Public interface of DMA routines.
More...
#include <stdint.h>
#define | BSP_VMEDMA_OPT_THROUGHPUT 1 |
#define | BSP_VMEDMA_OPT_LOWLATENCY 2 |
#define | BSP_VMEDMA_OPT_SHAREDBUS 3 |
#define | BSP_VMEDMA_OPT_DEFAULT 4 |
#define | BSP_VMEDMA_OPT_CUSTOM 5 |
#define | BSP_VMEDMA_MODE_NOINC_VME (1<<20) |
#define | BSP_VMEDMA_MODE_NOINC_PCI (1<<21) |
#define | BSP_VMEDMA_MODE_PCI2VME (1<<31) |
#define | BSP_VMEDMA_STATUS_OK 0 |
#define | BSP_VMEDMA_STATUS_UNSUP (-1) |
#define | BSP_VMEDMA_STATUS_BERR_VME 1 |
#define | BSP_VMEDMA_STATUS_BERR_PCI 2 |
#define | BSP_VMEDMA_STATUS_BUSY 3 |
#define | BSP_VMEDMA_STATUS_PERR 4 |
#define | BSP_VMEDMA_STATUS_OERR 5 |
#define | BSP_VMEDMA_MSK_ATTR (1<<0) |
#define | BSP_VMEDMA_MSK_PCIA (1<<1) |
#define | BSP_VMEDMA_MSK_VMEA (1<<2) |
#define | BSP_VMEDMA_MSK_BCNT (1<<3) |
#define | BSP_VMEDMA_MSK_ALL (0xf) |
typedef void * | BSP_VMEDmaListDescriptor |
typedef void(* | BSP_VMEDmaIRQCallback) (void *usr_arg) |
int | BSP_VMEDmaSetup (int channel, uint32_t bus_mode, uint32_t xfer_mode, void *custom_setup) |
int | BSP_VMEDmaStart (int channel, uint32_t pci_addr, uint32_t vme_addr, uint32_t n_bytes) |
uint32_t | BSP_VMEDmaStatus (int channel) |
int | BSP_VMEDmaInstallISR (int channel, BSP_VMEDmaIRQCallback cb, void *usr_arg) |
BSP_VMEDmaListDescriptor | BSP_VMEDmaListDescriptorSetup (BSP_VMEDmaListDescriptor d, uint32_t attr_mask, uint32_t xfer_mode, uint32_t pci_addr, uint32_t vme_addr, uint32_t n_bytes) |
int | BSP_VMEDmaListDescriptorDestroy (BSP_VMEDmaListDescriptor d) |
int | BSP_VMEDmaListDestroy (BSP_VMEDmaListDescriptor anchor) |
int | BSP_VMEDmaListDescriptorEnq (BSP_VMEDmaListDescriptor tail, BSP_VMEDmaListDescriptor d) |
BSP_VMEDmaListDescriptor | BSP_VMEDmaListDescriptorNext (BSP_VMEDmaListDescriptor d) |
BSP_VMEDmaListDescriptor | BSP_VMEDmaListDescriptorPrev (BSP_VMEDmaListDescriptor d) |
void | BSP_VMEDmaListDescriptorSetUsr (BSP_VMEDmaListDescriptor d, void *usrData) |
void * | BSP_VMEDmaListDescriptorGetUsr (BSP_VMEDmaListDescriptor d) |
int | BSP_VMEDmaListRefresh (BSP_VMEDmaListDescriptor anchor) |
int | BSP_VMEDmaListStart (int channel, BSP_VMEDmaListDescriptor list) |
