RTEMS 5.2
ne_softc Struct Reference
struct arpcom arpcom
unsigned int irno
unsigned int port
int accept_broadcasts
rtems_id tx_daemon_tid
rtems_id rx_daemon_tid
bool byte_transfers
int inuse
int nextavail
int nextsend
int transmitting
int sendlen [NE_TX_BUFS]
int overrun
int resend
struct {
   unsigned long   rx_packets
   unsigned long   tx_packets
   unsigned long   interrupts
   unsigned long   rx_acks
   unsigned long   tx_acks
   unsigned long   overruns
   unsigned long   rx_frame_errors
   unsigned long   rx_crc_errors
   unsigned long   rx_missed_errors
stats
struct {
stats
The documentation for this struct was generated from the following files:
