RTEMS 5.2
vis.h
1/* $NetBSD: vis.h,v 1.16 2005/09/13 01:44:32 christos Exp $ */
2
3/*-
4 * Copyright (c) 1990, 1993
5 * The Regents of the University of California. All rights reserved.
6 *
7 * Redistribution and use in source and binary forms, with or without
8 * modification, are permitted provided that the following conditions
9 * are met:
10 * 1. Redistributions of source code must retain the above copyright
11 * notice, this list of conditions and the following disclaimer.
12 * 2. Redistributions in binary form must reproduce the above copyright
13 * notice, this list of conditions and the following disclaimer in the
14 * documentation and/or other materials provided with the distribution.
15 * 3. Neither the name of the University nor the names of its contributors
16 * may be used to endorse or promote products derived from this software
17 * without specific prior written permission.
18 *
19 * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
20 * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
21 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
22 * ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
23 * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
24 * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
25 * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
26 * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
27 * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
28 * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
29 * SUCH DAMAGE.
30 *
31 * @(#)vis.h 8.1 (Berkeley) 6/2/93
32 */
33
34#ifndef _VIS_H_
35#define _VIS_H_
36
37#include <sys/types.h>
38
39/*
40 * to select alternate encoding format
41 */
42#define VIS_OCTAL 0x01 /* use octal \ddd format */
43#define VIS_CSTYLE 0x02 /* use \[nrft0..] where appropiate */
44
45/*
46 * to alter set of characters encoded (default is to encode all
47 * non-graphic except space, tab, and newline).
48 */
49#define VIS_SP 0x04 /* also encode space */
50#define VIS_TAB 0x08 /* also encode tab */
51#define VIS_NL 0x10 /* also encode newline */
52#define VIS_WHITE (VIS_SP | VIS_TAB | VIS_NL)
53#define VIS_SAFE 0x20 /* only encode "unsafe" characters */
54
55/*
56 * other
57 */
58#define VIS_NOSLASH 0x40 /* inhibit printing '\' */
59#define VIS_HTTPSTYLE 0x80 /* http-style escape % HEX HEX */
60
61/*
62 * unvis return codes
63 */
64#define UNVIS_VALID 1 /* character valid */
65#define UNVIS_VALIDPUSH 2 /* character valid, push back passed char */
66#define UNVIS_NOCHAR 3 /* valid sequence, no character produced */
67#define UNVIS_SYNBAD -1 /* unrecognized escape sequence */
68#define UNVIS_ERROR -2 /* decoder in unknown state (unrecoverable) */
69
70/*
71 * unvis flags
72 */
73#define UNVIS_END 1 /* no more characters */
74
75#include <sys/cdefs.h>
76
77__BEGIN_DECLS
78char *vis(char *, int, int, int);
79char *svis(char *, int, int, int, const char *);
80int strvis(char *, const char *, int);
81int strsvis(char *, const char *, int, const char *);
82int strvisx(char *, const char *, size_t, int);
83int strsvisx(char *, const char *, size_t, int, const char *);
84int strunvis(char *, const char *);
85int strunvisx(char *, const char *, int);
86#ifndef __LIBC12_SOURCE__
87//int unvis(char *, int, int *, int) __RENAME(__unvis13);
88#endif
89__END_DECLS
90
91#endif /* !_VIS_H_ */
