RTEMS 5.2
i596_dump_result Struct Reference
unsigned char bf
unsigned char config_bytes [11]
unsigned char reserved1 [2]
unsigned char ia_bytes [6]
unsigned short last_tx_status
unsigned short tx_crc_byte01
unsigned short tx_crc_byte23
unsigned short rx_crc_byte01
unsigned short rx_crc_byte23
unsigned short rx_temp_mem01
unsigned short rx_temp_mem23
unsigned short rx_temp_mem45
unsigned short last_rx_status
unsigned short hash_reg01
unsigned short hash_reg23
unsigned short hash_reg45
unsigned short hash_reg67
unsigned short slot_time_counter
unsigned short wait_time_counter
unsigned short rx_frame_length
unsigned long reserved2
unsigned long cb_in3
unsigned long cb_in2
unsigned long cb_in1
unsigned long la_cb_addr
unsigned long rdb_pointer
unsigned long int_memory
unsigned long rfd_size
unsigned long tbd_pointer
unsigned long base_addr
unsigned long ru_temp_reg
unsigned long tcb_count
unsigned long next_rb_size
unsigned long next_rb_addr
unsigned long curr_rb_size
unsigned long la_rbd_addr
unsigned long next_rbd_addr
unsigned long curr_rbd_addr
unsigned long curr_rb_count
unsigned long next_fd_addr
unsigned long curr_fd_add
unsigned long temp_cu_reg
unsigned long next_tb_count
unsigned long buffer_addr
unsigned long la_tbd_addr
unsigned long next_tbd_addr
unsigned long cb_command
unsigned long next_cb_addr
unsigned long curr_cb_addr
unsigned long scb_cmd_word
unsigned long scb_pointer
unsigned long cb_stat_word
unsigned long mm_lfsr
unsigned char micro_machine_bit_array [28]
unsigned char cu_port [16]
unsigned long mm_alu
unsigned long reserved3
unsigned long mm_temp_a_rr
unsigned long tx_dma_b_cnt
unsigned long mm_input_port_addr_reg
unsigned long tx_dma_addr
unsigned long mm_port_reg1
unsigned long rx_dma_b_cnt
unsigned long mm_port_reg2
unsigned long rx_dma_addr
unsigned long reserved4
unsigned long bus_t_timers
unsigned long diu_cntrl_reg
unsigned long reserved5
unsigned long sysbus
unsigned long biu_cntrl_reg
unsigned long mm_disp_reg
unsigned long mm_status_reg
unsigned short dump_status
