RTEMS
5.2
bsps
arm
include
bsp
zynq-uart.h
1
7
8
* SPDX-License-Identifier: BSD-2-Clause
9
10
* Copyright (C) 2013, XXX embedded brains GmbH
11
12
13
* modification, are permitted provided that the following conditions
14
* are met:
15
* 1. Redistributions of source code must retain the above copyright
16
* notice, this list of conditions and the following disclaimer.
17
* 2. Redistributions in binary form must reproduce the above copyright
18
* notice, this list of conditions and the following disclaimer in the
19
* documentation and/or other materials provided with the distribution.
20
21
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
22
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
23
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
24
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
25
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
26
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
27
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
28
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
29
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
30
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
31
* POSSIBILITY OF SUCH DAMAGE.
32
33
34
#ifndef LIBBSP_ARM_XILINX_ZYNQ_UART_H
35
#define LIBBSP_ARM_XILINX_ZYNQ_UART_H
36
37
rtems/termiostypes.h
38
39
#ifdef __cplusplus
40
extern
"C"
41
#endif
/* __cplusplus */
42
49
typedef
struct
50
rtems_termios_device_context
base;
51
volatile
struct
zynq_uart
*regs;
52
bool
transmitting;
53
rtems_vector_number
irq;
54
zynq_uart_context
55
56
extern
const
rtems_termios_device_handler
zynq_uart_handler;
57
58
#define ZYNQ_UART_DEFAULT_BAUD 115200
59
60
void
zynq_uart_initialize(
*base);
61
62
int
zynq_uart_read_polled(
*base);
63
64
void
zynq_uart_write_polled(
65
*base,
66
char
68
72
void
zynq_uart_reset_tx_flush
zynq_uart_context
*ctx);
73
74
int
zynq_cal_baud_rate(
75
uint32_t baudrate,
76
uint32_t* brgr,
77
uint32_t* bauddiv,
78
uint32_t modereg
79
80
81
#ifdef __cplusplus
82
83
#endif
/* __cplusplus */
84
85
#endif
/* LIBBSP_ARM_XILINX_ZYNQ_UART_H */
rtems_vector_number
ISR_Vector_number rtems_vector_number
Control block type used to manage the vectors.
Definition:
intr.h:47
Termios device context.
Definition:
termiostypes.h:75
Termios device handler.
Definition:
termiostypes.h:141
zynq_uart_context
Definition:
zynq-uart.h:49
zynq_uart
Definition:
zynq-uart-regs.h:48
termiostypes.h
void zynq_uart_reset_tx_flush(zynq_uart_context *ctx)
Definition:
zynq-uart-polled.c:173
