RTEMS 5.2
twiRegs.h
1/* Blackfin Two Wire Interface Registers
2 *
3 * Copyright (c) 2008 Kallisti Labs, Los Gatos, CA, USA
4 * written by Allan Hessenflow <allanh@kallisti.com>
5 *
6 * The license and distribution terms for this file may be
7 * found in the file LICENSE in this distribution or at
8 * http://www.rtems.org/license/LICENSE.
9 */
10
11#ifndef _twiRegs_h_
12#define _twiRegs_h_
13
14
15/* register addresses */
16
17#define TWI_CLKDIV_OFFSET 0x0000
18#define TWI_CONTROL_OFFSET 0x0004
19#define TWI_SLAVE_CTL_OFFSET 0x0008
20#define TWI_SLAVE_STAT_OFFSET 0x000c
21#define TWI_SLAVE_ADDR_OFFSET 0x0010
22#define TWI_MASTER_CTL_OFFSET 0x0014
23#define TWI_MASTER_STAT_OFFSET 0x0018
24#define TWI_MASTER_ADDR_OFFSET 0x001c
25#define TWI_INT_STAT_OFFSET 0x0020
26#define TWI_INT_MASK_OFFSET 0x0024
27#define TWI_FIFO_CTL_OFFSET 0x0028
28#define TWI_FIFO_STAT_OFFSET 0x002c
29#define TWI_XMT_DATA8_OFFSET 0x0080
30#define TWI_XMT_DATA16_OFFSET 0x0084
31#define TWI_RCV_DATA8_OFFSET 0x0088
32#define TWI_RCV_DATA16_OFFSET 0x008c
33
34
35/* register fields */
36
37#define TWI_CLKDIV_CLKHI_MASK 0xff00
38#define TWI_CLKDIV_CLKHI_SHIFT 8
39#define TWI_CLKDIV_CLKLOW_MASK 0x00ff
40#define TWI_CLKDIV_CLKLOW_SHIFT 0
41
42#define TWI_CONTROL_SCCB 0x0200
43#define TWI_CONTROL_TWI_ENA 0x0080
44#define TWI_CONTROL_PRESCALE_MASK 0x007f
45#define TWI_CONTROL_PRESCALE_SHIFT 0
46
47#define TWI_SLAVE_CTL_GEN 0x0010
48#define TWI_SLAVE_CTL_NAK 0x0008
49#define TWI_SLAVE_CTL_STDVAL 0x0004
50#define TWI_SLAVE_CTL_SEN 0x0001
51
52#define TWI_SLAVE_STAT_GCALL 0x0002
53#define TWI_SLAVE_STAT_SDIR 0x0001
54
55#define TWI_SLAVE_ADDR_SADDR_MASK 0x007f
56#define TWI_SLAVE_ADDR_SADDR_SHIFT 0
57
58#define TWI_MASTER_CTL_SCLOVR 0x8000
59#define TWI_MASTER_CTL_SDAOVR 0x4000
60#define TWI_MASTER_CTL_DCNT_MASK 0x3fc0
61#define TWI_MASTER_CTL_DCNT_SHIFT 6
62#define TWI_MASTER_CTL_RSTART 0x0020
63#define TWI_MASTER_CTL_STOP 0x0010
64#define TWI_MASTER_CTL_FAST 0x0008
65#define TWI_MASTER_CTL_MDIR 0x0004
66#define TWI_MASTER_CTL_MEN 0x0001
67
68#define TWI_MASTER_STAT_BUSBUSY 0x0100
69#define TWI_MASTER_STAT_SCLSEN 0x0080
70#define TWI_MASTER_STAT_SDASEN 0x0040
71#define TWI_MASTER_STAT_BUFWRERR 0x0020
72#define TWI_MASTER_STAT_BUFRDERR 0x0010
73#define TWI_MASTER_STAT_DNAK 0x0008
74#define TWI_MASTER_STAT_ANAK 0x0004
75#define TWI_MASTER_STAT_LOSTARB 0x0002
76#define TWI_MASTER_STAT_MPROG 0x0001
77
78#define TWI_MASTER_ADDR_MADDR_MASK 0x007f
79#define TWI_MASTER_ADDR_MADDR_SHIFT 0
80
81#define TWI_INT_STAT_RCVSERV 0x0080
82#define TWI_INT_STAT_XMTSERV 0x0040
83#define TWI_INT_STAT_MERR 0x0020
84#define TWI_INT_STAT_MCOMP 0x0010
85#define TWI_INT_STAT_SOVF 0x0008
86#define TWI_INT_STAT_SERR 0x0004
87#define TWI_INT_STAT_SCOMP 0x0002
88#define TWI_INT_STAT_SINIT 0x0001
89
90#define TWI_INT_MASK_RCVSERVM 0x0080
91#define TWI_INT_MASK_XMTSERVM 0x0040
92#define TWI_INT_MASK_MERRM 0x0020
93#define TWI_INT_MASK_MCOMPM 0x0010
94#define TWI_INT_MASK_SOVFM 0x0008
95#define TWI_INT_MASK_SERRM 0x0004
96#define TWI_INT_MASK_SCOMPM 0x0002
97#define TWI_INT_MASK_SINITM 0x0001
98
99#define TWI_FIFO_CTL_RCVINTLEN 0x0008
100#define TWI_FIFO_CTL_XMTINTLEN 0x0004
101#define TWI_FIFO_CTL_RCVFLUSH 0x0002
102#define TWI_FIFO_CTL_XMTFLUSH 0x0001
103
104#define TWI_FIFO_STAT_RCVSTAT_MASK 0x000c
105#define TWI_FIFO_STAT_RCVSTAT_EMPTY 0x0000
106#define TWI_FIFO_STAT_RCVSTAT_SHIFT 2
107#define TWI_FIFO_STAT_XMTSTAT_MASK 0x0003
108#define TWI_FIFO_STAT_XMTSTAT_FULL 0x0003
109#define TWI_FIFO_STAT_XMTSTAT_SHIFT 0
110
111#define TWI_XMT_DATA8_XMTDATA8_MASK 0x00ff
112#define TWI_XMT_DATA8_XMTDATA8_SHIFT 0
113
114#define TWI_RCV_DATA8_RCVDATA8_MASK 0x00ff
115#define TWI_RCV_DATA8_RCVDATA8_SHIFT 0
116
117
118#endif /* _twiRegs_h_ */
