RTEMS 5.2
tasksetup_general.h
1/******************************************************************************
2*
3* Copyright (c) 2004 Freescale Semiconductor, Inc.
4*
5* Permission is hereby granted, free of charge, to any person obtaining a
6* copy of this software and associated documentation files (the "Software"),
7* to deal in the Software without restriction, including without limitation
8* the rights to use, copy, modify, merge, publish, distribute, sublicense,
9* and/or sell copies of the Software, and to permit persons to whom the
10* Software is furnished to do so, subject to the following conditions:
11*
12* The above copyright notice and this permission notice shall be included
13* in all copies or substantial portions of the Software.
14*
15* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
16* IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
17* FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
18* THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR
19* OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE,
20* ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR
21* OTHER DEALINGS IN THE SOFTWARE.
22*
23******************************************************************************/
24
25/*
26 * Task builder generates a set #defines per configured task to
27 * condition this templete file.
28 */
29
30/**********************************************************
31 *
32 * Required #defines:
33 * ------------------
34 * TASKSETUP_NAME:
35 * TaskSetup function name, set to TaskSetup_<TASK_NAME>
36 * TASK_API:
37 * task API defined in dma_image.h
38 * MAX_BD:
39 * <=0 : non-BD task
40 * else: number of BD in BD table
41 * BD_FLAG:
42 * 0 : no flag implemented for BD
43 * else: flags can be passed on a per BD basis
44 * MISALIGNED:
45 * 0 : task API supports Bytes%IncrBytes==0
46 * else: task API supports any parameter settings
47 * AUTO_START:
48 * <-1 : do not start a task after task completion
49 * -1 : auto start the task after task completion
50 * <MAX_TASKS: auto start task with the TaskID = AUTO_START
51 * else : do not start a task after task completion
52 * INITIATOR_DATA:
53 * <0 : runtime configurable
54 * else: assume INITATOR_DATA equal hard-coded task initiator
55 * TYPE_SRC: (needs to be consistent with Task API)
56 * FLEX_T : Task API TYPE_SRC = flex, SzSrc defines size
57 * UINT8_T : Task API TYPE_SRC = char
58 * UINT16_T: Task API TASK_SRC = short
59 * UINT32_T: Task API TASK_SRC = int
60 * INCR_TYPE_SRC:
61 * 0 : FIFO address, do not implement data pointer
62 * 1 : automatic, set INCR_SRC based on SzSrc parameter
63 * 2 : runtime, set INCR_SRC to IncrSrc parameter
64 * else: used hard-coded INCR_SRC
65 * INCR_SRC:
66 * INCR_TYPE_SRC=0: force INCR_SRC=0
67 * else : use for src pointer increment
68 * TYPE_DST: (needs to be consistent with Task API)
69 * FLEX_T : Task API TYPE_DST = flex, SzDst defines size
70 * UINT8_T : Task API TYPE_DST = char
71 * UINT16_T: Task API TASK_DST = short
72 * UINT32_T: Task API TASK_DST = int
73 * INCR_TYPE_DST:
74 * 0 : FIFO address, do not implement data pointer
75 * 1 : automatic, set INCR_DST based on SzDst parameter
76 * 2 : runtime, set INCR_DST to IncrDst parameter
77 * else: used hard-coded INCR_DST
78 * INCR_DST:
79 * INCR_TYPE_DST=0: force INCR_DST=0
80 * else : use for dst pointer increment
81 * PRECISE_INCREMENT:
82 * 0 : increment when possible
83 * else: increment at end of iteration
84 * NO_ERROR_RESET:
85 * 0 : reset error flags on task enable
86 * else: leave error flags unmodified on task enable
87 * PACK_DATA:
88 * 0 : do not pack data
89 * else: pack data based on data type
90 * INTEGER_MODE:
91 * 0 : type conversions handle as fixed point numbers
92 * else: type conversions handle as integers
93 * WRITE_LINE_BUFFER:
94 * 0 : do not use write line buffers
95 * else: enable write line buffers
96 * READ_LINE_BUFFER:
97 * 0 : do not use read line buffers
98 * else: enable read line buffers
99 * SPEC_READS:
100 * 0 : do not speculatively read
101 * else: speculatively read data ahead of DMA engine
102 *
103 * Optional #defines:
104 * ------------------
105 * MAX_TASKS:
106 * 1 : #define MAX_TASKS>0
107 * else: 16
108 * ITERATIONS:
109 * 1 : #define ITERATIONS>0
110 * else: 1
111 * INCR_BYTES:
112 * This macro is defined based on following priority:
113 * 1 : INCR_SRC != 0
114 * 2 : DST_TYPE != 0
115 * 3 : #defined INCR_BYTES<0
116 * else: -4 (SZ_UINT32)
117 * DEBUG_BESTCOMM_API:
118 * >0 : print basic debug messages
119 * >=10: also print C-API interface variables
120 * >=20: also print task API interface variables
121 * else: do nothing
122 *
123 **********************************************************/
124
125#if defined(__rtems__) || defined(MPC5200_BAPI_LIBC_HEADERS)
126#include <stdlib.h>
127#endif
128
129#include "../dma_image.h"
130
131#include "../bestcomm_api.h"
132#include "tasksetup_bdtable.h"
133
134#include "bestcomm_api_mem.h"
135#include "bestcomm_cntrl.h"
136
137#ifndef DEBUG_BESTCOMM_API
138 #define DEBUG_BESTCOMM_API 0
139#endif
140
141#ifdef FLEX_T
142 #undef FLEX_T
143#endif
144#define FLEX_T SZ_FLEX
145
146#ifdef UINT8_T
147 #undef UINT8_T
148#endif
149#define UINT8_T SZ_UINT8
150
151#ifdef UINT16_T
152 #undef UINT16_T
153#endif
154#define UINT16_T SZ_UINT16
155
156#ifdef UINT32_T
157 #undef UINT32_T
158#endif
159#define UINT32_T SZ_UINT32
160
161#if (INCR_TYPE_SRC==0) /* FIFO address, no data pointer */
162 #undef INCR_SRC
163 #define INCR_SRC 0
164#endif
165
166#if (INCR_TYPE_DST==0) /* FIFO address, no data pointer */
167 #undef INCR_DST
168 #define INCR_DST 0
169#endif
170
171#ifndef MAX_TASKS
172 #define MAX_TASKS 16
173#else
174 #if (MAX_TASKS<=0)
175 #undef MAX_TASKS
176 #define MAX_TASKS 16
177 #endif
178#endif
179
180#ifndef ITERATIONS
181 #define ITERATIONS 1
182#else
183 #if (ITERATIONS<=0)
184 #undef ITERATIONS
185 #define ITERATIONS 1
186 #endif
187#endif
188
189#ifndef INCR_BYTES
190 #define INCR_BYTES -4
191#else
192 #if (INCR_BYTES>=0)
193 #undef INCR_BYTES
194 #define INCR_BYTES -4
195 #endif
196#endif
197
198/*
199 * These ifndefs will go away when support in task_capi wrappers
200 * in the image directories
201 */
202#ifndef PRECISE_INCREMENT
203 #define PRECISE_INCREMENT 0 /* bit=6 SAS->1, increment 0=when possible, 1=at the end of interation */
204#endif
205#ifndef NO_ERROR_RESET
206 #define NO_ERROR_RESET 0 /* bit=5 SAS->0, do not reset error codes on task enable */
207#endif
208#ifndef PACK_DATA
209 #define PACK_DATA 0 /* bit=4 SAS->0, pack data enable */
210#endif
211#ifndef INTEGER_MODE
212 #define INTEGER_MODE 0 /* bit=3 SAS->0, 0=fractional(msb aligned), 1=integer(lsb aligned) */
213#endif
214#ifndef SPEC_READS
215 #define SPEC_READS 1 /* bit=2 SAS->0, XLB speculative read enable */
216#endif
217#ifndef WRITE_LINE_BUFFER
218 #define WRITE_LINE_BUFFER 1 /* bit=1 SAS->0, write line buffer enable */
219#endif
220#ifndef READ_LINE_BUFFER
221 #define READ_LINE_BUFFER 1 /* bit=0 SAS->0, read line buffer enable */
222#endif
223#define SDMA_PRAGMA (0 <<SDMA_PRAGMA_BIT_RSV ) | \
224 (PRECISE_INCREMENT<<SDMA_PRAGMA_BIT_PRECISE_INC ) | \
225 (NO_ERROR_RESET <<SDMA_PRAGMA_BIT_RST_ERROR_NO) | \
226 (PACK_DATA <<SDMA_PRAGMA_BIT_PACK ) | \
227 (INTEGER_MODE <<SDMA_PRAGMA_BIT_INTEGER ) | \
228 (SPEC_READS <<SDMA_PRAGMA_BIT_SPECREAD ) | \
229 (WRITE_LINE_BUFFER<<SDMA_PRAGMA_BIT_CW ) | \
230 (READ_LINE_BUFFER <<SDMA_PRAGMA_BIT_RL )
231
232#ifndef TASKSETUP_NAME
233 #define PREPEND_TASKSETUP(name) TaskSetup_ ## name
234 #define FUNC_PREPEND_TASKSETUP(name) PREPEND_TASKSETUP(name)
235 #define TASKSETUP_NAME FUNC_PREPEND_TASKSETUP(TASK_BASE)
236#endif
237
238#ifndef TASK_API
239 #define APPEND_API(name) name ## _api_t
240 #define FUNC_APPEND_API(name) APPEND_API(name)
241 #define TASK_API FUNC_APPEND_API(TASK_BASE)
242#endif
243
244#ifndef INIT_DMA_IMAGE
245 #define PREPEND_INITDMA(name) init_dma_image_ ## name
246 #define FUNC_PREPEND_INITDMA(name) PREPEND_INITDMA(name)
247 #define INIT_DMA_IMAGE FUNC_PREPEND_INITDMA(TASK_BASE)
248#endif
249
250#define DRD_INIT_MASK 0xfc1fffff
251#define DRD_EXT_FLAG 0x40000000
252#define DRD_INIT_OFFSET 21
253
254TaskId TASKSETUP_NAME(TASK_API *TaskAPI,
255 TaskSetupParamSet_t *TaskSetupParams)
256{
257 TaskId TaskNum;
258#if ((MAX_BD>0)||(DEBUG_BESTCOMM_API>0))
259 uint32 Status = 0;
260#endif
261#if ((MAX_BD>0)&&((INCR_TYPE_SRC!=0)||(INCR_TYPE_DST!=0))||(DEBUG_BESTCOMM_API>0))
262 uint8 NumPtr = 0;
263#endif
264#if (INITIATOR_DATA<0) /* runtime configurable */
265 uint32 i, ext;
266#endif
267
268 INIT_DMA_IMAGE((uint8 *)(((sdma_regs *)(SDMA_TASK_BAR))->taskBar), MBarPhysOffsetGlobal);
269
270 TaskNum = (TaskId)SDMA_TASKNUM_EXT(TaskAPI->TaskNum);
271
272 TaskRunning[TaskNum] = 0;
273
274#if (DEBUG_BESTCOMM_API>0)
275 printf("\nBestComm API Debug Display Mode Enabled\n\n");
276 printf("TaskSetup: TaskID=%d\n", TaskNum);
277 if (Status!=0) {
278 printf("TaskSetup: Rx task\n");
279 } else {
280 printf("TaskSetup: Tx or DP task\n");
281 }
282#endif
283
284 /* Set the task pragma settings */
285 *(TaskAPI->TaskPragma)= (uint8) SDMA_PRAGMA;
286
287#if (MAX_BD>0) /* Buffer Descriptors */
288
289 #if (INCR_TYPE_SRC!=0)
290 ++NumPtr;
291 #endif
292 #if (INCR_TYPE_DST!=0)
293 ++NumPtr;
294 #endif
295
296 #if (DEBUG_BESTCOMM_API>0)
297 printf("TaskSetup: Using %d buffer descriptors, each with %d data pointers\n", MAX_BD, NumPtr);
298 #endif
299
300 /* Allocate BD table SRAM storage,
301 * and pass addresses to task API */
302
303 TaskSetup_BDTable(TaskAPI->BDTableBase,
304 TaskAPI->BDTableLast,
305 TaskAPI->BDTableStart,
306 TaskNum,
307 TaskSetupParams->NumBD,
308 MAX_BD, NumPtr,
309 BD_FLAG, Status);
310
311 *TaskAPI->AddrEnable = (uint32)((uint32)(((uint16 *)SDMA_TCR)+TaskNum) + MBarPhysOffsetGlobal);
312
313 #if BD_FLAG
314
315 #if (DEBUG_BESTCOMM_API>0)
316 printf("TaskSetup: Buffer descriptor flags are enabled\n");
317 #endif
318
319 /* always assume 2nd to last DRD */
320 *((TaskAPI->AddrDRD)) = (uint32)((uint32)TaskAPI->DRD[TaskAPI->AddrDRDIdx] + MBarPhysOffsetGlobal);
321 #endif /* #if BD_FLAG */
322
323#else /* No Buffer Descriptors */
324
325/* #error ATA should not be non-BD */
326
327 #if (DEBUG_BESTCOMM_API>0)
328 printf("TaskSetup: Task will complete %d iterations before disabling\n");
329 #endif
330
331 *((TaskAPI->IterExtra)) = (uint32)(ITERATIONS-1);
332#endif /* #if (MAX_BD>0) */
333
334/* Setup auto start */
335#if (AUTO_START <= -2 ) /* do not start a task */
336 #if (DEBUG_BESTCOMM_API>0)
337 printf("TaskSetup: Auto task start disabled\n");
338 #endif
339 SDMA_TASK_CFG(SDMA_TCR, TaskNum, 0, TaskNum);
340#elif (AUTO_START <= -1 ) /* restart task */
341 #if (DEBUG_BESTCOMM_API>0)
342 printf("TaskSetup: Auto start task\n");
343 #endif
344 SDMA_TASK_CFG(SDMA_TCR, TaskNum, 1, TaskNum);
345#elif (AUTO_START < MAX_TASKS) /* start specific task */
346 #if (DEBUG_BESTCOMM_API>0)
347 printf("TaskSetup: Auto start task with TaskID=%d\n", AUTO_START);
348 #endif
349 SDMA_TASK_CFG(SDMA_TCR, TaskNum, 1, AUTO_START);
350#else /* do not start a task */
351 #if (DEBUG_BESTCOMM_API>0)
352 printf("TaskSetup: Auto task start disabled\n");
353 #endif
354 SDMA_TASK_CFG(SDMA_TCR, TaskNum, 0, TaskNum);
355#endif
356
357#if (INITIATOR_DATA<0) /* runtime configurable */
358 SDMA_SET_INIT(SDMA_TCR, TaskNum, TaskSetupParams->Initiator);
359
360 /*
361 * Hard-code the task initiator in the DRD to avoid a problem w/ the
362 * hold initiator bit in the TCR.
363 */
364 ext = 0;
365 for (i = 0; i < TaskAPI->NumDRD; i++) {
366 if (ext == 0)
367 {
368#if (DEBUG_BESTCOMM_API>=10)
369 printf("TaskSetup: DRD[%d] initiator = %d\n", i, ((*(TaskAPI->DRD[i]) & ~DRD_INIT_MASK) >> DRD_INIT_OFFSET));
370#endif
371 if (((*(TaskAPI->DRD[i]) & ~DRD_INIT_MASK) >> DRD_INIT_OFFSET) != INITIATOR_ALWAYS) {
372#if (DEBUG_BESTCOMM_API>=10)
373 printf("TaskSetup: Replacing DRD[%d] initiator with %d\n", i, TaskSetupParams->Initiator);
374#endif
375 *(TaskAPI->DRD[i]) = (*(TaskAPI->DRD[i]) & DRD_INIT_MASK)
376 | (TaskSetupParams->Initiator << DRD_INIT_OFFSET);
377 }
378
379 if ((*(TaskAPI->DRD[i]) & DRD_EXT_FLAG) != 0)
380 {
381 ext = 1;
382 }
383 }
384 else
385 {
386 if ((*(TaskAPI->DRD[i]) & DRD_EXT_FLAG) == 0)
387 {
388 ext = 0;
389 }
390 }
391 }
392
393#else /* INITIATOR_DATA >= 0 */
394 TaskSetupParams->Initiator = INITIATOR_DATA;
395#endif
396
397#if (DEBUG_BESTCOMM_API>=10)
398 printf("\nTaskSetup: C-API Parameter Settings Passed to TaskSetup:\n");
399 printf("TaskSetup: NumBD = %d\n", TaskSetupParams->NumBD);
400 #if (MAX_BD>0)
401 printf("TaskSetup: MaxBuf = %d\n", TaskSetupParams->Size.MaxBuf);
402 #else
403 printf("TaskSetup: NumBytes = %d\n", TaskSetupParams->Size.NumBytes);
404 #endif
405 printf("TaskSetup: Initiator = %d\n", TaskSetupParams->Initiator);
406 printf("TaskSetup: StartAddrSrc = 0x%08X\n", TaskSetupParams->StartAddrSrc);
407 printf("TaskSetup: IncrSrc = %d\n", TaskSetupParams->IncrSrc);
408 printf("TaskSetup: SzSrc = %d\n", TaskSetupParams->SzSrc);
409 printf("TaskSetup: StartAddrDst = 0x%08X\n", TaskSetupParams->StartAddrDst);
410 printf("TaskSetup: IncrDst = %d\n", TaskSetupParams->IncrDst);
411 printf("TaskSetup: SzDst = %d\n", TaskSetupParams->SzDst);
412#endif
413
414#if (DEBUG_BESTCOMM_API>=20)
415 printf("\nTaskSetup: Task-API Parameter Settings Before TaskSetup Initialization:\n");
416 printf("TaskSetup: TaskNum = %d\n", (TaskAPI->TaskNum));
417 printf("TaskSetup: TaskPragma = 0x%02X\n", *((TaskAPI->TaskPragma)));
418 printf("TaskSetup: TCR = 0x%04x\n", SDMA_TASK_STATUS(SDMA_TCR, TaskNum));
419
420 #if (MAX_BD>0)
421 printf("TaskSetup: BDTableBase = 0x%08X\n", *((TaskAPI->BDTableBase)));
422 printf("TaskSetup: BDTableLast = 0x%08X\n", *((TaskAPI->BDTableLast)));
423 printf("TaskSetup: BDTableStart = 0x%08X\n", *((TaskAPI->BDTableStart)));
424 printf("TaskSetup: AddrEnable = 0x%08X\n", *((TaskAPI->AddrEnable)));
425 #if (INCR_TYPE_SRC==0)
426 printf("TaskSetup: AddrSrcFIFO = 0x%08X\n", *((TaskAPI->AddrSrcFIFO)));
427 #endif
428 #if (INCR_TYPE_DST==0)
429 printf("TaskSetup: AddrDstFIFO = 0x%08X\n", *((TaskAPI->AddrDstFIFO)));
430 #endif
431 #if (BD_FLAG)
432 printf("TaskSetup: AddrDRD = 0x%08X\n", *((TaskAPI->AddrDRD)));
433 printf("TaskSetup: AddrDRDIdx = %d\n", ((TaskAPI->AddrDRDIdx)));
434 #endif
435 #else
436 printf("TaskSetup: IterExtra = %d\n", *((TaskAPI->IterExtra)));
437 #if (INCR_TYPE_SRC==0)
438 printf("TaskSetup: AddrSrcFIFO = 0x%08X\n", *((TaskAPI->AddrSrcFIFO)));
439 #else
440 printf("TaskSetup: StartAddrSrc = 0x%08X\n", *((TaskAPI->StartAddrSrc)));
441 #endif
442 #if (INCR_TYPE_DST==0)
443 printf("TaskSetup: AddrDstFIFO = 0x%08X\n", *((TaskAPI->AddrDstFIFO)));
444 #else
445 printf("TaskSetup: StartAddrDst = 0x%08X\n", *((TaskAPI->StartAddrDst)));
446 #endif
447 #endif
448 #if (INCR_TYPE_SRC!=0)
449 printf("TaskSetup: IncrSrc = 0x%04X\n", *((TaskAPI->IncrSrc)));
450 #if (MISALIGNED | MISALIGNED_START)
451 printf("TaskSetup: IncrSrcMA = 0x%04X\n", *((TaskAPI->IncrSrcMA)));
452 #endif
453 #endif
454 #if (INCR_TYPE_DST!=0)
455 printf("TaskSetup: IncrDst = 0x%04X\n", *((TaskAPI->IncrDst)));
456 #if (MISALIGNED | MISALIGNED_START)
457 printf("TaskSetup: IncrDstMA = 0x%04X\n", *((TaskAPI->IncrDstMA)));
458 #endif
459 #endif
460 printf("TaskSetup: Bytes = %d\n", *((TaskAPI->Bytes)));
461 printf("TaskSetup: IncrBytes = %d\n", *((TaskAPI->IncrBytes)));
462#endif
463
464
465 *((TaskAPI->Bytes)) = (uint32)TaskSetupParams->Size.MaxBuf;
466
467
468#if (TYPE_SRC!=FLEX_T) /* size fixed in task code */
469 TaskSetupParams->SzSrc = TYPE_SRC;
470#endif
471
472#if (INCR_TYPE_SRC==0) /* no data pointer */
473 TaskSetupParams->IncrSrc = (sint16)0;
474 *((TaskAPI->AddrSrcFIFO)) = (uint32)TaskSetupParams->StartAddrSrc;
475#else
476
477 #if (INCR_TYPE_SRC==1) /* automatic */
478 if (TaskSetupParams->IncrSrc!=0) {
479 TaskSetupParams->IncrSrc = (sint16)+TaskSetupParams->SzSrc;
480 } else {
481 TaskSetupParams->IncrSrc = (sint16)+TaskSetupParams->IncrSrc;
482 }
483 #elif (INCR_TYPE_SRC!=2) /* hard-coded */
484 TaskSetupParams->IncrSrc = (sint16)INCR_SRC;
485 #endif
486 *((TaskAPI->IncrSrc)) = (sint16)TaskSetupParams->IncrSrc;
487
488 #if (MAX_BD>0) /* pointer in BD Table */
489 /* pass back address of first BD */
490 TaskSetupParams->StartAddrSrc = (uint32)TaskGetBDRing(TaskNum);
491 #else
492 *((TaskAPI->StartAddrSrc)) = (uint32)TaskSetupParams->StartAddrSrc;
493 #endif
494
495 #if MISALIGNED | MISALIGNED_START
496 if (TaskSetupParams->IncrSrc < 0) {
497 *((TaskAPI->IncrSrcMA)) = (sint16)-1;
498 } else if (TaskSetupParams->IncrSrc > 0) {
499 *((TaskAPI->IncrSrcMA)) = (sint16)+1;
500 } else {
501 *((TaskAPI->IncrSrcMA)) = (sint16)0;
502 }
503 #endif
504#endif
505
506
507#if (TYPE_DST!=FLEX_T) /* size fixed in task code */
508 TaskSetupParams->SzDst = TYPE_DST;
509#endif
510
511#if (INCR_TYPE_DST==0) /* no data pointer */
512 TaskSetupParams->IncrDst = (sint16)0;
513 *((TaskAPI->AddrDstFIFO)) = (uint32)TaskSetupParams->StartAddrDst;
514#else
515 #if (INCR_TYPE_DST==1) /* automatic */
516 if (TaskSetupParams->IncrDst!=0) {
517 TaskSetupParams->IncrDst = (sint16)+TaskSetupParams->SzDst;
518 } else {
519 TaskSetupParams->IncrDst = (sint16)+TaskSetupParams->IncrDst;
520 }
521 #elif (INCR_TYPE_DST!=2) /* hard-coded */
522 TaskSetupParams->IncrDst = (sint16)INCR_DST;
523 #endif
524 *((TaskAPI->IncrDst)) = (sint16)TaskSetupParams->IncrDst;
525
526 #if (MAX_BD>0)
527 /* pass back address of first BD */
528 TaskSetupParams->StartAddrDst = (uint32)TaskGetBDRing(TaskNum);
529 #else
530 *((TaskAPI->StartAddrDst)) = (uint32)TaskSetupParams->StartAddrDst;
531 #endif
532
533 #if MISALIGNED | MISALIGNED_START
534 if (TaskSetupParams->IncrDst < 0) {
535 *((TaskAPI->IncrDstMA)) = (sint16)-1;
536 } else if (TaskSetupParams->IncrDst > 0) {
537 *((TaskAPI->IncrDstMA)) = (sint16)+1;
538 } else {
539 *((TaskAPI->IncrDstMA)) = (sint16)0;
540 }
541 #endif
542#endif
543
544/* always use macro, only affect code with #define TYPE_? flex */
545 SDMA_SET_SIZE(SDMA_TASK_SIZE, TaskNum, TaskSetupParams->SzSrc, TaskSetupParams->SzDst);
546
547
548 if (TaskSetupParams->IncrSrc != 0) {
549 *((TaskAPI->IncrBytes)) = (sint16)-abs(TaskSetupParams->IncrSrc);
550 } else if (TaskSetupParams->IncrDst != 0) {
551 *((TaskAPI->IncrBytes)) = (sint16)-abs(TaskSetupParams->IncrDst);
552 } else {
553 *((TaskAPI->IncrBytes)) = (sint16)-abs(INCR_BYTES);
554 }
555
556
557#if (DEBUG_BESTCOMM_API>=10)
558 printf("\nTaskSetup: C-API Parameter Settings Returned from TaskSetup:\n");
559 printf("TaskSetup: NumBD = %d\n", TaskSetupParams->NumBD);
560 #if (MAX_BD>0)
561 printf("TaskSetup: MaxBuf = %d\n", TaskSetupParams->Size.MaxBuf);
562 #else
563 printf("TaskSetup: NumBytes = %d\n", TaskSetupParams->Size.NumBytes);
564 #endif
565 printf("TaskSetup: Initiator = %d\n", TaskSetupParams->Initiator);
566 printf("TaskSetup: StartAddrSrc = 0x%08X\n", TaskSetupParams->StartAddrSrc);
567 printf("TaskSetup: IncrSrc = %d\n", TaskSetupParams->IncrSrc);
568 printf("TaskSetup: SzSrc = %d\n", TaskSetupParams->SzSrc);
569 printf("TaskSetup: StartAddrDst = 0x%08X\n", TaskSetupParams->StartAddrDst);
570 printf("TaskSetup: IncrDst = %d\n", TaskSetupParams->IncrDst);
571 printf("TaskSetup: SzDst = %d\n", TaskSetupParams->SzDst);
572#endif
573
574#if (DEBUG_BESTCOMM_API>=20)
575 printf("\nTaskSetup: Task-API Parameter Settings After TaskSetup Initialization:\n");
576 printf("TaskSetup: TaskNum = %d\n", ((TaskAPI->TaskNum)));
577 printf("TaskSetup: TaskPragma = 0x%02X\n", *((TaskAPI->TaskPragma)));
578
579 #if (MAX_BD>0)
580 printf("TaskSetup: BDTableBase = 0x%08X\n", *((TaskAPI->BDTableBase)));
581 printf("TaskSetup: BDTableLast = 0x%08X\n", *((TaskAPI->BDTableLast)));
582 printf("TaskSetup: BDTableStart = 0x%08X\n", *((TaskAPI->BDTableStart)));
583 printf("TaskSetup: AddrEnable = 0x%08X\n", *((TaskAPI->AddrEnable)));
584 #if (INCR_TYPE_SRC==0)
585 printf("TaskSetup: AddrSrcFIFO = 0x%08X\n", *((TaskAPI->AddrSrcFIFO)));
586 #endif
587 #if (INCR_TYPE_DST==0)
588 printf("TaskSetup: AddrDstFIFO = 0x%08X\n", *((TaskAPI->AddrDstFIFO)));
589 #endif
590 #if (BD_FLAG)
591 printf("TaskSetup: AddrDRD = 0x%08X\n", *((TaskAPI->AddrDRD)));
592 printf("TaskSetup: AddrDRDIdx = %d\n", ((TaskAPI->AddrDRDIdx)));
593 #endif
594 #else
595 printf("TaskSetup: IterExtra = %d\n", *((TaskAPI->IterExtra)));
596 #if (INCR_TYPE_SRC==0)
597 printf("TaskSetup: AddrSrcFIFO = 0x%08X\n", *((TaskAPI->AddrSrcFIFO)));
598 #else
599 printf("TaskSetup: StartAddrSrc = 0x%08X\n", *((TaskAPI->StartAddrSrc)));
600 #endif
601 #if (INCR_TYPE_DST==0)
602 printf("TaskSetup: AddrDstFIFO = 0x%08X\n", *((TaskAPI->AddrDstFIFO)));
603 #else
604 printf("TaskSetup: StartAddrDst = 0x%08X\n", *((TaskAPI->StartAddrDst)));
605 #endif
606 #endif
607 #if (INCR_TYPE_SRC!=0)
608 printf("TaskSetup: IncrSrc = 0x%04X\n", *((TaskAPI->IncrSrc)));
609 #if (MISALIGNED | MISALIGNED_START)
610 printf("TaskSetup: IncrSrcMA = 0x%04X\n", *((TaskAPI->IncrSrcMA)));
611 #endif
612 #endif
613 #if (INCR_TYPE_DST!=0)
614 printf("TaskSetup: IncrDst = 0x%04X\n", *((TaskAPI->IncrDst)));
615 #if (MISALIGNED | MISALIGNED_START)
616 printf("TaskSetup: IncrDstMA = 0x%04X\n", *((TaskAPI->IncrDstMA)));
617 #endif
618 #endif
619 printf("TaskSetup: Bytes = %d\n", *((TaskAPI->Bytes)));
620 printf("TaskSetup: IncrBytes = %d\n", *((TaskAPI->IncrBytes)));
621#endif
622
623 return TaskNum;
624}
Parameters for TaskSetup()
Definition: bestcomm_api.h:194
Sz_t SzDst
Definition: bestcomm_api.h:209
MPC5200Initiator_t Initiator
Definition: bestcomm_api.h:203
uint32 NumBytes
Definition: bestcomm_api.h:199
uint32 StartAddrSrc
Definition: bestcomm_api.h:204
Sz_t SzSrc
Definition: bestcomm_api.h:206
uint32 MaxBuf
Definition: bestcomm_api.h:198
union TaskSetupParamSet_t::@188 Size
uint32 StartAddrDst
Definition: bestcomm_api.h:207
sint16 IncrSrc
Definition: bestcomm_api.h:205
uint32 NumBD
Definition: bestcomm_api.h:195
sint16 IncrDst
Definition: bestcomm_api.h:208
Definition: sdma.h:28
