RTEMS 5.2
uti596_softc Struct Reference
struct arpcom arpcom
i596_scppScp
i596_scpbase_scp
i596_iscp iscp
i596_scb scb
i596_set_add set_add
i596_configure set_conf
i596_tdr tdr
i596_nop nop
i596_txpTxCmd
i596_tbdpTbd
i596_rfdpBeginRFA
i596_rfdpEndRFA
i596_rfdpLastUnkRFD
i596_rbdpLastUnkRBD
i596_rfdpEndSavedQueue
i596_cmdpCmdHead
i596_cmdpCmdTail
rtems_id rxDaemonTid
rtems_id txDaemonTid
rtems_id resetDaemonTid
struct enet_statistics stats
int started
unsigned long rxInterrupts
unsigned long txInterrupts
volatile int cmdOk
unsigned short * pCurrent_command_status
int resetDone
unsigned long txRawWait
i596_rfdpInboundFrameQueue
short int rxBdCount
short int txBdCount
short int countRFD
short int savedCount
i596_rfdpSavedRfdQueue
rtems_name semaphore_name
rtems_id semaphore_id
char zeroes [64]
unsigned long rawsndcnt
int nic_reset
