RTEMS 5.2
timepps.h
1/*-
2 * ----------------------------------------------------------------------------
3 * "THE BEER-WARE LICENSE" (Revision 42):
4 * <phk@FreeBSD.org> wrote this file. As long as you retain this notice you
5 * can do whatever you want with this stuff. If we meet some day, and you think
6 * this stuff is worth it, you can buy me a beer in return. Poul-Henning Kamp
7 * ----------------------------------------------------------------------------
8 *
9 * Copyright (c) 2011 The FreeBSD Foundation
10 * All rights reserved.
11 *
12 * Portions of this software were developed by Julien Ridoux at the University
13 * of Melbourne under sponsorship from the FreeBSD Foundation.
14 *
15 * $FreeBSD: head/sys/sys/timepps.h 282424 2015-05-04 17:59:39Z ian $
16 *
17 * The is a FreeBSD version of the RFC 2783 API for Pulse Per Second
18 * timing interfaces.
19 */
20
21#ifndef _SYS_TIMEPPS_H_
22#define _SYS_TIMEPPS_H_
23
24#include <sys/_ffcounter.h>
25#include <sys/ioccom.h>
26#include <sys/time.h>
27
28#define PPS_API_VERS_1 1
29
30typedef int pps_handle_t;
31
32typedef unsigned pps_seq_t;
33
34typedef struct ntp_fp {
35 unsigned int integral;
36 unsigned int fractional;
37} ntp_fp_t;
38
39typedef union pps_timeu {
40 struct timespec tspec;
41 ntp_fp_t ntpfp;
42 unsigned long longpad[3];
44
45typedef struct {
46 pps_seq_t assert_sequence; /* assert event seq # */
47 pps_seq_t clear_sequence; /* clear event seq # */
48 pps_timeu_t assert_tu;
49 pps_timeu_t clear_tu;
50 int current_mode; /* current mode bits */
52
53typedef struct {
54 pps_seq_t assert_sequence; /* assert event seq # */
55 pps_seq_t clear_sequence; /* clear event seq # */
56 pps_timeu_t assert_tu;
57 pps_timeu_t clear_tu;
58 ffcounter assert_ffcount; /* ffcounter on assert event */
59 ffcounter clear_ffcount; /* ffcounter on clear event */
60 int current_mode; /* current mode bits */
62
63#define assert_timestamp assert_tu.tspec
64#define clear_timestamp clear_tu.tspec
65
66#define assert_timestamp_ntpfp assert_tu.ntpfp
67#define clear_timestamp_ntpfp clear_tu.ntpfp
68
69typedef struct {
70 int api_version; /* API version # */
71 int mode; /* mode bits */
72 pps_timeu_t assert_off_tu;
73 pps_timeu_t clear_off_tu;
75
76#define assert_offset assert_off_tu.tspec
77#define clear_offset clear_off_tu.tspec
78
79#define assert_offset_ntpfp assert_off_tu.ntpfp
80#define clear_offset_ntpfp clear_off_tu.ntpfp
81
82
83#define PPS_CAPTUREASSERT 0x01
84#define PPS_CAPTURECLEAR 0x02
85#define PPS_CAPTUREBOTH 0x03
86
87#define PPS_OFFSETASSERT 0x10
88#define PPS_OFFSETCLEAR 0x20
89
90#define PPS_ECHOASSERT 0x40
91#define PPS_ECHOCLEAR 0x80
92
93#define PPS_CANWAIT 0x100
94#define PPS_CANPOLL 0x200
95
96#define PPS_TSFMT_TSPEC 0x1000
97#define PPS_TSFMT_NTPFP 0x2000
98
99#define PPS_TSCLK_FBCK 0x10000
100#define PPS_TSCLK_FFWD 0x20000
101#define PPS_TSCLK_MASK 0x30000
102
103#define PPS_KC_HARDPPS 0
104#define PPS_KC_HARDPPS_PLL 1
105#define PPS_KC_HARDPPS_FLL 2
106
108 int tsformat;
109 pps_info_t pps_info_buf;
110 struct timespec timeout;
111};
112
114 int tsformat;
115 pps_info_ffc_t pps_info_buf_ffc;
116 struct timespec timeout;
117};
118
120 int kernel_consumer;
121 int edge;
122 int tsformat;
123};
124
125#define PPS_IOC_CREATE _IO('1', 1)
126#define PPS_IOC_DESTROY _IO('1', 2)
127#define PPS_IOC_SETPARAMS _IOW('1', 3, pps_params_t)
128#define PPS_IOC_GETPARAMS _IOR('1', 4, pps_params_t)
129#define PPS_IOC_GETCAP _IOR('1', 5, int)
130#define PPS_IOC_FETCH _IOWR('1', 6, struct pps_fetch_args)
131#define PPS_IOC_KCBIND _IOW('1', 7, struct pps_kcbind_args)
132#define PPS_IOC_FETCH_FFCOUNTER _IOWR('1', 8, struct pps_fetch_ffc_args)
133
134#ifdef _KERNEL
135
136struct mtx;
137
138#define KCMODE_EDGEMASK 0x03
139#define KCMODE_ABIFLAG 0x80000000 /* Internal use: abi-aware driver. */
140
141#define PPS_ABI_VERSION 1
142
143#define PPSFLAG_MTX_SPIN 0x01 /* Driver mtx is MTX_SPIN type. */
144
145struct pps_state {
146 /* Capture information. */
147 struct timehands *capth;
148 struct fftimehands *capffth;
149 unsigned capgen;
150 unsigned capcount;
151
152 /* State information. */
153 pps_params_t ppsparam;
154 pps_info_t ppsinfo;
155 pps_info_ffc_t ppsinfo_ffc;
156 int kcmode;
157 int ppscap;
158 struct timecounter *ppstc;
159 unsigned ppscount[3];
160 /*
161 * The following fields are valid if the driver calls pps_init_abi().
162 */
163 uint16_t driver_abi; /* Driver sets before pps_init_abi(). */
164 uint16_t kernel_abi; /* Kernel sets during pps_init_abi(). */
165 struct mtx *driver_mtx; /* Optional, valid if non-NULL. */
166 uint32_t flags;
167};
168
169void pps_capture(struct pps_state *pps);
170void pps_event(struct pps_state *pps, int event);
171void pps_init(struct pps_state *pps);
172void pps_init_abi(struct pps_state *pps);
173int pps_ioctl(unsigned long cmd, caddr_t data, struct pps_state *pps);
174void hardpps(struct timespec *tsp, long nsec);
175
176#else /* !_KERNEL */
177
178static __inline int
179time_pps_create(int filedes, pps_handle_t *handle)
180{
181 int error;
182
183 *handle = -1;
184 error = ioctl(filedes, PPS_IOC_CREATE, 0);
185 if (error < 0)
186 return (-1);
187 *handle = filedes;
188 return (0);
189}
190
191static __inline int
192time_pps_destroy(pps_handle_t handle)
193{
194 return (ioctl(handle, PPS_IOC_DESTROY, 0));
195}
196
197static __inline int
198time_pps_setparams(pps_handle_t handle, const pps_params_t *ppsparams)
199{
200 return (ioctl(handle, PPS_IOC_SETPARAMS, ppsparams));
201}
202
203static __inline int
204time_pps_getparams(pps_handle_t handle, pps_params_t *ppsparams)
205{
206 return (ioctl(handle, PPS_IOC_GETPARAMS, ppsparams));
207}
208
209static __inline int
210time_pps_getcap(pps_handle_t handle, int *mode)
211{
212 return (ioctl(handle, PPS_IOC_GETCAP, mode));
213}
214
215static __inline int
216time_pps_fetch(pps_handle_t handle, const int tsformat,
217 pps_info_t *ppsinfobuf, const struct timespec *timeout)
218{
219 int error;
220 struct pps_fetch_args arg;
221
222 arg.tsformat = tsformat;
223 if (timeout == NULL) {
224 arg.timeout.tv_sec = -1;
225 arg.timeout.tv_nsec = -1;
226 } else
227 arg.timeout = *timeout;
228 error = ioctl(handle, PPS_IOC_FETCH, &arg);
229 *ppsinfobuf = arg.pps_info_buf;
230 return (error);
231}
232
233static __inline int
234time_pps_fetch_ffc(pps_handle_t handle, const int tsformat,
235 pps_info_ffc_t *ppsinfobuf, const struct timespec *timeout)
236{
237 struct pps_fetch_ffc_args arg;
238 int error;
239
240 arg.tsformat = tsformat;
241 if (timeout == NULL) {
242 arg.timeout.tv_sec = -1;
243 arg.timeout.tv_nsec = -1;
244 } else {
245 arg.timeout = *timeout;
246 }
247 error = ioctl(handle, PPS_IOC_FETCH_FFCOUNTER, &arg);
248 *ppsinfobuf = arg.pps_info_buf_ffc;
249 return (error);
250}
251
252static __inline int
253time_pps_kcbind(pps_handle_t handle, const int kernel_consumer,
254 const int edge, const int tsformat)
255{
256 struct pps_kcbind_args arg;
257
258 arg.kernel_consumer = kernel_consumer;
259 arg.edge = edge;
260 arg.tsformat = tsformat;
261 return (ioctl(handle, PPS_IOC_KCBIND, &arg));
262}
263
264#endif /* KERNEL */
265
266#endif /* !_SYS_TIMEPPS_H_ */
#define NULL
Requests a GPIO pin group configuration.
Definition: bestcomm_api.h:77
Definition: if_fxpvar.h:78
Definition: timepps.h:34
Definition: timepps.h:107
Definition: timepps.h:113
Definition: timepps.h:53
Definition: timepps.h:45
Definition: timepps.h:119
Definition: timepps.h:69
Definition: timetc.h:46
Definition: kern_tc.c:165
Definition: timepps.h:39
