RTEMS 5.2
cpu_asm.h
1/*
2 * Copyright (c) 2018.
3 * Amaan Cheval <amaan.cheval@gmail.com>
4 *
5 * Redistribution and use in source and binary forms, with or without
6 * modification, are permitted provided that the following conditions
7 * are met:
8 * 1. Redistributions of source code must retain the above copyright
9 * notice, this list of conditions and the following disclaimer.
10 * 2. Redistributions in binary form must reproduce the above copyright
11 * notice, this list of conditions and the following disclaimer in the
12 * documentation and/or other materials provided with the distribution.
13 *
14 * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
15 * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
16 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
17 * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
18 * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
19 * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
20 * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
21 * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
22 * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
23 * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
24 * SUCH DAMAGE.
25 */
26
27#ifndef _RTEMS_SCORE_CPU_ASM_H
28#define _RTEMS_SCORE_CPU_ASM_H
29
30#if !ASM
31
33
34RTEMS_INLINE_ROUTINE uint8_t inport_byte(uint16_t port)
35{
36 uint8_t ret;
37 __asm__ volatile ( "inb %1, %0"
38 : "=a" (ret)
39 : "Nd" (port) );
40 return ret;
41}
42
43RTEMS_INLINE_ROUTINE void outport_byte(uint16_t port, uint8_t val)
44{
45 __asm__ volatile ( "outb %0, %1" : : "a" (val), "Nd" (port) );
46}
47
48RTEMS_INLINE_ROUTINE uint16_t amd64_get_cs(void)
49{
50 uint16_t segment = 0;
51
52 __asm__ volatile ( "movw %%cs, %0" : "=r" (segment) : "0" (segment) );
53
54 return segment;
55}
56
57RTEMS_INLINE_ROUTINE void amd64_set_cr3(uint64_t segment)
58{
59 __asm__ volatile ( "movq %0, %%cr3" : "=r" (segment) : "0" (segment) );
60}
61
62RTEMS_INLINE_ROUTINE void cpuid(
63 uint32_t code, uint32_t *eax, uint32_t *ebx, uint32_t *ecx, uint32_t *edx
64) {
65 __asm__ volatile ( "cpuid"
66 : "=a" (*eax), "=b" (*ebx), "=c" (*ecx), "=d" (*edx)
67 : "a" (code) );
68}
69
70RTEMS_INLINE_ROUTINE uint64_t rdmsr(uint32_t msr)
71{
72 uint32_t low, high;
73 __asm__ volatile ( "rdmsr" :
74 "=a" (low), "=d" (high) :
75 "c" (msr) );
76 return low | (uint64_t) high << 32;
77}
78
79RTEMS_INLINE_ROUTINE void wrmsr(uint32_t msr, uint32_t low, uint32_t high)
80{
81 __asm__ volatile ( "wrmsr" : :
82 "a" (low), "d" (high), "c" (msr) );
83}
84
85RTEMS_INLINE_ROUTINE void amd64_enable_interrupts(void)
86{
87 __asm__ volatile ( "sti" );
88}
89
90RTEMS_INLINE_ROUTINE void amd64_disable_interrupts(void)
91{
92 __asm__ volatile ( "cli" );
93}
94
95RTEMS_INLINE_ROUTINE void stub_io_wait(void)
96{
97 /* XXX: This likely won't be required on any modern boards, but this function
98 * exists so it's easier to find all the places it may be used.
99 */
100}
101
102#endif /* !ASM */
103
104#endif
Basic Definitions.
#define RTEMS_INLINE_ROUTINE
Definition: basedefs.h:66
register struct Per_CPU_Control *_SPARC_Per_CPU_current __asm__("g6")
The pointer to the current per-CPU control is available via register g6.
Definition: inftrees.h:24
