RTEMS 5.2
lpc_eth_driver_entry Struct Reference
struct arpcom arpcom
lpc_eth_state state
struct rtems_mdio_info mdio
uint32_t anlpar
rtems_id receive_task
rtems_id transmit_task
unsigned rx_unit_count
unsigned tx_unit_count
volatile lpc_eth_transfer_descriptorrx_desc_table
volatile lpc_eth_receive_statusrx_status_table
struct mbuf ** rx_mbuf_table
volatile lpc_eth_transfer_descriptortx_desc_table
volatile uint32_t * tx_status_table
void * tx_buf_table
unsigned received_frames
unsigned receive_interrupts
unsigned transmitted_frames
unsigned transmit_interrupts
unsigned receive_drop_errors
unsigned receive_overrun_errors
unsigned receive_fragment_errors
unsigned receive_crc_errors
unsigned receive_symbol_errors
unsigned receive_length_errors
unsigned receive_alignment_errors
unsigned receive_no_descriptor_errors
unsigned receive_fatal_errors
unsigned transmit_underrun_errors
unsigned transmit_late_collision_errors
unsigned transmit_excessive_collision_errors
unsigned transmit_excessive_defer_errors
unsigned transmit_no_descriptor_errors
unsigned transmit_overflow_errors
unsigned transmit_fatal_errors
uint32_t phy_id
int phy
rtems_vector_number interrupt_number
rtems_id control_task
