RTEMS 5.2
tsmac.h
1
7/*
8 * This file contains definitions for LatticeMico32 TSMAC (Tri-Speed MAC)
9 *
10 * COPYRIGHT (c) 1989-1999.
11 * On-Line Applications Research Corporation (OAR).
12 *
13 * The license and distribution terms for this file may be
14 * found in the file LICENSE in this distribution or at
15 * http://www.rtems.org/license/LICENSE.
16 *
17 * Jukka Pietarinen <jukka.pietarinen@mrf.fi>, 2008,
18 * Micro-Research Finland Oy
19 */
20
28#ifndef _BSPTSMAC_H
29#define _BSPTSMAC_H
30
31/* FIFO Registers */
32
33#define LM32_TSMAC_RX_LEN_FIFO (0x000)
34#define LM32_TSMAC_RX_DATA_FIFO (0x004)
35#define LM32_TSMAC_TX_LEN_FIFO (0x008)
36#define LM32_TSMAC_TX_DATA_FIFO (0x00C)
37
38/* Control and Status Registers */
39
40#define LM32_TSMAC_VERID (0x100)
41#define LM32_TSMAC_INTR_SRC (0x104)
42#define INTR_RX_SMRY (0x00020000)
43#define INTR_TX_SMRY (0x00010000)
44#define INTR_RX_FIFO_FULL (0x00001000)
45#define INTR_RX_ERROR (0x00000800)
46#define INTR_RX_FIFO_ERROR (0x00000400)
47#define INTR_RX_FIFO_ALMOST_FULL (0x00000200)
48#define INTR_RX_PKT_RDY (0x00000100)
49#define INTR_TX_FIFO_FULL (0x00000010)
50#define INTR_TX_DISCFRM (0x00000008)
51#define INTR_TX_FIFO_ALMOST_EMPTY (0x00000004)
52#define INTR_TX_FIFO_ALMOST_FULL (0x00000002)
53#define INTR_TX_PKT_SENT (0x00000001)
54#define LM32_TSMAC_INTR_ENB (0x108)
55#define INTR_ENB (0x00040000)
56#define LM32_TSMAC_RX_STATUS (0x10C)
57#define STAT_RX_FIFO_FULL (0x00000010)
58#define STAT_RX_ERROR (0x00000008)
59#define STAT_RX_FIFO_ERROR (0x00000004)
60#define STAT_RX_FIFO_ALMOST_FULL (0x00000002)
61#define STAT_RX_PKT_RDY (0x00000001)
62#define LM32_TSMAC_TX_STATUS (0x110)
63#define STAT_TX_FIFO_FULL (0x00000010)
64#define STAT_TX_DISCFRM (0x00000008)
65#define STAT_TX_FIFO_ALMOST_EMPTY (0x00000004)
66#define STAT_TX_FIFO_ALMOST_FULL (0x00000002)
67#define STAT_TX_PKT_SENT (0x00000001)
68#define LM32_TSMAC_RX_FRAMES_CNT (0x114)
69#define LM32_TSMAC_TX_FRAMES_CNT (0x118)
70#define LM32_TSMAC_RX_FIFO_TH (0x11C)
71#define LM32_TSMAC_TX_FIFO_TH (0x120)
72#define LM32_TSMAC_SYS_CTL (0x124)
73#define SYS_CTL_TX_FIFO_FLUSH (0x00000010)
74#define SYS_CTL_RX_FIFO_FLUSH (0x00000008)
75#define SYS_CTL_TX_SNDPAUSREQ (0x00000004)
76#define SYS_CTL_TX_FIFOCTRL (0x00000002)
77#define SYS_CTL_IGNORE_NEXT_PKT (0x00000001)
78#define LM32_TSMAC_PAUSE_TMR (0x128)
79
80/* Tri-Speed MAC Registers */
81
82#define LM32_TSMAC_MAC_REGS_DATA (0x200)
83#define LM32_TSMAC_MAC_REGS_ADDR_RW (0x204)
84#define REGS_ADDR_WRITE (0x80000000)
85#define LM32_TSMAC_MODE_BYTE0 (0x000)
86#define MODE_TX_EN (1<<3)
87#define MODE_RX_EN (1<<2)
88#define MODE_FC_EN (1<<1)
89#define MODE_GBIT_EN (1<<0)
90#define LM32_TSMAC_TX_RX_CTL_BYTE0 (0x002)
91#define TX_RX_CTL_RECEIVE_SHORT (1<<8)
92#define TX_RX_CTL_RECEIVE_BRDCST (1<<7)
93#define TX_RX_CTL_DIS_RTRY (1<<6)
94#define TX_RX_CTL_HDEN (1<<5)
95#define TX_RX_CTL_RECEIVE_MLTCST (1<<4)
96#define TX_RX_CTL_RECEIVE_PAUSE (1<<3)
97#define TX_RX_CTL_TX_DIS_FCS (1<<2)
98#define TX_RX_CTL_DISCARD_FCS (1<<1)
99#define TX_RX_CTL_PRMS (1<<0)
100#define LM32_TSMAC_MAX_PKT_SIZE_BYTE0 (0x004)
101#define LM32_TSMAC_IPG_VAL_BYTE0 (0x008)
102#define LM32_TSMAC_MAC_ADDR_0_BYTE0 (0x00A)
103#define LM32_TSMAC_MAC_ADDR_1_BYTE0 (0x00C)
104#define LM32_TSMAC_MAC_ADDR_2_BYTE0 (0x00E)
105#define LM32_TSMAC_TX_RX_STS_BYTE0 (0x012)
106#define TX_RX_STS_RX_IDLE (1<<10)
107#define TX_RX_STS_TAGGED_FRAME (1<<9)
108#define TX_RX_STS_BRDCST_FRAME (1<<8)
109#define TX_RX_STS_MULTCST_FRAME (1<<7)
110#define TX_RX_STS_IPG_SHRINK (1<<6)
111#define TX_RX_STS_SHORT_FRAME (1<<5)
112#define TX_RX_STS_LONG_FRAME (1<<4)
113#define TX_RX_STS_ERROR_FRAME (1<<3)
114#define TX_RX_STS_CRC (1<<2)
115#define TX_RX_STS_PAUSE_FRAME (1<<1)
116#define TX_RX_STS_TX_IDLE (1<<0)
117#define LM32_TSMAC_GMII_MNG_CTL_BYTE0 (0x014)
118#define GMII_MNG_CTL_CMD_FIN (1<<14)
119#define GMII_MNG_CTL_READ_PHYREG (0)
120#define GMII_MNG_CTL_WRITE_PHYREG (1<<13)
121#define GMII_MNG_CTL_PHY_ADD_MASK (0x001f)
122#define GMII_MNG_CTL_PHY_ADD_SHIFT (8)
123#define GMII_MNG_CTL_REG_ADD_MASK (0x001f)
124#define GMII_MNG_CTL_REG_ADD_SHIFT (0)
125#define LM32_TSMAC_GMII_MNG_DAT_BYTE0 (0x016)
126#define LM32_TSMAC_MLT_TAB_0_BYTE0 (0x022)
127#define LM32_TSMAC_MLT_TAB_1_BYTE0 (0x024)
128#define LM32_TSMAC_MLT_TAB_2_BYTE0 (0x026)
129#define LM32_TSMAC_MLT_TAB_3_BYTE0 (0x028)
130#define LM32_TSMAC_MLT_TAB_4_BYTE0 (0x02A)
131#define LM32_TSMAC_MLT_TAB_5_BYTE0 (0x02C)
132#define LM32_TSMAC_MLT_TAB_6_BYTE0 (0x02E)
133#define LM32_TSMAC_MLT_TAB_7_BYTE0 (0x030)
134#define LM32_TSMAC_VLAN_TAG_BYTE0 (0x032)
135#define LM32_TSMAC_PAUS_OP_BYTE0 (0x034)
136
137/* Receive Statistics Counters */
138
139#define LM32_TSMAC_RX_PKT_IGNR_CNT (0x300)
140#define LM32_TSMAC_RX_LEN_CHK_ERR_CNT (0x304)
141#define LM32_TSMAC_RX_LNG_FRM_CNT (0x308)
142#define LM32_TSMAC_RX_SHRT_FRM_CNT (0x30C)
143#define LM32_TSMAC_RX_IPG_VIOL_CNT (0x310)
144#define LM32_TSMAC_RX_CRC_ERR_CNT (0x314)
145#define LM32_TSMAC_RX_OK_PKT_CNT (0x318)
146#define LM32_TSMAC_RX_CTL_FRM_CNT (0x31C)
147#define LM32_TSMAC_RX_PAUSE_FRM_CNT (0x320)
148#define LM32_TSMAC_RX_MULTICAST_CNT (0x324)
149#define LM32_TSMAC_RX_BRDCAST_CNT (0x328)
150#define LM32_TSMAC_RX_VLAN_TAG_CNT (0x32C)
151#define LM32_TSMAC_RX_PRE_SHRINK_CNT (0x330)
152#define LM32_TSMAC_RX_DRIB_NIB_CNT (0x334)
153#define LM32_TSMAC_RX_UNSUP_OPCD_CNT (0x338)
154#define LM32_TSMAC_RX_BYTE_CNT (0x33C)
155
156/* Transmit Statistics Counters */
157
158#define LM32_TSMAC_TX_UNICAST_CNT (0x400)
159#define LM32_TSMAC_TX_PAUSE_FRM_CNT (0x404)
160#define LM32_TSMAC_TX_MULTICAST_CNT (0x408)
161#define LM32_TSMAC_TX_BRDCAST_CNT (0x40C)
162#define LM32_TSMAC_TX_VLAN_TAG_CNT (0x410)
163#define LM32_TSMAC_TX_BAD_FCS_CNT (0x414)
164#define LM32_TSMAC_TX_JUMBO_CNT (0x418)
165#define LM32_TSMAC_TX_BYTE_CNT (0x41C)
166
167#ifdef CPU_U32_FIX
168void ipalign(struct mbuf *m);
169#endif
170
171#endif /* _BSPTSMAC_H */
