RTEMS 5.2
wdt.h
6/* */
7/* All rights reserved. */
8/* */
11/* */
14/* */
17/* */
29
44#ifndef _WDT_
45#define _WDT_
46
47#include "chip.h"
48
49#include <stdint.h>
50
51#ifdef __cplusplus
52extern "C" {
53#endif
54
55/*----------------------------------------------------------------------------
56 * Exported functions
57 *----------------------------------------------------------------------------*/
58
59extern void WDT_Enable(Wdt *pWDT, uint32_t dwMode);
60
61extern void WDT_Disable(Wdt *pWDT);
62
63extern void WDT_Restart(Wdt *pWDT);
64
65extern uint32_t WDT_GetStatus(Wdt *pWDT);
66
67extern uint32_t WDT_GetPeriod(uint32_t dwMs);
68
69#ifdef __cplusplus
70}
71#endif
72
73#endif /* #ifndef _WDT_ */
74
Wdt hardware registers.
Definition: component_wdt.h:41
Disable watchdog.
Definition: wdt.c:101
Watchdog restart.
Definition: wdt.c:109
Watchdog get period.
Definition: wdt.c:127
Enable watchdog with given mode.
Definition: wdt.c:90
Watchdog get status.
Definition: wdt.c:117
