RTEMS 6.1
linker-symbols-arch.h
2
12/*
13 * Copyright (C) 2020 On-Line Applications Research Corporation (OAR)
14 * Written by Kinsey Moore <kinsey.moore@oarcorp.com>
15 *
16 * Redistribution and use in source and binary forms, with or without
17 * modification, are permitted provided that the following conditions
18 * are met:
19 * 1. Redistributions of source code must retain the above copyright
20 * notice, this list of conditions and the following disclaimer.
21 * 2. Redistributions in binary form must reproduce the above copyright
22 * notice, this list of conditions and the following disclaimer in the
23 * documentation and/or other materials provided with the distribution.
24 *
25 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
26 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
27 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
28 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
29 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
30 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
31 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
32 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
33 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
34 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
35 * POSSIBILITY OF SUCH DAMAGE.
36 */
37
38#ifndef LIBBSP_AARCH64_SHARED_LINKER_SYMBOLS_H
39#define LIBBSP_AARCH64_SHARED_LINKER_SYMBOLS_H
40
41#ifdef __cplusplus
42extern "C" {
43#endif /* __cplusplus */
44
56#ifndef ASM
57 #define LINKER_SYMBOL(sym) extern char sym [];
58#else
59 #define LINKER_SYMBOL(sym) .extern sym
60#endif
61
62LINKER_SYMBOL(bsp_stack_exception_size)
63LINKER_SYMBOL(bsp_stack_hyp_size)
64
65LINKER_SYMBOL(bsp_section_vector_begin)
66LINKER_SYMBOL(bsp_section_vector_end)
67LINKER_SYMBOL(bsp_section_vector_size)
68
69LINKER_SYMBOL(bsp_vector_table_begin)
70LINKER_SYMBOL(bsp_vector_table_end)
71LINKER_SYMBOL(bsp_vector_table_size)
72
73LINKER_SYMBOL(bsp_start_vector_table_begin)
74LINKER_SYMBOL(bsp_start_vector_table_end)
75LINKER_SYMBOL(bsp_start_vector_table_size)
76
77LINKER_SYMBOL(bsp_translation_table_base)
78LINKER_SYMBOL(bsp_translation_table_end)
79
80
82#ifdef __cplusplus
83}
84#endif /* __cplusplus */
85
86#endif /* LIBBSP_AARCH64_SHARED_LINKER_SYMBOLS_H */
