RTEMS 6.1
_kernel_uio.h
1/*-
2 * SPDX-License-Identifier: BSD-3-Clause
3 *
4 * Copyright (c) 1982, 1986, 1993, 1994
5 * The Regents of the University of California. All rights reserved.
6 *
7 * Redistribution and use in source and binary forms, with or without
8 * modification, are permitted provided that the following conditions
9 * are met:
10 * 1. Redistributions of source code must retain the above copyright
11 * notice, this list of conditions and the following disclaimer.
12 * 2. Redistributions in binary form must reproduce the above copyright
13 * notice, this list of conditions and the following disclaimer in the
14 * documentation and/or other materials provided with the distribution.
15 * 3. Neither the name of the University nor the names of its contributors
16 * may be used to endorse or promote products derived from this software
17 * without specific prior written permission.
18 *
19 * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
20 * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
21 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
22 * ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
23 * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
24 * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
25 * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
26 * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
27 * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
28 * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
29 * SUCH DAMAGE.
30 *
31 * @(#)uio.h 8.5 (Berkeley) 2/22/94
32 * $FreeBSD: head/sys/sys/uio.h 331621 2018-03-27 15:20:03Z brooks $
33 */
34
44#if defined(_SYS_UIO_H_) && defined(_KERNEL)
45
46struct uio {
47 struct iovec *uio_iov; /* scatter/gather list */
48 int uio_iovcnt; /* length of scatter/gather list */
49 off_t uio_offset; /* offset in target object */
50 ssize_t uio_resid; /* remaining bytes to process */
51 enum uio_seg uio_segflg; /* address space */
52 enum uio_rw uio_rw; /* operation */
53 struct thread *uio_td; /* owner */
54};
55
56/*
57 * Limits
58 *
59 * N.B.: UIO_MAXIOV must be no less than IOV_MAX from <sys/syslimits.h>
60 * which in turn must be no less than _XOPEN_IOV_MAX from <limits.h>. If
61 * we ever make this tunable (probably pointless), then IOV_MAX should be
62 * removed from <sys/syslimits.h> and applications would be expected to use
63 * sysconf(3) to find out the correct value, or else assume the worst
64 * (_XOPEN_IOV_MAX). Perhaps UIO_MAXIOV should be simply defined as
65 * IOV_MAX.
66 */
67#define UIO_MAXIOV 1024 /* max 1K of iov's */
68
69struct vm_object;
70struct vm_page;
71struct bus_dma_segment;
72
73struct uio *cloneuio(struct uio *uiop);
74int copyiniov(const struct iovec *iovp, u_int iovcnt, struct iovec **iov,
75 int error);
76int copyinuio(const struct iovec *iovp, u_int iovcnt, struct uio **uiop);
77int copyout_map(struct thread *td, vm_offset_t *addr, size_t sz);
78int copyout_unmap(struct thread *td, vm_offset_t addr, size_t sz);
79int physcopyin(void *src, vm_paddr_t dst, size_t len);
80int physcopyout(vm_paddr_t src, void *dst, size_t len);
81int physcopyin_vlist(struct bus_dma_segment *src, off_t offset,
82 vm_paddr_t dst, size_t len);
83int physcopyout_vlist(vm_paddr_t src, struct bus_dma_segment *dst,
84 off_t offset, size_t len);
85int uiomove(void *cp, int n, struct uio *uio);
86int uiomove_frombuf(void *buf, int buflen, struct uio *uio);
87int uiomove_fromphys(struct vm_page *ma[], vm_offset_t offset, int n,
88 struct uio *uio);
89int uiomove_nofault(void *cp, int n, struct uio *uio);
90int uiomove_object(struct vm_object *obj, off_t obj_size, struct uio *uio);
91
92#else /* !_SYS_UIO_H_ || !_KERNEL */
93#error "must be included via <sys/uio.h> in kernel space"
94#endif /* _SYS_UIO_H_ && _KERNEL */
unsigned cp
Definition: tte.h:14
