RTEMS 5.2
yp_prot.h
1/*
2 * Copyright (c) 1992/3 Theo de Raadt <deraadt@fsa.ca>
3 * All rights reserved.
4 *
5 * Redistribution and use in source and binary forms, with or without
6 * modification, are permitted provided that the following conditions
7 * are met:
8 * 1. Redistributions of source code must retain the above copyright
9 * notice, this list of conditions and the following disclaimer.
10 * 2. Redistributions in binary form must reproduce the above copyright
11 * notice, this list of conditions and the following disclaimer in the
12 * documentation and/or other materials provided with the distribution.
13 * 3. The name of the author may not be used to endorse or promote
14 * products derived from this software without specific prior written
15 * permission.
16 *
17 * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS
18 * OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
19 * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
20 * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR ANY
21 * DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
22 * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
23 * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
24 * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
25 * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
26 * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
27 * SUCH DAMAGE.
28 *
29 * $FreeBSD: src/include/rpcsvc/yp_prot.h,v 1.10 1999/08/27 23:45:12 peter Exp $
30 */
31
32#ifndef _RPCSVC_YP_PROT_H_
33#define _RPCSVC_YP_PROT_H_
34
35/*
36 * YPSERV PROTOCOL:
37 *
38 * ypserv supports the following procedures:
39 *
40 * YPPROC_NULL takes (void), returns (void).
41 * called to check if server is alive.
42 * YPPROC_DOMAIN takes (char *), returns (bool_t).
43 * true if ypserv serves the named domain.
44 * YPPROC_DOMAIN_NOACK takes (char *), returns (bool_t).
45 * true if ypserv serves the named domain.
46 * used for broadcasts, does not ack if ypserv
47 * doesn't handle named domain.
48 * YPPROC_MATCH takes (struct ypreq_key), returns (struct ypresp_val)
49 * does a lookup.
50 * YPPROC_FIRST takes (struct ypreq_nokey) returns (ypresp_key_val).
51 * gets the first key/datum from the map.
52 * YPPROC_NEXT takes (struct ypreq_key) returns (ypresp_key_val).
53 * gets the next key/datum from the map.
54 * YPPROC_XFR takes (struct ypreq_xfr), returns (void).
55 * tells ypserv to check if there is a new version of
56 * the map.
57 * YPPROC_CLEAR takes (void), returns (void).
58 * tells ypserv to flush it's file cache, so that
59 * newly transferred files will get read.
60 * YPPROC_ALL takes (struct ypreq_nokey), returns (bool_t and
61 * struct ypresp_key_val).
62 * returns an array of data, with the bool_t being
63 * false on the last datum. read the source, it's
64 * convoluted.
65 * YPPROC_MASTER takes (struct ypreq_nokey), returns (ypresp_master).
66 * YPPROC_ORDER takes (struct ypreq_nokey), returns (ypresp_order).
67 * YPPROC_MAPLIST takes (char *), returns (struct ypmaplist *).
68 */
69
70#ifndef BOOL_DEFINED
71typedef u_int bool;
72#define BOOL_DEFINED
73#endif
74
75/* Program and version symbols, magic numbers */
76
77#define YPPROG ((u_long)100004)
78#define YPVERS ((u_long)2)
79#define YPVERS_ORIG ((u_long)1)
80#define YPMAXRECORD ((u_long)1024)
81#define YPMAXDOMAIN ((u_long)64)
82#define YPMAXMAP ((u_long)64)
83#define YPMAXPEER ((u_long)256)
84
85/*
86 * I don't know if anything of sun's depends on this, or if they
87 * simply defined it so that their own code wouldn't try to send
88 * packets over the ethernet MTU. This YP code doesn't use it.
89 */
90#define YPMSGSZ 1600
91
92#ifndef DATUM
93typedef struct {
94 char *dptr;
95 int dsize;
96} datum;
97#define DATUM
98#endif
99
101 char *domain;
102 char *map;
103 u_long ordernum;
104 char *owner;
105};
106
107struct ypreq_key {
108 char *domain;
109 char *map;
110 datum keydat;
111};
112
114 char *domain;
115 char *map;
116};
117
118struct ypreq_xfr {
119 struct ypmap_parms map_parms;
120 u_long transid;
121 u_long proto;
122 u_short port;
123};
124#define ypxfr_domain map_parms.domain
125#define ypxfr_map map_parms.map
126#define ypxfr_ordernum map_parms.ordernum
127#define ypxfr_owner map_parms.owner
128
130 u_long status;
131 datum valdat;
132};
133
135 u_long status;
136 datum keydat;
137 datum valdat;
138};
139
141 u_long status;
142 char *master;
143};
144
146 u_long status;
147 u_long ordernum;
148};
149
150struct ypmaplist {
151 char ypml_name[YPMAXMAP + 1];
152 struct ypmaplist *ypml_next;
153};
154
156 u_long status;
157 struct ypmaplist *list;
158};
159
160/* ypserv procedure numbers */
161#define YPPROC_NULL ((u_long)0)
162#define YPPROC_DOMAIN ((u_long)1)
163#define YPPROC_DOMAIN_NONACK ((u_long)2)
164#define YPPROC_MATCH ((u_long)3)
165#define YPPROC_FIRST ((u_long)4)
166#define YPPROC_NEXT ((u_long)5)
167#define YPPROC_XFR ((u_long)6)
168#define YPPROC_CLEAR ((u_long)7)
169#define YPPROC_ALL ((u_long)8)
170#define YPPROC_MASTER ((u_long)9)
171#define YPPROC_ORDER ((u_long)10)
172#define YPPROC_MAPLIST ((u_long)11)
173
174/* ypserv procedure return status values */
175#define YP_TRUE ((long)1) /* general purpose success code */
176#define YP_NOMORE ((long)2) /* no more entries in map */
177#define YP_FALSE ((long)0) /* general purpose failure code */
178#define YP_NOMAP ((long)-1) /* no such map in domain */
179#define YP_NODOM ((long)-2) /* domain not supported */
180#define YP_NOKEY ((long)-3) /* no such key in map */
181#define YP_BADOP ((long)-4) /* invalid operation */
182#define YP_BADDB ((long)-5) /* server data base is bad */
183#define YP_YPERR ((long)-6) /* YP server error */
184#define YP_BADARGS ((long)-7) /* request arguments bad */
185#define YP_VERS ((long)-8) /* YP server version mismatch */
186
187/*
188 * Sun's header file says:
189 * "Domain binding data structure, used by ypclnt package and ypserv modules.
190 * Users of the ypclnt package (or of this protocol) don't HAVE to know about
191 * it, but it must be available to users because _yp_dobind is a public
192 * interface."
193 *
194 * This is totally bogus! Nowhere else does Sun state that _yp_dobind() is
195 * a public interface, and I don't know any reason anyone would want to call
196 * it. But, just in case anyone does actually expect it to be available..
197 * we provide this.. exactly as Sun wants it.
198 */
200 struct dom_binding *dom_pnext;
201 char dom_domain[YPMAXDOMAIN + 1];
202 struct sockaddr_in dom_server_addr;
203 u_short dom_server_port;
204 int dom_socket;
205 CLIENT *dom_client;
206 u_short dom_local_port;
207 long dom_vers;
208};
209
210/*
211 * YPBIND PROTOCOL:
212 *
213 * ypbind supports the following procedures:
214 *
215 * YPBINDPROC_NULL takes (void), returns (void).
216 * to check if ypbind is running.
217 * YPBINDPROC_DOMAIN takes (char *), returns (struct ypbind_resp).
218 * requests that ypbind start to serve the
219 * named domain (if it doesn't already)
220 * YPBINDPROC_SETDOM takes (struct ypbind_setdom), returns (void).
221 * used by ypset.
222 */
223
224#define YPBINDPROG ((u_long)100007)
225#define YPBINDVERS ((u_long)2)
226#define YPBINDVERS_ORIG ((u_long)1)
227
228/* ypbind procedure numbers */
229#define YPBINDPROC_NULL ((u_long)0)
230#define YPBINDPROC_DOMAIN ((u_long)1)
231#define YPBINDPROC_SETDOM ((u_long)2)
232
233/* error code in ypbind_resp.ypbind_status */
234enum ypbind_resptype {
235 YPBIND_SUCC_VAL = 1,
236 YPBIND_FAIL_VAL = 2,
237 _YPBIND_RESPTYPE = 0xffffffff
238};
239
240/* network order, of course */
242 struct in_addr ypbind_binding_addr;
243 u_short ypbind_binding_port;
244};
245
247 enum ypbind_resptype ypbind_status;
248 union {
249 u_long ypbind_error;
250 struct ypbind_binding ypbind_bindinfo;
251 } ypbind_respbody;
252};
253
254/* error code in ypbind_resp.ypbind_respbody.ypbind_error */
255#define YPBIND_ERR_ERR 1 /* internal error */
256#define YPBIND_ERR_NOSERV 2 /* no bound server for passed domain */
257#define YPBIND_ERR_RESC 3 /* system resource allocation failure */
258
259/*
260 * Request data structure for ypbind "Set domain" procedure.
261 */
263 char ypsetdom_domain[YPMAXDOMAIN + 1];
264 struct ypbind_binding ypsetdom_binding;
265 u_short ypsetdom_vers;
266};
267#define ypsetdom_addr ypsetdom_binding.ypbind_binding_addr
268#define ypsetdom_port ypsetdom_binding.ypbind_binding_port
269
270/*
271 * YPPUSH PROTOCOL:
272 *
273 * Sun says:
274 * "Protocol between clients (ypxfr, only) and yppush
275 * yppush speaks a protocol in the transient range, which
276 * is supplied to ypxfr as a command-line parameter when it
277 * is activated by ypserv."
278 *
279 * This protocol is not implemented, naturally, because this YP
280 * implementation only does the client side.
281 */
282#define YPPUSHVERS ((u_long)1)
283#define YPPUSHVERS_ORIG ((u_long)1)
284
285/* yppush procedure numbers */
286#define YPPUSHPROC_NULL ((u_long)0)
287#define YPPUSHPROC_XFRRESP ((u_long)1)
288
290 u_long transid;
291 u_long status;
292};
293
294/* yppush status value in yppushresp_xfr.status */
295#define YPPUSH_SUCC ((long)1) /* Success */
296#define YPPUSH_AGE ((long)2) /* Master's version not newer */
297#define YPPUSH_NOMAP ((long)-1) /* Can't find server for map */
298#define YPPUSH_NODOM ((long)-2) /* Domain not supported */
299#define YPPUSH_RSRC ((long)-3) /* Local resource alloc failure */
300#define YPPUSH_RPC ((long)-4) /* RPC failure talking to server */
301#define YPPUSH_MADDR ((long)-5) /* Can't get master address */
302#define YPPUSH_YPERR ((long)-6) /* YP server/map db error */
303#define YPPUSH_BADARGS ((long)-7) /* Request arguments bad */
304#define YPPUSH_DBM ((long)-8) /* Local dbm operation failed */
305#define YPPUSH_FILE ((long)-9) /* Local file I/O operation failed */
306#define YPPUSH_SKEW ((long)-10) /* Map version skew during transfer */
307#define YPPUSH_CLEAR ((long)-11) /* Can't send "Clear" req to local ypserv */
308#define YPPUSH_FORCE ((long)-12) /* No local order number in map - use -f */
309#define YPPUSH_XFRERR ((long)-13) /* ypxfr error */
310#define YPPUSH_REFUSED ((long)-14) /* Transfer request refused by ypserv */
311
312struct inaddr;
313__BEGIN_DECLS
314bool_t xdr_datum (XDR *, datum *);
315bool_t xdr_ypreq_key (XDR *, struct ypreq_key *);
316bool_t xdr_ypreq_nokey (XDR *, struct ypreq_nokey *);
317bool_t xdr_ypreq_xfr (XDR *, struct ypreq_xfr *);
318bool_t xdr_ypresp_val (XDR *, struct ypresp_val *);
319bool_t xdr_ypresp_key_val (XDR *, struct ypresp_key_val *);
320bool_t xdr_ypbind_resp (XDR *, struct ypbind_resp *);
321bool_t xdr_ypbind_setdom (XDR *, struct ypbind_setdom *);
322bool_t xdr_yp_inaddr (XDR *, struct inaddr *);
323bool_t xdr_ypmap_parms (XDR *, struct ypmap_parms *);
324bool_t xdr_yppushresp_xfr (XDR *, struct yppushresp_xfr *);
325bool_t xdr_ypresp_order (XDR *, struct ypresp_order *);
326bool_t xdr_ypresp_master (XDR *, struct ypresp_master *);
327bool_t xdr_ypresp_maplist (XDR *, struct ypresp_maplist *);
328__END_DECLS
329
330#endif /* _RPCSVC_YP_PROT_H_ */
Definition: mm.c:60
Definition: yp_prot.h:93
Definition: yp_prot.h:199
Definition: yp_prot.h:241
Definition: yp_prot.h:246
Definition: yp_prot.h:262
Definition: yp_prot.h:100
Definition: yp_prot.h:150
Definition: yp_prot.h:289
Definition: yp_prot.h:107
Definition: yp_prot.h:113
Definition: yp_prot.h:118
Definition: yp_prot.h:134
Definition: yp_prot.h:155
Definition: yp_prot.h:140
Definition: yp_prot.h:145
Definition: yp_prot.h:129
