RTEMS 5.2
LEON_Register_Map Struct Reference
volatile unsigned int Memory_Config_1
volatile unsigned int Memory_Config_2
volatile unsigned int Edac_Control
volatile unsigned int Failed_Address
volatile unsigned int Memory_Status
volatile unsigned int Cache_Control
volatile unsigned int Power_Down
volatile unsigned int Write_Protection_1
volatile unsigned int Write_Protection_2
volatile unsigned int Leon_Configuration
volatile unsigned int dummy2
volatile unsigned int dummy3
volatile unsigned int dummy4
volatile unsigned int dummy5
volatile unsigned int dummy6
volatile unsigned int dummy7
volatile unsigned int Timer_Counter_1
volatile unsigned int Timer_Reload_1
volatile unsigned int Timer_Control_1
volatile unsigned int Watchdog
volatile unsigned int Timer_Counter_2
volatile unsigned int Timer_Reload_2
volatile unsigned int Timer_Control_2
volatile unsigned int dummy8
volatile unsigned int Scaler_Counter
volatile unsigned int Scaler_Reload
volatile unsigned int dummy9
volatile unsigned int dummy10
volatile unsigned int UART_Channel_1
volatile unsigned int UART_Status_1
volatile unsigned int UART_Control_1
volatile unsigned int UART_Scaler_1
volatile unsigned int UART_Channel_2
volatile unsigned int UART_Status_2
volatile unsigned int UART_Control_2
volatile unsigned int UART_Scaler_2
volatile unsigned int Interrupt_Mask
volatile unsigned int Interrupt_Pending
volatile unsigned int Interrupt_Force
volatile unsigned int Interrupt_Clear
volatile unsigned int PIO_Data
volatile unsigned int PIO_Direction
volatile unsigned int PIO_Interrupt
