RTEMS 5.2
pccchip2_regs_ Struct Reference
unsigned char chip_id
unsigned char chip_revision
unsigned char gen_control
unsigned char vector_base
unsigned long timer_cmp_1
unsigned long timer_cnt_1
unsigned long timer_cmp_2
unsigned long timer_cnt_2
unsigned char LSB_prescaler_count
unsigned char prescaler_clock_adjust
unsigned char timer_ctl_2
unsigned char timer_ctl_1
unsigned char gpi_int_ctl
unsigned char gpio_ctl
unsigned char timer_int_ctl_2
unsigned char timer_int_ctl_1
unsigned char SCC_error
unsigned char SCC_modem_int_ctl
unsigned char SCC_tx_int_ctl
unsigned char SCC_rx_int_ctl
unsigned char reserved1 [3]
unsigned char modem_piack
unsigned char reserved2
unsigned char tx_piack
unsigned char reserved3
unsigned char rx_piack
unsigned char LANC_error
unsigned char reserved4
unsigned char LANC_int_ctl
unsigned char LANC_berr_ctl
unsigned char SCSI_error
unsigned char reserved5 [2]
unsigned char SCSI_int_ctl
unsigned char print_ack_int_ctl
unsigned char print_fault_int_ctl
unsigned char print_sel_int_ctl
unsigned char print_pe_int_ctl
unsigned char print_busy_int_ctl
unsigned char reserved6
unsigned char print_input_status
unsigned char print_ctl
unsigned char chip_speed
unsigned char reserved7
unsigned char print_data
unsigned char reserved8 [3]
unsigned char int_level
unsigned char int_mask
