RTEMS 5.2
grtm_ioc_config Struct Reference
unsigned char mode
unsigned short frame_length
unsigned short limit
unsigned int as_marker
unsigned short phy_subrate
unsigned short phy_symbolrate
unsigned char phy_opts
unsigned char code_rsdep
unsigned char code_ce_rate
unsigned char code_csel
unsigned int code_opts
unsigned char all_izlen
unsigned char all_opts
unsigned char mf_opts
unsigned short idle_scid
unsigned char idle_vcid
unsigned char idle_opts
unsigned int enable_cnt
int isr_desc_proc
int blocking
rtems_interval timeout
