RTEMS 5.2
ypclnt.h
1/*
2 * Copyright (c) 1992/3 Theo de Raadt <deraadt@fsa.ca>
3 * All rights reserved.
4 *
5 * Redistribution and use in source and binary forms, with or without
6 * modification, are permitted provided that the following conditions
7 * are met:
8 * 1. Redistributions of source code must retain the above copyright
9 * notice, this list of conditions and the following disclaimer.
10 * 2. Redistributions in binary form must reproduce the above copyright
11 * notice, this list of conditions and the following disclaimer in the
12 * documentation and/or other materials provided with the distribution.
13 * 3. The name of the author may not be used to endorse or promote
14 * products derived from this software without specific prior written
15 * permission.
16 *
17 * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS
18 * OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
19 * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
20 * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR ANY
21 * DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
22 * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
23 * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
24 * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
25 * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
26 * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
27 * SUCH DAMAGE.
28 *
29 * $FreeBSD: src/include/rpcsvc/ypclnt.h,v 1.11 1999/08/27 23:45:12 peter Exp $
30 */
31
32#ifndef _RPCSVC_YPCLNT_H_
33#define _RPCSVC_YPCLNT_H_
34
35#include <sys/cdefs.h>
36
37#define YPERR_BADARGS 1 /* args to function are bad */
38#define YPERR_RPC 2 /* RPC failure */
39#define YPERR_DOMAIN 3 /* can't bind to a server for domain */
40#define YPERR_MAP 4 /* no such map in server's domain */
41#define YPERR_KEY 5 /* no such key in map */
42#define YPERR_YPERR 6 /* some internal YP server or client error */
43#define YPERR_RESRC 7 /* local resource allocation failure */
44#define YPERR_NOMORE 8 /* no more records in map database */
45#define YPERR_PMAP 9 /* can't communicate with portmapper */
46#define YPERR_YPBIND 10 /* can't communicate with ypbind */
47#define YPERR_YPSERV 11 /* can't communicate with ypserv */
48#define YPERR_NODOM 12 /* local domain name not set */
49#define YPERR_BADDB 13 /* YP data base is bad */
50#define YPERR_VERS 14 /* YP version mismatch */
51#define YPERR_ACCESS 15 /* access violation */
52#define YPERR_BUSY 16 /* database is busy */
53
54/*
55 * Types of update operations
56 */
57#define YPOP_CHANGE 1 /* change, do not add */
58#define YPOP_INSERT 2 /* add, do not change */
59#define YPOP_DELETE 3 /* delete this entry */
60#define YPOP_STORE 4 /* add, or change */
61
63 /* return non-0 to stop getting called */
64 int (*foreach) (unsigned long, char *, int, char *, int, void *);
65 char *data; /* opaque pointer for use of callback fn */
66};
67
68struct dom_binding;
69
70__BEGIN_DECLS
71int yp_bind (char *dom);
72int _yp_dobind (char *dom, struct dom_binding **ypdb);
73void yp_unbind (char *dom);
74int yp_get_default_domain (char **domp);
75int yp_match (char *indomain, char *inmap,
76 const char *inkey, int inkeylen, char **outval,
77 int *outvallen);
78int yp_first (char *indomain, char *inmap,
79 char **outkey, int *outkeylen, char **outval,
80 int *outvallen);
81int yp_next (char *indomain, char *inmap,
82 char *inkey, int inkeylen, char **outkey,
83 int *outkeylen, char **outval, int *outvallen);
84int yp_master (char *indomain, char *inmap, char **outname);
85int yp_order (char *indomain, char *inmap, int *outorder);
86int yp_all (char *indomain, char *inmap,
87 struct ypall_callback *incallback);
88char * yperr_string (int incode);
89char * ypbinderr_string (int incode);
90int ypprot_err (unsigned int incode);
91__END_DECLS
92
93#endif /* _RPCSVC_YPCLNT_H_ */
Definition: yp_prot.h:199
Definition: ypclnt.h:62
