RTEMS 5.2
Public Member Functions | Data Fields
grcan_priv Struct Reference
 SPIN_DECLARE (devlock)
struct drvmgr_devdev
char devName [32]
unsigned int baseaddr
unsigned int ram_base
struct grcan_regsregs
int irq
int minor
int open
int started
unsigned int channel
int flushing
unsigned int corefreq_hz
int fd_capable
void * _rx
void * _rx_hw
void * _tx
void * _tx_hw
void * txbuf_adr
void * rxbuf_adr
struct grcan_msgrx
struct grcan_msgtx
unsigned int rxbuf_size
unsigned int txbuf_size
int txblock
int rxblock
int txcomplete
int rxcomplete
struct grcan_filter sfilter
struct grcan_filter afilter
int config_changed
struct grcan_config config
struct grcan_stats stats
rtems_id rx_sem
rtems_id tx_sem
rtems_id txempty_sem
rtems_id dev_sem
