RTEMS
5.2
bsps
include
libchip
z85c30.h
1
8
9
* COPYRIGHT (c) 1998 by Radstone Technology
10
11
12
* THIS FILE IS PROVIDED TO YOU, THE USER, "AS IS", WITHOUT WARRANTY OF ANY
13
* KIND, EITHER EXPRESSED OR IMPLIED, INCLUDING, BUT NOT LIMITED TO, THE
14
* IMPLIED WARRANTY OF FITNESS FOR A PARTICULAR PURPOSE. THE ENTIRE RISK
15
* AS TO THE QUALITY AND PERFORMANCE OF ALL CODE IN THIS FILE IS WITH YOU.
16
17
* You are hereby granted permission to use, copy, modify, and distribute
18
* this file, provided that this notice, plus the above copyright notice
19
* and disclaimer, appears in all copies. Radstone Technology will provide
20
* no support for this code.
21
22
* COPYRIGHT (c) 1989-1997.
23
* On-Line Applications Research Corporation (OAR).
24
25
* The license and distribution terms for this file may in
26
* the file LICENSE in this distribution or at
27
* http://www.rtems.org/license/LICENSE.
28
29
30
#ifndef __Z85C30_H
31
#define __Z85C30_H
32
33
#include <stdint.h>
34
35
libchip/serial.h
36
37
#ifdef __cplusplus
38
extern
"C"
39
#endif
40
41
42
* Driver function table
43
44
45
extern
const
console_fns
z85c30_fns;
46
extern
const
console_fns
z85c30_fns_polled;
47
48
49
* Flow control function tables
50
51
52
extern
const
console_flow
z85c30_flow_RTSCTS;
53
extern
const
console_flow
z85c30_flow_DTRCTS;
54
55
56
* Default register access routines
57
58
59
uint8_t z85c30_get_register(
/* registers are byte-wide */
60
uintptr_t ulCtrlPort,
61
uint8_t ucRegNum
62
63
64
void
z85c30_set_register(
65
66
uint8_t ucRegNum,
67
uint8_t ucData
68
69
70
uint8_t z85c30_get_data(
71
uint32_t ulDataPort
72
73
74
void
z85c30_set_data(
75
uint32_t ulDataPort,
76
uint8_t ucData
77
78
79
#ifdef __cplusplus
80
81
#endif
82
83
#endif
serial.h
The generic libchip serial driver interface.
_console_flow
Definition:
serial.h:94
_console_fns
Definition:
serial.h:76
