RTEMS
5.2
bsps
include
grlib
spictrl.h
1
2
* SPICTRL SPI Driver interface.
3
4
* COPYRIGHT (c) 2009.
5
* Cobham Gaisler AB.
6
7
* The license and distribution terms for this file may be
8
* found in the file LICENSE in this distribution or at
9
* http://www.rtems.org/license/LICENSE.
10
11
12
#ifndef __SPICTRL_H__
13
#define __SPICTRL_H__
14
15
#ifdef __cplusplus
16
extern
"C"
17
#endif
18
19
extern
void
spictrl_register_drv (
void
20
21
/*** REGISTER LAYOUT ***/
22
struct
spictrl_regs
23
volatile
unsigned
int
capability;
/* 0x00 */
24
volatile
unsigned
int
resv[7];
/* 0x04 */
25
volatile
unsigned
int
mode;
/* 0x20 */
26
volatile
unsigned
int
event;
/* 0x24 */
27
volatile
unsigned
int
mask;
/* 0x28 */
28
volatile
unsigned
int
command;
/* 0x2c */
29
volatile
unsigned
int
tx;
/* 0x30 */
30
volatile
unsigned
int
rx;
/* 0x34 */
31
volatile
unsigned
int
slvsel;
/* 0x38 */
32
volatile
unsigned
int
am_slvsel;
/* 0x3c */
33
volatile
unsigned
int
am_cfg;
/* 0x40 */
34
volatile
unsigned
int
am_period;
/* 0x44 */
35
int
reserved0[2];
36
volatile
unsigned
int
am_mask[4];
/* 0x50-0x5C */
37
int
reserved1[(0x200-0x60)/4];
38
volatile
unsigned
int
am_tx[128];
/* 0x200-0x3FC */
39
volatile
unsigned
int
am_rx[128];
/* 0x400-0x5FC */
40
41
42
/* -- About automated periodic transfer mode --
43
44
* Core must support this feature.
45
46
* The SPI core must be configured in periodic mode before
47
* writing the data into the transfer FIFO which will be used
48
* mutiple times in different transfers, it will also make
49
* the receive FIFO to be updated.
50
51
* In periodic mode the following sequence is performed,
52
* 1. start()
53
* 2. ioctl(CONFIG, &config) - Enable periodic mode
54
* 3. set_address()
55
* 4. write() - Fills TX FIFO, this has some constraints
56
* 5. ioctl(START) - Starts the periodic transmission of the TX FIFO
57
* 6. read() - Read one response of the tranistted data. It will
58
* hang until data is available. If hanging is not an
59
* options use ioctl(STATUS)
60
* 7. go back to 6.
61
62
* 8. ioctl(STOP) - Stop to set up a new periodic or normal transfer
63
* 9. stop()
64
65
* Note that the the read length must equal the total write length.
66
67
68
/* Custom SPICTRL driver ioctl commands */
69
#define SPICTRL_IOCTL_PERIOD_START 5000
/* Start automated periodic transfer mode */
70
#define SPICTRL_IOCTL_PERIOD_STOP 5001
/* Stop to SPI core from doing periodic transfers */
71
#define SPICTRL_IOCTL_CONFIG 5002
/* Configure Periodic transfer mode (before calling write() and START) */
72
#define SPICTRL_IOCTL_STATUS 5003
/* Get status */
73
74
#define SPICTRL_IOCTL_PERIOD_READ 5005
/* Write transmit registers and mask register
75
* (only in automatic periodic mode)
76
* Note that it is probably prefferred to read
77
* the received words using the read() using
78
* operations instead.
79
80
#define SPICTRL_IOCTL_PERIOD_WRITE 5006
/* Read receive registers and mask register
81
* (only in automatic periodic mode) */
82
#define SPICTRL_IOCTL_REGS 5007
/* Get SPICTRL Register */
83
84
/* SPICTRL_IOCTL_CONFIG argument */
85
struct
spictrl_ioctl_config
86
int
clock_gap;
/* Clock GAP between */
87
unsigned
int
flags;
/* Normal mode flags */
88
int
periodic_mode;
/* 1=Enables Automated periodic transfers if supported by hardware */
89
unsigned
int
period;
/* Number of clocks between automated transfers are started */
90
unsigned
int
period_flags;
/* Options */
91
unsigned
int
period_slvsel;
/* Slave Select when transfer is not active, default is 0xffffffff */
92
93
#define SPICTRL_FLAGS_TAC 0x10
94
95
#define SPICTRL_PERIOD_FLAGS_ERPT 0x80
/* Trigger start-period from external signal */
96
#define SPICTRL_PERIOD_FLAGS_SEQ 0x40
97
#define SPICTRL_PERIOD_FLAGS_STRICT 0x20
98
#define SPICTRL_PERIOD_FLAGS_OVTB 0x10
99
#define SPICTRL_PERIOD_FLAGS_OVDB 0x08
100
#define SPICTRL_PERIOD_FLAGS_ASEL 0x04
101
#define SPICTRL_PERIOD_FLAGS_EACT 0x01
102
103
/* SPICTRL_IOCTL_PERIOD_READ and SPICTRL_IOCTL_PERIOD_WRITE Argument data structure
104
105
* Note that the order of reading the mask registers are different for read/write
106
* operation. See options notes.
107
108
struct
spictrl_period_io
109
int
options;
/* READ: bit0=Read Mask Registers into masks[].
110
* bit1=Read Receive registers according to masks[]
111
* (after reading masks).
112
113
* WRITE: bit0=Update Mask accoring to masks[].
114
* bit1=Update Transmit registers according to masks[].
115
* (before reading masks)
116
117
unsigned
int
masks[4];
118
119
void
*data;
/* Data read sequentially according to masks[] bit. */
120
121
122
#ifdef __cplusplus
123
124
#endif
125
126
#endif
Definition:
spictrl.h:79
spictrl_period_io
Definition:
spictrl.h:102
spictrl_regs
Definition:
spictrl.h:22
