RTEMS 5.2
tfs.h
1
10/* Based upon code from MicroMonitor 1.17 from http://www.umonfw.com/
11 * which includes this notice:
12 *
13 **************************************************************************
14 * General notice:
15 * This code is part of a boot-monitor package developed as a generic base
16 * platform for embedded system designs. As such, it is likely to be
17 * distributed to various projects beyond the control of the original
18 * author. Please notify the author of any enhancements made or bugs found
19 * so that all may benefit from the changes. In addition, notification back
20 * to the author will allow the new user to pick up changes that may have
21 * been made by other users after this version of the code was distributed.
22 *
23 * Note1: the majority of this code was edited with 4-space tabs.
24 * Note2: as more and more contributions are accepted, the term "author"
25 * is becoming a mis-representation of credit.
26 *
27 * Original author: Ed Sutter
28 * Email: esutter@alcatel-lucent.com
29 * Phone: 908-582-2351
30 **************************************************************************
31 *
32 * Ed Sutter has been informed that this code is being used in RTEMS.
33 *
34 * This code was reformatted by Joel Sherrill from OAR Corporation and
35 * Fernando Nicodemos <fgnicodemos@terra.com.br> from NCB - Sistemas
36 * Embarcados Ltda. (Brazil) to be more compliant with RTEMS coding
37 * standards and to eliminate C++ style comments.
38 */
39
40#ifndef _tfs_h
41#define _tfs_h
42
51#define TFSINFOSIZE 23 /* Max size of info string (mod4-1). */
52
53#ifndef TFSNAMESIZE /* This specifies the maximum size of a file */
54#define TFSNAMESIZE 23 /* name that can be used in TFS. */
55#endif /* This MUST be some value mod4 - 1. */
56
57#ifndef TFS_CHANGELOG_FILE /* Information used for change-log */
58#define TFS_CHANGELOG_SIZE 0 /* facility within tfs. */
59#define TFS_CHANGELOG_FILE ".tfschlog"
60#endif
61
62#ifndef SYMFILE /* This specifies the default filename */
63#define SYMFILE "symtbl" /* used by the monitor for the symbol */
64#endif /* table. */
65
66#define MINUSRLEVEL 0 /* Minimum user level supported. */
67#define MAXUSRLEVEL 3 /* Maximum user level supported. */
68
69#ifndef TFS_RESERVED
70#define TFS_RESERVED 4 /* Number of "reserved" entries (ulong) */
71#endif /* in the TFS header. */
72
73
74/* Flags: */
75#define TFS_EXEC 0x00000001 /* 'e': Executable script. */
76#define TFS_BRUN 0x00000002 /* 'b': To be executed at boot. */
77#define TFS_QRYBRUN 0x00000004 /* 'B': To be executed at boot if */
78 /* query passes. */
79#define TFS_SYMLINK 0x00000008 /* 'l': Symbolic link file. */
80#define TFS_EBIN 0x00000010 /* 'E': Executable binary (coff/elf/a.out). */
81#define TFS_CPRS 0x00000040 /* 'c': File is compressed. */
82#define TFS_IPMOD 0x00000080 /* 'i': File is in-place modifiable. */
83#define TFS_UNREAD 0x00000100 /* 'u': File is not even readable if the */
84 /* user-level requirement is not met; */
85 /* else, it is read-only. */
86#define TFS_ULVLMSK 0x00000600 /* User level mask defines 4 access levels: */
87#define TFS_ULVL0 0x00000000 /* '0' level 0 */
88#define TFS_ULVL1 0x00000200 /* '1' level 1 */
89#define TFS_ULVL2 0x00000400 /* '2' level 2 */
90#define TFS_ULVL3 0x00000600 /* '3' level 3 */
91#define TFS_NSTALE 0x00000800 /* File is NOT stale, invisible to user.
92 * When this bit is clear, the file is
93 * considered stale (see notes in tfsadd()).
94 * See notes in tfsclose() for this.
95 */
96#define TFS_ACTIVE 0x00008000 /* Used to indicate that file is not deleted. */
97
98#define TFS_ULVLMAX TFS_ULVL3
99#define TFS_USRLVL(f) ((f->flags & TFS_ULVLMSK) >> 9)
100
101/* Open modes */
102#define TFS_RDONLY 0x00010000 /* File is opened for reading. */
103#define TFS_CREATE 0x00020000 /* File is to be created. Error if file */
104 /* with the same name already exists. */
105#define TFS_APPEND 0x00040000 /* Append to existing file. If OR'ed */
106 /* with TFS_CREATE, then create if */
107 /* necessary. */
108#define TFS_ALLFFS 0x00080000 /* File is created with all FFs. */
109#define TFS_CREATERM 0x00100000 /* File is to be created. If file with */
110 /* same name already exists, then allow */
111 /* tfsadd() to remove it if necessary. */
112
113/* The function tfsrunrc() will search through the current file set and */
114/* if the file defined by TFS_RCFILE exists, it will be executed. */
115/* If this file exists, it will NOT be run by tfsrunboot(). */
116#define TFS_RCFILE "monrc"
117
118/* Requests that can be made to tfsctrl(): */
119#define TFS_ERRMSG 1
120#define TFS_MEMUSE 2
121#define TFS_MEMDEAD 3
122#define TFS_DEFRAG 4
123#define TFS_TELL 5
124#define TFS_UNOPEN 7
125#define TFS_FATOB 8
126#define TFS_FBTOA 9
127#define TFS_MEMAVAIL 10
128#define TFS_TIMEFUNCS 11
129#define TFS_DOCOMMAND 12
130#define TFS_INITDEV 13
131#define TFS_CHECKDEV 14
132#define TFS_DEFRAGDEV 15
133#define TFS_DEFRAGOFF 16
134#define TFS_DEFRAGON 17
135#define TFS_HEADROOM 18
136#define TFS_FCOUNT 19
137
138/* struct tfshdr:
139 * It is in FLASH as part of the file system to record the attributes of
140 * the file at the time of creation.
141 */
142struct tfshdr {
143 unsigned short hdrsize; /* Size of this header. */
144 unsigned short hdrvrsn; /* Header version #. */
145 long filsize; /* Size of the file. */
146 long flags; /* Flags describing the file. */
147 unsigned long filcrc; /* 32 bit CRC of file. */
148 unsigned long hdrcrc; /* 32 bit CRC of the header. */
149 unsigned long modtime; /* Time when file was last modified. */
150 struct tfshdr *next; /* Pointer to next file in list. */
151 char name[TFSNAMESIZE+1]; /* Name of file. */
152 char info[TFSINFOSIZE+1]; /* Miscellaneous info field. */
153#if TFS_RESERVED
154 unsigned long rsvd[TFS_RESERVED];
155#endif
156};
157
158#define TFSHDRSIZ sizeof(struct tfshdr)
159
160/* TFS error returns. */
161#define TFS_OKAY 0
162#define TFSERR_NOFILE -1
163#define TFSERR_NOSLOT -2
164#define TFSERR_EOF -3
165#define TFSERR_BADARG -4
166#define TFSERR_NOTEXEC -5
167#define TFSERR_BADCRC -6
168#define TFSERR_FILEEXISTS -7
169#define TFSERR_FLASHFAILURE -8
170#define TFSERR_WRITEMAX -9
171#define TFSERR_RDONLY -10
172#define TFSERR_BADFD -11
173#define TFSERR_BADHDR -12
174#define TFSERR_CORRUPT -13
175#define TFSERR_MEMFAIL -14
176#define TFSERR_NOTIPMOD -16
177#define TFSERR_MUTEXFAILURE -17
178#define TFSERR_FLASHFULL -18
179#define TFSERR_USERDENIED -19
180#define TFSERR_NAMETOOBIG -20
181#define TFSERR_FILEINUSE -21
182#define TFSERR_NOTCPRS -22
183#define TFSERR_NOTAVAILABLE -23
184#define TFSERR_BADFLAG -24
185#define TFSERR_CLEANOFF -25
186#define TFSERR_FLAKEYSOURCE -26
187#define TFSERR_BADEXTENSION -27
188#define TFSERR_MIN -100
189
190/* TFS seek options. */
191#define TFS_BEGIN 1
192#define TFS_CURRENT 2
193#define TFS_END 3
194
195/* Macros: */
196#define TFS_DELETED(fp) (!((fp)->flags & TFS_ACTIVE))
197#define TFS_FILEEXISTS(fp) ((fp)->flags & TFS_ACTIVE)
198#define TFS_ISCPRS(fp) ((fp)->flags & TFS_CPRS)
199#define TFS_ISEXEC(fp) ((fp)->flags & TFS_EXEC)
200#define TFS_ISBOOT(fp) ((fp)->flags & TFS_BRUN)
201#define TFS_ISLINK(fp) ((fp)->flags & TFS_SYMLINK)
202#define TFS_STALE(fp) (!((fp)->flags & TFS_NSTALE))
203#define TFS_FLAGS(fp) ((fp)->flags)
204#define TFS_NAME(fp) ((fp)->name)
205#define TFS_SIZE(fp) ((fp)->filsize)
206#define TFS_TIME(fp) ((fp)->modtime)
207#define TFS_INFO(fp) ((fp)->info)
208#define TFS_NEXT(fp) ((fp)->next)
209#define TFS_CRC(fp) ((fp)->filcrc)
210#define TFS_ENTRY(fp) ((fp)->entry)
211#define TFS_BASE(fp) ((char *)(fp)+(fp)->hdrsize)
212
213typedef struct tfshdr TFILE;
214#endif
Definition: tfs.h:138
