RTEMS 5.2
epapr_hcalls.h
1/*
2 * ePAPR hcall interface
3 *
4 * Copyright 2008-2011 Freescale Semiconductor, Inc.
5 *
6 * Author: Timur Tabi <timur@freescale.com>
7 *
8 * This file is provided under a dual BSD/GPL license. When using or
9 * redistributing this file, you may do so under either license.
10 *
11 * Redistribution and use in source and binary forms, with or without
12 * modification, are permitted provided that the following conditions are met:
13 * * Redistributions of source code must retain the above copyright
14 * notice, this list of conditions and the following disclaimer.
15 * * Redistributions in binary form must reproduce the above copyright
16 * notice, this list of conditions and the following disclaimer in the
17 * documentation and/or other materials provided with the distribution.
18 * * Neither the name of Freescale Semiconductor nor the
19 * names of its contributors may be used to endorse or promote products
20 * derived from this software without specific prior written permission.
21 *
22 *
23 * ALTERNATIVELY, this software may be distributed under the terms of the
24 * GNU General Public License ("GPL") as published by the Free Software
25 * Foundation, either version 2 of that License or (at your option) any
26 * later version.
27 *
28 * THIS SOFTWARE IS PROVIDED BY Freescale Semiconductor ``AS IS'' AND ANY
29 * EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
30 * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
31 * DISCLAIMED. IN NO EVENT SHALL Freescale Semiconductor BE LIABLE FOR ANY
32 * DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
33 * (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
34 * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
35 * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
36 * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
37 * SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
38 */
39
40#ifndef _UAPI_ASM_POWERPC_EPAPR_HCALLS_H
41#define _UAPI_ASM_POWERPC_EPAPR_HCALLS_H
42
43#define EV_BYTE_CHANNEL_SEND 1
44#define EV_BYTE_CHANNEL_RECEIVE 2
45#define EV_BYTE_CHANNEL_POLL 3
46#define EV_INT_SET_CONFIG 4
47#define EV_INT_GET_CONFIG 5
48#define EV_INT_SET_MASK 6
49#define EV_INT_GET_MASK 7
50#define EV_INT_IACK 9
51#define EV_INT_EOI 10
52#define EV_INT_SEND_IPI 11
53#define EV_INT_SET_TASK_PRIORITY 12
54#define EV_INT_GET_TASK_PRIORITY 13
55#define EV_DOORBELL_SEND 14
56#define EV_MSGSND 15
57#define EV_IDLE 16
58
59/* vendor ID: epapr */
60#define EV_LOCAL_VENDOR_ID 0 /* for private use */
61#define EV_EPAPR_VENDOR_ID 1
62#define EV_FSL_VENDOR_ID 2 /* Freescale Semiconductor */
63#define EV_IBM_VENDOR_ID 3 /* IBM */
64#define EV_GHS_VENDOR_ID 4 /* Green Hills Software */
65#define EV_ENEA_VENDOR_ID 5 /* Enea */
66#define EV_WR_VENDOR_ID 6 /* Wind River Systems */
67#define EV_AMCC_VENDOR_ID 7 /* Applied Micro Circuits */
68#define EV_KVM_VENDOR_ID 42 /* KVM */
69
70/* The max number of bytes that a byte channel can send or receive per call */
71#define EV_BYTE_CHANNEL_MAX_BYTES 16
72
73
74#define _EV_HCALL_TOKEN(id, num) (((id) << 16) | (num))
75#define EV_HCALL_TOKEN(hcall_num) _EV_HCALL_TOKEN(EV_EPAPR_VENDOR_ID, hcall_num)
76
77/* epapr return codes */
78#define EV_SUCCESS 0
79#define EV_EPERM 1 /* Operation not permitted */
80#define EV_ENOENT 2 /* Entry Not Found */
81#define EV_EIO 3 /* I/O error occurred */
82#define EV_EAGAIN 4 /* The operation had insufficient
83 * resources to complete and should be
84 * retried
85 */
86#define EV_ENOMEM 5 /* There was insufficient memory to
87 * complete the operation */
88#define EV_EFAULT 6 /* Bad guest address */
89#define EV_ENODEV 7 /* No such device */
90#define EV_EINVAL 8 /* An argument supplied to the hcall
91 was out of range or invalid */
92#define EV_INTERNAL 9 /* An internal error occurred */
93#define EV_CONFIG 10 /* A configuration error was detected */
94#define EV_INVALID_STATE 11 /* The object is in an invalid state */
95#define EV_UNIMPLEMENTED 12 /* Unimplemented hypercall */
96#define EV_BUFFER_OVERFLOW 13 /* Caller-supplied buffer too small */
97
98#endif /* _UAPI_ASM_POWERPC_EPAPR_HCALLS_H */
