#define | ALT_GPIO_SWPORTA_DR_GPIO_SWPORTA_DR_LSB 0 |
#define | ALT_GPIO_SWPORTA_DR_GPIO_SWPORTA_DR_MSB 28 |
#define | ALT_GPIO_SWPORTA_DR_GPIO_SWPORTA_DR_WIDTH 29 |
#define | ALT_GPIO_SWPORTA_DR_GPIO_SWPORTA_DR_SET_MSK 0x1fffffff |
#define | ALT_GPIO_SWPORTA_DR_GPIO_SWPORTA_DR_CLR_MSK 0xe0000000 |
#define | ALT_GPIO_SWPORTA_DR_GPIO_SWPORTA_DR_RESET 0x0 |
#define | ALT_GPIO_SWPORTA_DR_GPIO_SWPORTA_DR_GET(value) (((value) & 0x1fffffff) >> 0) |
#define | ALT_GPIO_SWPORTA_DR_GPIO_SWPORTA_DR_SET(value) (((value) << 0) & 0x1fffffff) |
#define | ALT_GPIO_SWPORTA_DR_OFST 0x0 |
#define | ALT_GPIO_SWPORTA_DR_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_GPIO_SWPORTA_DR_OFST)) |
#define | ALT_GPIO_SWPORTA_DDR_GPIO_SWPORTA_DDR_E_IN 0x0 |
#define | ALT_GPIO_SWPORTA_DDR_GPIO_SWPORTA_DDR_E_OUT 0x1 |
#define | ALT_GPIO_SWPORTA_DDR_GPIO_SWPORTA_DDR_LSB 0 |
#define | ALT_GPIO_SWPORTA_DDR_GPIO_SWPORTA_DDR_MSB 28 |
#define | ALT_GPIO_SWPORTA_DDR_GPIO_SWPORTA_DDR_WIDTH 29 |
#define | ALT_GPIO_SWPORTA_DDR_GPIO_SWPORTA_DDR_SET_MSK 0x1fffffff |
#define | ALT_GPIO_SWPORTA_DDR_GPIO_SWPORTA_DDR_CLR_MSK 0xe0000000 |
#define | ALT_GPIO_SWPORTA_DDR_GPIO_SWPORTA_DDR_RESET 0x0 |
#define | ALT_GPIO_SWPORTA_DDR_GPIO_SWPORTA_DDR_GET(value) (((value) & 0x1fffffff) >> 0) |
#define | ALT_GPIO_SWPORTA_DDR_GPIO_SWPORTA_DDR_SET(value) (((value) << 0) & 0x1fffffff) |
#define | ALT_GPIO_SWPORTA_DDR_OFST 0x4 |
#define | ALT_GPIO_SWPORTA_DDR_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_GPIO_SWPORTA_DDR_OFST)) |
#define | ALT_GPIO_INTEN_GPIO_INTEN_E_DIS 0x0 |
#define | ALT_GPIO_INTEN_GPIO_INTEN_E_EN 0x1 |
#define | ALT_GPIO_INTEN_GPIO_INTEN_LSB 0 |
#define | ALT_GPIO_INTEN_GPIO_INTEN_MSB 28 |
#define | ALT_GPIO_INTEN_GPIO_INTEN_WIDTH 29 |
#define | ALT_GPIO_INTEN_GPIO_INTEN_SET_MSK 0x1fffffff |
#define | ALT_GPIO_INTEN_GPIO_INTEN_CLR_MSK 0xe0000000 |
#define | ALT_GPIO_INTEN_GPIO_INTEN_RESET 0x0 |
#define | ALT_GPIO_INTEN_GPIO_INTEN_GET(value) (((value) & 0x1fffffff) >> 0) |
#define | ALT_GPIO_INTEN_GPIO_INTEN_SET(value) (((value) << 0) & 0x1fffffff) |
#define | ALT_GPIO_INTEN_OFST 0x30 |
#define | ALT_GPIO_INTEN_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_GPIO_INTEN_OFST)) |
#define | ALT_GPIO_INTMSK_GPIO_INTMSK_E_DIS 0x0 |
#define | ALT_GPIO_INTMSK_GPIO_INTMSK_E_EN 0x1 |
#define | ALT_GPIO_INTMSK_GPIO_INTMSK_LSB 0 |
#define | ALT_GPIO_INTMSK_GPIO_INTMSK_MSB 28 |
#define | ALT_GPIO_INTMSK_GPIO_INTMSK_WIDTH 29 |
#define | ALT_GPIO_INTMSK_GPIO_INTMSK_SET_MSK 0x1fffffff |
#define | ALT_GPIO_INTMSK_GPIO_INTMSK_CLR_MSK 0xe0000000 |
#define | ALT_GPIO_INTMSK_GPIO_INTMSK_RESET 0x0 |
#define | ALT_GPIO_INTMSK_GPIO_INTMSK_GET(value) (((value) & 0x1fffffff) >> 0) |
#define | ALT_GPIO_INTMSK_GPIO_INTMSK_SET(value) (((value) << 0) & 0x1fffffff) |
#define | ALT_GPIO_INTMSK_OFST 0x34 |
#define | ALT_GPIO_INTMSK_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_GPIO_INTMSK_OFST)) |
#define | ALT_GPIO_INTTYPE_LEVEL_GPIO_INTTYPE_LEVEL_E_LEVEL 0x0 |
#define | ALT_GPIO_INTTYPE_LEVEL_GPIO_INTTYPE_LEVEL_E_EDGE 0x1 |
#define | ALT_GPIO_INTTYPE_LEVEL_GPIO_INTTYPE_LEVEL_LSB 0 |
#define | ALT_GPIO_INTTYPE_LEVEL_GPIO_INTTYPE_LEVEL_MSB 28 |
#define | ALT_GPIO_INTTYPE_LEVEL_GPIO_INTTYPE_LEVEL_WIDTH 29 |
#define | ALT_GPIO_INTTYPE_LEVEL_GPIO_INTTYPE_LEVEL_SET_MSK 0x1fffffff |
#define | ALT_GPIO_INTTYPE_LEVEL_GPIO_INTTYPE_LEVEL_CLR_MSK 0xe0000000 |
#define | ALT_GPIO_INTTYPE_LEVEL_GPIO_INTTYPE_LEVEL_RESET 0x0 |
#define | ALT_GPIO_INTTYPE_LEVEL_GPIO_INTTYPE_LEVEL_GET(value) (((value) & 0x1fffffff) >> 0) |
#define | ALT_GPIO_INTTYPE_LEVEL_GPIO_INTTYPE_LEVEL_SET(value) (((value) << 0) & 0x1fffffff) |
#define | ALT_GPIO_INTTYPE_LEVEL_OFST 0x38 |
#define | ALT_GPIO_INTTYPE_LEVEL_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_GPIO_INTTYPE_LEVEL_OFST)) |
#define | ALT_GPIO_INT_POL_GPIO_INT_POL_E_ACTLOW 0x0 |
#define | ALT_GPIO_INT_POL_GPIO_INT_POL_E_ACTHIGH 0x1 |
#define | ALT_GPIO_INT_POL_GPIO_INT_POL_LSB 0 |
#define | ALT_GPIO_INT_POL_GPIO_INT_POL_MSB 28 |
#define | ALT_GPIO_INT_POL_GPIO_INT_POL_WIDTH 29 |
#define | ALT_GPIO_INT_POL_GPIO_INT_POL_SET_MSK 0x1fffffff |
#define | ALT_GPIO_INT_POL_GPIO_INT_POL_CLR_MSK 0xe0000000 |
#define | ALT_GPIO_INT_POL_GPIO_INT_POL_RESET 0x0 |
#define | ALT_GPIO_INT_POL_GPIO_INT_POL_GET(value) (((value) & 0x1fffffff) >> 0) |
#define | ALT_GPIO_INT_POL_GPIO_INT_POL_SET(value) (((value) << 0) & 0x1fffffff) |
#define | ALT_GPIO_INT_POL_OFST 0x3c |
#define | ALT_GPIO_INT_POL_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_GPIO_INT_POL_OFST)) |
#define | ALT_GPIO_INTSTAT_GPIO_INTSTAT_E_INACT 0x0 |
#define | ALT_GPIO_INTSTAT_GPIO_INTSTAT_E_ACT 0x1 |
#define | ALT_GPIO_INTSTAT_GPIO_INTSTAT_LSB 0 |
#define | ALT_GPIO_INTSTAT_GPIO_INTSTAT_MSB 28 |
#define | ALT_GPIO_INTSTAT_GPIO_INTSTAT_WIDTH 29 |
#define | ALT_GPIO_INTSTAT_GPIO_INTSTAT_SET_MSK 0x1fffffff |
#define | ALT_GPIO_INTSTAT_GPIO_INTSTAT_CLR_MSK 0xe0000000 |
#define | ALT_GPIO_INTSTAT_GPIO_INTSTAT_RESET 0x0 |
#define | ALT_GPIO_INTSTAT_GPIO_INTSTAT_GET(value) (((value) & 0x1fffffff) >> 0) |
#define | ALT_GPIO_INTSTAT_GPIO_INTSTAT_SET(value) (((value) << 0) & 0x1fffffff) |
#define | ALT_GPIO_INTSTAT_OFST 0x40 |
#define | ALT_GPIO_INTSTAT_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_GPIO_INTSTAT_OFST)) |
#define | ALT_GPIO_RAW_INTSTAT_GPIO_RAW_INTSTAT_E_INACT 0x0 |
#define | ALT_GPIO_RAW_INTSTAT_GPIO_RAW_INTSTAT_E_ACT 0x1 |
#define | ALT_GPIO_RAW_INTSTAT_GPIO_RAW_INTSTAT_LSB 0 |
#define | ALT_GPIO_RAW_INTSTAT_GPIO_RAW_INTSTAT_MSB 28 |
#define | ALT_GPIO_RAW_INTSTAT_GPIO_RAW_INTSTAT_WIDTH 29 |
#define | ALT_GPIO_RAW_INTSTAT_GPIO_RAW_INTSTAT_SET_MSK 0x1fffffff |
#define | ALT_GPIO_RAW_INTSTAT_GPIO_RAW_INTSTAT_CLR_MSK 0xe0000000 |
#define | ALT_GPIO_RAW_INTSTAT_GPIO_RAW_INTSTAT_RESET 0x0 |
#define | ALT_GPIO_RAW_INTSTAT_GPIO_RAW_INTSTAT_GET(value) (((value) & 0x1fffffff) >> 0) |
#define | ALT_GPIO_RAW_INTSTAT_GPIO_RAW_INTSTAT_SET(value) (((value) << 0) & 0x1fffffff) |
#define | ALT_GPIO_RAW_INTSTAT_OFST 0x44 |
#define | ALT_GPIO_RAW_INTSTAT_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_GPIO_RAW_INTSTAT_OFST)) |
#define | ALT_GPIO_DEBOUNCE_GPIO_DEBOUNCE_E_DIS 0x0 |
#define | ALT_GPIO_DEBOUNCE_GPIO_DEBOUNCE_E_EN 0x1 |
#define | ALT_GPIO_DEBOUNCE_GPIO_DEBOUNCE_LSB 0 |
#define | ALT_GPIO_DEBOUNCE_GPIO_DEBOUNCE_MSB 28 |
#define | ALT_GPIO_DEBOUNCE_GPIO_DEBOUNCE_WIDTH 29 |
#define | ALT_GPIO_DEBOUNCE_GPIO_DEBOUNCE_SET_MSK 0x1fffffff |
#define | ALT_GPIO_DEBOUNCE_GPIO_DEBOUNCE_CLR_MSK 0xe0000000 |
#define | ALT_GPIO_DEBOUNCE_GPIO_DEBOUNCE_RESET 0x0 |
#define | ALT_GPIO_DEBOUNCE_GPIO_DEBOUNCE_GET(value) (((value) & 0x1fffffff) >> 0) |
#define | ALT_GPIO_DEBOUNCE_GPIO_DEBOUNCE_SET(value) (((value) << 0) & 0x1fffffff) |
#define | ALT_GPIO_DEBOUNCE_OFST 0x48 |
#define | ALT_GPIO_DEBOUNCE_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_GPIO_DEBOUNCE_OFST)) |
#define | ALT_GPIO_PORTA_EOI_GPIO_PORTA_EOI_E_NOCLR 0x0 |
#define | ALT_GPIO_PORTA_EOI_GPIO_PORTA_EOI_E_CLR 0x1 |
#define | ALT_GPIO_PORTA_EOI_GPIO_PORTA_EOI_LSB 0 |
#define | ALT_GPIO_PORTA_EOI_GPIO_PORTA_EOI_MSB 28 |
#define | ALT_GPIO_PORTA_EOI_GPIO_PORTA_EOI_WIDTH 29 |
#define | ALT_GPIO_PORTA_EOI_GPIO_PORTA_EOI_SET_MSK 0x1fffffff |
#define | ALT_GPIO_PORTA_EOI_GPIO_PORTA_EOI_CLR_MSK 0xe0000000 |
#define | ALT_GPIO_PORTA_EOI_GPIO_PORTA_EOI_RESET 0x0 |
#define | ALT_GPIO_PORTA_EOI_GPIO_PORTA_EOI_GET(value) (((value) & 0x1fffffff) >> 0) |
#define | ALT_GPIO_PORTA_EOI_GPIO_PORTA_EOI_SET(value) (((value) << 0) & 0x1fffffff) |
#define | ALT_GPIO_PORTA_EOI_OFST 0x4c |
#define | ALT_GPIO_PORTA_EOI_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_GPIO_PORTA_EOI_OFST)) |
#define | ALT_GPIO_EXT_PORTA_GPIO_EXT_PORTA_LSB 0 |
#define | ALT_GPIO_EXT_PORTA_GPIO_EXT_PORTA_MSB 28 |
#define | ALT_GPIO_EXT_PORTA_GPIO_EXT_PORTA_WIDTH 29 |
#define | ALT_GPIO_EXT_PORTA_GPIO_EXT_PORTA_SET_MSK 0x1fffffff |
#define | ALT_GPIO_EXT_PORTA_GPIO_EXT_PORTA_CLR_MSK 0xe0000000 |
#define | ALT_GPIO_EXT_PORTA_GPIO_EXT_PORTA_RESET 0x0 |
#define | ALT_GPIO_EXT_PORTA_GPIO_EXT_PORTA_GET(value) (((value) & 0x1fffffff) >> 0) |
#define | ALT_GPIO_EXT_PORTA_GPIO_EXT_PORTA_SET(value) (((value) << 0) & 0x1fffffff) |
#define | ALT_GPIO_EXT_PORTA_OFST 0x50 |
#define | ALT_GPIO_EXT_PORTA_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_GPIO_EXT_PORTA_OFST)) |
#define | ALT_GPIO_LS_SYNC_GPIO_LS_SYNC_E_NOSYNC 0x0 |
#define | ALT_GPIO_LS_SYNC_GPIO_LS_SYNC_E_SYNC 0x1 |
#define | ALT_GPIO_LS_SYNC_GPIO_LS_SYNC_LSB 0 |
#define | ALT_GPIO_LS_SYNC_GPIO_LS_SYNC_MSB 0 |
#define | ALT_GPIO_LS_SYNC_GPIO_LS_SYNC_WIDTH 1 |
#define | ALT_GPIO_LS_SYNC_GPIO_LS_SYNC_SET_MSK 0x00000001 |
#define | ALT_GPIO_LS_SYNC_GPIO_LS_SYNC_CLR_MSK 0xfffffffe |
#define | ALT_GPIO_LS_SYNC_GPIO_LS_SYNC_RESET 0x0 |
#define | ALT_GPIO_LS_SYNC_GPIO_LS_SYNC_GET(value) (((value) & 0x00000001) >> 0) |
#define | ALT_GPIO_LS_SYNC_GPIO_LS_SYNC_SET(value) (((value) << 0) & 0x00000001) |
#define | ALT_GPIO_LS_SYNC_OFST 0x60 |
#define | ALT_GPIO_LS_SYNC_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_GPIO_LS_SYNC_OFST)) |
#define | ALT_GPIO_ID_CODE_GPIO_ID_CODE_LSB 0 |
#define | ALT_GPIO_ID_CODE_GPIO_ID_CODE_MSB 31 |
#define | ALT_GPIO_ID_CODE_GPIO_ID_CODE_WIDTH 32 |
#define | ALT_GPIO_ID_CODE_GPIO_ID_CODE_SET_MSK 0xffffffff |
#define | ALT_GPIO_ID_CODE_GPIO_ID_CODE_CLR_MSK 0x00000000 |
#define | ALT_GPIO_ID_CODE_GPIO_ID_CODE_RESET 0x0 |
#define | ALT_GPIO_ID_CODE_GPIO_ID_CODE_GET(value) (((value) & 0xffffffff) >> 0) |
#define | ALT_GPIO_ID_CODE_GPIO_ID_CODE_SET(value) (((value) << 0) & 0xffffffff) |
#define | ALT_GPIO_ID_CODE_OFST 0x64 |
#define | ALT_GPIO_ID_CODE_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_GPIO_ID_CODE_OFST)) |
#define | ALT_GPIO_VER_ID_CODE_GPIO_VER_ID_CODE_LSB 0 |
#define | ALT_GPIO_VER_ID_CODE_GPIO_VER_ID_CODE_MSB 31 |
#define | ALT_GPIO_VER_ID_CODE_GPIO_VER_ID_CODE_WIDTH 32 |
#define | ALT_GPIO_VER_ID_CODE_GPIO_VER_ID_CODE_SET_MSK 0xffffffff |
#define | ALT_GPIO_VER_ID_CODE_GPIO_VER_ID_CODE_CLR_MSK 0x00000000 |
#define | ALT_GPIO_VER_ID_CODE_GPIO_VER_ID_CODE_RESET 0x3230382a |
#define | ALT_GPIO_VER_ID_CODE_GPIO_VER_ID_CODE_GET(value) (((value) & 0xffffffff) >> 0) |
#define | ALT_GPIO_VER_ID_CODE_GPIO_VER_ID_CODE_SET(value) (((value) << 0) & 0xffffffff) |
#define | ALT_GPIO_VER_ID_CODE_OFST 0x6c |
#define | ALT_GPIO_VER_ID_CODE_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_GPIO_VER_ID_CODE_OFST)) |
#define | ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_A_E_WIDTHLESSONE8BITS 0x7 |
#define | ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_A_E_WIDTHLESSONE29BITS 0x1c |
#define | ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_A_LSB 0 |
#define | ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_A_MSB 4 |
#define | ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_A_WIDTH 5 |
#define | ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_A_SET_MSK 0x0000001f |
#define | ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_A_CLR_MSK 0xffffffe0 |
#define | ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_A_RESET 0x1c |
#define | ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_A_GET(value) (((value) & 0x0000001f) >> 0) |
#define | ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_A_SET(value) (((value) << 0) & 0x0000001f) |
#define | ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_B_E_WIDTHLESSONE8BITS 0x7 |
#define | ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_B_E_WIDTHLESSONE29BITS 0x1c |
#define | ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_B_LSB 5 |
#define | ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_B_MSB 9 |
#define | ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_B_WIDTH 5 |
#define | ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_B_SET_MSK 0x000003e0 |
#define | ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_B_CLR_MSK 0xfffffc1f |
#define | ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_B_RESET 0x7 |
#define | ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_B_GET(value) (((value) & 0x000003e0) >> 5) |
#define | ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_B_SET(value) (((value) << 5) & 0x000003e0) |
#define | ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_C_E_WIDTHLESSONE8BITS 0x7 |
#define | ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_C_E_WIDTHLESSONE29BITS 0x1c |
#define | ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_C_LSB 10 |
#define | ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_C_MSB 14 |
#define | ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_C_WIDTH 5 |
#define | ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_C_SET_MSK 0x00007c00 |
#define | ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_C_CLR_MSK 0xffff83ff |
#define | ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_C_RESET 0x7 |
#define | ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_C_GET(value) (((value) & 0x00007c00) >> 10) |
#define | ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_C_SET(value) (((value) << 10) & 0x00007c00) |
#define | ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_D_E_WIDTHLESSONE8BITS 0x7 |
#define | ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_D_E_WIDTHLESSONE29BITS 0x1c |
#define | ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_D_LSB 15 |
#define | ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_D_MSB 19 |
#define | ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_D_WIDTH 5 |
#define | ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_D_SET_MSK 0x000f8000 |
#define | ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_D_CLR_MSK 0xfff07fff |
#define | ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_D_RESET 0x7 |
#define | ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_D_GET(value) (((value) & 0x000f8000) >> 15) |
#define | ALT_GPIO_CFG_REG2_ENC_ID_PWIDTH_D_SET(value) (((value) << 15) & 0x000f8000) |
#define | ALT_GPIO_CFG_REG2_OFST 0x70 |
#define | ALT_GPIO_CFG_REG2_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_GPIO_CFG_REG2_OFST)) |
#define | ALT_GPIO_CFG_REG1_APB_DATA_WIDTH_E_WIDTH32BITS 0x2 |
#define | ALT_GPIO_CFG_REG1_APB_DATA_WIDTH_LSB 0 |
#define | ALT_GPIO_CFG_REG1_APB_DATA_WIDTH_MSB 1 |
#define | ALT_GPIO_CFG_REG1_APB_DATA_WIDTH_WIDTH 2 |
#define | ALT_GPIO_CFG_REG1_APB_DATA_WIDTH_SET_MSK 0x00000003 |
#define | ALT_GPIO_CFG_REG1_APB_DATA_WIDTH_CLR_MSK 0xfffffffc |
#define | ALT_GPIO_CFG_REG1_APB_DATA_WIDTH_RESET 0x2 |
#define | ALT_GPIO_CFG_REG1_APB_DATA_WIDTH_GET(value) (((value) & 0x00000003) >> 0) |
#define | ALT_GPIO_CFG_REG1_APB_DATA_WIDTH_SET(value) (((value) << 0) & 0x00000003) |
#define | ALT_GPIO_CFG_REG1_NUM_PORTS_E_ONEPORTA 0x0 |
#define | ALT_GPIO_CFG_REG1_NUM_PORTS_LSB 2 |
#define | ALT_GPIO_CFG_REG1_NUM_PORTS_MSB 3 |
#define | ALT_GPIO_CFG_REG1_NUM_PORTS_WIDTH 2 |
#define | ALT_GPIO_CFG_REG1_NUM_PORTS_SET_MSK 0x0000000c |
#define | ALT_GPIO_CFG_REG1_NUM_PORTS_CLR_MSK 0xfffffff3 |
#define | ALT_GPIO_CFG_REG1_NUM_PORTS_RESET 0x0 |
#define | ALT_GPIO_CFG_REG1_NUM_PORTS_GET(value) (((value) & 0x0000000c) >> 2) |
#define | ALT_GPIO_CFG_REG1_NUM_PORTS_SET(value) (((value) << 2) & 0x0000000c) |
#define | ALT_GPIO_CFG_REG1_PORTA_SINGLE_CTL_E_SOFTCTLONLY 0x1 |
#define | ALT_GPIO_CFG_REG1_PORTA_SINGLE_CTL_LSB 4 |
#define | ALT_GPIO_CFG_REG1_PORTA_SINGLE_CTL_MSB 4 |
#define | ALT_GPIO_CFG_REG1_PORTA_SINGLE_CTL_WIDTH 1 |
#define | ALT_GPIO_CFG_REG1_PORTA_SINGLE_CTL_SET_MSK 0x00000010 |
#define | ALT_GPIO_CFG_REG1_PORTA_SINGLE_CTL_CLR_MSK 0xffffffef |
#define | ALT_GPIO_CFG_REG1_PORTA_SINGLE_CTL_RESET 0x1 |
#define | ALT_GPIO_CFG_REG1_PORTA_SINGLE_CTL_GET(value) (((value) & 0x00000010) >> 4) |
#define | ALT_GPIO_CFG_REG1_PORTA_SINGLE_CTL_SET(value) (((value) << 4) & 0x00000010) |
#define | ALT_GPIO_CFG_REG1_PORTB_SINGLE_CTL_E_SOFTCTLONLY 0x1 |
#define | ALT_GPIO_CFG_REG1_PORTB_SINGLE_CTL_LSB 5 |
#define | ALT_GPIO_CFG_REG1_PORTB_SINGLE_CTL_MSB 5 |
#define | ALT_GPIO_CFG_REG1_PORTB_SINGLE_CTL_WIDTH 1 |
#define | ALT_GPIO_CFG_REG1_PORTB_SINGLE_CTL_SET_MSK 0x00000020 |
#define | ALT_GPIO_CFG_REG1_PORTB_SINGLE_CTL_CLR_MSK 0xffffffdf |
#define | ALT_GPIO_CFG_REG1_PORTB_SINGLE_CTL_RESET 0x1 |
#define | ALT_GPIO_CFG_REG1_PORTB_SINGLE_CTL_GET(value) (((value) & 0x00000020) >> 5) |
#define | ALT_GPIO_CFG_REG1_PORTB_SINGLE_CTL_SET(value) (((value) << 5) & 0x00000020) |
#define | ALT_GPIO_CFG_REG1_PORTC_SINGLE_CTL_E_SOFTCTLONLY 0x1 |
#define | ALT_GPIO_CFG_REG1_PORTC_SINGLE_CTL_LSB 6 |
#define | ALT_GPIO_CFG_REG1_PORTC_SINGLE_CTL_MSB 6 |
#define | ALT_GPIO_CFG_REG1_PORTC_SINGLE_CTL_WIDTH 1 |
#define | ALT_GPIO_CFG_REG1_PORTC_SINGLE_CTL_SET_MSK 0x00000040 |
#define | ALT_GPIO_CFG_REG1_PORTC_SINGLE_CTL_CLR_MSK 0xffffffbf |
#define | ALT_GPIO_CFG_REG1_PORTC_SINGLE_CTL_RESET 0x1 |
#define | ALT_GPIO_CFG_REG1_PORTC_SINGLE_CTL_GET(value) (((value) & 0x00000040) >> 6) |
#define | ALT_GPIO_CFG_REG1_PORTC_SINGLE_CTL_SET(value) (((value) << 6) & 0x00000040) |
#define | ALT_GPIO_CFG_REG1_PORTD_SINGLE_CTL_E_SOFTCTLONLY 0x1 |
#define | ALT_GPIO_CFG_REG1_PORTD_SINGLE_CTL_LSB 7 |
#define | ALT_GPIO_CFG_REG1_PORTD_SINGLE_CTL_MSB 7 |
#define | ALT_GPIO_CFG_REG1_PORTD_SINGLE_CTL_WIDTH 1 |
#define | ALT_GPIO_CFG_REG1_PORTD_SINGLE_CTL_SET_MSK 0x00000080 |
#define | ALT_GPIO_CFG_REG1_PORTD_SINGLE_CTL_CLR_MSK 0xffffff7f |
#define | ALT_GPIO_CFG_REG1_PORTD_SINGLE_CTL_RESET 0x1 |
#define | ALT_GPIO_CFG_REG1_PORTD_SINGLE_CTL_GET(value) (((value) & 0x00000080) >> 7) |
#define | ALT_GPIO_CFG_REG1_PORTD_SINGLE_CTL_SET(value) (((value) << 7) & 0x00000080) |
#define | ALT_GPIO_CFG_REG1_HW_PORTA_E_PORTANOHARD 0x0 |
#define | ALT_GPIO_CFG_REG1_HW_PORTA_LSB 8 |
#define | ALT_GPIO_CFG_REG1_HW_PORTA_MSB 8 |
#define | ALT_GPIO_CFG_REG1_HW_PORTA_WIDTH 1 |
#define | ALT_GPIO_CFG_REG1_HW_PORTA_SET_MSK 0x00000100 |
#define | ALT_GPIO_CFG_REG1_HW_PORTA_CLR_MSK 0xfffffeff |
#define | ALT_GPIO_CFG_REG1_HW_PORTA_RESET 0x0 |
#define | ALT_GPIO_CFG_REG1_HW_PORTA_GET(value) (((value) & 0x00000100) >> 8) |
#define | ALT_GPIO_CFG_REG1_HW_PORTA_SET(value) (((value) << 8) & 0x00000100) |
#define | ALT_GPIO_CFG_REG1_PORTA_INTR_E_PORTAINTERR 0x1 |
#define | ALT_GPIO_CFG_REG1_PORTA_INTR_LSB 12 |
#define | ALT_GPIO_CFG_REG1_PORTA_INTR_MSB 12 |
#define | ALT_GPIO_CFG_REG1_PORTA_INTR_WIDTH 1 |
#define | ALT_GPIO_CFG_REG1_PORTA_INTR_SET_MSK 0x00001000 |
#define | ALT_GPIO_CFG_REG1_PORTA_INTR_CLR_MSK 0xffffefff |
#define | ALT_GPIO_CFG_REG1_PORTA_INTR_RESET 0x1 |
#define | ALT_GPIO_CFG_REG1_PORTA_INTR_GET(value) (((value) & 0x00001000) >> 12) |
#define | ALT_GPIO_CFG_REG1_PORTA_INTR_SET(value) (((value) << 12) & 0x00001000) |
#define | ALT_GPIO_CFG_REG1_DEBOUNCE_E_DEBOUNCEA 0x1 |
#define | ALT_GPIO_CFG_REG1_DEBOUNCE_LSB 13 |
#define | ALT_GPIO_CFG_REG1_DEBOUNCE_MSB 13 |
#define | ALT_GPIO_CFG_REG1_DEBOUNCE_WIDTH 1 |
#define | ALT_GPIO_CFG_REG1_DEBOUNCE_SET_MSK 0x00002000 |
#define | ALT_GPIO_CFG_REG1_DEBOUNCE_CLR_MSK 0xffffdfff |
#define | ALT_GPIO_CFG_REG1_DEBOUNCE_RESET 0x1 |
#define | ALT_GPIO_CFG_REG1_DEBOUNCE_GET(value) (((value) & 0x00002000) >> 13) |
#define | ALT_GPIO_CFG_REG1_DEBOUNCE_SET(value) (((value) << 13) & 0x00002000) |
#define | ALT_GPIO_CFG_REG1_ADD_ENC_PARAMS_E_ADDENCPARAMS 0x1 |
#define | ALT_GPIO_CFG_REG1_ADD_ENC_PARAMS_LSB 14 |
#define | ALT_GPIO_CFG_REG1_ADD_ENC_PARAMS_MSB 14 |
#define | ALT_GPIO_CFG_REG1_ADD_ENC_PARAMS_WIDTH 1 |
#define | ALT_GPIO_CFG_REG1_ADD_ENC_PARAMS_SET_MSK 0x00004000 |
#define | ALT_GPIO_CFG_REG1_ADD_ENC_PARAMS_CLR_MSK 0xffffbfff |
#define | ALT_GPIO_CFG_REG1_ADD_ENC_PARAMS_RESET 0x1 |
#define | ALT_GPIO_CFG_REG1_ADD_ENC_PARAMS_GET(value) (((value) & 0x00004000) >> 14) |
#define | ALT_GPIO_CFG_REG1_ADD_ENC_PARAMS_SET(value) (((value) << 14) & 0x00004000) |
#define | ALT_GPIO_CFG_REG1_GPIO_ID_E_IDCODE 0x1 |
#define | ALT_GPIO_CFG_REG1_GPIO_ID_LSB 15 |
#define | ALT_GPIO_CFG_REG1_GPIO_ID_MSB 15 |
#define | ALT_GPIO_CFG_REG1_GPIO_ID_WIDTH 1 |
#define | ALT_GPIO_CFG_REG1_GPIO_ID_SET_MSK 0x00008000 |
#define | ALT_GPIO_CFG_REG1_GPIO_ID_CLR_MSK 0xffff7fff |
#define | ALT_GPIO_CFG_REG1_GPIO_ID_RESET 0x1 |
#define | ALT_GPIO_CFG_REG1_GPIO_ID_GET(value) (((value) & 0x00008000) >> 15) |
#define | ALT_GPIO_CFG_REG1_GPIO_ID_SET(value) (((value) << 15) & 0x00008000) |
#define | ALT_GPIO_CFG_REG1_ENC_ID_WIDTH_E_ENCIDWIDTH 0x1f |
#define | ALT_GPIO_CFG_REG1_ENC_ID_WIDTH_LSB 16 |
#define | ALT_GPIO_CFG_REG1_ENC_ID_WIDTH_MSB 20 |
#define | ALT_GPIO_CFG_REG1_ENC_ID_WIDTH_WIDTH 5 |
#define | ALT_GPIO_CFG_REG1_ENC_ID_WIDTH_SET_MSK 0x001f0000 |
#define | ALT_GPIO_CFG_REG1_ENC_ID_WIDTH_CLR_MSK 0xffe0ffff |
#define | ALT_GPIO_CFG_REG1_ENC_ID_WIDTH_RESET 0x1f |
#define | ALT_GPIO_CFG_REG1_ENC_ID_WIDTH_GET(value) (((value) & 0x001f0000) >> 16) |
#define | ALT_GPIO_CFG_REG1_ENC_ID_WIDTH_SET(value) (((value) << 16) & 0x001f0000) |
#define | ALT_GPIO_CFG_REG1_OFST 0x74 |
#define | ALT_GPIO_CFG_REG1_ADDR(base) ALT_CAST(void *, (ALT_CAST(char *, (base)) + ALT_GPIO_CFG_REG1_OFST)) |
