RTEMS 6.1
fsl_flexspi_nor_boot.h
1/*
2 * Copyright 2019-2021 NXP
3 * All rights reserved.
4 *
5 * SPDX-License-Identifier: BSD-3-Clause
6 */
7
8#ifndef __FLEXSPI_NOR_BOOT_H__
9#define __FLEXSPI_NOR_BOOT_H__
10
11#include <stdint.h>
12#include "fsl_common.h"
13#ifndef __rtems__
14#ifndef BOARD_FLASH_SIZE
15#include "board.h"
16#endif
17#endif /* __rtems__ */
18
22#define FSL_XIP_DEVICE_DRIVER_VERSION (MAKE_VERSION(2, 0, 5))
25/*************************************
26 * IVT Data
27 *************************************/
28typedef struct _ivt_
29{
33 uint32_t hdr;
37 uint32_t entry;
39 uint32_t reserved1;
41 uint32_t dcd;
45 uint32_t boot_data;
47 uint32_t self;
49 uint32_t csf;
51 uint32_t reserved2;
52} ivt;
53
54#define IVT_MAJOR_VERSION 0x4
55#define IVT_MAJOR_VERSION_SHIFT 0x4
56#define IVT_MAJOR_VERSION_MASK 0xF
57#define IVT_MINOR_VERSION 0x1
58#define IVT_MINOR_VERSION_SHIFT 0x0
59#define IVT_MINOR_VERSION_MASK 0xF
60
61#define IVT_VERSION(major, minor) \
62 ((((major)&IVT_MAJOR_VERSION_MASK) << IVT_MAJOR_VERSION_SHIFT) | \
63 (((minor)&IVT_MINOR_VERSION_MASK) << IVT_MINOR_VERSION_SHIFT))
64
65/* IVT header */
66#define IVT_TAG_HEADER 0xD1
67#define IVT_SIZE 0x2000
68#define IVT_PAR IVT_VERSION(IVT_MAJOR_VERSION, IVT_MINOR_VERSION)
69#define IVT_HEADER (IVT_TAG_HEADER | (IVT_SIZE << 8) | (IVT_PAR << 24))
70
71/* Set resume entry */
72#if defined(__CC_ARM) || defined(__ARMCC_VERSION)
73extern uint32_t Reset_Handler[];
74#define IMAGE_ENTRY_ADDRESS ((uint32_t)Reset_Handler)
75#define BOOT_IMAGE_BASE ((uint32_t)FLASH_BASE)
76#define BOOT_IMAGE_SIZE ((uint32_t)FLASH_SIZE)
77#define BOOT_DATA_ADDRESS &g_boot_data
78#define IVT_ADDRESS &image_vector_table
79#define DCD_DATA_ADDRESS dcd_data
80#elif defined(__MCUXPRESSO)
81extern uint32_t ResetISR[];
82extern uint32_t __boot_hdr_start__[];
83extern uint32_t __boot_hdr_ivt_loadaddr__[];
84extern uint32_t __boot_hdr_boot_data_loadaddr__[];
85extern uint32_t __boot_hdr_dcd_loadaddr__[];
86extern uint32_t _boot_loadaddr[];
87extern uint32_t _boot_size[];
88#define IMAGE_ENTRY_ADDRESS ((uint32_t)ResetISR)
89#define BOOT_IMAGE_BASE ((uint32_t)_boot_loadaddr)
90#define BOOT_IMAGE_SIZE ((uint32_t)_boot_size)
91#define BOOT_DATA_ADDRESS ((uint32_t)__boot_hdr_boot_data_loadaddr__)
92#define IVT_ADDRESS ((uint32_t)__boot_hdr_ivt_loadaddr__)
93#define DCD_DATA_ADDRESS ((uint32_t)__boot_hdr_dcd_loadaddr__)
94#elif defined(__ICCARM__)
95extern uint32_t Reset_Handler[];
96#define IMAGE_ENTRY_ADDRESS ((uint32_t)Reset_Handler)
97#define BOOT_IMAGE_BASE ((uint32_t)FLASH_BASE)
98#define BOOT_IMAGE_SIZE ((uint32_t)FLASH_SIZE)
99#define BOOT_DATA_ADDRESS &g_boot_data
100#define IVT_ADDRESS &image_vector_table
101#define DCD_DATA_ADDRESS dcd_data
102#elif defined(__GNUC__)
103extern uint32_t Reset_Handler[];
104#define IMAGE_ENTRY_ADDRESS ((uint32_t)Reset_Handler)
105#define BOOT_IMAGE_BASE ((uint32_t)FLASH_BASE)
106#define BOOT_IMAGE_SIZE ((uint32_t)FLASH_SIZE)
107#define BOOT_DATA_ADDRESS &g_boot_data
108#define IVT_ADDRESS &image_vector_table
109#define DCD_DATA_ADDRESS dcd_data
110#endif
111#if defined(XIP_BOOT_HEADER_ENABLE) && (XIP_BOOT_HEADER_ENABLE == 1)
112#if defined(XIP_BOOT_HEADER_DCD_ENABLE) && (1 == XIP_BOOT_HEADER_DCD_ENABLE)
113#define DCD_ADDRESS DCD_DATA_ADDRESS
114#else
115#define DCD_ADDRESS 0
116#endif
117#endif
118#define CSF_ADDRESS 0
119#define IVT_RSVD (uint32_t)(0x00000000)
120
121/*************************************
122 * Boot Data
123 *************************************/
124typedef struct _boot_data_
125{
126 uint32_t start; /* boot start location */
127 uint32_t size; /* size */
128 uint32_t plugin; /* plugin flag - 1 if downloaded application is plugin */
129 uint32_t placeholder; /* placehoder to make even 0x10 size */
131
132#if __CORTEX_M == 7
133#define FLASH_BASE FlexSPI1_AMBA_BASE
134#elif __CORTEX_M == 4
135#define FLASH_BASE FlexSPI1_ALIAS_BASE
136#endif
137
138#ifndef __rtems__
139#if defined(BOARD_FLASH_SIZE)
140#define FLASH_SIZE BOARD_FLASH_SIZE
141#else
142#error "Please define macro BOARD_FLASH_SIZE"
143#endif
144#endif /* __rtems__ */
145#define PLUGIN_FLAG (uint32_t)0
146
147/* External Variables */
148extern const BOOT_DATA_T g_boot_data;
149#if defined(XIP_BOOT_HEADER_DCD_ENABLE) && (1 == XIP_BOOT_HEADER_DCD_ENABLE)
150extern const uint8_t dcd_data[];
151#endif
152
153#endif /* __FLEXSPI_NOR_BOOT_H__ */
Definition: fsl_flexspi_nor_boot.h:100
Definition: fsl_flexspi_nor_boot.h:29
uint32_t reserved2
Definition: fsl_flexspi_nor_boot.h:51
uint32_t csf
Definition: fsl_flexspi_nor_boot.h:49
uint32_t entry
Definition: fsl_flexspi_nor_boot.h:37
uint32_t dcd
Definition: fsl_flexspi_nor_boot.h:41
uint32_t self
Definition: fsl_flexspi_nor_boot.h:47
uint32_t reserved1
Definition: fsl_flexspi_nor_boot.h:39
uint32_t boot_data
Definition: fsl_flexspi_nor_boot.h:45
uint32_t hdr
Definition: fsl_flexspi_nor_boot.h:33
