volatile uint32_t _pad_0x0_0x7[2]; /* *UNDEFINED* */
4237 volatile uint32_t fn_mod_bm_iss; /* ALT_L3_FN_MOD_BM_ISS */
4238};
4239
4240/* The typedef declaration for the raw register contents of register group ALT_L3_MST_L4SP. */
4241typedef volatile struct ALT_L3_MST_L4SP_raw_s ALT_L3_MST_L4SP_raw_t;
4242#endif /* __ASSEMBLY__ */
4243
4244
4245/*
4246 * Register Group : L4 MP - ALT_L3_MST_L4MP
4247 * L4 MP
4248 *
4249 * Registers associated with the L4 MP master. This master is used to access the
4250 * APB slaves on the L4 MP bus.
4251 *
4252 */
4253#ifndef __ASSEMBLY__
4254/*
4255 * WARNING: The C register and register group struct declarations are provided for
4256 * convenience and illustrative purposes. They should, however, be used with
4257 * caution as the C language standard provides no guarantees about the alignment or
4258 * atomicity of device memory accesses. The recommended practice for writing
4259 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
4260 * alt_write_word() functions.
4261 *
4262 * The struct declaration for register group ALT_L3_MST_L4MP.
4263 */
4265{
4266 volatile uint32_t _pad_0x0_0x7[2]; /* *UNDEFINED* */
4267 volatile ALT_L3_FN_MOD_BM_ISS_t fn_mod_bm_iss; /* ALT_L3_FN_MOD_BM_ISS */
4268};
4269
4270/* The typedef declaration for register group ALT_L3_MST_L4MP. */
4271typedef volatile struct ALT_L3_MST_L4MP_s ALT_L3_MST_L4MP_t;
4272/* The struct declaration for the raw register contents of register group ALT_L3_MST_L4MP. */
4274{
4275 volatile uint32_t _pad_0x0_0x7[2]; /* *UNDEFINED* */
4276 volatile uint32_t fn_mod_bm_iss; /* ALT_L3_FN_MOD_BM_ISS */
4277};
4278
4279/* The typedef declaration for the raw register contents of register group ALT_L3_MST_L4MP. */
4280typedef volatile struct ALT_L3_MST_L4MP_raw_s ALT_L3_MST_L4MP_raw_t;
4281#endif /* __ASSEMBLY__ */
4282
4283
4284/*
4285 * Register Group : L4 OSC1 - ALT_L3_MST_L4OSC1
4286 * L4 OSC1
4287 *
4288 * Registers associated with the L4 OSC1 master. This master is used to access the
4289 * APB slaves on the L4 OSC1 bus.
4290 *
4291 */
4292#ifndef __ASSEMBLY__
4293/*
4294 * WARNING: The C register and register group struct declarations are provided for
4295 * convenience and illustrative purposes. They should, however, be used with
4296 * caution as the C language standard provides no guarantees about the alignment or
4297 * atomicity of device memory accesses. The recommended practice for writing
4298 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
4299 * alt_write_word() functions.
4300 *
4301 * The struct declaration for register group ALT_L3_MST_L4OSC1.
4302 */
4304{
4305 volatile uint32_t _pad_0x0_0x7[2]; /* *UNDEFINED* */
4306 volatile ALT_L3_FN_MOD_BM_ISS_t fn_mod_bm_iss; /* ALT_L3_FN_MOD_BM_ISS */
4307};
4308
4309/* The typedef declaration for register group ALT_L3_MST_L4OSC1. */
4310typedef volatile struct ALT_L3_MST_L4OSC1_s ALT_L3_MST_L4OSC1_t;
4311/* The struct declaration for the raw register contents of register group ALT_L3_MST_L4OSC1. */
4313{
4314 volatile uint32_t _pad_0x0_0x7[2]; /* *UNDEFINED* */
4315 volatile uint32_t fn_mod_bm_iss; /* ALT_L3_FN_MOD_BM_ISS */
4316};
4317
4318/* The typedef declaration for the raw register contents of register group ALT_L3_MST_L4OSC1. */
4319typedef volatile struct ALT_L3_MST_L4OSC1_raw_s ALT_L3_MST_L4OSC1_raw_t;
4320#endif /* __ASSEMBLY__ */
4321
4322
4323/*
4324 * Register Group : L4 SPIM - ALT_L3_MST_L4SPIM
4325 * L4 SPIM
4326 *
4327 * Registers associated with the L4 SPIM master. This master is used to access the
4328 * APB slaves on the L4 SPIM bus.
4329 *
4330 */
4331#ifndef __ASSEMBLY__
4332/*
4333 * WARNING: The C register and register group struct declarations are provided for
4334 * convenience and illustrative purposes. They should, however, be used with
4335 * caution as the C language standard provides no guarantees about the alignment or
4336 * atomicity of device memory accesses. The recommended practice for writing
4337 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
4338 * alt_write_word() functions.
4339 *
4340 * The struct declaration for register group ALT_L3_MST_L4SPIM.
4341 */
4343{
4344 volatile uint32_t _pad_0x0_0x7[2]; /* *UNDEFINED* */
4345 volatile ALT_L3_FN_MOD_BM_ISS_t fn_mod_bm_iss; /* ALT_L3_FN_MOD_BM_ISS */
4346};
4347
4348/* The typedef declaration for register group ALT_L3_MST_L4SPIM. */
4349typedef volatile struct ALT_L3_MST_L4SPIM_s ALT_L3_MST_L4SPIM_t;
4350/* The struct declaration for the raw register contents of register group ALT_L3_MST_L4SPIM. */
4352{
4353 volatile uint32_t _pad_0x0_0x7[2]; /* *UNDEFINED* */
4354 volatile uint32_t fn_mod_bm_iss; /* ALT_L3_FN_MOD_BM_ISS */
4355};
4356
4357/* The typedef declaration for the raw register contents of register group ALT_L3_MST_L4SPIM. */
4358typedef volatile struct ALT_L3_MST_L4SPIM_raw_s ALT_L3_MST_L4SPIM_raw_t;
4359#endif /* __ASSEMBLY__ */
4360
4361
4362/*
4363 * Register Group : STM - ALT_L3_MST_STM
4364 * STM
4365 *
4366 * Registers associated with the STM master. This master is used to access the STM
4367 * AXI slave.
4368 *
4369 */
4370/*
4371 * Register : Issuing Functionality Modification Register - fn_mod
4372 *
4373 * Sets the block issuing capability to multiple or single outstanding
4374 * transactions.
4375 *
4376 * Register Layout
4377 *
4378 * Bits | Access | Reset | Description
4379 * :-------|:-------|:------|:-----------------
4380 * [0] | RW | 0x0 | ALT_L3_FN_MOD_RD
4381 * [1] | RW | 0x0 | ALT_L3_FN_MOD_WR
4382 * [31:2] | ??? | 0x0 | *UNDEFINED*
4383 *
4384 */
4385/*
4386 * Field : rd
4387 *
4388 * Field Enumeration Values:
4389 *
4390 * Enum | Value | Description
4391 * :--------------------------|:------|:-------------------------------------------
4392 * ALT_L3_FN_MOD_RD_E_MULT | 0x0 | Multiple outstanding read transactions
4393 * ALT_L3_FN_MOD_RD_E_SINGLE | 0x1 | Only a single outstanding read transaction
4394 *
4395 * Field Access Macros:
4396 *
4397 */
4398/*
4399 * Enumerated value for register field ALT_L3_FN_MOD_RD
4400 *
4401 * Multiple outstanding read transactions
4402 */
4403#define ALT_L3_FN_MOD_RD_E_MULT 0x0
4404/*
4405 * Enumerated value for register field ALT_L3_FN_MOD_RD
4406 *
4407 * Only a single outstanding read transaction
4408 */
4409#define ALT_L3_FN_MOD_RD_E_SINGLE 0x1
4410
4411/* The Least Significant Bit (LSB) position of the ALT_L3_FN_MOD_RD register field. */
4412#define ALT_L3_FN_MOD_RD_LSB 0
4413/* The Most Significant Bit (MSB) position of the ALT_L3_FN_MOD_RD register field. */
4414#define ALT_L3_FN_MOD_RD_MSB 0
4415/* The width in bits of the ALT_L3_FN_MOD_RD register field. */
4416#define ALT_L3_FN_MOD_RD_WIDTH 1
4417/* The mask used to set the ALT_L3_FN_MOD_RD register field value. */
4418#define ALT_L3_FN_MOD_RD_SET_MSK 0x00000001
4419/* The mask used to clear the ALT_L3_FN_MOD_RD register field value. */
4420#define ALT_L3_FN_MOD_RD_CLR_MSK 0xfffffffe
4421/* The reset value of the ALT_L3_FN_MOD_RD register field. */
4422#define ALT_L3_FN_MOD_RD_RESET 0x0
4423/* Extracts the ALT_L3_FN_MOD_RD field value from a register. */
4424#define ALT_L3_FN_MOD_RD_GET(value) (((value) & 0x00000001) >> 0)
4425/* Produces a ALT_L3_FN_MOD_RD register field value suitable for setting the register. */
4426#define ALT_L3_FN_MOD_RD_SET(value) (((value) << 0) & 0x00000001)
4427
4428/*
4429 * Field : wr
4430 *
4431 * Field Enumeration Values:
4432 *
4433 * Enum | Value | Description
4434 * :--------------------------|:------|:--------------------------------------------
4435 * ALT_L3_FN_MOD_WR_E_MULT | 0x0 | Multiple outstanding write transactions
4436 * ALT_L3_FN_MOD_WR_E_SINGLE | 0x1 | Only a single outstanding write transaction
4437 *
4438 * Field Access Macros:
4439 *
4440 */
4441/*
4442 * Enumerated value for register field ALT_L3_FN_MOD_WR
4443 *
4444 * Multiple outstanding write transactions
4445 */
4446#define ALT_L3_FN_MOD_WR_E_MULT 0x0
4447/*
4448 * Enumerated value for register field ALT_L3_FN_MOD_WR
4449 *
4450 * Only a single outstanding write transaction
4451 */
4452#define ALT_L3_FN_MOD_WR_E_SINGLE 0x1
4453
4454/* The Least Significant Bit (LSB) position of the ALT_L3_FN_MOD_WR register field. */
4455#define ALT_L3_FN_MOD_WR_LSB 1
4456/* The Most Significant Bit (MSB) position of the ALT_L3_FN_MOD_WR register field. */
4457#define ALT_L3_FN_MOD_WR_MSB 1
4458/* The width in bits of the ALT_L3_FN_MOD_WR register field. */
4459#define ALT_L3_FN_MOD_WR_WIDTH 1
4460/* The mask used to set the ALT_L3_FN_MOD_WR register field value. */
4461#define ALT_L3_FN_MOD_WR_SET_MSK 0x00000002
4462/* The mask used to clear the ALT_L3_FN_MOD_WR register field value. */
4463#define ALT_L3_FN_MOD_WR_CLR_MSK 0xfffffffd
4464/* The reset value of the ALT_L3_FN_MOD_WR register field. */
4465#define ALT_L3_FN_MOD_WR_RESET 0x0
4466/* Extracts the ALT_L3_FN_MOD_WR field value from a register. */
4467#define ALT_L3_FN_MOD_WR_GET(value) (((value) & 0x00000002) >> 1)
4468/* Produces a ALT_L3_FN_MOD_WR register field value suitable for setting the register. */
4469#define ALT_L3_FN_MOD_WR_SET(value) (((value) << 1) & 0x00000002)
4470
4471#ifndef __ASSEMBLY__
4472/*
4473 * WARNING: The C register and register group struct declarations are provided for
4474 * convenience and illustrative purposes. They should, however, be used with
4475 * caution as the C language standard provides no guarantees about the alignment or
4476 * atomicity of device memory accesses. The recommended practice for writing
4477 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
4478 * alt_write_word() functions.
4479 *
4480 * The struct declaration for register ALT_L3_FN_MOD.
4481 */
4483{
4484 uint32_t rd : 1; /* ALT_L3_FN_MOD_RD */
4485 uint32_t wr : 1; /* ALT_L3_FN_MOD_WR */
4486 uint32_t : 30; /* *UNDEFINED* */
4487};
4488
4489/* The typedef declaration for register ALT_L3_FN_MOD. */
4490typedef volatile struct ALT_L3_FN_MOD_s ALT_L3_FN_MOD_t;
4491#endif /* __ASSEMBLY__ */
4492
4493/* The byte offset of the ALT_L3_FN_MOD register from the beginning of the component. */
4494#define ALT_L3_FN_MOD_OFST 0x108
4495/* The address of the ALT_L3_FN_MOD register. */
4496#define ALT_L3_FN_MOD_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_L3_FN_MOD_OFST))
4497
4498#ifndef __ASSEMBLY__
4499/*
4500 * WARNING: The C register and register group struct declarations are provided for
4501 * convenience and illustrative purposes. They should, however, be used with
4502 * caution as the C language standard provides no guarantees about the alignment or
4503 * atomicity of device memory accesses. The recommended practice for writing
4504 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
4505 * alt_write_word() functions.
4506 *
4507 * The struct declaration for register group ALT_L3_MST_STM.
4508 */
4510{
4511 volatile uint32_t _pad_0x0_0x7[2]; /* *UNDEFINED* */
4512 volatile ALT_L3_FN_MOD_BM_ISS_t fn_mod_bm_iss; /* ALT_L3_FN_MOD_BM_ISS */
4513 volatile uint32_t _pad_0xc_0x107[63]; /* *UNDEFINED* */
4514 volatile ALT_L3_FN_MOD_t fn_mod; /* ALT_L3_FN_MOD */
4515};
4516
4517/* The typedef declaration for register group ALT_L3_MST_STM. */
4518typedef volatile struct ALT_L3_MST_STM_s ALT_L3_MST_STM_t;
4519/* The struct declaration for the raw register contents of register group ALT_L3_MST_STM. */
4521{
4522 volatile uint32_t _pad_0x0_0x7[2]; /* *UNDEFINED* */
4523 volatile uint32_t fn_mod_bm_iss; /* ALT_L3_FN_MOD_BM_ISS */
4524 volatile uint32_t _pad_0xc_0x107[63]; /* *UNDEFINED* */
4525 volatile uint32_t fn_mod; /* ALT_L3_FN_MOD */
4526};
4527
4528/* The typedef declaration for the raw register contents of register group ALT_L3_MST_STM. */
4529typedef volatile struct ALT_L3_MST_STM_raw_s ALT_L3_MST_STM_raw_t;
4530#endif /* __ASSEMBLY__ */
4531
4532
4533/*
4534 * Register Group : LWHPS2FPGA - ALT_L3_MST_LWH2F
4535 * LWHPS2FPGA
4536 *
4537 * Registers associated with the LWHPS2FPGA AXI Bridge master. This master is used
4538 * to access the LWHPS2FPGA AXI Bridge slave. This slave is used to access the
4539 * registers for all 3 AXI bridges and to access slaves in the FPGA connected to
4540 * the LWHPS2FPGA AXI Bridge.
4541 *
4542 */
4543#ifndef __ASSEMBLY__
4544/*
4545 * WARNING: The C register and register group struct declarations are provided for
4546 * convenience and illustrative purposes. They should, however, be used with
4547 * caution as the C language standard provides no guarantees about the alignment or
4548 * atomicity of device memory accesses. The recommended practice for writing
4549 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
4550 * alt_write_word() functions.
4551 *
4552 * The struct declaration for register group ALT_L3_MST_LWH2F.
4553 */
4555{
4556 volatile uint32_t _pad_0x0_0x7[2]; /* *UNDEFINED* */
4557 volatile ALT_L3_FN_MOD_BM_ISS_t fn_mod_bm_iss; /* ALT_L3_FN_MOD_BM_ISS */
4558 volatile uint32_t _pad_0xc_0x107[63]; /* *UNDEFINED* */
4559 volatile ALT_L3_FN_MOD_t fn_mod; /* ALT_L3_FN_MOD */
4560};
4561
4562/* The typedef declaration for register group ALT_L3_MST_LWH2F. */
4563typedef volatile struct ALT_L3_MST_LWH2F_s ALT_L3_MST_LWH2F_t;
4564/* The struct declaration for the raw register contents of register group ALT_L3_MST_LWH2F. */
4566{
4567 volatile uint32_t _pad_0x0_0x7[2]; /* *UNDEFINED* */
4568 volatile uint32_t fn_mod_bm_iss; /* ALT_L3_FN_MOD_BM_ISS */
4569 volatile uint32_t _pad_0xc_0x107[63]; /* *UNDEFINED* */
4570 volatile uint32_t fn_mod; /* ALT_L3_FN_MOD */
4571};
4572
4573/* The typedef declaration for the raw register contents of register group ALT_L3_MST_LWH2F. */
4574typedef volatile struct ALT_L3_MST_LWH2F_raw_s ALT_L3_MST_LWH2F_raw_t;
4575#endif /* __ASSEMBLY__ */
4576
4577
4578/*
4579 * Register Group : USB1 - ALT_L3_MST_USB1
4580 * USB1
4581 *
4582 * Registers associated with the USB1 master. This master is used to access the
4583 * registers in USB1.
4584 *
4585 */
4586/*
4587 * Register : AHB Control Register - ahb_cntl
4588 *
4589 * Sets the block issuing capability to one outstanding transaction.
4590 *
4591 * Register Layout
4592 *
4593 * Bits | Access | Reset | Description
4594 * :-------|:-------|:------|:---------------------------
4595 * [0] | RW | 0x0 | ALT_L3_AHB_CNTL_DECERR_EN
4596 * [1] | RW | 0x0 | ALT_L3_AHB_CNTL_FORCE_INCR
4597 * [31:2] | ??? | 0x0 | *UNDEFINED*
4598 *
4599 */
4600/*
4601 * Field : decerr_en
4602 *
4603 * Field Enumeration Values:
4604 *
4605 * Enum | Value | Description
4606 * :--------------------------------|:------|:-------------------------------------------------
4607 * ALT_L3_AHB_CNTL_DECERR_EN_E_DIS | 0x0 | No DECERR response.
4608 * ALT_L3_AHB_CNTL_DECERR_EN_E_EN | 0x1 | If the AHB protocol conversion function receives
4609 * : | | an unaligned address or a write data beat
4610 * : | | without all the byte strobes set, creates a
4611 * : | | DECERR response.
4612 *
4613 * Field Access Macros:
4614 *
4615 */
4616/*
4617 * Enumerated value for register field ALT_L3_AHB_CNTL_DECERR_EN
4618 *
4619 * No DECERR response.
4620 */
4621#define ALT_L3_AHB_CNTL_DECERR_EN_E_DIS 0x0
4622/*
4623 * Enumerated value for register field ALT_L3_AHB_CNTL_DECERR_EN
4624 *
4625 * If the AHB protocol conversion function receives an unaligned address or a write
4626 * data beat without all the byte strobes set, creates a DECERR response.
4627 */
4628#define ALT_L3_AHB_CNTL_DECERR_EN_E_EN 0x1
4629
4630/* The Least Significant Bit (LSB) position of the ALT_L3_AHB_CNTL_DECERR_EN register field. */
4631#define ALT_L3_AHB_CNTL_DECERR_EN_LSB 0
4632/* The Most Significant Bit (MSB) position of the ALT_L3_AHB_CNTL_DECERR_EN register field. */
4633#define ALT_L3_AHB_CNTL_DECERR_EN_MSB 0
4634/* The width in bits of the ALT_L3_AHB_CNTL_DECERR_EN register field. */
4635#define ALT_L3_AHB_CNTL_DECERR_EN_WIDTH 1
4636/* The mask used to set the ALT_L3_AHB_CNTL_DECERR_EN register field value. */
4637#define ALT_L3_AHB_CNTL_DECERR_EN_SET_MSK 0x00000001
4638/* The mask used to clear the ALT_L3_AHB_CNTL_DECERR_EN register field value. */
4639#define ALT_L3_AHB_CNTL_DECERR_EN_CLR_MSK 0xfffffffe
4640/* The reset value of the ALT_L3_AHB_CNTL_DECERR_EN register field. */
4641#define ALT_L3_AHB_CNTL_DECERR_EN_RESET 0x0
4642/* Extracts the ALT_L3_AHB_CNTL_DECERR_EN field value from a register. */
4643#define ALT_L3_AHB_CNTL_DECERR_EN_GET(value) (((value) & 0x00000001) >> 0)
4644/* Produces a ALT_L3_AHB_CNTL_DECERR_EN register field value suitable for setting the register. */
4645#define ALT_L3_AHB_CNTL_DECERR_EN_SET(value) (((value) << 0) & 0x00000001)
4646
4647/*
4648 * Field : force_incr
4649 *
4650 * Field Enumeration Values:
4651 *
4652 * Enum | Value | Description
4653 * :---------------------------------|:------|:-------------------------------------------------
4654 * ALT_L3_AHB_CNTL_FORCE_INCR_E_DIS | 0x0 | Multiple outstanding write transactions
4655 * ALT_L3_AHB_CNTL_FORCE_INCR_E_EN | 0x1 | If a beat is received that has no write data
4656 * : | | strobes set, that write data beat is replaced
4657 * : | | with an IDLE beat. Also, causes all transactions
4658 * : | | that are to be output to the AHB domain to be an
4659 * : | | undefined length INCR.
4660 *
4661 * Field Access Macros:
4662 *
4663 */
4664/*
4665 * Enumerated value for register field ALT_L3_AHB_CNTL_FORCE_INCR
4666 *
4667 * Multiple outstanding write transactions
4668 */
4669#define ALT_L3_AHB_CNTL_FORCE_INCR_E_DIS 0x0
4670/*
4671 * Enumerated value for register field ALT_L3_AHB_CNTL_FORCE_INCR
4672 *
4673 * If a beat is received that has no write data strobes set, that write data beat
4674 * is replaced with an IDLE beat. Also, causes all transactions that are to be
4675 * output to the AHB domain to be an undefined length INCR.
4676 */
4677#define ALT_L3_AHB_CNTL_FORCE_INCR_E_EN 0x1
4678
4679/* The Least Significant Bit (LSB) position of the ALT_L3_AHB_CNTL_FORCE_INCR register field. */
4680#define ALT_L3_AHB_CNTL_FORCE_INCR_LSB 1
4681/* The Most Significant Bit (MSB) position of the ALT_L3_AHB_CNTL_FORCE_INCR register field. */
4682#define ALT_L3_AHB_CNTL_FORCE_INCR_MSB 1
4683/* The width in bits of the ALT_L3_AHB_CNTL_FORCE_INCR register field. */
4684#define ALT_L3_AHB_CNTL_FORCE_INCR_WIDTH 1
4685/* The mask used to set the ALT_L3_AHB_CNTL_FORCE_INCR register field value. */
4686#define ALT_L3_AHB_CNTL_FORCE_INCR_SET_MSK 0x00000002
4687/* The mask used to clear the ALT_L3_AHB_CNTL_FORCE_INCR register field value. */
4688#define ALT_L3_AHB_CNTL_FORCE_INCR_CLR_MSK 0xfffffffd
4689/* The reset value of the ALT_L3_AHB_CNTL_FORCE_INCR register field. */
4690#define ALT_L3_AHB_CNTL_FORCE_INCR_RESET 0x0
4691/* Extracts the ALT_L3_AHB_CNTL_FORCE_INCR field value from a register. */
4692#define ALT_L3_AHB_CNTL_FORCE_INCR_GET(value) (((value) & 0x00000002) >> 1)
4693/* Produces a ALT_L3_AHB_CNTL_FORCE_INCR register field value suitable for setting the register. */
4694#define ALT_L3_AHB_CNTL_FORCE_INCR_SET(value) (((value) << 1) & 0x00000002)
4695
4696#ifndef __ASSEMBLY__
4697/*
4698 * WARNING: The C register and register group struct declarations are provided for
4699 * convenience and illustrative purposes. They should, however, be used with
4700 * caution as the C language standard provides no guarantees about the alignment or
4701 * atomicity of device memory accesses. The recommended practice for writing
4702 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
4703 * alt_write_word() functions.
4704 *
4705 * The struct declaration for register ALT_L3_AHB_CNTL.
4706 */
4708{
4709 uint32_t decerr_en : 1; /* ALT_L3_AHB_CNTL_DECERR_EN */
4710 uint32_t force_incr : 1; /* ALT_L3_AHB_CNTL_FORCE_INCR */
4711 uint32_t : 30; /* *UNDEFINED* */
4712};
4713
4714/* The typedef declaration for register ALT_L3_AHB_CNTL. */
4715typedef volatile struct ALT_L3_AHB_CNTL_s ALT_L3_AHB_CNTL_t;
4716#endif /* __ASSEMBLY__ */
4717
4718/* The byte offset of the ALT_L3_AHB_CNTL register from the beginning of the component. */
4719#define ALT_L3_AHB_CNTL_OFST 0x44
4720/* The address of the ALT_L3_AHB_CNTL register. */
4721#define ALT_L3_AHB_CNTL_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_L3_AHB_CNTL_OFST))
4722
4723#ifndef __ASSEMBLY__
4724/*
4725 * WARNING: The C register and register group struct declarations are provided for
4726 * convenience and illustrative purposes. They should, however, be used with
4727 * caution as the C language standard provides no guarantees about the alignment or
4728 * atomicity of device memory accesses. The recommended practice for writing
4729 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
4730 * alt_write_word() functions.
4731 *
4732 * The struct declaration for register group ALT_L3_MST_USB1.
4733 */
4735{
4736 volatile uint32_t _pad_0x0_0x7[2]; /* *UNDEFINED* */
4737 volatile ALT_L3_FN_MOD_BM_ISS_t fn_mod_bm_iss; /* ALT_L3_FN_MOD_BM_ISS */
4738 volatile uint32_t _pad_0xc_0x43[14]; /* *UNDEFINED* */
4739 volatile ALT_L3_AHB_CNTL_t ahb_cntl; /* ALT_L3_AHB_CNTL */
4740};
4741
4742/* The typedef declaration for register group ALT_L3_MST_USB1. */
4743typedef volatile struct ALT_L3_MST_USB1_s ALT_L3_MST_USB1_t;
4744/* The struct declaration for the raw register contents of register group ALT_L3_MST_USB1. */
4746{
4747 volatile uint32_t _pad_0x0_0x7[2]; /* *UNDEFINED* */
4748 volatile uint32_t fn_mod_bm_iss; /* ALT_L3_FN_MOD_BM_ISS */
4749 volatile uint32_t _pad_0xc_0x43[14]; /* *UNDEFINED* */
4750 volatile uint32_t ahb_cntl; /* ALT_L3_AHB_CNTL */
4751};
4752
4753/* The typedef declaration for the raw register contents of register group ALT_L3_MST_USB1. */
4754typedef volatile struct ALT_L3_MST_USB1_raw_s ALT_L3_MST_USB1_raw_t;
4755#endif /* __ASSEMBLY__ */
4756
4757
4758/*
4759 * Register Group : NANDDATA - ALT_L3_MST_NANDDATA
4760 * NANDDATA
4761 *
4762 * Registers associated with the NANDDATA master. This master is used to access
4763 * data in the NAND flash controller.
4764 *
4765 */
4766#ifndef __ASSEMBLY__
4767/*
4768 * WARNING: The C register and register group struct declarations are provided for
4769 * convenience and illustrative purposes. They should, however, be used with
4770 * caution as the C language standard provides no guarantees about the alignment or
4771 * atomicity of device memory accesses. The recommended practice for writing
4772 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
4773 * alt_write_word() functions.
4774 *
4775 * The struct declaration for register group ALT_L3_MST_NANDDATA.
4776 */
4778{
4779 volatile uint32_t _pad_0x0_0x7[2]; /* *UNDEFINED* */
4780 volatile ALT_L3_FN_MOD_BM_ISS_t fn_mod_bm_iss; /* ALT_L3_FN_MOD_BM_ISS */
4781 volatile uint32_t _pad_0xc_0x107[63]; /* *UNDEFINED* */
4782 volatile ALT_L3_FN_MOD_t fn_mod; /* ALT_L3_FN_MOD */
4783};
4784
4785/* The typedef declaration for register group ALT_L3_MST_NANDDATA. */
4786typedef volatile struct ALT_L3_MST_NANDDATA_s ALT_L3_MST_NANDDATA_t;
4787/* The struct declaration for the raw register contents of register group ALT_L3_MST_NANDDATA. */
4789{
4790 volatile uint32_t _pad_0x0_0x7[2]; /* *UNDEFINED* */
4791 volatile uint32_t fn_mod_bm_iss; /* ALT_L3_FN_MOD_BM_ISS */
4792 volatile uint32_t _pad_0xc_0x107[63]; /* *UNDEFINED* */
4793 volatile uint32_t fn_mod; /* ALT_L3_FN_MOD */
4794};
4795
4796/* The typedef declaration for the raw register contents of register group ALT_L3_MST_NANDDATA. */
4798#endif /* __ASSEMBLY__ */
4799
4800
4801/*
4802 * Register Group : USB0 - ALT_L3_MST_USB0
4803 * USB0
4804 *
4805 * Registers associated with the USB0 master. This master is used to access the
4806 * registers in USB0.
4807 *
4808 */
4809#ifndef __ASSEMBLY__
4810/*
4811 * WARNING: The C register and register group struct declarations are provided for
4812 * convenience and illustrative purposes. They should, however, be used with
4813 * caution as the C language standard provides no guarantees about the alignment or
4814 * atomicity of device memory accesses. The recommended practice for writing
4815 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
4816 * alt_write_word() functions.
4817 *
4818 * The struct declaration for register group ALT_L3_MST_USB0.
4819 */
4821{
4822 volatile uint32_t _pad_0x0_0x7[2]; /* *UNDEFINED* */
4823 volatile ALT_L3_FN_MOD_BM_ISS_t fn_mod_bm_iss; /* ALT_L3_FN_MOD_BM_ISS */
4824 volatile uint32_t _pad_0xc_0x43[14]; /* *UNDEFINED* */
4825 volatile ALT_L3_AHB_CNTL_t ahb_cntl; /* ALT_L3_AHB_CNTL */
4826};
4827
4828/* The typedef declaration for register group ALT_L3_MST_USB0. */
4829typedef volatile struct ALT_L3_MST_USB0_s ALT_L3_MST_USB0_t;
4830/* The struct declaration for the raw register contents of register group ALT_L3_MST_USB0. */
4832{
4833 volatile uint32_t _pad_0x0_0x7[2]; /* *UNDEFINED* */
4834 volatile uint32_t fn_mod_bm_iss; /* ALT_L3_FN_MOD_BM_ISS */
4835 volatile uint32_t _pad_0xc_0x43[14]; /* *UNDEFINED* */
4836 volatile uint32_t ahb_cntl; /* ALT_L3_AHB_CNTL */
4837};
4838
4839/* The typedef declaration for the raw register contents of register group ALT_L3_MST_USB0. */
4840typedef volatile struct ALT_L3_MST_USB0_raw_s ALT_L3_MST_USB0_raw_t;
4841#endif /* __ASSEMBLY__ */
4842
4843
4844/*
4845 * Register Group : NANDREGS - ALT_L3_MST_NAND
4846 * NANDREGS
4847 *
4848 * Registers associated with the NANDREGS master. This master is used to access the
4849 * registers in the NAND flash controller.
4850 *
4851 */
4852#ifndef __ASSEMBLY__
4853/*
4854 * WARNING: The C register and register group struct declarations are provided for
4855 * convenience and illustrative purposes. They should, however, be used with
4856 * caution as the C language standard provides no guarantees about the alignment or
4857 * atomicity of device memory accesses. The recommended practice for writing
4858 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
4859 * alt_write_word() functions.
4860 *
4861 * The struct declaration for register group ALT_L3_MST_NAND.
4862 */
4864{
4865 volatile uint32_t _pad_0x0_0x7[2]; /* *UNDEFINED* */
4866 volatile ALT_L3_FN_MOD_BM_ISS_t fn_mod_bm_iss; /* ALT_L3_FN_MOD_BM_ISS */
4867 volatile uint32_t _pad_0xc_0x107[63]; /* *UNDEFINED* */
4868 volatile ALT_L3_FN_MOD_t fn_mod; /* ALT_L3_FN_MOD */
4869};
4870
4871/* The typedef declaration for register group ALT_L3_MST_NAND. */
4872typedef volatile struct ALT_L3_MST_NAND_s ALT_L3_MST_NAND_t;
4873/* The struct declaration for the raw register contents of register group ALT_L3_MST_NAND. */
4875{
4876 volatile uint32_t _pad_0x0_0x7[2]; /* *UNDEFINED* */
4877 volatile uint32_t fn_mod_bm_iss; /* ALT_L3_FN_MOD_BM_ISS */
4878 volatile uint32_t _pad_0xc_0x107[63]; /* *UNDEFINED* */
4879 volatile uint32_t fn_mod; /* ALT_L3_FN_MOD */
4880};
4881
4882/* The typedef declaration for the raw register contents of register group ALT_L3_MST_NAND. */
4883typedef volatile struct ALT_L3_MST_NAND_raw_s ALT_L3_MST_NAND_raw_t;
4884#endif /* __ASSEMBLY__ */
4885
4886
4887/*
4888 * Register Group : QSPIDATA - ALT_L3_MST_QSPIDATA
4889 * QSPIDATA
4890 *
4891 * Registers associated with the QSPIDATA master. This master is used to access
4892 * data in the QSPI flash controller.
4893 *
4894 */
4895#ifndef __ASSEMBLY__
4896/*
4897 * WARNING: The C register and register group struct declarations are provided for
4898 * convenience and illustrative purposes. They should, however, be used with
4899 * caution as the C language standard provides no guarantees about the alignment or
4900 * atomicity of device memory accesses. The recommended practice for writing
4901 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
4902 * alt_write_word() functions.
4903 *
4904 * The struct declaration for register group ALT_L3_MST_QSPIDATA.
4905 */
4907{
4908 volatile uint32_t _pad_0x0_0x7[2]; /* *UNDEFINED* */
4909 volatile ALT_L3_FN_MOD_BM_ISS_t fn_mod_bm_iss; /* ALT_L3_FN_MOD_BM_ISS */
4910 volatile uint32_t _pad_0xc_0x43[14]; /* *UNDEFINED* */
4911 volatile ALT_L3_AHB_CNTL_t ahb_cntl; /* ALT_L3_AHB_CNTL */
4912};
4913
4914/* The typedef declaration for register group ALT_L3_MST_QSPIDATA. */
4915typedef volatile struct ALT_L3_MST_QSPIDATA_s ALT_L3_MST_QSPIDATA_t;
4916/* The struct declaration for the raw register contents of register group ALT_L3_MST_QSPIDATA. */
4918{
4919 volatile uint32_t _pad_0x0_0x7[2]; /* *UNDEFINED* */
4920 volatile uint32_t fn_mod_bm_iss; /* ALT_L3_FN_MOD_BM_ISS */
4921 volatile uint32_t _pad_0xc_0x43[14]; /* *UNDEFINED* */
4922 volatile uint32_t ahb_cntl; /* ALT_L3_AHB_CNTL */
4923};
4924
4925/* The typedef declaration for the raw register contents of register group ALT_L3_MST_QSPIDATA. */
4927#endif /* __ASSEMBLY__ */
4928
4929
4930/*
4931 * Register Group : FPGAMGRDATA - ALT_L3_MST_FPGAMGRDATA
4932 * FPGAMGRDATA
4933 *
4934 * Registers associated with the FPGAMGRDATA master. This master is used to send
4935 * FPGA configuration image data to the FPGA Manager.
4936 *
4937 */
4938/*
4939 * Register : Write Tidemark - wr_tidemark
4940 *
4941 * Controls the release of the transaction in the write data FIFO.
4942 *
4943 * Register Layout
4944 *
4945 * Bits | Access | Reset | Description
4946 * :-------|:-------|:------|:------------
4947 * [3:0] | RW | 0x4 | Level
4948 * [31:4] | ??? | 0x0 | *UNDEFINED*
4949 *
4950 */
4951/*
4952 * Field : Level - level
4953 *
4954 * Stalls the transaction in the write data FIFO until the number of occupied slots
4955 * in the write data FIFO exceeds the level. Note that the transaction is released
4956 * before this level is achieved if the network receives the WLAST beat or the
4957 * write FIFO becomes full.
4958 *
4959 * Field Access Macros:
4960 *
4961 */
4962/* The Least Significant Bit (LSB) position of the ALT_L3_WR_TIDEMARK_LEVEL register field. */
4963#define ALT_L3_WR_TIDEMARK_LEVEL_LSB 0
4964/* The Most Significant Bit (MSB) position of the ALT_L3_WR_TIDEMARK_LEVEL register field. */
4965#define ALT_L3_WR_TIDEMARK_LEVEL_MSB 3
4966/* The width in bits of the ALT_L3_WR_TIDEMARK_LEVEL register field. */
4967#define ALT_L3_WR_TIDEMARK_LEVEL_WIDTH 4
4968/* The mask used to set the ALT_L3_WR_TIDEMARK_LEVEL register field value. */
4969#define ALT_L3_WR_TIDEMARK_LEVEL_SET_MSK 0x0000000f
4970/* The mask used to clear the ALT_L3_WR_TIDEMARK_LEVEL register field value. */
4971#define ALT_L3_WR_TIDEMARK_LEVEL_CLR_MSK 0xfffffff0
4972/* The reset value of the ALT_L3_WR_TIDEMARK_LEVEL register field. */
4973#define ALT_L3_WR_TIDEMARK_LEVEL_RESET 0x4
4974/* Extracts the ALT_L3_WR_TIDEMARK_LEVEL field value from a register. */
4975#define ALT_L3_WR_TIDEMARK_LEVEL_GET(value) (((value) & 0x0000000f) >> 0)
4976/* Produces a ALT_L3_WR_TIDEMARK_LEVEL register field value suitable for setting the register. */
4977#define ALT_L3_WR_TIDEMARK_LEVEL_SET(value) (((value) << 0) & 0x0000000f)
4978
4979#ifndef __ASSEMBLY__
4980/*
4981 * WARNING: The C register and register group struct declarations are provided for
4982 * convenience and illustrative purposes. They should, however, be used with
4983 * caution as the C language standard provides no guarantees about the alignment or
4984 * atomicity of device memory accesses. The recommended practice for writing
4985 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
4986 * alt_write_word() functions.
4987 *
4988 * The struct declaration for register ALT_L3_WR_TIDEMARK.
4989 */
4991{
4992 uint32_t level : 4; /* Level */
4993 uint32_t : 28; /* *UNDEFINED* */
4994};
4995
4996/* The typedef declaration for register ALT_L3_WR_TIDEMARK. */
4997typedef volatile struct ALT_L3_WR_TIDEMARK_s ALT_L3_WR_TIDEMARK_t;
4998#endif /* __ASSEMBLY__ */
4999
5000/* The byte offset of the ALT_L3_WR_TIDEMARK register from the beginning of the component. */
5001#define ALT_L3_WR_TIDEMARK_OFST 0x40
5002/* The address of the ALT_L3_WR_TIDEMARK register. */
5003#define ALT_L3_WR_TIDEMARK_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_L3_WR_TIDEMARK_OFST))
5004
5005#ifndef __ASSEMBLY__
5006/*
5007 * WARNING: The C register and register group struct declarations are provided for
5008 * convenience and illustrative purposes. They should, however, be used with
5009 * caution as the C language standard provides no guarantees about the alignment or
5010 * atomicity of device memory accesses. The recommended practice for writing
5011 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
5012 * alt_write_word() functions.
5013 *
5014 * The struct declaration for register group ALT_L3_MST_FPGAMGRDATA.
5015 */
5017{
5018 volatile uint32_t _pad_0x0_0x7[2]; /* *UNDEFINED* */
5019 volatile ALT_L3_FN_MOD_BM_ISS_t fn_mod_bm_iss; /* ALT_L3_FN_MOD_BM_ISS */
5020 volatile uint32_t _pad_0xc_0x3f[13]; /* *UNDEFINED* */
5021 volatile ALT_L3_WR_TIDEMARK_t wr_tidemark; /* ALT_L3_WR_TIDEMARK */
5022 volatile uint32_t _pad_0x44_0x107[49]; /* *UNDEFINED* */
5023 volatile ALT_L3_FN_MOD_t fn_mod; /* ALT_L3_FN_MOD */
5024};
5025
5026/* The typedef declaration for register group ALT_L3_MST_FPGAMGRDATA. */
5028/* The struct declaration for the raw register contents of register group ALT_L3_MST_FPGAMGRDATA. */
5030{
5031 volatile uint32_t _pad_0x0_0x7[2]; /* *UNDEFINED* */
5032 volatile uint32_t fn_mod_bm_iss; /* ALT_L3_FN_MOD_BM_ISS */
5033 volatile uint32_t _pad_0xc_0x3f[13]; /* *UNDEFINED* */
5034 volatile uint32_t wr_tidemark; /* ALT_L3_WR_TIDEMARK */
5035 volatile uint32_t _pad_0x44_0x107[49]; /* *UNDEFINED* */
5036 volatile uint32_t fn_mod; /* ALT_L3_FN_MOD */
5037};
5038
5039/* The typedef declaration for the raw register contents of register group ALT_L3_MST_FPGAMGRDATA. */
5041#endif /* __ASSEMBLY__ */
5042
5043
5044/*
5045 * Register Group : HPS2FPGA - ALT_L3_MST_H2F
5046 * HPS2FPGA
5047 *
5048 * Registers associated with the HPS2FPGA AXI Bridge master. This master is used to
5049 * access the HPS2FPGA AXI Bridge slave. This slave is used to access slaves in the
5050 * FPGA connected to the HPS2FPGA AXI Bridge.
5051 *
5052 */
5053#ifndef __ASSEMBLY__
5054/*
5055 * WARNING: The C register and register group struct declarations are provided for
5056 * convenience and illustrative purposes. They should, however, be used with
5057 * caution as the C language standard provides no guarantees about the alignment or
5058 * atomicity of device memory accesses. The recommended practice for writing
5059 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
5060 * alt_write_word() functions.
5061 *
5062 * The struct declaration for register group ALT_L3_MST_H2F.
5063 */
5065{
5066 volatile uint32_t _pad_0x0_0x7[2]; /* *UNDEFINED* */
5067 volatile ALT_L3_FN_MOD_BM_ISS_t fn_mod_bm_iss; /* ALT_L3_FN_MOD_BM_ISS */
5068 volatile uint32_t _pad_0xc_0x3f[13]; /* *UNDEFINED* */
5069 volatile ALT_L3_WR_TIDEMARK_t wr_tidemark; /* ALT_L3_WR_TIDEMARK */
5070 volatile uint32_t _pad_0x44_0x107[49]; /* *UNDEFINED* */
5071 volatile ALT_L3_FN_MOD_t fn_mod; /* ALT_L3_FN_MOD */
5072};
5073
5074/* The typedef declaration for register group ALT_L3_MST_H2F. */
5075typedef volatile struct ALT_L3_MST_H2F_s ALT_L3_MST_H2F_t;
5076/* The struct declaration for the raw register contents of register group ALT_L3_MST_H2F. */
5078{
5079 volatile uint32_t _pad_0x0_0x7[2]; /* *UNDEFINED* */
5080 volatile uint32_t fn_mod_bm_iss; /* ALT_L3_FN_MOD_BM_ISS */
5081 volatile uint32_t _pad_0xc_0x3f[13]; /* *UNDEFINED* */
5082 volatile uint32_t wr_tidemark; /* ALT_L3_WR_TIDEMARK */
5083 volatile uint32_t _pad_0x44_0x107[49]; /* *UNDEFINED* */
5084 volatile uint32_t fn_mod; /* ALT_L3_FN_MOD */
5085};
5086
5087/* The typedef declaration for the raw register contents of register group ALT_L3_MST_H2F. */
5088typedef volatile struct ALT_L3_MST_H2F_raw_s ALT_L3_MST_H2F_raw_t;
5089#endif /* __ASSEMBLY__ */
5090
5091
5092/*
5093 * Register Group : ACP - ALT_L3_MST_ACP
5094 * ACP
5095 *
5096 * Registers associated with the ACP master. This master is used to access the MPU
5097 * ACP slave via the ACP ID Mapper.
5098 *
5099 */
5100#ifndef __ASSEMBLY__
5101/*
5102 * WARNING: The C register and register group struct declarations are provided for
5103 * convenience and illustrative purposes. They should, however, be used with
5104 * caution as the C language standard provides no guarantees about the alignment or
5105 * atomicity of device memory accesses. The recommended practice for writing
5106 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
5107 * alt_write_word() functions.
5108 *
5109 * The struct declaration for register group ALT_L3_MST_ACP.
5110 */
5112{
5113 volatile uint32_t _pad_0x0_0x7[2]; /* *UNDEFINED* */
5114 volatile ALT_L3_FN_MOD_BM_ISS_t fn_mod_bm_iss; /* ALT_L3_FN_MOD_BM_ISS */
5115 volatile uint32_t _pad_0xc_0x107[63]; /* *UNDEFINED* */
5116 volatile ALT_L3_FN_MOD_t fn_mod; /* ALT_L3_FN_MOD */
5117};
5118
5119/* The typedef declaration for register group ALT_L3_MST_ACP. */
5120typedef volatile struct ALT_L3_MST_ACP_s ALT_L3_MST_ACP_t;
5121/* The struct declaration for the raw register contents of register group ALT_L3_MST_ACP. */
5123{
5124 volatile uint32_t _pad_0x0_0x7[2]; /* *UNDEFINED* */
5125 volatile uint32_t fn_mod_bm_iss; /* ALT_L3_FN_MOD_BM_ISS */
5126 volatile uint32_t _pad_0xc_0x107[63]; /* *UNDEFINED* */
5127 volatile uint32_t fn_mod; /* ALT_L3_FN_MOD */
5128};
5129
5130/* The typedef declaration for the raw register contents of register group ALT_L3_MST_ACP. */
5131typedef volatile struct ALT_L3_MST_ACP_raw_s ALT_L3_MST_ACP_raw_t;
5132#endif /* __ASSEMBLY__ */
5133
5134
5135/*
5136 * Register Group : Boot ROM - ALT_L3_MST_ROM
5137 * Boot ROM
5138 *
5139 * Registers associated with the Boot ROM master. This master is used to access the
5140 * contents of the Boot ROM.
5141 *
5142 */
5143#ifndef __ASSEMBLY__
5144/*
5145 * WARNING: The C register and register group struct declarations are provided for
5146 * convenience and illustrative purposes. They should, however, be used with
5147 * caution as the C language standard provides no guarantees about the alignment or
5148 * atomicity of device memory accesses. The recommended practice for writing
5149 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
5150 * alt_write_word() functions.
5151 *
5152 * The struct declaration for register group ALT_L3_MST_ROM.
5153 */
5155{
5156 volatile uint32_t _pad_0x0_0x7[2]; /* *UNDEFINED* */
5157 volatile ALT_L3_FN_MOD_BM_ISS_t fn_mod_bm_iss; /* ALT_L3_FN_MOD_BM_ISS */
5158 volatile uint32_t _pad_0xc_0x107[63]; /* *UNDEFINED* */
5159 volatile ALT_L3_FN_MOD_t fn_mod; /* ALT_L3_FN_MOD */
5160};
5161
5162/* The typedef declaration for register group ALT_L3_MST_ROM. */
5163typedef volatile struct ALT_L3_MST_ROM_s ALT_L3_MST_ROM_t;
5164/* The struct declaration for the raw register contents of register group ALT_L3_MST_ROM. */
5166{
5167 volatile uint32_t _pad_0x0_0x7[2]; /* *UNDEFINED* */
5168 volatile uint32_t fn_mod_bm_iss; /* ALT_L3_FN_MOD_BM_ISS */
5169 volatile uint32_t _pad_0xc_0x107[63]; /* *UNDEFINED* */
5170 volatile uint32_t fn_mod; /* ALT_L3_FN_MOD */
5171};
5172
5173/* The typedef declaration for the raw register contents of register group ALT_L3_MST_ROM. */
5174typedef volatile struct ALT_L3_MST_ROM_raw_s ALT_L3_MST_ROM_raw_t;
5175#endif /* __ASSEMBLY__ */
5176
5177
5178/*
5179 * Register Group : On-chip RAM - ALT_L3_MST_OCRAM
5180 * On-chip RAM
5181 *
5182 * Registers associated with the On-chip RAM master. This master is used to access
5183 * the contents of the On-chip RAM.
5184 *
5185 */
5186#ifndef __ASSEMBLY__
5187/*
5188 * WARNING: The C register and register group struct declarations are provided for
5189 * convenience and illustrative purposes. They should, however, be used with
5190 * caution as the C language standard provides no guarantees about the alignment or
5191 * atomicity of device memory accesses. The recommended practice for writing
5192 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
5193 * alt_write_word() functions.
5194 *
5195 * The struct declaration for register group ALT_L3_MST_OCRAM.
5196 */
5198{
5199 volatile uint32_t _pad_0x0_0x7[2]; /* *UNDEFINED* */
5200 volatile ALT_L3_FN_MOD_BM_ISS_t fn_mod_bm_iss; /* ALT_L3_FN_MOD_BM_ISS */
5201 volatile uint32_t _pad_0xc_0x3f[13]; /* *UNDEFINED* */
5202 volatile ALT_L3_WR_TIDEMARK_t wr_tidemark; /* ALT_L3_WR_TIDEMARK */
5203 volatile uint32_t _pad_0x44_0x107[49]; /* *UNDEFINED* */
5204 volatile ALT_L3_FN_MOD_t fn_mod; /* ALT_L3_FN_MOD */
5205};
5206
5207/* The typedef declaration for register group ALT_L3_MST_OCRAM. */
5208typedef volatile struct ALT_L3_MST_OCRAM_s ALT_L3_MST_OCRAM_t;
5209/* The struct declaration for the raw register contents of register group ALT_L3_MST_OCRAM. */
5211{
5212 volatile uint32_t _pad_0x0_0x7[2]; /* *UNDEFINED* */
5213 volatile uint32_t fn_mod_bm_iss; /* ALT_L3_FN_MOD_BM_ISS */
5214 volatile uint32_t _pad_0xc_0x3f[13]; /* *UNDEFINED* */
5215 volatile uint32_t wr_tidemark; /* ALT_L3_WR_TIDEMARK */
5216 volatile uint32_t _pad_0x44_0x107[49]; /* *UNDEFINED* */
5217 volatile uint32_t fn_mod; /* ALT_L3_FN_MOD */
5218};
5219
5220/* The typedef declaration for the raw register contents of register group ALT_L3_MST_OCRAM. */
5221typedef volatile struct ALT_L3_MST_OCRAM_raw_s ALT_L3_MST_OCRAM_raw_t;
5222#endif /* __ASSEMBLY__ */
5223
5224
5225#ifndef __ASSEMBLY__
5226/*
5227 * WARNING: The C register and register group struct declarations are provided for
5228 * convenience and illustrative purposes. They should, however, be used with
5229 * caution as the C language standard provides no guarantees about the alignment or
5230 * atomicity of device memory accesses. The recommended practice for writing
5231 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
5232 * alt_write_word() functions.
5233 *
5234 * The struct declaration for register group ALT_L3_MSTGRP.
5235 */
5237{
5238 volatile ALT_L3_MST_L4MAIN_t mastergrp_l4main; /* ALT_L3_MST_L4MAIN */
5239 volatile uint32_t _pad_0xc_0xfff[1021]; /* *UNDEFINED* */
5240 volatile ALT_L3_MST_L4SP_t mastergrp_l4sp; /* ALT_L3_MST_L4SP */
5241 volatile uint32_t _pad_0x100c_0x1fff[1021]; /* *UNDEFINED* */
5242 volatile ALT_L3_MST_L4MP_t mastergrp_l4mp; /* ALT_L3_MST_L4MP */
5243 volatile uint32_t _pad_0x200c_0x2fff[1021]; /* *UNDEFINED* */
5244 volatile ALT_L3_MST_L4OSC1_t mastergrp_l4osc1; /* ALT_L3_MST_L4OSC1 */
5245 volatile uint32_t _pad_0x300c_0x3fff[1021]; /* *UNDEFINED* */
5246 volatile ALT_L3_MST_L4SPIM_t mastergrp_l4spim; /* ALT_L3_MST_L4SPIM */
5247 volatile uint32_t _pad_0x400c_0x4fff[1021]; /* *UNDEFINED* */
5248 volatile ALT_L3_MST_STM_t mastergrp_stm; /* ALT_L3_MST_STM */
5249 volatile uint32_t _pad_0x510c_0x5fff[957]; /* *UNDEFINED* */
5250 volatile ALT_L3_MST_LWH2F_t mastergrp_lwhps2fpga; /* ALT_L3_MST_LWH2F */
5251 volatile uint32_t _pad_0x610c_0x7fff[1981]; /* *UNDEFINED* */
5252 volatile ALT_L3_MST_USB1_t mastergrp_usb1; /* ALT_L3_MST_USB1 */
5253 volatile uint32_t _pad_0x8048_0x8fff[1006]; /* *UNDEFINED* */
5254 volatile ALT_L3_MST_NANDDATA_t mastergrp_nanddata; /* ALT_L3_MST_NANDDATA */
5255 volatile uint32_t _pad_0x910c_0x1dfff[21437]; /* *UNDEFINED* */
5256 volatile ALT_L3_MST_USB0_t mastergrp_usb0; /* ALT_L3_MST_USB0 */
5257 volatile uint32_t _pad_0x1e048_0x1efff[1006]; /* *UNDEFINED* */
5258 volatile ALT_L3_MST_NAND_t mastergrp_nandregs; /* ALT_L3_MST_NAND */
5259 volatile uint32_t _pad_0x1f10c_0x1ffff[957]; /* *UNDEFINED* */
5260 volatile ALT_L3_MST_QSPIDATA_t mastergrp_qspidata; /* ALT_L3_MST_QSPIDATA */
5261 volatile uint32_t _pad_0x20048_0x20fff[1006]; /* *UNDEFINED* */
5262 volatile ALT_L3_MST_FPGAMGRDATA_t mastergrp_fpgamgrdata; /* ALT_L3_MST_FPGAMGRDATA */
5263 volatile uint32_t _pad_0x2110c_0x21fff[957]; /* *UNDEFINED* */
5264 volatile ALT_L3_MST_H2F_t mastergrp_hps2fpga; /* ALT_L3_MST_H2F */
5265 volatile uint32_t _pad_0x2210c_0x22fff[957]; /* *UNDEFINED* */
5266 volatile ALT_L3_MST_ACP_t mastergrp_acp; /* ALT_L3_MST_ACP */
5267 volatile uint32_t _pad_0x2310c_0x23fff[957]; /* *UNDEFINED* */
5268 volatile ALT_L3_MST_ROM_t mastergrp_rom; /* ALT_L3_MST_ROM */
5269 volatile uint32_t _pad_0x2410c_0x24fff[957]; /* *UNDEFINED* */
5270 volatile ALT_L3_MST_OCRAM_t mastergrp_ocram; /* ALT_L3_MST_OCRAM */
5271};
5272
5273/* The typedef declaration for register group ALT_L3_MSTGRP. */
5274typedef volatile struct ALT_L3_MSTGRP_s ALT_L3_MSTGRP_t;
5275/* The struct declaration for the raw register contents of register group ALT_L3_MSTGRP. */
5277{
5278 volatile ALT_L3_MST_L4MAIN_raw_t mastergrp_l4main; /* ALT_L3_MST_L4MAIN */
5279 volatile uint32_t _pad_0xc_0xfff[1021]; /* *UNDEFINED* */
5280 volatile ALT_L3_MST_L4SP_raw_t mastergrp_l4sp; /* ALT_L3_MST_L4SP */
5281 volatile uint32_t _pad_0x100c_0x1fff[1021]; /* *UNDEFINED* */
5282 volatile ALT_L3_MST_L4MP_raw_t mastergrp_l4mp; /* ALT_L3_MST_L4MP */
5283 volatile uint32_t _pad_0x200c_0x2fff[1021]; /* *UNDEFINED* */
5284 volatile ALT_L3_MST_L4OSC1_raw_t mastergrp_l4osc1; /* ALT_L3_MST_L4OSC1 */
5285 volatile uint32_t _pad_0x300c_0x3fff[1021]; /* *UNDEFINED* */
5286 volatile ALT_L3_MST_L4SPIM_raw_t mastergrp_l4spim; /* ALT_L3_MST_L4SPIM */
5287 volatile uint32_t _pad_0x400c_0x4fff[1021]; /* *UNDEFINED* */
5288 volatile ALT_L3_MST_STM_raw_t mastergrp_stm; /* ALT_L3_MST_STM */
5289 volatile uint32_t _pad_0x510c_0x5fff[957]; /* *UNDEFINED* */
5290 volatile ALT_L3_MST_LWH2F_raw_t mastergrp_lwhps2fpga; /* ALT_L3_MST_LWH2F */
5291 volatile uint32_t _pad_0x610c_0x7fff[1981]; /* *UNDEFINED* */
5292 volatile ALT_L3_MST_USB1_raw_t mastergrp_usb1; /* ALT_L3_MST_USB1 */
5293 volatile uint32_t _pad_0x8048_0x8fff[1006]; /* *UNDEFINED* */
5294 volatile ALT_L3_MST_NANDDATA_raw_t mastergrp_nanddata; /* ALT_L3_MST_NANDDATA */
5295 volatile uint32_t _pad_0x910c_0x1dfff[21437]; /* *UNDEFINED* */
5296 volatile ALT_L3_MST_USB0_raw_t mastergrp_usb0; /* ALT_L3_MST_USB0 */
5297 volatile uint32_t _pad_0x1e048_0x1efff[1006]; /* *UNDEFINED* */
5298 volatile ALT_L3_MST_NAND_raw_t mastergrp_nandregs; /* ALT_L3_MST_NAND */
5299 volatile uint32_t _pad_0x1f10c_0x1ffff[957]; /* *UNDEFINED* */
5300 volatile ALT_L3_MST_QSPIDATA_raw_t mastergrp_qspidata; /* ALT_L3_MST_QSPIDATA */
5301 volatile uint32_t _pad_0x20048_0x20fff[1006]; /* *UNDEFINED* */
5302 volatile ALT_L3_MST_FPGAMGRDATA_raw_t mastergrp_fpgamgrdata; /* ALT_L3_MST_FPGAMGRDATA */
5303 volatile uint32_t _pad_0x2110c_0x21fff[957]; /* *UNDEFINED* */
5304 volatile ALT_L3_MST_H2F_raw_t mastergrp_hps2fpga; /* ALT_L3_MST_H2F */
5305 volatile uint32_t _pad_0x2210c_0x22fff[957]; /* *UNDEFINED* */
5306 volatile ALT_L3_MST_ACP_raw_t mastergrp_acp; /* ALT_L3_MST_ACP */
5307 volatile uint32_t _pad_0x2310c_0x23fff[957]; /* *UNDEFINED* */
5308 volatile ALT_L3_MST_ROM_raw_t mastergrp_rom; /* ALT_L3_MST_ROM */
5309 volatile uint32_t _pad_0x2410c_0x24fff[957]; /* *UNDEFINED* */
5310 volatile ALT_L3_MST_OCRAM_raw_t mastergrp_ocram; /* ALT_L3_MST_OCRAM */
5311};
5312
5313/* The typedef declaration for the raw register contents of register group ALT_L3_MSTGRP. */
5314typedef volatile struct ALT_L3_MSTGRP_raw_s ALT_L3_MSTGRP_raw_t;
5315#endif /* __ASSEMBLY__ */
5316
5317
5318/*
5319 * Register Group : Slave Register Group - ALT_L3_SLVGRP
5320 * Slave Register Group
5321 *
5322 * Registers associated with slave interfaces.
5323 *
5324 */
5325/*
5326 * Register Group : DAP - ALT_L3_SLV_DAP
5327 * DAP
5328 *
5329 * Registers associated with the DAP slave interface. This slave is used by the DAP
5330 * to access slaves attached to the L3/L4 Interconnect.
5331 *
5332 */
5333/*
5334 * Register : Functionality Modification 2 Register - fn_mod2
5335 *
5336 * Controls bypass merge of upsizing/downsizing.
5337 *
5338 * Register Layout
5339 *
5340 * Bits | Access | Reset | Description
5341 * :-------|:-------|:------|:-------------
5342 * [0] | RW | 0x0 | Bypass Merge
5343 * [31:1] | ??? | 0x0 | *UNDEFINED*
5344 *
5345 */
5346/*
5347 * Field : Bypass Merge - bypass_merge
5348 *
5349 * Controls bypass merge of upsizing/downsizing.
5350 *
5351 * Field Enumeration Values:
5352 *
5353 * Enum | Value | Description
5354 * :--------------------------------------|:------|:-------------------------------------------------
5355 * ALT_L3_FN_MOD2_BYPASS_MERGE_E_ALTER | 0x0 | The network can alter transactions.
5356 * ALT_L3_FN_MOD2_BYPASS_MERGE_E_NOALTER | 0x1 | The network does not alter any transactions that
5357 * : | | could pass through the upsizer legally without
5358 * : | | alteration.
5359 *
5360 * Field Access Macros:
5361 *
5362 */
5363/*
5364 * Enumerated value for register field ALT_L3_FN_MOD2_BYPASS_MERGE
5365 *
5366 * The network can alter transactions.
5367 */
5368#define ALT_L3_FN_MOD2_BYPASS_MERGE_E_ALTER 0x0
5369/*
5370 * Enumerated value for register field ALT_L3_FN_MOD2_BYPASS_MERGE
5371 *
5372 * The network does not alter any transactions that could pass through the upsizer
5373 * legally without alteration.
5374 */
5375#define ALT_L3_FN_MOD2_BYPASS_MERGE_E_NOALTER 0x1
5376
5377/* The Least Significant Bit (LSB) position of the ALT_L3_FN_MOD2_BYPASS_MERGE register field. */
5378#define ALT_L3_FN_MOD2_BYPASS_MERGE_LSB 0
5379/* The Most Significant Bit (MSB) position of the ALT_L3_FN_MOD2_BYPASS_MERGE register field. */
5380#define ALT_L3_FN_MOD2_BYPASS_MERGE_MSB 0
5381/* The width in bits of the ALT_L3_FN_MOD2_BYPASS_MERGE register field. */
5382#define ALT_L3_FN_MOD2_BYPASS_MERGE_WIDTH 1
5383/* The mask used to set the ALT_L3_FN_MOD2_BYPASS_MERGE register field value. */
5384#define ALT_L3_FN_MOD2_BYPASS_MERGE_SET_MSK 0x00000001
5385/* The mask used to clear the ALT_L3_FN_MOD2_BYPASS_MERGE register field value. */
5386#define ALT_L3_FN_MOD2_BYPASS_MERGE_CLR_MSK 0xfffffffe
5387/* The reset value of the ALT_L3_FN_MOD2_BYPASS_MERGE register field. */
5388#define ALT_L3_FN_MOD2_BYPASS_MERGE_RESET 0x0
5389/* Extracts the ALT_L3_FN_MOD2_BYPASS_MERGE field value from a register. */
5390#define ALT_L3_FN_MOD2_BYPASS_MERGE_GET(value) (((value) & 0x00000001) >> 0)
5391/* Produces a ALT_L3_FN_MOD2_BYPASS_MERGE register field value suitable for setting the register. */
5392#define ALT_L3_FN_MOD2_BYPASS_MERGE_SET(value) (((value) << 0) & 0x00000001)
5393
5394#ifndef __ASSEMBLY__
5395/*
5396 * WARNING: The C register and register group struct declarations are provided for
5397 * convenience and illustrative purposes. They should, however, be used with
5398 * caution as the C language standard provides no guarantees about the alignment or
5399 * atomicity of device memory accesses. The recommended practice for writing
5400 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
5401 * alt_write_word() functions.
5402 *
5403 * The struct declaration for register ALT_L3_FN_MOD2.
5404 */
5406{
5407 uint32_t bypass_merge : 1; /* Bypass Merge */
5408 uint32_t : 31; /* *UNDEFINED* */
5409};
5410
5411/* The typedef declaration for register ALT_L3_FN_MOD2. */
5412typedef volatile struct ALT_L3_FN_MOD2_s ALT_L3_FN_MOD2_t;
5413#endif /* __ASSEMBLY__ */
5414
5415/* The byte offset of the ALT_L3_FN_MOD2 register from the beginning of the component. */
5416#define ALT_L3_FN_MOD2_OFST 0x24
5417/* The address of the ALT_L3_FN_MOD2 register. */
5418#define ALT_L3_FN_MOD2_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_L3_FN_MOD2_OFST))
5419
5420/*
5421 * Register : Functionality Modification AHB Register - fn_mod_ahb
5422 *
5423 * Controls how AHB-lite burst transactions are converted to AXI tranactions.
5424 *
5425 * Register Layout
5426 *
5427 * Bits | Access | Reset | Description
5428 * :-------|:-------|:------|:-------------------------
5429 * [0] | RW | 0x0 | Read Increment Override
5430 * [1] | RW | 0x0 | Write Increment Override
5431 * [31:2] | ??? | 0x0 | *UNDEFINED*
5432 *
5433 */
5434/*
5435 * Field : Read Increment Override - rd_incr_override
5436 *
5437 * Controls how AHB-lite read burst transactions are converted to AXI tranactions.
5438 *
5439 * Field Enumeration Values:
5440 *
5441 * Enum | Value | Description
5442 * :---------------------------------------------|:------|:----------------------------------------------
5443 * ALT_L3_FN_MOD_AHB_RD_INCR_OVERRIDE_E_DEFAULT | 0x0 | The L3 Interconnect converts AHB-lite read
5444 * : | | bursts to AXI transactions in accordance with
5445 * : | | the default behavior as specified in the ARM
5446 * : | | NIC-301 documentation.
5447 * ALT_L3_FN_MOD_AHB_RD_INCR_OVERRIDE_E_SINGLES | 0x1 | The L3 Interconnect converts AHB-lite read
5448 * : | | bursts to AXI single transactions.
5449 *
5450 * Field Access Macros:
5451 *
5452 */
5453/*
5454 * Enumerated value for register field ALT_L3_FN_MOD_AHB_RD_INCR_OVERRIDE
5455 *
5456 * The L3 Interconnect converts AHB-lite read bursts to AXI transactions in
5457 * accordance with the default behavior as specified in the ARM NIC-301
5458 * documentation.
5459 */
5460#define ALT_L3_FN_MOD_AHB_RD_INCR_OVERRIDE_E_DEFAULT 0x0
5461/*
5462 * Enumerated value for register field ALT_L3_FN_MOD_AHB_RD_INCR_OVERRIDE
5463 *
5464 * The L3 Interconnect converts AHB-lite read bursts to AXI single transactions.
5465 */
5466#define ALT_L3_FN_MOD_AHB_RD_INCR_OVERRIDE_E_SINGLES 0x1
5467
5468/* The Least Significant Bit (LSB) position of the ALT_L3_FN_MOD_AHB_RD_INCR_OVERRIDE register field. */
5469#define ALT_L3_FN_MOD_AHB_RD_INCR_OVERRIDE_LSB 0
5470/* The Most Significant Bit (MSB) position of the ALT_L3_FN_MOD_AHB_RD_INCR_OVERRIDE register field. */
5471#define ALT_L3_FN_MOD_AHB_RD_INCR_OVERRIDE_MSB 0
5472/* The width in bits of the ALT_L3_FN_MOD_AHB_RD_INCR_OVERRIDE register field. */
5473#define ALT_L3_FN_MOD_AHB_RD_INCR_OVERRIDE_WIDTH 1
5474/* The mask used to set the ALT_L3_FN_MOD_AHB_RD_INCR_OVERRIDE register field value. */
5475#define ALT_L3_FN_MOD_AHB_RD_INCR_OVERRIDE_SET_MSK 0x00000001
5476/* The mask used to clear the ALT_L3_FN_MOD_AHB_RD_INCR_OVERRIDE register field value. */
5477#define ALT_L3_FN_MOD_AHB_RD_INCR_OVERRIDE_CLR_MSK 0xfffffffe
5478/* The reset value of the ALT_L3_FN_MOD_AHB_RD_INCR_OVERRIDE register field. */
5479#define ALT_L3_FN_MOD_AHB_RD_INCR_OVERRIDE_RESET 0x0
5480/* Extracts the ALT_L3_FN_MOD_AHB_RD_INCR_OVERRIDE field value from a register. */
5481#define ALT_L3_FN_MOD_AHB_RD_INCR_OVERRIDE_GET(value) (((value) & 0x00000001) >> 0)
5482/* Produces a ALT_L3_FN_MOD_AHB_RD_INCR_OVERRIDE register field value suitable for setting the register. */
5483#define ALT_L3_FN_MOD_AHB_RD_INCR_OVERRIDE_SET(value) (((value) << 0) & 0x00000001)
5484
5485/*
5486 * Field : Write Increment Override - wr_incr_override
5487 *
5488 * Controls how AHB-lite write burst transactions are converted to AXI tranactions.
5489 *
5490 * Field Enumeration Values:
5491 *
5492 * Enum | Value | Description
5493 * :---------------------------------------------|:------|:----------------------------------------------
5494 * ALT_L3_FN_MOD_AHB_WR_INCR_OVERRIDE_E_DEFAULT | 0x0 | The L3 Interconnect converts AHB-lite write
5495 * : | | bursts to AXI transactions in accordance with
5496 * : | | the default behavior as specified in the ARM
5497 * : | | NIC-301 documentation.
5498 * ALT_L3_FN_MOD_AHB_WR_INCR_OVERRIDE_E_SINGLES | 0x1 | The L3 Interconnect converts AHB-lite write
5499 * : | | bursts to AXI single transactions.
5500 *
5501 * Field Access Macros:
5502 *
5503 */
5504/*
5505 * Enumerated value for register field ALT_L3_FN_MOD_AHB_WR_INCR_OVERRIDE
5506 *
5507 * The L3 Interconnect converts AHB-lite write bursts to AXI transactions in
5508 * accordance with the default behavior as specified in the ARM NIC-301
5509 * documentation.
5510 */
5511#define ALT_L3_FN_MOD_AHB_WR_INCR_OVERRIDE_E_DEFAULT 0x0
5512/*
5513 * Enumerated value for register field ALT_L3_FN_MOD_AHB_WR_INCR_OVERRIDE
5514 *
5515 * The L3 Interconnect converts AHB-lite write bursts to AXI single transactions.
5516 */
5517#define ALT_L3_FN_MOD_AHB_WR_INCR_OVERRIDE_E_SINGLES 0x1
5518
5519/* The Least Significant Bit (LSB) position of the ALT_L3_FN_MOD_AHB_WR_INCR_OVERRIDE register field. */
5520#define ALT_L3_FN_MOD_AHB_WR_INCR_OVERRIDE_LSB 1
5521/* The Most Significant Bit (MSB) position of the ALT_L3_FN_MOD_AHB_WR_INCR_OVERRIDE register field. */
5522#define ALT_L3_FN_MOD_AHB_WR_INCR_OVERRIDE_MSB 1
5523/* The width in bits of the ALT_L3_FN_MOD_AHB_WR_INCR_OVERRIDE register field. */
5524#define ALT_L3_FN_MOD_AHB_WR_INCR_OVERRIDE_WIDTH 1
5525/* The mask used to set the ALT_L3_FN_MOD_AHB_WR_INCR_OVERRIDE register field value. */
5526#define ALT_L3_FN_MOD_AHB_WR_INCR_OVERRIDE_SET_MSK 0x00000002
5527/* The mask used to clear the ALT_L3_FN_MOD_AHB_WR_INCR_OVERRIDE register field value. */
5528#define ALT_L3_FN_MOD_AHB_WR_INCR_OVERRIDE_CLR_MSK 0xfffffffd
5529/* The reset value of the ALT_L3_FN_MOD_AHB_WR_INCR_OVERRIDE register field. */
5530#define ALT_L3_FN_MOD_AHB_WR_INCR_OVERRIDE_RESET 0x0
5531/* Extracts the ALT_L3_FN_MOD_AHB_WR_INCR_OVERRIDE field value from a register. */
5532#define ALT_L3_FN_MOD_AHB_WR_INCR_OVERRIDE_GET(value) (((value) & 0x00000002) >> 1)
5533/* Produces a ALT_L3_FN_MOD_AHB_WR_INCR_OVERRIDE register field value suitable for setting the register. */
5534#define ALT_L3_FN_MOD_AHB_WR_INCR_OVERRIDE_SET(value) (((value) << 1) & 0x00000002)
5535
5536#ifndef __ASSEMBLY__
5537/*
5538 * WARNING: The C register and register group struct declarations are provided for
5539 * convenience and illustrative purposes. They should, however, be used with
5540 * caution as the C language standard provides no guarantees about the alignment or
5541 * atomicity of device memory accesses. The recommended practice for writing
5542 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
5543 * alt_write_word() functions.
5544 *
5545 * The struct declaration for register ALT_L3_FN_MOD_AHB.
5546 */
5548{
5549 uint32_t rd_incr_override : 1; /* Read Increment Override */
5550 uint32_t wr_incr_override : 1; /* Write Increment Override */
5551 uint32_t : 30; /* *UNDEFINED* */
5552};
5553
5554/* The typedef declaration for register ALT_L3_FN_MOD_AHB. */
5555typedef volatile struct ALT_L3_FN_MOD_AHB_s ALT_L3_FN_MOD_AHB_t;
5556#endif /* __ASSEMBLY__ */
5557
5558/* The byte offset of the ALT_L3_FN_MOD_AHB register from the beginning of the component. */
5559#define ALT_L3_FN_MOD_AHB_OFST 0x28
5560/* The address of the ALT_L3_FN_MOD_AHB register. */
5561#define ALT_L3_FN_MOD_AHB_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_L3_FN_MOD_AHB_OFST))
5562
5563/*
5564 * Register : Read Channel QoS Value - read_qos
5565 *
5566 * QoS (Quality of Service) value for the read channel.
5567 *
5568 * Register Layout
5569 *
5570 * Bits | Access | Reset | Description
5571 * :-------|:-------|:------|:------------
5572 * [3:0] | RW | 0x0 | Priority
5573 * [31:4] | ??? | 0x0 | *UNDEFINED*
5574 *
5575 */
5576/*
5577 * Field : Priority - pri
5578 *
5579 * QoS (Quality of Service) value for the read channel. A higher value has a higher
5580 * priority.
5581 *
5582 * Field Access Macros:
5583 *
5584 */
5585/* The Least Significant Bit (LSB) position of the ALT_L3_RD_QOS_PRI register field. */
5586#define ALT_L3_RD_QOS_PRI_LSB 0
5587/* The Most Significant Bit (MSB) position of the ALT_L3_RD_QOS_PRI register field. */
5588#define ALT_L3_RD_QOS_PRI_MSB 3
5589/* The width in bits of the ALT_L3_RD_QOS_PRI register field. */
5590#define ALT_L3_RD_QOS_PRI_WIDTH 4
5591/* The mask used to set the ALT_L3_RD_QOS_PRI register field value. */
5592#define ALT_L3_RD_QOS_PRI_SET_MSK 0x0000000f
5593/* The mask used to clear the ALT_L3_RD_QOS_PRI register field value. */
5594#define ALT_L3_RD_QOS_PRI_CLR_MSK 0xfffffff0
5595/* The reset value of the ALT_L3_RD_QOS_PRI register field. */
5596#define ALT_L3_RD_QOS_PRI_RESET 0x0
5597/* Extracts the ALT_L3_RD_QOS_PRI field value from a register. */
5598#define ALT_L3_RD_QOS_PRI_GET(value) (((value) & 0x0000000f) >> 0)
5599/* Produces a ALT_L3_RD_QOS_PRI register field value suitable for setting the register. */
5600#define ALT_L3_RD_QOS_PRI_SET(value) (((value) << 0) & 0x0000000f)
5601
5602#ifndef __ASSEMBLY__
5603/*
5604 * WARNING: The C register and register group struct declarations are provided for
5605 * convenience and illustrative purposes. They should, however, be used with
5606 * caution as the C language standard provides no guarantees about the alignment or
5607 * atomicity of device memory accesses. The recommended practice for writing
5608 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
5609 * alt_write_word() functions.
5610 *
5611 * The struct declaration for register ALT_L3_RD_QOS.
5612 */
5614{
5615 uint32_t pri : 4; /* Priority */
5616 uint32_t : 28; /* *UNDEFINED* */
5617};
5618
5619/* The typedef declaration for register ALT_L3_RD_QOS. */
5620typedef volatile struct ALT_L3_RD_QOS_s ALT_L3_RD_QOS_t;
5621#endif /* __ASSEMBLY__ */
5622
5623/* The byte offset of the ALT_L3_RD_QOS register from the beginning of the component. */
5624#define ALT_L3_RD_QOS_OFST 0x100
5625/* The address of the ALT_L3_RD_QOS register. */
5626#define ALT_L3_RD_QOS_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_L3_RD_QOS_OFST))
5627
5628/*
5629 * Register : Write Channel QoS Value - write_qos
5630 *
5631 * QoS (Quality of Service) value for the write channel.
5632 *
5633 * Register Layout
5634 *
5635 * Bits | Access | Reset | Description
5636 * :-------|:-------|:------|:------------
5637 * [3:0] | RW | 0x0 | Priority
5638 * [31:4] | ??? | 0x0 | *UNDEFINED*
5639 *
5640 */
5641/*
5642 * Field : Priority - pri
5643 *
5644 * QoS (Quality of Service) value for the write channel. A higher value has a
5645 * higher priority.
5646 *
5647 * Field Access Macros:
5648 *
5649 */
5650/* The Least Significant Bit (LSB) position of the ALT_L3_WR_QOS_PRI register field. */
5651#define ALT_L3_WR_QOS_PRI_LSB 0
5652/* The Most Significant Bit (MSB) position of the ALT_L3_WR_QOS_PRI register field. */
5653#define ALT_L3_WR_QOS_PRI_MSB 3
5654/* The width in bits of the ALT_L3_WR_QOS_PRI register field. */
5655#define ALT_L3_WR_QOS_PRI_WIDTH 4
5656/* The mask used to set the ALT_L3_WR_QOS_PRI register field value. */
5657#define ALT_L3_WR_QOS_PRI_SET_MSK 0x0000000f
5658/* The mask used to clear the ALT_L3_WR_QOS_PRI register field value. */
5659#define ALT_L3_WR_QOS_PRI_CLR_MSK 0xfffffff0
5660/* The reset value of the ALT_L3_WR_QOS_PRI register field. */
5661#define ALT_L3_WR_QOS_PRI_RESET 0x0
5662/* Extracts the ALT_L3_WR_QOS_PRI field value from a register. */
5663#define ALT_L3_WR_QOS_PRI_GET(value) (((value) & 0x0000000f) >> 0)
5664/* Produces a ALT_L3_WR_QOS_PRI register field value suitable for setting the register. */
5665#define ALT_L3_WR_QOS_PRI_SET(value) (((value) << 0) & 0x0000000f)
5666
5667#ifndef __ASSEMBLY__
5668/*
5669 * WARNING: The C register and register group struct declarations are provided for
5670 * convenience and illustrative purposes. They should, however, be used with
5671 * caution as the C language standard provides no guarantees about the alignment or
5672 * atomicity of device memory accesses. The recommended practice for writing
5673 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
5674 * alt_write_word() functions.
5675 *
5676 * The struct declaration for register ALT_L3_WR_QOS.
5677 */
5679{
5680 uint32_t pri : 4; /* Priority */
5681 uint32_t : 28; /* *UNDEFINED* */
5682};
5683
5684/* The typedef declaration for register ALT_L3_WR_QOS. */
5685typedef volatile struct ALT_L3_WR_QOS_s ALT_L3_WR_QOS_t;
5686#endif /* __ASSEMBLY__ */
5687
5688/* The byte offset of the ALT_L3_WR_QOS register from the beginning of the component. */
5689#define ALT_L3_WR_QOS_OFST 0x104
5690/* The address of the ALT_L3_WR_QOS register. */
5691#define ALT_L3_WR_QOS_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_L3_WR_QOS_OFST))
5692
5693#ifndef __ASSEMBLY__
5694/*
5695 * WARNING: The C register and register group struct declarations are provided for
5696 * convenience and illustrative purposes. They should, however, be used with
5697 * caution as the C language standard provides no guarantees about the alignment or
5698 * atomicity of device memory accesses. The recommended practice for writing
5699 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
5700 * alt_write_word() functions.
5701 *
5702 * The struct declaration for register group ALT_L3_SLV_DAP.
5703 */
5705{
5706 volatile uint32_t _pad_0x0_0x23[9]; /* *UNDEFINED* */
5707 volatile ALT_L3_FN_MOD2_t fn_mod2; /* ALT_L3_FN_MOD2 */
5708 volatile ALT_L3_FN_MOD_AHB_t fn_mod_ahb; /* ALT_L3_FN_MOD_AHB */
5709 volatile uint32_t _pad_0x2c_0xff[53]; /* *UNDEFINED* */
5710 volatile ALT_L3_RD_QOS_t read_qos; /* ALT_L3_RD_QOS */
5711 volatile ALT_L3_WR_QOS_t write_qos; /* ALT_L3_WR_QOS */
5712 volatile ALT_L3_FN_MOD_t fn_mod; /* ALT_L3_FN_MOD */
5713};
5714
5715/* The typedef declaration for register group ALT_L3_SLV_DAP. */
5716typedef volatile struct ALT_L3_SLV_DAP_s ALT_L3_SLV_DAP_t;
5717/* The struct declaration for the raw register contents of register group ALT_L3_SLV_DAP. */
5719{
5720 volatile uint32_t _pad_0x0_0x23[9]; /* *UNDEFINED* */
5721 volatile uint32_t fn_mod2; /* ALT_L3_FN_MOD2 */
5722 volatile uint32_t fn_mod_ahb; /* ALT_L3_FN_MOD_AHB */
5723 volatile uint32_t _pad_0x2c_0xff[53]; /* *UNDEFINED* */
5724 volatile uint32_t read_qos; /* ALT_L3_RD_QOS */
5725 volatile uint32_t write_qos; /* ALT_L3_WR_QOS */
5726 volatile uint32_t fn_mod; /* ALT_L3_FN_MOD */
5727};
5728
5729/* The typedef declaration for the raw register contents of register group ALT_L3_SLV_DAP. */
5730typedef volatile struct ALT_L3_SLV_DAP_raw_s ALT_L3_SLV_DAP_raw_t;
5731#endif /* __ASSEMBLY__ */
5732
5733
5734/*
5735 * Register Group : MPU - ALT_L3_SLV_MPU
5736 * MPU
5737 *
5738 * Registers associated with the MPU slave interface. This slave is used by the MPU
5739 * to access slaves attached to the L3/L4 Interconnect.
5740 *
5741 */
5742#ifndef __ASSEMBLY__
5743/*
5744 * WARNING: The C register and register group struct declarations are provided for
5745 * convenience and illustrative purposes. They should, however, be used with
5746 * caution as the C language standard provides no guarantees about the alignment or
5747 * atomicity of device memory accesses. The recommended practice for writing
5748 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
5749 * alt_write_word() functions.
5750 *
5751 * The struct declaration for register group ALT_L3_SLV_MPU.
5752 */
5754{
5755 volatile uint32_t _pad_0x0_0xff[64]; /* *UNDEFINED* */
5756 volatile ALT_L3_RD_QOS_t read_qos; /* ALT_L3_RD_QOS */
5757 volatile ALT_L3_WR_QOS_t write_qos; /* ALT_L3_WR_QOS */
5758 volatile ALT_L3_FN_MOD_t fn_mod; /* ALT_L3_FN_MOD */
5759};
5760
5761/* The typedef declaration for register group ALT_L3_SLV_MPU. */
5762typedef volatile struct ALT_L3_SLV_MPU_s ALT_L3_SLV_MPU_t;
5763/* The struct declaration for the raw register contents of register group ALT_L3_SLV_MPU. */
5765{
5766 volatile uint32_t _pad_0x0_0xff[64]; /* *UNDEFINED* */
5767 volatile uint32_t read_qos; /* ALT_L3_RD_QOS */
5768 volatile uint32_t write_qos; /* ALT_L3_WR_QOS */
5769 volatile uint32_t fn_mod; /* ALT_L3_FN_MOD */
5770};
5771
5772/* The typedef declaration for the raw register contents of register group ALT_L3_SLV_MPU. */
5773typedef volatile struct ALT_L3_SLV_MPU_raw_s ALT_L3_SLV_MPU_raw_t;
5774#endif /* __ASSEMBLY__ */
5775
5776
5777/*
5778 * Register Group : SDMMC - ALT_L3_SLV_SDMMC
5779 * SDMMC
5780 *
5781 * Registers associated with the SDMMC slave interface. This slave is used by the
5782 * DMA controller built into the SDMMC to access slaves attached to the L3/L4
5783 * Interconnect.
5784 *
5785 */
5786#ifndef __ASSEMBLY__
5787/*
5788 * WARNING: The C register and register group struct declarations are provided for
5789 * convenience and illustrative purposes. They should, however, be used with
5790 * caution as the C language standard provides no guarantees about the alignment or
5791 * atomicity of device memory accesses. The recommended practice for writing
5792 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
5793 * alt_write_word() functions.
5794 *
5795 * The struct declaration for register group ALT_L3_SLV_SDMMC.
5796 */
5798{
5799 volatile uint32_t _pad_0x0_0x27[10]; /* *UNDEFINED* */
5800 volatile ALT_L3_FN_MOD_AHB_t fn_mod_ahb; /* ALT_L3_FN_MOD_AHB */
5801 volatile uint32_t _pad_0x2c_0xff[53]; /* *UNDEFINED* */
5802 volatile ALT_L3_RD_QOS_t read_qos; /* ALT_L3_RD_QOS */
5803 volatile ALT_L3_WR_QOS_t write_qos; /* ALT_L3_WR_QOS */
5804 volatile ALT_L3_FN_MOD_t fn_mod; /* ALT_L3_FN_MOD */
5805};
5806
5807/* The typedef declaration for register group ALT_L3_SLV_SDMMC. */
5808typedef volatile struct ALT_L3_SLV_SDMMC_s ALT_L3_SLV_SDMMC_t;
5809/* The struct declaration for the raw register contents of register group ALT_L3_SLV_SDMMC. */
5811{
5812 volatile uint32_t _pad_0x0_0x27[10]; /* *UNDEFINED* */
5813 volatile uint32_t fn_mod_ahb; /* ALT_L3_FN_MOD_AHB */
5814 volatile uint32_t _pad_0x2c_0xff[53]; /* *UNDEFINED* */
5815 volatile uint32_t read_qos; /* ALT_L3_RD_QOS */
5816 volatile uint32_t write_qos; /* ALT_L3_WR_QOS */
5817 volatile uint32_t fn_mod; /* ALT_L3_FN_MOD */
5818};
5819
5820/* The typedef declaration for the raw register contents of register group ALT_L3_SLV_SDMMC. */
5821typedef volatile struct ALT_L3_SLV_SDMMC_raw_s ALT_L3_SLV_SDMMC_raw_t;
5822#endif /* __ASSEMBLY__ */
5823
5824
5825/*
5826 * Register Group : DMA - ALT_L3_SLV_DMA
5827 * DMA
5828 *
5829 * Registers associated with the DMA Controller slave interface. This slave is used
5830 * by the DMA Controller to access slaves attached to the L3/L4 Interconnect.
5831 *
5832 */
5833#ifndef __ASSEMBLY__
5834/*
5835 * WARNING: The C register and register group struct declarations are provided for
5836 * convenience and illustrative purposes. They should, however, be used with
5837 * caution as the C language standard provides no guarantees about the alignment or
5838 * atomicity of device memory accesses. The recommended practice for writing
5839 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
5840 * alt_write_word() functions.
5841 *
5842 * The struct declaration for register group ALT_L3_SLV_DMA.
5843 */
5845{
5846 volatile uint32_t _pad_0x0_0xff[64]; /* *UNDEFINED* */
5847 volatile ALT_L3_RD_QOS_t read_qos; /* ALT_L3_RD_QOS */
5848 volatile ALT_L3_WR_QOS_t write_qos; /* ALT_L3_WR_QOS */
5849 volatile ALT_L3_FN_MOD_t fn_mod; /* ALT_L3_FN_MOD */
5850};
5851
5852/* The typedef declaration for register group ALT_L3_SLV_DMA. */
5853typedef volatile struct ALT_L3_SLV_DMA_s ALT_L3_SLV_DMA_t;
5854/* The struct declaration for the raw register contents of register group ALT_L3_SLV_DMA. */
5856{
5857 volatile uint32_t _pad_0x0_0xff[64]; /* *UNDEFINED* */
5858 volatile uint32_t read_qos; /* ALT_L3_RD_QOS */
5859 volatile uint32_t write_qos; /* ALT_L3_WR_QOS */
5860 volatile uint32_t fn_mod; /* ALT_L3_FN_MOD */
5861};
5862
5863/* The typedef declaration for the raw register contents of register group ALT_L3_SLV_DMA. */
5864typedef volatile struct ALT_L3_SLV_DMA_raw_s ALT_L3_SLV_DMA_raw_t;
5865#endif /* __ASSEMBLY__ */
5866
5867
5868/*
5869 * Register Group : FPGA2HPS - ALT_L3_SLV_F2H
5870 * FPGA2HPS
5871 *
5872 * Registers associated with the FPGA2HPS AXI Bridge slave interface. This slave is
5873 * used by the FPGA2HPS AXI Bridge to access slaves attached to the L3/L4
5874 * Interconnect.
5875 *
5876 */
5877#ifndef __ASSEMBLY__
5878/*
5879 * WARNING: The C register and register group struct declarations are provided for
5880 * convenience and illustrative purposes. They should, however, be used with
5881 * caution as the C language standard provides no guarantees about the alignment or
5882 * atomicity of device memory accesses. The recommended practice for writing
5883 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
5884 * alt_write_word() functions.
5885 *
5886 * The struct declaration for register group ALT_L3_SLV_F2H.
5887 */
5889{
5890 volatile uint32_t _pad_0x0_0x3f[16]; /* *UNDEFINED* */
5891 volatile ALT_L3_WR_TIDEMARK_t wr_tidemark; /* ALT_L3_WR_TIDEMARK */
5892 volatile uint32_t _pad_0x44_0xff[47]; /* *UNDEFINED* */
5893 volatile ALT_L3_RD_QOS_t read_qos; /* ALT_L3_RD_QOS */
5894 volatile ALT_L3_WR_QOS_t write_qos; /* ALT_L3_WR_QOS */
5895 volatile ALT_L3_FN_MOD_t fn_mod; /* ALT_L3_FN_MOD */
5896};
5897
5898/* The typedef declaration for register group ALT_L3_SLV_F2H. */
5899typedef volatile struct ALT_L3_SLV_F2H_s ALT_L3_SLV_F2H_t;
5900/* The struct declaration for the raw register contents of register group ALT_L3_SLV_F2H. */
5902{
5903 volatile uint32_t _pad_0x0_0x3f[16]; /* *UNDEFINED* */
5904 volatile uint32_t wr_tidemark; /* ALT_L3_WR_TIDEMARK */
5905 volatile uint32_t _pad_0x44_0xff[47]; /* *UNDEFINED* */
5906 volatile uint32_t read_qos; /* ALT_L3_RD_QOS */
5907 volatile uint32_t write_qos; /* ALT_L3_WR_QOS */
5908 volatile uint32_t fn_mod; /* ALT_L3_FN_MOD */
5909};
5910
5911/* The typedef declaration for the raw register contents of register group ALT_L3_SLV_F2H. */
5912typedef volatile struct ALT_L3_SLV_F2H_raw_s ALT_L3_SLV_F2H_raw_t;
5913#endif /* __ASSEMBLY__ */
5914
5915
5916/*
5917 * Register Group : ETR - ALT_L3_SLV_ETR
5918 * ETR
5919 *
5920 * Registers associated with the ETR (TMC) slave interface. This slave is used by
5921 * the ETR to access slaves attached to the L3/L4 Interconnect.
5922 *
5923 */
5924#ifndef __ASSEMBLY__
5925/*
5926 * WARNING: The C register and register group struct declarations are provided for
5927 * convenience and illustrative purposes. They should, however, be used with
5928 * caution as the C language standard provides no guarantees about the alignment or
5929 * atomicity of device memory accesses. The recommended practice for writing
5930 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
5931 * alt_write_word() functions.
5932 *
5933 * The struct declaration for register group ALT_L3_SLV_ETR.
5934 */
5936{
5937 volatile uint32_t _pad_0x0_0xff[64]; /* *UNDEFINED* */
5938 volatile ALT_L3_RD_QOS_t read_qos; /* ALT_L3_RD_QOS */
5939 volatile ALT_L3_WR_QOS_t write_qos; /* ALT_L3_WR_QOS */
5940 volatile ALT_L3_FN_MOD_t fn_mod; /* ALT_L3_FN_MOD */
5941};
5942
5943/* The typedef declaration for register group ALT_L3_SLV_ETR. */
5944typedef volatile struct ALT_L3_SLV_ETR_s ALT_L3_SLV_ETR_t;
5945/* The struct declaration for the raw register contents of register group ALT_L3_SLV_ETR. */
5947{
5948 volatile uint32_t _pad_0x0_0xff[64]; /* *UNDEFINED* */
5949 volatile uint32_t read_qos; /* ALT_L3_RD_QOS */
5950 volatile uint32_t write_qos; /* ALT_L3_WR_QOS */
5951 volatile uint32_t fn_mod; /* ALT_L3_FN_MOD */
5952};
5953
5954/* The typedef declaration for the raw register contents of register group ALT_L3_SLV_ETR. */
5955typedef volatile struct ALT_L3_SLV_ETR_raw_s ALT_L3_SLV_ETR_raw_t;
5956#endif /* __ASSEMBLY__ */
5957
5958
5959/*
5960 * Register Group : EMAC0 - ALT_L3_SLV_EMAC0
5961 * EMAC0
5962 *
5963 * Registers associated with the EMAC0 slave interface. This slave is used by the
5964 * DMA controller built into the EMAC0 to access slaves attached to the L3/L4
5965 * Interconnect.
5966 *
5967 */
5968#ifndef __ASSEMBLY__
5969/*
5970 * WARNING: The C register and register group struct declarations are provided for
5971 * convenience and illustrative purposes. They should, however, be used with
5972 * caution as the C language standard provides no guarantees about the alignment or
5973 * atomicity of device memory accesses. The recommended practice for writing
5974 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
5975 * alt_write_word() functions.
5976 *
5977 * The struct declaration for register group ALT_L3_SLV_EMAC0.
5978 */
5980{
5981 volatile uint32_t _pad_0x0_0xff[64]; /* *UNDEFINED* */
5982 volatile ALT_L3_RD_QOS_t read_qos; /* ALT_L3_RD_QOS */
5983 volatile ALT_L3_WR_QOS_t write_qos; /* ALT_L3_WR_QOS */
5984 volatile ALT_L3_FN_MOD_t fn_mod; /* ALT_L3_FN_MOD */
5985};
5986
5987/* The typedef declaration for register group ALT_L3_SLV_EMAC0. */
5988typedef volatile struct ALT_L3_SLV_EMAC0_s ALT_L3_SLV_EMAC0_t;
5989/* The struct declaration for the raw register contents of register group ALT_L3_SLV_EMAC0. */
5991{
5992 volatile uint32_t _pad_0x0_0xff[64]; /* *UNDEFINED* */
5993 volatile uint32_t read_qos; /* ALT_L3_RD_QOS */
5994 volatile uint32_t write_qos; /* ALT_L3_WR_QOS */
5995 volatile uint32_t fn_mod; /* ALT_L3_FN_MOD */
5996};
5997
5998/* The typedef declaration for the raw register contents of register group ALT_L3_SLV_EMAC0. */
5999typedef volatile struct ALT_L3_SLV_EMAC0_raw_s ALT_L3_SLV_EMAC0_raw_t;
6000#endif /* __ASSEMBLY__ */
6001
6002
6003/*
6004 * Register Group : EMAC1 - ALT_L3_SLV_EMAC1
6005 * EMAC1
6006 *
6007 * Registers associated with the EMAC1 slave interface. This slave is used by the
6008 * DMA controller built into the EMAC1 to access slaves attached to the L3/L4
6009 * Interconnect.
6010 *
6011 */
6012#ifndef __ASSEMBLY__
6013/*
6014 * WARNING: The C register and register group struct declarations are provided for
6015 * convenience and illustrative purposes. They should, however, be used with
6016 * caution as the C language standard provides no guarantees about the alignment or
6017 * atomicity of device memory accesses. The recommended practice for writing
6018 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
6019 * alt_write_word() functions.
6020 *
6021 * The struct declaration for register group ALT_L3_SLV_EMAC1.
6022 */
6024{
6025 volatile uint32_t _pad_0x0_0xff[64]; /* *UNDEFINED* */
6026 volatile ALT_L3_RD_QOS_t read_qos; /* ALT_L3_RD_QOS */
6027 volatile ALT_L3_WR_QOS_t write_qos; /* ALT_L3_WR_QOS */
6028 volatile ALT_L3_FN_MOD_t fn_mod; /* ALT_L3_FN_MOD */
6029};
6030
6031/* The typedef declaration for register group ALT_L3_SLV_EMAC1. */
6032typedef volatile struct ALT_L3_SLV_EMAC1_s ALT_L3_SLV_EMAC1_t;
6033/* The struct declaration for the raw register contents of register group ALT_L3_SLV_EMAC1. */
6035{
6036 volatile uint32_t _pad_0x0_0xff[64]; /* *UNDEFINED* */
6037 volatile uint32_t read_qos; /* ALT_L3_RD_QOS */
6038 volatile uint32_t write_qos; /* ALT_L3_WR_QOS */
6039 volatile uint32_t fn_mod; /* ALT_L3_FN_MOD */
6040};
6041
6042/* The typedef declaration for the raw register contents of register group ALT_L3_SLV_EMAC1. */
6043typedef volatile struct ALT_L3_SLV_EMAC1_raw_s ALT_L3_SLV_EMAC1_raw_t;
6044#endif /* __ASSEMBLY__ */
6045
6046
6047/*
6048 * Register Group : USB0 - ALT_L3_SLV_USB0
6049 * USB0
6050 *
6051 * Registers associated with the USB0 slave interface. This slave is used by the
6052 * DMA controller built into the USB0 to access slaves attached to the L3/L4
6053 * Interconnect.
6054 *
6055 */
6056#ifndef __ASSEMBLY__
6057/*
6058 * WARNING: The C register and register group struct declarations are provided for
6059 * convenience and illustrative purposes. They should, however, be used with
6060 * caution as the C language standard provides no guarantees about the alignment or
6061 * atomicity of device memory accesses. The recommended practice for writing
6062 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
6063 * alt_write_word() functions.
6064 *
6065 * The struct declaration for register group ALT_L3_SLV_USB0.
6066 */
6068{
6069 volatile uint32_t _pad_0x0_0x27[10]; /* *UNDEFINED* */
6070 volatile ALT_L3_FN_MOD_AHB_t fn_mod_ahb; /* ALT_L3_FN_MOD_AHB */
6071 volatile uint32_t _pad_0x2c_0xff[53]; /* *UNDEFINED* */
6072 volatile ALT_L3_RD_QOS_t read_qos; /* ALT_L3_RD_QOS */
6073 volatile ALT_L3_WR_QOS_t write_qos; /* ALT_L3_WR_QOS */
6074 volatile ALT_L3_FN_MOD_t fn_mod; /* ALT_L3_FN_MOD */
6075};
6076
6077/* The typedef declaration for register group ALT_L3_SLV_USB0. */
6078typedef volatile struct ALT_L3_SLV_USB0_s ALT_L3_SLV_USB0_t;
6079/* The struct declaration for the raw register contents of register group ALT_L3_SLV_USB0. */
6081{
6082 volatile uint32_t _pad_0x0_0x27[10]; /* *UNDEFINED* */
6083 volatile uint32_t fn_mod_ahb; /* ALT_L3_FN_MOD_AHB */
6084 volatile uint32_t _pad_0x2c_0xff[53]; /* *UNDEFINED* */
6085 volatile uint32_t read_qos; /* ALT_L3_RD_QOS */
6086 volatile uint32_t write_qos; /* ALT_L3_WR_QOS */
6087 volatile uint32_t fn_mod; /* ALT_L3_FN_MOD */
6088};
6089
6090/* The typedef declaration for the raw register contents of register group ALT_L3_SLV_USB0. */
6091typedef volatile struct ALT_L3_SLV_USB0_raw_s ALT_L3_SLV_USB0_raw_t;
6092#endif /* __ASSEMBLY__ */
6093
6094
6095/*
6096 * Register Group : NAND - ALT_L3_SLV_NAND
6097 * NAND
6098 *
6099 * Registers associated with the NAND slave interface. This slave is used by the
6100 * DMA controller built into the NAND flash controller to access slaves attached to
6101 * the L3/L4 Interconnect.
6102 *
6103 */
6104#ifndef __ASSEMBLY__
6105/*
6106 * WARNING: The C register and register group struct declarations are provided for
6107 * convenience and illustrative purposes. They should, however, be used with
6108 * caution as the C language standard provides no guarantees about the alignment or
6109 * atomicity of device memory accesses. The recommended practice for writing
6110 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
6111 * alt_write_word() functions.
6112 *
6113 * The struct declaration for register group ALT_L3_SLV_NAND.
6114 */
6116{
6117 volatile uint32_t _pad_0x0_0xff[64]; /* *UNDEFINED* */
6118 volatile ALT_L3_RD_QOS_t read_qos; /* ALT_L3_RD_QOS */
6119 volatile ALT_L3_WR_QOS_t write_qos; /* ALT_L3_WR_QOS */
6120 volatile ALT_L3_FN_MOD_t fn_mod; /* ALT_L3_FN_MOD */
6121};
6122
6123/* The typedef declaration for register group ALT_L3_SLV_NAND. */
6124typedef volatile struct ALT_L3_SLV_NAND_s ALT_L3_SLV_NAND_t;
6125/* The struct declaration for the raw register contents of register group ALT_L3_SLV_NAND. */
6127{
6128 volatile uint32_t _pad_0x0_0xff[64]; /* *UNDEFINED* */
6129 volatile uint32_t read_qos; /* ALT_L3_RD_QOS */
6130 volatile uint32_t write_qos; /* ALT_L3_WR_QOS */
6131 volatile uint32_t fn_mod; /* ALT_L3_FN_MOD */
6132};
6133
6134/* The typedef declaration for the raw register contents of register group ALT_L3_SLV_NAND. */
6135typedef volatile struct ALT_L3_SLV_NAND_raw_s ALT_L3_SLV_NAND_raw_t;
6136#endif /* __ASSEMBLY__ */
6137
6138
6139/*
6140 * Register Group : USB1 - ALT_L3_SLV_USB1
6141 * USB1
6142 *
6143 * Registers associated with the USB1 slave interface. This slave is used by the
6144 * DMA controller built into the USB1 to access slaves attached to the L3/L4
6145 * Interconnect.
6146 *
6147 */
6148#ifndef __ASSEMBLY__
6149/*
6150 * WARNING: The C register and register group struct declarations are provided for
6151 * convenience and illustrative purposes. They should, however, be used with
6152 * caution as the C language standard provides no guarantees about the alignment or
6153 * atomicity of device memory accesses. The recommended practice for writing
6154 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
6155 * alt_write_word() functions.
6156 *
6157 * The struct declaration for register group ALT_L3_SLV_USB1.
6158 */
6160{
6161 volatile uint32_t _pad_0x0_0x27[10]; /* *UNDEFINED* */
6162 volatile ALT_L3_FN_MOD_AHB_t fn_mod_ahb; /* ALT_L3_FN_MOD_AHB */
6163 volatile uint32_t _pad_0x2c_0xff[53]; /* *UNDEFINED* */
6164 volatile ALT_L3_RD_QOS_t read_qos; /* ALT_L3_RD_QOS */
6165 volatile ALT_L3_WR_QOS_t write_qos; /* ALT_L3_WR_QOS */
6166 volatile ALT_L3_FN_MOD_t fn_mod; /* ALT_L3_FN_MOD */
6167};
6168
6169/* The typedef declaration for register group ALT_L3_SLV_USB1. */
6170typedef volatile struct ALT_L3_SLV_USB1_s ALT_L3_SLV_USB1_t;
6171/* The struct declaration for the raw register contents of register group ALT_L3_SLV_USB1. */
6173{
6174 volatile uint32_t _pad_0x0_0x27[10]; /* *UNDEFINED* */
6175 volatile uint32_t fn_mod_ahb; /* ALT_L3_FN_MOD_AHB */
6176 volatile uint32_t _pad_0x2c_0xff[53]; /* *UNDEFINED* */
6177 volatile uint32_t read_qos; /* ALT_L3_RD_QOS */
6178 volatile uint32_t write_qos; /* ALT_L3_WR_QOS */
6179 volatile uint32_t fn_mod; /* ALT_L3_FN_MOD */
6180};
6181
6182/* The typedef declaration for the raw register contents of register group ALT_L3_SLV_USB1. */
6183typedef volatile struct ALT_L3_SLV_USB1_raw_s ALT_L3_SLV_USB1_raw_t;
6184#endif /* __ASSEMBLY__ */
6185
6186
6187#ifndef __ASSEMBLY__
6188/*
6189 * WARNING: The C register and register group struct declarations are provided for
6190 * convenience and illustrative purposes. They should, however, be used with
6191 * caution as the C language standard provides no guarantees about the alignment or
6192 * atomicity of device memory accesses. The recommended practice for writing
6193 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
6194 * alt_write_word() functions.
6195 *
6196 * The struct declaration for register group ALT_L3_SLVGRP.
6197 */
6199{
6200 volatile ALT_L3_SLV_DAP_t slavegrp_dap; /* ALT_L3_SLV_DAP */
6201 volatile uint32_t _pad_0x10c_0xfff[957]; /* *UNDEFINED* */
6202 volatile ALT_L3_SLV_MPU_t slavegrp_mpu; /* ALT_L3_SLV_MPU */
6203 volatile uint32_t _pad_0x110c_0x1fff[957]; /* *UNDEFINED* */
6204 volatile ALT_L3_SLV_SDMMC_t slavegrp_sdmmc; /* ALT_L3_SLV_SDMMC */
6205 volatile uint32_t _pad_0x210c_0x2fff[957]; /* *UNDEFINED* */
6206 volatile ALT_L3_SLV_DMA_t slavegrp_dma; /* ALT_L3_SLV_DMA */
6207 volatile uint32_t _pad_0x310c_0x3fff[957]; /* *UNDEFINED* */
6208 volatile ALT_L3_SLV_F2H_t slavegrp_fpga2hps; /* ALT_L3_SLV_F2H */
6209 volatile uint32_t _pad_0x410c_0x4fff[957]; /* *UNDEFINED* */
6210 volatile ALT_L3_SLV_ETR_t slavegrp_etr; /* ALT_L3_SLV_ETR */
6211 volatile uint32_t _pad_0x510c_0x5fff[957]; /* *UNDEFINED* */
6212 volatile ALT_L3_SLV_EMAC0_t slavegrp_emac0; /* ALT_L3_SLV_EMAC0 */
6213 volatile uint32_t _pad_0x610c_0x6fff[957]; /* *UNDEFINED* */
6214 volatile ALT_L3_SLV_EMAC1_t slavegrp_emac1; /* ALT_L3_SLV_EMAC1 */
6215 volatile uint32_t _pad_0x710c_0x7fff[957]; /* *UNDEFINED* */
6216 volatile ALT_L3_SLV_USB0_t slavegrp_usb0; /* ALT_L3_SLV_USB0 */
6217 volatile uint32_t _pad_0x810c_0x8fff[957]; /* *UNDEFINED* */
6218 volatile ALT_L3_SLV_NAND_t slavegrp_nand; /* ALT_L3_SLV_NAND */
6219 volatile uint32_t _pad_0x910c_0x9fff[957]; /* *UNDEFINED* */
6220 volatile ALT_L3_SLV_USB1_t slavegrp_usb1; /* ALT_L3_SLV_USB1 */
6221};
6222
6223/* The typedef declaration for register group ALT_L3_SLVGRP. */
6224typedef volatile struct ALT_L3_SLVGRP_s ALT_L3_SLVGRP_t;
6225/* The struct declaration for the raw register contents of register group ALT_L3_SLVGRP. */
6227{
6228 volatile ALT_L3_SLV_DAP_raw_t slavegrp_dap; /* ALT_L3_SLV_DAP */
6229 volatile uint32_t _pad_0x10c_0xfff[957]; /* *UNDEFINED* */
6230 volatile ALT_L3_SLV_MPU_raw_t slavegrp_mpu; /* ALT_L3_SLV_MPU */
6231 volatile uint32_t _pad_0x110c_0x1fff[957]; /* *UNDEFINED* */
6232 volatile ALT_L3_SLV_SDMMC_raw_t slavegrp_sdmmc; /* ALT_L3_SLV_SDMMC */
6233 volatile uint32_t _pad_0x210c_0x2fff[957]; /* *UNDEFINED* */
6234 volatile ALT_L3_SLV_DMA_raw_t slavegrp_dma; /* ALT_L3_SLV_DMA */
6235 volatile uint32_t _pad_0x310c_0x3fff[957]; /* *UNDEFINED* */
6236 volatile ALT_L3_SLV_F2H_raw_t slavegrp_fpga2hps; /* ALT_L3_SLV_F2H */
6237 volatile uint32_t _pad_0x410c_0x4fff[957]; /* *UNDEFINED* */
6238 volatile ALT_L3_SLV_ETR_raw_t slavegrp_etr; /* ALT_L3_SLV_ETR */
6239 volatile uint32_t _pad_0x510c_0x5fff[957]; /* *UNDEFINED* */
6240 volatile ALT_L3_SLV_EMAC0_raw_t slavegrp_emac0; /* ALT_L3_SLV_EMAC0 */
6241 volatile uint32_t _pad_0x610c_0x6fff[957]; /* *UNDEFINED* */
6242 volatile ALT_L3_SLV_EMAC1_raw_t slavegrp_emac1; /* ALT_L3_SLV_EMAC1 */
6243 volatile uint32_t _pad_0x710c_0x7fff[957]; /* *UNDEFINED* */
6244 volatile ALT_L3_SLV_USB0_raw_t slavegrp_usb0; /* ALT_L3_SLV_USB0 */
6245 volatile uint32_t _pad_0x810c_0x8fff[957]; /* *UNDEFINED* */
6246 volatile ALT_L3_SLV_NAND_raw_t slavegrp_nand; /* ALT_L3_SLV_NAND */
6247 volatile uint32_t _pad_0x910c_0x9fff[957]; /* *UNDEFINED* */
6248 volatile ALT_L3_SLV_USB1_raw_t slavegrp_usb1; /* ALT_L3_SLV_USB1 */
6249};
6250
6251/* The typedef declaration for the raw register contents of register group ALT_L3_SLVGRP. */
6252typedef volatile struct ALT_L3_SLVGRP_raw_s ALT_L3_SLVGRP_raw_t;
6253#endif /* __ASSEMBLY__ */
6254
6255
6256#ifndef __ASSEMBLY__
6257/*
6258 * WARNING: The C register and register group struct declarations are provided for
6259 * convenience and illustrative purposes. They should, however, be used with
6260 * caution as the C language standard provides no guarantees about the alignment or
6261 * atomicity of device memory accesses. The recommended practice for writing
6262 * hardware drivers is to use the SoCAL access macros and alt_read_word() and
6263 * alt_write_word() functions.
6264 *
6265 * The struct declaration for register group ALT_L3.
6266 */
6268{
6269 volatile ALT_L3_REMAP_t remap; /* ALT_L3_REMAP */
6270 volatile uint32_t _pad_0x4_0x7; /* *UNDEFINED* */
6271 volatile ALT_L3_SECGRP_t secgrp; /* ALT_L3_SECGRP */
6272 volatile uint32_t _pad_0xa4_0xfff[983]; /* *UNDEFINED* */
6273 volatile ALT_L3_IDGRP_t idgrp; /* ALT_L3_IDGRP */
6274 volatile ALT_L3_MSTGRP_t mastergrp; /* ALT_L3_MSTGRP */
6275 volatile uint32_t _pad_0x2710c_0x41fff[27581]; /* *UNDEFINED* */
6276 volatile ALT_L3_SLVGRP_t slavegrp; /* ALT_L3_SLVGRP */
6277 volatile uint32_t _pad_0x4c10c_0x80000[53181]; /* *UNDEFINED* */
6278};
6279
6280/* The typedef declaration for register group ALT_L3. */
6281typedef volatile struct ALT_L3_s ALT_L3_t;
6282/* The struct declaration for the raw register contents of register group ALT_L3. */
6284{
6285 volatile uint32_t remap; /* ALT_L3_REMAP */
6286 volatile uint32_t _pad_0x4_0x7; /* *UNDEFINED* */
6287 volatile ALT_L3_SECGRP_raw_t secgrp; /* ALT_L3_SECGRP */
6288 volatile uint32_t _pad_0xa4_0xfff[983]; /* *UNDEFINED* */
6289 volatile ALT_L3_IDGRP_raw_t idgrp; /* ALT_L3_IDGRP */
6290 volatile ALT_L3_MSTGRP_raw_t mastergrp; /* ALT_L3_MSTGRP */
6291 volatile uint32_t _pad_0x2710c_0x41fff[27581]; /* *UNDEFINED* */
6292 volatile ALT_L3_SLVGRP_raw_t slavegrp; /* ALT_L3_SLVGRP */
6293 volatile uint32_t _pad_0x4c10c_0x80000[53181]; /* *UNDEFINED* */
6294};
6295
6296/* The typedef declaration for the raw register contents of register group ALT_L3. */
6297typedef volatile struct ALT_L3_raw_s ALT_L3_raw_t;
6298#endif /* __ASSEMBLY__ */
6299
6300
6301#ifdef __cplusplus
6302}
6303#endif /* __cplusplus */
6304#endif /* __ALTERA_ALT_L3_H__ */
6305
Definition: alt_l3.h:4708
Definition: alt_l3.h:5406
Definition: alt_l3.h:5548
Definition: alt_l3.h:4160
Definition: alt_l3.h:4483
Definition: alt_l3.h:4012
Definition: alt_l3.h:3994
Definition: alt_l3.h:3784
Definition: alt_l3.h:3846
Definition: alt_l3.h:3908
Definition: alt_l3.h:3970
Definition: alt_l3.h:3509
Definition: alt_l3.h:3571
Definition: alt_l3.h:3633
Definition: alt_l3.h:3721
Definition: alt_l3.h:3447
Definition: alt_l3.h:5277
Definition: alt_l3.h:5237
Definition: alt_l3.h:5123
Definition: alt_l3.h:5112
Definition: alt_l3.h:5030
Definition: alt_l3.h:5017
Definition: alt_l3.h:5078
Definition: alt_l3.h:5065
Definition: alt_l3.h:4196
Definition: alt_l3.h:4187
Definition: alt_l3.h:4274
Definition: alt_l3.h:4265
Definition: alt_l3.h:4313
Definition: alt_l3.h:4304
Definition: alt_l3.h:4352
Definition: alt_l3.h:4343
Definition: alt_l3.h:4235
Definition: alt_l3.h:4226
Definition: alt_l3.h:4566
Definition: alt_l3.h:4555
Definition: alt_l3.h:4789
Definition: alt_l3.h:4778
Definition: alt_l3.h:4875
Definition: alt_l3.h:4864
Definition: alt_l3.h:5211
Definition: alt_l3.h:5198
Definition: alt_l3.h:4918
Definition: alt_l3.h:4907
Definition: alt_l3.h:5166
Definition: alt_l3.h:5155
Definition: alt_l3.h:4521
Definition: alt_l3.h:4510
Definition: alt_l3.h:4832
Definition: alt_l3.h:4821
Definition: alt_l3.h:4746
Definition: alt_l3.h:4735
Definition: alt_l3.h:5614
Definition: alt_l3.h:298
Definition: alt_l3.h:3362
Definition: alt_l3.h:3335
Definition: alt_l3.h:3059
Definition: alt_l3.h:2890
Definition: alt_l3.h:2975
Definition: alt_l3.h:538
Definition: alt_l3.h:1637
Definition: alt_l3.h:2023
Definition: alt_l3.h:2209
Definition: alt_l3.h:1108
Definition: alt_l3.h:2380
Definition: alt_l3.h:2550
Definition: alt_l3.h:2720
Definition: alt_l3.h:3227
Definition: alt_l3.h:2805
Definition: alt_l3.h:3143
Definition: alt_l3.h:3311
Definition: alt_l3.h:2295
Definition: alt_l3.h:2635
Definition: alt_l3.h:2465
Definition: alt_l3.h:6227
Definition: alt_l3.h:6199
Definition: alt_l3.h:5719
Definition: alt_l3.h:5705
Definition: alt_l3.h:5856
Definition: alt_l3.h:5845
Definition: alt_l3.h:5991
Definition: alt_l3.h:5980
Definition: alt_l3.h:6035
Definition: alt_l3.h:6024
Definition: alt_l3.h:5947
Definition: alt_l3.h:5936
Definition: alt_l3.h:5902
Definition: alt_l3.h:5889
Definition: alt_l3.h:5765
Definition: alt_l3.h:5754
Definition: alt_l3.h:6127
Definition: alt_l3.h:6116
Definition: alt_l3.h:5811
Definition: alt_l3.h:5798
Definition: alt_l3.h:6081
Definition: alt_l3.h:6068
Definition: alt_l3.h:6173
Definition: alt_l3.h:6160
Definition: alt_l3.h:5679
Definition: alt_l3.h:4991
Definition: alt_l3.h:6284
Definition: alt_l3.h:6268
