RTEMS 6.1
adc-defs.h
1
9/*
10 * Copyright (c) 2014 Taller Technologies.
11 *
12 * @author Diaz Marcos (marcos.diaz@tallertechnologies.com)
13 *
14 * The license and distribution terms for this file may be
15 * found in the file LICENSE in this distribution or at
16 * http://www.rtems.org/license/LICENSE.
17 */
18#ifndef LPC176X_ADC_DEFS_H
19#define LPC176X_ADC_DEFS_H
20
21#include <bsp.h>
22#include <bsp/io.h>
23#include <bsp/lpc176x.h>
24#include <bsp/adc.h>
25
26#ifdef __cplusplus
27extern "C" {
28#endif /* __cplusplus */
29
33typedef enum {
34 ADC_0,
35 ADC_1,
36 ADC_2,
37 ADC_3,
38 ADC_4,
39 ADC_5,
40 ADC_6,
41 ADC_7,
42 ADC_DEVICES_COUNT
44
45#define MAX_ADC_CLK 13000000u
46
47#define ADC_RANGE 0xFFFu
48
49#define ADC_NUMBER_VALID( number ) ( ( (uint32_t) number ) < \
50 ADC_DEVICES_COUNT )
51
52#define ADC_CR_SEL( val ) BSP_FLD32( val, 0, 7 )
53#define ADC_CR_SEL_GET( val ) BSP_FLD32GET( val, 0, 7 )
54#define ADC_CR_SEL_SET( reg, val ) BSP_FLD32SET( reg, val, 0, 7 )
55#define ADC_CR_CLKDIV( val ) BSP_FLD32( val, 8, 15 )
56#define ADC_CR_CLKDIV_GET( reg ) BSP_FLD32GET( reg, 8, 15 )
57#define ADC_CR_CLKDIV_SET( reg, val ) BSP_FLD32SET( reg, val, 8, 15 )
58#define ADC_CR_BURST BSP_BIT32( 16 )
59#define ADC_CR_CLKS( val ) BSP_FLD32( val, 17, 19 )
60#define ADC_CR_PDN BSP_BIT32( 21 )
61#define ADC_CR_START_NOW BSP_BIT32( 24 )
62#define ADC_CR_START( val ) BSP_FLD32( val, 24, 26 )
63#define ADC_CR_EDGE BSP_BIT32( 27 )
64
65#define ADC_DR_VALUE( reg ) BSP_FLD32GET( reg, 4, 15 )
66#define ADC_DR_OVERRUN BSP_BIT32( 30 )
67#define ADC_DR_DONE BSP_BIT32( 31 )
68
69#define ADC_DATA_CONVERSION_DONE( val ) ( ( val & ADC_DR_DONE ) != 0u )
70
74typedef struct {
75 volatile uint32_t ADCR;
76 volatile uint32_t ADGDR;
77 volatile uint32_t RESERVED0;
78 volatile uint32_t ADINTEN;
79 volatile uint32_t ADDR[ ADC_DEVICES_COUNT ];
80 volatile uint32_t ADSTAT;
81 volatile uint32_t ADTRM;
83
87typedef struct {
88 uint32_t pin_number;
89 lpc176x_pin_function pin_function;
91
92#ifdef __cplusplus
93}
94#endif /* __cplusplus */
95
96#endif
lpc176x_adc_number
The ADC inputs of the board.
Definition: adc-defs.h:33
Defines the functions according to the pin.
Definition: io-defs.h:68
ADC library for the lpc176x bsp.
Specific register definitions according to lpc176x family boards.
The ADC low-level device.
Definition: adc-defs.h:74
Represents the pin and function for each ADC input.
Definition: adc-defs.h:87
