RTEMS 5.2
rtems_debugger_server Struct Reference
#include <rtems-debugger-server.h>
int port
int timeout
rtems_task_priority priority
rtems_rx_mutex lock
rtems_debugger_remoteremote
rtems_id server_task
rtems_rx_cond server_cond
volatile bool server_running
volatile bool server_finished
rtems_id events_task
volatile bool events_running
volatile bool events_finished
rtems_printer printer
uint32_t flags
pid_t pid
bool remote_debug
bool ack_pending
size_t output_level
uint8_t input [RTEMS_DEBUGGER_BUFFER_SIZE]
uint8_t output [RTEMS_DEBUGGER_BUFFER_SIZE]
rtems_debugger_threadsthreads
rtems_chain_control exception_threads
int signal
rtems_debugger_targettarget
Debugger data.
