RTEMS 6.1
alt_interrupt_common.h
1
7/******************************************************************************
8*
9* Copyright 2013 Altera Corporation. All Rights Reserved.
10*
11* Redistribution and use in source and binary forms, with or without
12* modification, are permitted provided that the following conditions are met:
13*
14* 1. Redistributions of source code must retain the above copyright notice,
15* this list of conditions and the following disclaimer.
16*
17* 2. Redistributions in binary form must reproduce the above copyright notice,
18* this list of conditions and the following disclaimer in the documentation
19* and/or other materials provided with the distribution.
20*
21* 3. The name of the author may not be used to endorse or promote products
22* derived from this software without specific prior written permission.
23*
24* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDER "AS IS" AND ANY EXPRESS OR
25* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
26* MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE, ARE DISCLAIMED. IN NO
27* EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
28* EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT
29* OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
30* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
31* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING
32* IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
33* OF SUCH DAMAGE.
34*
35******************************************************************************/
36
37#ifndef __ALT_INT_COMMON_H__
38#define __ALT_INT_COMMON_H__
39
40#include "hwlib.h"
41#include <stdbool.h>
42#include <stddef.h>
43
44#ifdef __cplusplus
45extern "C"
46{
47#endif
48
62{
430
437typedef uint32_t alt_int_cpu_target_t;
438
443{
450
457
463
472
480
489{
495
501
509
513#define ALT_INT_ICCIAR_CPUID_GET(icciar) ((icciar >> 10) & 0x7)
514
518#define ALT_INT_ICCIAR_ACKINTID_GET(icciar) (icciar & 0x3FF)
519
529typedef void (*alt_int_callback_t)(uint32_t icciar, void * context);
530
535#ifdef __cplusplus
536}
537#endif
538
539#endif /* __ALT_INT_COMMON_H__ */
Definition: alt_interrupt_common.h:437
enum ALT_INT_INTERRUPT_e ALT_INT_INTERRUPT_t
enum ALT_INT_TRIGGER_e ALT_INT_TRIGGER_t
ALT_INT_TRIGGER_e
Definition: alt_interrupt_common.h:443
ALT_INT_SGI_TARGET_e
Definition: alt_interrupt_common.h:489
void(* alt_int_callback_t)(uint32_t icciar, void *context)
Definition: alt_interrupt_common.h:529
enum ALT_INT_SGI_TARGET_e ALT_INT_SGI_TARGET_t
ALT_INT_INTERRUPT_e
Definition: alt_interrupt_common.h:62
@ ALT_INT_TRIGGER_LEVEL
Definition: alt_interrupt_common.h:456
@ ALT_INT_TRIGGER_SOFTWARE
Definition: alt_interrupt_common.h:462
@ ALT_INT_TRIGGER_EDGE
Definition: alt_interrupt_common.h:449
@ ALT_INT_TRIGGER_AUTODETECT
Definition: alt_interrupt_common.h:471
@ ALT_INT_TRIGGER_NA
Definition: alt_interrupt_common.h:477
@ ALT_INT_SGI_TARGET_SENDER_ONLY
Definition: alt_interrupt_common.h:506
@ ALT_INT_SGI_TARGET_ALL_EXCL_SENDER
Definition: alt_interrupt_common.h:500
@ ALT_INT_SGI_TARGET_LIST
Definition: alt_interrupt_common.h:494
@ ALT_INT_INTERRUPT_EMAC1_TX_ECC_UNCORRECTED_IRQ
Definition: alt_interrupt_common.h:274
@ ALT_INT_INTERRUPT_F2S_FPGA_IRQ26
Definition: alt_interrupt_common.h:203
@ ALT_INT_INTERRUPT_L2_ECC_BYTE_WR_IRQ
Definition: alt_interrupt_common.h:155
@ ALT_INT_INTERRUPT_CPU0_DEFLAGS1
Definition: alt_interrupt_common.h:103
@ ALT_INT_INTERRUPT_DMA_IRQ2
Definition: alt_interrupt_common.h:248
@ ALT_INT_INTERRUPT_F2S_FPGA_IRQ31
Definition: alt_interrupt_common.h:208
@ ALT_INT_INTERRUPT_F2S_FPGA_IRQ36
Definition: alt_interrupt_common.h:213
@ ALT_INT_INTERRUPT_CPU1_PARITYFAIL_I_TAG
Definition: alt_interrupt_common.h:123
@ ALT_INT_INTERRUPT_CPU0_PARITYFAIL_I_TAG
Definition: alt_interrupt_common.h:96
@ ALT_INT_INTERRUPT_TIMER_OSC1_1_IRQ
Definition: alt_interrupt_common.h:384
@ ALT_INT_INTERRUPT_F2S_FPGA_IRQ20
Definition: alt_interrupt_common.h:197
@ ALT_INT_INTERRUPT_USB0_IRQ
Definition: alt_interrupt_common.h:282
@ ALT_INT_INTERRUPT_SGI9
Definition: alt_interrupt_common.h:72
@ ALT_INT_INTERRUPT_NANDW_ECC_UNCORRECTED_IRQ
Definition: alt_interrupt_common.h:330
@ ALT_INT_INTERRUPT_DMA_IRQ0
Definition: alt_interrupt_common.h:246
@ ALT_INT_INTERRUPT_CPU1_PARITYFAIL_TLB
Definition: alt_interrupt_common.h:125
@ ALT_INT_INTERRUPT_F2S_FPGA_IRQ6
Definition: alt_interrupt_common.h:183
@ ALT_INT_INTERRUPT_CPU0_DEFLAGS5
Definition: alt_interrupt_common.h:107
@ ALT_INT_INTERRUPT_QSPI_ECC_UNCORRECTED_IRQ
Definition: alt_interrupt_common.h:340
@ ALT_INT_INTERRUPT_F2S_FPGA_IRQ56
Definition: alt_interrupt_common.h:233
@ ALT_INT_INTERRUPT_F2S_FPGA_IRQ17
Definition: alt_interrupt_common.h:194
@ ALT_INT_INTERRUPT_F2S_FPGA_IRQ34
Definition: alt_interrupt_common.h:211
@ ALT_INT_INTERRUPT_SGI5
Definition: alt_interrupt_common.h:68
@ ALT_INT_INTERRUPT_CAN0_STS_IRQ
Definition: alt_interrupt_common.h:298
@ ALT_INT_INTERRUPT_PPI_TIMER_WATCHDOG
Definition: alt_interrupt_common.h:86
@ ALT_INT_INTERRUPT_DMA_ECC_UNCORRECTED_IRQ
Definition: alt_interrupt_common.h:256
@ ALT_INT_INTERRUPT_F2S_FPGA_IRQ4
Definition: alt_interrupt_common.h:181
@ ALT_INT_INTERRUPT_F2S_FPGA_IRQ13
Definition: alt_interrupt_common.h:190
@ ALT_INT_INTERRUPT_CAN1_ECC_CORRECTED_IRQ
Definition: alt_interrupt_common.h:309
@ ALT_INT_INTERRUPT_CPU0_PARITYFAIL_D_TAG
Definition: alt_interrupt_common.h:100
@ ALT_INT_INTERRUPT_F2S_FPGA_IRQ41
Definition: alt_interrupt_common.h:218
@ ALT_INT_INTERRUPT_NANDR_ECC_UNCORRECTED_IRQ
Definition: alt_interrupt_common.h:328
@ ALT_INT_INTERRUPT_F2S_FPGA_IRQ55
Definition: alt_interrupt_common.h:232
@ ALT_INT_INTERRUPT_F2S_FPGA_IRQ42
Definition: alt_interrupt_common.h:219
@ ALT_INT_INTERRUPT_PPI_TIMER_GLOBAL
Definition: alt_interrupt_common.h:84
@ ALT_INT_INTERRUPT_L2_COMBINED_IRQ
Definition: alt_interrupt_common.h:158
@ ALT_INT_INTERRUPT_SCU_PARITYFAIL0
Definition: alt_interrupt_common.h:147
@ ALT_INT_INTERRUPT_CPU0_DEFLAGS4
Definition: alt_interrupt_common.h:106
@ ALT_INT_INTERRUPT_RAM_ECC_CORRECTED_IRQ
Definition: alt_interrupt_common.h:422
@ ALT_INT_INTERRUPT_SGI3
Definition: alt_interrupt_common.h:66
@ ALT_INT_INTERRUPT_L2_ECC_UNCORRECTED_IRQ
Definition: alt_interrupt_common.h:157
@ ALT_INT_INTERRUPT_DMA_IRQ6
Definition: alt_interrupt_common.h:252
@ ALT_INT_INTERRUPT_NANDE_ECC_CORRECTED_IRQ
Definition: alt_interrupt_common.h:331
@ ALT_INT_INTERRUPT_F2S_FPGA_IRQ0
Definition: alt_interrupt_common.h:177
@ ALT_INT_INTERRUPT_CPU1_PARITYFAIL_GHB
Definition: alt_interrupt_common.h:122
@ ALT_INT_INTERRUPT_F2S_FPGA_IRQ48
Definition: alt_interrupt_common.h:225
Definition: alt_interrupt_common.h:93
@ ALT_INT_INTERRUPT_SDMMC_PORTB_ECC_UNCORRECTED
Definition: alt_interrupt_common.h:320
@ ALT_INT_INTERRUPT_EMAC0_TX_ECC_UNCORRECTED_IRQ
Definition: alt_interrupt_common.h:264
@ ALT_INT_INTERRUPT_EMAC1_TX_ECC_CORRECTED_IRQ
Definition: alt_interrupt_common.h:273
@ ALT_INT_INTERRUPT_CPU0_PARITYFAIL_D_DATA
Definition: alt_interrupt_common.h:101
@ ALT_INT_INTERRUPT_CPU1_DEFLAGS6
Definition: alt_interrupt_common.h:135
@ ALT_INT_INTERRUPT_F2S_FPGA_IRQ63
Definition: alt_interrupt_common.h:240
@ ALT_INT_INTERRUPT_SPI0_IRQ
Definition: alt_interrupt_common.h:346
@ ALT_INT_INTERRUPT_UART1
Definition: alt_interrupt_common.h:367
@ ALT_INT_INTERRUPT_F2S_FPGA_IRQ47
Definition: alt_interrupt_common.h:224
@ ALT_INT_INTERRUPT_QSPI_IRQ
Definition: alt_interrupt_common.h:338
@ ALT_INT_INTERRUPT_F2S_FPGA_IRQ8
Definition: alt_interrupt_common.h:185
Definition: alt_interrupt_common.h:180
@ ALT_INT_INTERRUPT_F2S_FPGA_IRQ18
Definition: alt_interrupt_common.h:195
@ ALT_INT_INTERRUPT_CPU0_PARITYFAIL_D_OUTER
Definition: alt_interrupt_common.h:99
@ ALT_INT_INTERRUPT_CPU1_DEFLAGS4
Definition: alt_interrupt_common.h:133
@ ALT_INT_INTERRUPT_SGI12
Definition: alt_interrupt_common.h:75
@ ALT_INT_INTERRUPT_F2S_FPGA_IRQ60
Definition: alt_interrupt_common.h:237
@ ALT_INT_INTERRUPT_SGI4
Definition: alt_interrupt_common.h:67
@ ALT_INT_INTERRUPT_I2C3_IRQ
Definition: alt_interrupt_common.h:360
@ ALT_INT_INTERRUPT_CPU1_PARITYFAIL_BTAC
Definition: alt_interrupt_common.h:121
@ ALT_INT_INTERRUPT_SPI1_IRQ
Definition: alt_interrupt_common.h:347
@ ALT_INT_INTERRUPT_CPU1_DEFLAGS1
Definition: alt_interrupt_common.h:130
Definition: alt_interrupt_common.h:64
@ ALT_INT_INTERRUPT_CPU1_PARITYFAIL_D_DATA
Definition: alt_interrupt_common.h:128
@ ALT_INT_INTERRUPT_CLKMGR_IRQ
Definition: alt_interrupt_common.h:397
@ ALT_INT_INTERRUPT_SDMMC_PORTA_ECC_UNCORRECTED
Definition: alt_interrupt_common.h:318
@ ALT_INT_INTERRUPT_F2S_FPGA_IRQ57
Definition: alt_interrupt_common.h:234
@ ALT_INT_INTERRUPT_F2S_FPGA_IRQ59
Definition: alt_interrupt_common.h:236
@ ALT_INT_INTERRUPT_F2S_FPGA_IRQ11
Definition: alt_interrupt_common.h:188
@ ALT_INT_INTERRUPT_F2S_FPGA_IRQ51
Definition: alt_interrupt_common.h:228
@ ALT_INT_INTERRUPT_I2C2_IRQ
Definition: alt_interrupt_common.h:359
@ ALT_INT_INTERRUPT_EMAC0_RX_ECC_CORRECTED_IRQ
Definition: alt_interrupt_common.h:265
@ ALT_INT_INTERRUPT_SGI15
Definition: alt_interrupt_common.h:78
@ ALT_INT_INTERRUPT_SCU_EV_ABORT
Definition: alt_interrupt_common.h:149
@ ALT_INT_INTERRUPT_CPU0_DEFLAGS6
Definition: alt_interrupt_common.h:108
@ ALT_INT_INTERRUPT_WDOG1_IRQ
Definition: alt_interrupt_common.h:391
@ ALT_INT_INTERRUPT_F2S_FPGA_IRQ16
Definition: alt_interrupt_common.h:193
@ ALT_INT_INTERRUPT_CPU0_DEFLAGS3
Definition: alt_interrupt_common.h:105
@ ALT_INT_INTERRUPT_PPI_TIMER_PRIVATE
Definition: alt_interrupt_common.h:85
@ ALT_INT_INTERRUPT_NANDW_ECC_CORRECTED_IRQ
Definition: alt_interrupt_common.h:329
@ ALT_INT_INTERRUPT_CPU1_DEFLAGS0
Definition: alt_interrupt_common.h:129
@ ALT_INT_INTERRUPT_SGI2
Definition: alt_interrupt_common.h:65
@ ALT_INT_INTERRUPT_SDMMC_PORTA_ECC_CORRECTED
Definition: alt_interrupt_common.h:317
@ ALT_INT_INTERRUPT_F2S_FPGA_IRQ21
Definition: alt_interrupt_common.h:198
@ ALT_INT_INTERRUPT_WDOG0_IRQ
Definition: alt_interrupt_common.h:390
@ ALT_INT_INTERRUPT_EMAC0_IRQ
Definition: alt_interrupt_common.h:262
@ ALT_INT_INTERRUPT_DMA_IRQ5
Definition: alt_interrupt_common.h:251
@ ALT_INT_INTERRUPT_CPU0_PARITYFAIL_I_DATA
Definition: alt_interrupt_common.h:97
@ ALT_INT_INTERRUPT_SGI0
Definition: alt_interrupt_common.h:63
@ ALT_INT_INTERRUPT_CPU1_PARITYFAIL_D_TAG
Definition: alt_interrupt_common.h:127
@ ALT_INT_INTERRUPT_GPIO1
Definition: alt_interrupt_common.h:374
@ ALT_INT_INTERRUPT_F2S_FPGA_IRQ43
Definition: alt_interrupt_common.h:220
@ ALT_INT_INTERRUPT_NCTIIRQ1
Definition: alt_interrupt_common.h:416
@ ALT_INT_INTERRUPT_GPIO0
Definition: alt_interrupt_common.h:373
@ ALT_INT_INTERRUPT_TIMER_OSC1_0_IRQ
Definition: alt_interrupt_common.h:383
@ ALT_INT_INTERRUPT_DMA_IRQ1
Definition: alt_interrupt_common.h:247
@ ALT_INT_INTERRUPT_F2S_FPGA_IRQ53
Definition: alt_interrupt_common.h:230
@ ALT_INT_INTERRUPT_F2S_FPGA_IRQ12
Definition: alt_interrupt_common.h:189
@ ALT_INT_INTERRUPT_F2S_FPGA_IRQ32
Definition: alt_interrupt_common.h:209
@ ALT_INT_INTERRUPT_F2S_FPGA_IRQ35
Definition: alt_interrupt_common.h:212
@ ALT_INT_INTERRUPT_SDMMC_PORTB_ECC_CORRECTED
Definition: alt_interrupt_common.h:319
@ ALT_INT_INTERRUPT_CPU0_DEFLAGS0
Definition: alt_interrupt_common.h:102
@ ALT_INT_INTERRUPT_CPU1_PARITYFAIL_D_OUTER
Definition: alt_interrupt_common.h:126
@ ALT_INT_INTERRUPT_CPU1_PARITYFAIL_I_DATA
Definition: alt_interrupt_common.h:124
@ ALT_INT_INTERRUPT_UART0
Definition: alt_interrupt_common.h:366
@ ALT_INT_INTERRUPT_SGI13
Definition: alt_interrupt_common.h:76
@ ALT_INT_INTERRUPT_F2S_FPGA_IRQ37
Definition: alt_interrupt_common.h:214
@ ALT_INT_INTERRUPT_I2C1_IRQ
Definition: alt_interrupt_common.h:358
@ ALT_INT_INTERRUPT_F2S_FPGA_IRQ7
Definition: alt_interrupt_common.h:184
@ ALT_INT_INTERRUPT_EMAC1_RX_ECC_CORRECTED_IRQ
Definition: alt_interrupt_common.h:275
@ ALT_INT_INTERRUPT_F2S_FPGA_IRQ50
Definition: alt_interrupt_common.h:227
@ ALT_INT_INTERRUPT_F2S_FPGA_IRQ9
Definition: alt_interrupt_common.h:186
@ ALT_INT_INTERRUPT_CAN0_MO_IRQ
Definition: alt_interrupt_common.h:299
@ ALT_INT_INTERRUPT_GPIO2
Definition: alt_interrupt_common.h:375
@ ALT_INT_INTERRUPT_SGI6
Definition: alt_interrupt_common.h:69
@ ALT_INT_INTERRUPT_SGI7
Definition: alt_interrupt_common.h:70
@ ALT_INT_INTERRUPT_SGI10
Definition: alt_interrupt_common.h:73
@ ALT_INT_INTERRUPT_SGI14
Definition: alt_interrupt_common.h:77
@ ALT_INT_INTERRUPT_DMA_IRQ_ABORT
Definition: alt_interrupt_common.h:254
@ ALT_INT_INTERRUPT_CAN1_STS_IRQ
Definition: alt_interrupt_common.h:307
@ ALT_INT_INTERRUPT_NCTIIRQ0
Definition: alt_interrupt_common.h:415
@ ALT_INT_INTERRUPT_F2S_FPGA_IRQ49
Definition: alt_interrupt_common.h:226
@ ALT_INT_INTERRUPT_F2S_FPGA_IRQ38
Definition: alt_interrupt_common.h:215
@ ALT_INT_INTERRUPT_CPU1_DEFLAGS5
Definition: alt_interrupt_common.h:134
@ ALT_INT_INTERRUPT_F2S_FPGA_IRQ54
Definition: alt_interrupt_common.h:231
@ ALT_INT_INTERRUPT_FPGA_MAN_IRQ
Definition: alt_interrupt_common.h:409
@ ALT_INT_INTERRUPT_CAN0_ECC_CORRECTED_IRQ
Definition: alt_interrupt_common.h:300
@ ALT_INT_INTERRUPT_USB1_ECC_CORRECTED
Definition: alt_interrupt_common.h:291
@ ALT_INT_INTERRUPT_SCU_PARITYFAIL1
Definition: alt_interrupt_common.h:148
@ ALT_INT_INTERRUPT_F2S_FPGA_IRQ29
Definition: alt_interrupt_common.h:206
@ ALT_INT_INTERRUPT_NANDE_ECC_UNCORRECTED_IRQ
Definition: alt_interrupt_common.h:332
@ ALT_INT_INTERRUPT_CAN1_MO_IRQ
Definition: alt_interrupt_common.h:308
@ ALT_INT_INTERRUPT_F2S_FPGA_IRQ22
Definition: alt_interrupt_common.h:199
@ ALT_INT_INTERRUPT_L2_ECC_CORRECTED_IRQ
Definition: alt_interrupt_common.h:156
@ ALT_INT_INTERRUPT_CAN1_ECC_UNCORRECTED_IRQ
Definition: alt_interrupt_common.h:310
@ ALT_INT_INTERRUPT_USB0_ECC_CORRECTED
Definition: alt_interrupt_common.h:283
@ ALT_INT_INTERRUPT_CPU0_DEFLAGS2
Definition: alt_interrupt_common.h:104
@ ALT_INT_INTERRUPT_F2S_FPGA_IRQ30
Definition: alt_interrupt_common.h:207
@ ALT_INT_INTERRUPT_SPI2_IRQ
Definition: alt_interrupt_common.h:348
@ ALT_INT_INTERRUPT_F2S_FPGA_IRQ62
Definition: alt_interrupt_common.h:239
@ ALT_INT_INTERRUPT_CAN0_ECC_UNCORRECTED_IRQ
Definition: alt_interrupt_common.h:301
@ ALT_INT_INTERRUPT_USB1_IRQ
Definition: alt_interrupt_common.h:290
@ ALT_INT_INTERRUPT_USB1_ECC_UNCORRECTED
Definition: alt_interrupt_common.h:292
@ ALT_INT_INTERRUPT_DMA_IRQ3
Definition: alt_interrupt_common.h:249
@ ALT_INT_INTERRUPT_F2S_FPGA_IRQ58
Definition: alt_interrupt_common.h:235
@ ALT_INT_INTERRUPT_DMA_IRQ4
Definition: alt_interrupt_common.h:250
@ ALT_INT_INTERRUPT_F2S_FPGA_IRQ52
Definition: alt_interrupt_common.h:229
@ ALT_INT_INTERRUPT_NAND_IRQ
Definition: alt_interrupt_common.h:326
@ ALT_INT_INTERRUPT_F2S_FPGA_IRQ25
Definition: alt_interrupt_common.h:202
@ ALT_INT_INTERRUPT_QSPI_ECC_CORRECTED_IRQ
Definition: alt_interrupt_common.h:339
@ ALT_INT_INTERRUPT_DMA_IRQ7
Definition: alt_interrupt_common.h:253
@ ALT_INT_INTERRUPT_EMAC0_TX_ECC_CORRECTED_IRQ
Definition: alt_interrupt_common.h:263
Definition: alt_interrupt_common.h:178
@ ALT_INT_INTERRUPT_CPU1_DEFLAGS2
Definition: alt_interrupt_common.h:131
@ ALT_INT_INTERRUPT_F2S_FPGA_IRQ44
Definition: alt_interrupt_common.h:221
@ ALT_INT_INTERRUPT_USB0_ECC_UNCORRECTED
Definition: alt_interrupt_common.h:284
@ ALT_INT_INTERRUPT_EMAC0_RX_ECC_UNCORRECTED_IRQ
Definition: alt_interrupt_common.h:266
@ ALT_INT_INTERRUPT_TIMER_L4SP_1_IRQ
Definition: alt_interrupt_common.h:382
@ ALT_INT_INTERRUPT_CPU0_PARITYFAIL_BTAC
Definition: alt_interrupt_common.h:94
Definition: alt_interrupt_common.h:182
@ ALT_INT_INTERRUPT_DDR_ECC_ERROR_IRQ
Definition: alt_interrupt_common.h:171
@ ALT_INT_INTERRUPT_DMA_ECC_CORRECTED_IRQ
Definition: alt_interrupt_common.h:255
@ ALT_INT_INTERRUPT_TIMER_L4SP_0_IRQ
Definition: alt_interrupt_common.h:381
@ ALT_INT_INTERRUPT_I2C0_IRQ
Definition: alt_interrupt_common.h:357
@ ALT_INT_INTERRUPT_F2S_FPGA_IRQ40
Definition: alt_interrupt_common.h:217
@ ALT_INT_INTERRUPT_CPU0_PARITYFAIL_TLB
Definition: alt_interrupt_common.h:98
@ ALT_INT_INTERRUPT_F2S_FPGA_IRQ33
Definition: alt_interrupt_common.h:210
@ ALT_INT_INTERRUPT_F2S_FPGA_IRQ14
Definition: alt_interrupt_common.h:191
@ ALT_INT_INTERRUPT_MPUWAKEUP_IRQ
Definition: alt_interrupt_common.h:403
@ ALT_INT_INTERRUPT_F2S_FPGA_IRQ24
Definition: alt_interrupt_common.h:201
@ ALT_INT_INTERRUPT_CPU0_PARITYFAIL_GHB
Definition: alt_interrupt_common.h:95
@ ALT_INT_INTERRUPT_SGI8
Definition: alt_interrupt_common.h:71
Definition: alt_interrupt_common.h:179
@ ALT_INT_INTERRUPT_SPI3_IRQ
Definition: alt_interrupt_common.h:349
@ ALT_INT_INTERRUPT_EMAC1_IRQ
Definition: alt_interrupt_common.h:272
Definition: alt_interrupt_common.h:120
@ ALT_INT_INTERRUPT_F2S_FPGA_IRQ46
Definition: alt_interrupt_common.h:223
@ ALT_INT_INTERRUPT_SGI11
Definition: alt_interrupt_common.h:74
@ ALT_INT_INTERRUPT_CPU1_DEFLAGS3
Definition: alt_interrupt_common.h:132
@ ALT_INT_INTERRUPT_F2S_FPGA_IRQ19
Definition: alt_interrupt_common.h:196
@ ALT_INT_INTERRUPT_F2S_FPGA_IRQ23
Definition: alt_interrupt_common.h:200
@ ALT_INT_INTERRUPT_F2S_FPGA_IRQ39
Definition: alt_interrupt_common.h:216
@ ALT_INT_INTERRUPT_EMAC1_RX_ECC_UNCORRECTED_IRQ
Definition: alt_interrupt_common.h:276
@ ALT_INT_INTERRUPT_F2S_FPGA_IRQ61
Definition: alt_interrupt_common.h:238
@ ALT_INT_INTERRUPT_NANDR_ECC_CORRECTED_IRQ
Definition: alt_interrupt_common.h:327
@ ALT_INT_INTERRUPT_F2S_FPGA_IRQ27
Definition: alt_interrupt_common.h:204
@ ALT_INT_INTERRUPT_SDMMC_IRQ
Definition: alt_interrupt_common.h:316
@ ALT_INT_INTERRUPT_F2S_FPGA_IRQ15
Definition: alt_interrupt_common.h:192
@ ALT_INT_INTERRUPT_F2S_FPGA_IRQ45
Definition: alt_interrupt_common.h:222
@ ALT_INT_INTERRUPT_RAM_ECC_UNCORRECTED_IRQ
Definition: alt_interrupt_common.h:423
@ ALT_INT_INTERRUPT_F2S_FPGA_IRQ28
Definition: alt_interrupt_common.h:205
@ ALT_INT_INTERRUPT_F2S_FPGA_IRQ10
Definition: alt_interrupt_common.h:187
rtems_termios_device_context * context
Definition: console-config.c:62
