RTEMS 5.2
unsigned char chipID
unsigned char chipREV
unsigned char gen_control
unsigned char vector_base
unsigned long timer_cmp_1
unsigned long timer_cnt_1
unsigned long timer_cmp_2
unsigned long timer_cnt_2
unsigned char LSB_prescaler_count
unsigned char prescaler_clock_adjust
unsigned char time_ctl_2
unsigned char time_ctl_1
unsigned char time_int_ctl_4
unsigned char time_int_ctl_3
unsigned char time_int_ctl_2
unsigned char time_int_ctl_1
unsigned char dram_err_int_ctl
unsigned char SCC_int_ctl
unsigned char time_ctl_4
unsigned char time_ctl_3
unsigned short DRAM_space_base
unsigned short SRAM_space_base
unsigned char DRAM_size
unsigned char DRAM_SRAM_opt
unsigned char SRAM_size
unsigned char reserved
unsigned char LANC_error
unsigned char reserved1
unsigned char LANC_int_ctl
unsigned char LANC_berr_ctl
unsigned char SCSI_error
unsigned char general_inputs
unsigned char MVME_162_version
unsigned char SCSI_int_ctl
unsigned long timer_cmp_3
unsigned long timer_cnt_3
unsigned long timer_cmp_4
unsigned long timer_cnt_4
unsigned char bus_clk
unsigned char PROM_acc_time_ctl
unsigned char FLASH_acc_time_ctl
unsigned char ABORT_int_ctl
unsigned char RESET_ctl
unsigned char watchdog_timer_ctl
unsigned char acc_watchdog_time_base_sel
unsigned char reserved2
unsigned char DRAM_ctl
unsigned char reserved4
unsigned char MPU_status
unsigned char reserved3
unsigned long prescaler_count
