RTEMS 5.2
utf8proc.h
1/*
2 * Copyright (c) 2009 Public Software Group e. V., Berlin, Germany
3 *
4 * Permission is hereby granted, free of charge, to any person obtaining a
5 * copy of this software and associated documentation files (the "Software"),
6 * to deal in the Software without restriction, including without limitation
7 * the rights to use, copy, modify, merge, publish, distribute, sublicense,
8 * and/or sell copies of the Software, and to permit persons to whom the
9 * Software is furnished to do so, subject to the following conditions:
10 *
11 * The above copyright notice and this permission notice shall be included in
12 * all copies or substantial portions of the Software.
13 *
14 * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
15 * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
16 * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
17 * AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
18 * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
19 * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
20 * DEALINGS IN THE SOFTWARE.
21 */
22
23
24/*
25 * File name: utf8proc.h
26 *
27 * Description:
28 * Header files for libutf8proc, which is a mapping tool for UTF-8 strings
29 * with following features:
30 * - decomposing and composing of strings
31 * - replacing compatibility characters with their equivalents
32 * - stripping of "default ignorable characters"
33 * like SOFT-HYPHEN or ZERO-WIDTH-SPACE
34 * - folding of certain characters for string comparison
35 * (e.g. HYPHEN U+2010 and MINUS U+2212 to ASCII "-")
36 * (see "LUMP" option)
37 * - optional rejection of strings containing non-assigned code points
38 * - stripping of control characters
39 * - stripping of character marks (accents, etc.)
40 * - transformation of LF, CRLF, CR and NEL to line-feed (LF)
41 * or to the unicode chararacters for paragraph separation (PS)
42 * or line separation (LS).
43 * - unicode case folding (for case insensitive string comparisons)
44 * - rejection of illegal UTF-8 data
45 * (i.e. UTF-8 encoded UTF-16 surrogates)
46 * - support for korean hangul characters
47 * Unicode Version 5.0.0 is supported.
48 */
49
50
51#ifndef UTF8PROC_H
52#define UTF8PROC_H
53
54
55#include <stdlib.h>
56#include <sys/types.h>
57#ifdef _MSC_VER
58typedef signed char int8_t;
59typedef unsigned char uint8_t;
60typedef short int16_t;
61typedef unsigned short uint16_t;
62typedef int int32_t;
63#ifdef _WIN64
64#define ssize_t __int64
65#else
66#define ssize_t int
67#endif
68typedef unsigned char bool;
69enum {false, true};
70#else
71#include <stdbool.h>
72#include <inttypes.h>
73#endif
74#include <limits.h>
75
76#ifdef __cplusplus
77extern "C" {
78#endif
79
80#ifndef SSIZE_MAX
81#define SSIZE_MAX ((size_t)SIZE_MAX/2)
82#endif
83
84#define UTF8PROC_NULLTERM (1<<0)
85#define UTF8PROC_STABLE (1<<1)
86#define UTF8PROC_COMPAT (1<<2)
87#define UTF8PROC_COMPOSE (1<<3)
88#define UTF8PROC_DECOMPOSE (1<<4)
89#define UTF8PROC_IGNORE (1<<5)
90#define UTF8PROC_REJECTNA (1<<6)
91#define UTF8PROC_NLF2LS (1<<7)
92#define UTF8PROC_NLF2PS (1<<8)
93#define UTF8PROC_NLF2LF (UTF8PROC_NLF2LS | UTF8PROC_NLF2PS)
94#define UTF8PROC_STRIPCC (1<<9)
95#define UTF8PROC_CASEFOLD (1<<10)
96#define UTF8PROC_CHARBOUND (1<<11)
97#define UTF8PROC_LUMP (1<<12)
98#define UTF8PROC_STRIPMARK (1<<13)
99/*
100 * Flags being regarded by several functions in the library:
101 * NULLTERM: The given UTF-8 input is NULL terminated.
102 * STABLE: Unicode Versioning Stability has to be respected.
103 * COMPAT: Compatiblity decomposition
104 * (i.e. formatting information is lost)
105 * COMPOSE: Return a result with composed characters.
106 * DECOMPOSE: Return a result with decomposed characters.
107 * IGNORE: Strip "default ignorable characters"
108 * REJECTNA: Return an error, if the input contains unassigned
109 * code points.
110 * NLF2LS: Indicating that NLF-sequences (LF, CRLF, CR, NEL) are
111 * representing a line break, and should be converted to the
112 * unicode character for line separation (LS).
113 * NLF2PS: Indicating that NLF-sequences are representing a paragraph
114 * break, and should be converted to the unicode character for
115 * paragraph separation (PS).
116 * NLF2LF: Indicating that the meaning of NLF-sequences is unknown.
117 * STRIPCC: Strips and/or convers control characters.
118 * NLF-sequences are transformed into space, except if one of
119 * the NLF2LS/PS/LF options is given.
120 * HorizontalTab (HT) and FormFeed (FF) are treated as a
121 * NLF-sequence in this case.
122 * All other control characters are simply removed.
123 * CASEFOLD: Performs unicode case folding, to be able to do a
124 * case-insensitive string comparison.
125 * CHARBOUND: Inserts 0xFF bytes at the beginning of each sequence which
126 * is representing a single grapheme cluster (see UAX#29).
127 * LUMP: Lumps certain characters together
128 * (e.g. HYPHEN U+2010 and MINUS U+2212 to ASCII "-").
129 * (See lump.txt for details.)
130 * If NLF2LF is set, this includes a transformation of
131 * paragraph and line separators to ASCII line-feed (LF).
132 * STRIPMARK: Strips all character markings
133 * (non-spacing, spacing and enclosing) (i.e. accents)
134 * NOTE: this option works only with COMPOSE or DECOMPOSE
135 */
136
137#define UTF8PROC_ERROR_NOMEM -1
138#define UTF8PROC_ERROR_OVERFLOW -2
139#define UTF8PROC_ERROR_INVALIDUTF8 -3
140#define UTF8PROC_ERROR_NOTASSIGNED -4
141#define UTF8PROC_ERROR_INVALIDOPTS -5
142/*
143 * Error codes being returned by almost all functions:
144 * ERROR_NOMEM: Memory could not be allocated.
145 * ERROR_OVERFLOW: The given string is too long to be processed.
146 * ERROR_INVALIDUTF8: The given string is not a legal UTF-8 string.
147 * ERROR_NOTASSIGNED: The REJECTNA flag was set,
148 * and an unassigned code point was found.
149 * ERROR_INVALIDOPTS: Invalid options have been used.
150 */
151
152typedef int16_t utf8proc_propval_t;
154 utf8proc_propval_t category;
155 utf8proc_propval_t combining_class;
156 utf8proc_propval_t bidi_class;
157 utf8proc_propval_t decomp_type;
158 const int32_t *decomp_mapping;
159 unsigned bidi_mirrored:1;
160 int32_t uppercase_mapping;
161 int32_t lowercase_mapping;
162 int32_t titlecase_mapping;
163 int32_t comb1st_index;
164 int32_t comb2nd_index;
165 unsigned comp_exclusion:1;
166 unsigned ignorable:1;
167 unsigned control_boundary:1;
168 unsigned extend:1;
169 const int32_t *casefold_mapping;
171
172#define UTF8PROC_CATEGORY_LU 1
173#define UTF8PROC_CATEGORY_LL 2
174#define UTF8PROC_CATEGORY_LT 3
175#define UTF8PROC_CATEGORY_LM 4
176#define UTF8PROC_CATEGORY_LO 5
177#define UTF8PROC_CATEGORY_MN 6
178#define UTF8PROC_CATEGORY_MC 7
179#define UTF8PROC_CATEGORY_ME 8
180#define UTF8PROC_CATEGORY_ND 9
181#define UTF8PROC_CATEGORY_NL 10
182#define UTF8PROC_CATEGORY_NO 11
183#define UTF8PROC_CATEGORY_PC 12
184#define UTF8PROC_CATEGORY_PD 13
185#define UTF8PROC_CATEGORY_PS 14
186#define UTF8PROC_CATEGORY_PE 15
187#define UTF8PROC_CATEGORY_PI 16
188#define UTF8PROC_CATEGORY_PF 17
189#define UTF8PROC_CATEGORY_PO 18
190#define UTF8PROC_CATEGORY_SM 19
191#define UTF8PROC_CATEGORY_SC 20
192#define UTF8PROC_CATEGORY_SK 21
193#define UTF8PROC_CATEGORY_SO 22
194#define UTF8PROC_CATEGORY_ZS 23
195#define UTF8PROC_CATEGORY_ZL 24
196#define UTF8PROC_CATEGORY_ZP 25
197#define UTF8PROC_CATEGORY_CC 26
198#define UTF8PROC_CATEGORY_CF 27
199#define UTF8PROC_CATEGORY_CS 28
200#define UTF8PROC_CATEGORY_CO 29
201#define UTF8PROC_CATEGORY_CN 30
202#define UTF8PROC_BIDI_CLASS_L 1
203#define UTF8PROC_BIDI_CLASS_LRE 2
204#define UTF8PROC_BIDI_CLASS_LRO 3
205#define UTF8PROC_BIDI_CLASS_R 4
206#define UTF8PROC_BIDI_CLASS_AL 5
207#define UTF8PROC_BIDI_CLASS_RLE 6
208#define UTF8PROC_BIDI_CLASS_RLO 7
209#define UTF8PROC_BIDI_CLASS_PDF 8
210#define UTF8PROC_BIDI_CLASS_EN 9
211#define UTF8PROC_BIDI_CLASS_ES 10
212#define UTF8PROC_BIDI_CLASS_ET 11
213#define UTF8PROC_BIDI_CLASS_AN 12
214#define UTF8PROC_BIDI_CLASS_CS 13
215#define UTF8PROC_BIDI_CLASS_NSM 14
216#define UTF8PROC_BIDI_CLASS_BN 15
217#define UTF8PROC_BIDI_CLASS_B 16
218#define UTF8PROC_BIDI_CLASS_S 17
219#define UTF8PROC_BIDI_CLASS_WS 18
220#define UTF8PROC_BIDI_CLASS_ON 19
221#define UTF8PROC_DECOMP_TYPE_FONT 1
222#define UTF8PROC_DECOMP_TYPE_NOBREAK 2
223#define UTF8PROC_DECOMP_TYPE_INITIAL 3
224#define UTF8PROC_DECOMP_TYPE_MEDIAL 4
225#define UTF8PROC_DECOMP_TYPE_FINAL 5
226#define UTF8PROC_DECOMP_TYPE_ISOLATED 6
227#define UTF8PROC_DECOMP_TYPE_CIRCLE 7
228#define UTF8PROC_DECOMP_TYPE_SUPER 8
229#define UTF8PROC_DECOMP_TYPE_SUB 9
230#define UTF8PROC_DECOMP_TYPE_VERTICAL 10
231#define UTF8PROC_DECOMP_TYPE_WIDE 11
232#define UTF8PROC_DECOMP_TYPE_NARROW 12
233#define UTF8PROC_DECOMP_TYPE_SMALL 13
234#define UTF8PROC_DECOMP_TYPE_SQUARE 14
235#define UTF8PROC_DECOMP_TYPE_FRACTION 15
236#define UTF8PROC_DECOMP_TYPE_COMPAT 16
237
238extern const int8_t utf8proc_utf8class[256];
239
240const char *utf8proc_version(void);
241
242const char *utf8proc_errmsg(ssize_t errcode);
243/*
244 * Returns a static error string for the given error code.
245 */
246
247ssize_t utf8proc_iterate(const uint8_t *str, ssize_t strlen, int32_t *dst);
248/*
249 * Reads a single char from the UTF-8 sequence being pointed to by 'str'.
250 * The maximum number of bytes read is 'strlen', unless 'strlen' is
251 * negative.
252 * If a valid unicode char could be read, it is stored in the variable
253 * being pointed to by 'dst', otherwise that variable will be set to -1.
254 * In case of success the number of bytes read is returned, otherwise a
255 * negative error code is returned.
256 */
257
258bool utf8proc_codepoint_valid(int32_t uc);
259/*
260 * Returns 1, if the given unicode code-point is valid, otherwise 0.
261 */
262
263ssize_t utf8proc_encode_char(int32_t uc, uint8_t *dst);
264/*
265 * Encodes the unicode char with the code point 'uc' as an UTF-8 string in
266 * the byte array being pointed to by 'dst'. This array has to be at least
267 * 4 bytes long.
268 * In case of success the number of bytes written is returned,
269 * otherwise 0.
270 * This function does not check if 'uc' is a valid unicode code point.
271 */
272
273const utf8proc_property_t *utf8proc_get_property(int32_t uc);
274/*
275 * Returns a pointer to a (constant) struct containing information about
276 * the unicode char with the given code point 'uc'.
277 * If the character is not existent a pointer to a special struct is
278 * returned, where 'category' is a NULL pointer.
279 * WARNING: The parameter 'uc' has to be in the range of 0x0000 to
280 * 0x10FFFF, otherwise the program might crash!
281 */
282
283ssize_t utf8proc_decompose_char(
284 int32_t uc, int32_t *dst, ssize_t bufsize,
285 int options, int *last_boundclass
286);
287/*
288 * Writes a decomposition of the unicode char 'uc' into the array being
289 * pointed to by 'dst'.
290 * Following flags in the 'options' field are regarded:
291 * REJECTNA: an unassigned unicode code point leads to an error
292 * IGNORE: "default ignorable" chars are stripped
293 * CASEFOLD: unicode casefolding is applied
294 * COMPAT: replace certain characters with their
295 * compatibility decomposition
296 * CHARBOUND: Inserts 0xFF bytes before each grapheme cluster
297 * LUMP: lumps certain different characters together
298 * STRIPMARK: removes all character marks
299 * The pointer 'last_boundclass' has to point to an integer variable which
300 * is storing the last character boundary class, if the CHARBOUND option
301 * is used.
302 * In case of success the number of chars written is returned,
303 * in case of an error, a negative error code is returned.
304 * If the number of written chars would be bigger than 'bufsize',
305 * the buffer (up to 'bufsize') has inpredictable data, and the needed
306 * buffer size is returned.
307 * WARNING: The parameter 'uc' has to be in the range of 0x0000 to
308 * 0x10FFFF, otherwise the program might crash!
309 */
310
311ssize_t utf8proc_decompose(
312 const uint8_t *str, ssize_t strlen,
313 int32_t *buffer, ssize_t bufsize, int options
314);
315/*
316 * Does the same as 'utf8proc_decompose_char', but acts on a whole UTF-8
317 * string, and orders the decomposed sequences correctly.
318 * If the NULLTERM flag in 'options' is set, processing will be stopped,
319 * when a NULL byte is encounted, otherwise 'strlen' bytes are processed.
320 * The result in form of unicode code points is written into the buffer
321 * being pointed to by 'buffer', having the length of 'bufsize' entries.
322 * In case of success the number of chars written is returned,
323 * in case of an error, a negative error code is returned.
324 * If the number of written chars would be bigger than 'bufsize',
325 * the buffer (up to 'bufsize') has inpredictable data, and the needed
326 * buffer size is returned.
327 */
328
329ssize_t utf8proc_reencode(int32_t *buffer, ssize_t length, int options);
330/*
331 * Reencodes the sequence of unicode characters given by the pointer
332 * 'buffer' and 'length' as UTF-8.
333 * The result is stored in the same memory area where the data is read.
334 * Following flags in the 'options' field are regarded:
335 * NLF2LS: converts LF, CRLF, CR and NEL into LS
336 * NLF2PS: converts LF, CRLF, CR and NEL into PS
337 * NLF2LF: converts LF, CRLF, CR and NEL into LF
338 * STRIPCC: strips or converts all non-affected control characters
339 * COMPOSE: tries to combine decomposed characters into composite
340 * characters
341 * STABLE: prohibits combining characters which would violate
342 * the unicode versioning stability
343 * In case of success the length of the resulting UTF-8 string is
344 * returned, otherwise a negative error code is returned.
345 * WARNING: The amount of free space being pointed to by 'buffer', has to
346 * exceed the amount of the input data by one byte, and the
347 * entries of the array pointed to by 'str' have to be in the
348 * range of 0x0000 to 0x10FFFF, otherwise the program might
349 * crash!
350 */
351
352ssize_t utf8proc_map(
353 const uint8_t *str, ssize_t strlen, uint8_t **dstptr, int options
354);
355/*
356 * Maps the given UTF-8 string being pointed to by 'str' to a new UTF-8
357 * string, which is allocated dynamically, and afterwards pointed to by
358 * the pointer being pointed to by 'dstptr'.
359 * If the NULLTERM flag in the 'options' field is set, the length is
360 * determined by a NULL terminator, otherwise the parameter 'strlen' is
361 * evaluated to determine the string length, but in any case the result
362 * will be NULL terminated (though it might contain NULL characters
363 * before). Other flags in the 'options' field are passed to the functions
364 * defined above, and regarded as described.
365 * In case of success the length of the new string is returned,
366 * otherwise a negative error code is returned.
367 * NOTICE: The memory of the new UTF-8 string will have been allocated with
368 * 'malloc', and has theirfore to be freed with 'free'.
369 */
370
371uint8_t *utf8proc_NFD(const uint8_t *str);
372uint8_t *utf8proc_NFC(const uint8_t *str);
373uint8_t *utf8proc_NFKD(const uint8_t *str);
374uint8_t *utf8proc_NFKC(const uint8_t *str);
375/*
376 * Returns a pointer to newly allocated memory of a NFD, NFC, NFKD or NFKC
377 * normalized version of the null-terminated string 'str'.
378 */
379
380#ifdef __cplusplus
381}
382#endif
383
384#endif
385
Provide printf() PRIxxx Constante Beyond Standards.
Definition: utf8proc.h:153
