RTEMS 5.2
spw_config Struct Reference
unsigned int nodeaddr
unsigned int destkey
unsigned int clkdiv
unsigned int rxmaxlen
unsigned int timer
unsigned int disconnect
unsigned int promiscuous
unsigned int rmapen
unsigned int rmapbufdis
unsigned int linkdisabled
unsigned int linkstart
unsigned int check_rmap_err
unsigned int rm_prot_id
unsigned int tx_blocking
unsigned int tx_block_on_full
unsigned int rx_blocking
unsigned int disable_err
unsigned int link_err_irq
rtems_id event_id
unsigned int is_rmap
unsigned int is_rxunaligned
unsigned int is_rmapcrc
unsigned int nodemask
unsigned int keep_source
unsigned int rtimeout
