RTEMS 5.2
sparc.h
1
14/*
15 * COPYRIGHT (c) 1989-2011.
16 * On-Line Applications Research Corporation (OAR).
17 *
18 * The license and distribution terms for this file may be
19 * found in the file LICENSE in this distribution or at
20 * http://www.rtems.org/license/LICENSE.
21 */
22
23#ifndef _RTEMS_SCORE_SPARC_H
24#define _RTEMS_SCORE_SPARC_H
25
27
28#ifdef __cplusplus
29extern "C" {
30#endif
31
32/*
33 *
34 * Currently recognized feature flags:
35 *
36 * + SPARC_HAS_FPU
37 * 0 - no HW FPU
38 * 1 - has HW FPU (assumed to be compatible w/90C602)
39 *
40 * + SPARC_HAS_BITSCAN
41 * 0 - does not have scan instructions
42 * 1 - has scan instruction (not currently implemented)
43 *
44 * + SPARC_NUMBER_OF_REGISTER_WINDOWS
45 * 8 is the most common number supported by SPARC implementations.
46 * SPARC_PSR_CWP_MASK is derived from this value.
47 */
48
55#define SPARC_HAS_BITSCAN 0
56
63#define SPARC_NUMBER_OF_REGISTER_WINDOWS 8
64
69#if defined(__FIX_LEON3FT_B2BST)
70 #define SPARC_LEON3FT_B2BST_NOP nop
71#else
72 #define SPARC_LEON3FT_B2BST_NOP
73#endif
74
80#if defined(_SOFT_FLOAT)
81 #define SPARC_HAS_FPU 0
82#else
83 #define SPARC_HAS_FPU 1
84#endif
85
90#if SPARC_HAS_FPU
91 #define CPU_MODEL_NAME "w/FPU"
92#else
93 #define CPU_MODEL_NAME "w/soft-float"
94#endif
95
99#define CPU_NAME "SPARC"
100
101/*
102 * Miscellaneous constants
103 */
104
110#if (SPARC_NUMBER_OF_REGISTER_WINDOWS == 8)
111 #define SPARC_PSR_CWP_MASK 0x07 /* bits 0 - 4 */
112#elif (SPARC_NUMBER_OF_REGISTER_WINDOWS == 16)
113 #define SPARC_PSR_CWP_MASK 0x0F /* bits 0 - 4 */
114#elif (SPARC_NUMBER_OF_REGISTER_WINDOWS == 32)
115 #define SPARC_PSR_CWP_MASK 0x1F /* bits 0 - 4 */
116#else
117 #error "Unsupported number of register windows for this cpu"
118#endif
119
121#define SPARC_PSR_ET_MASK 0x00000020 /* bit 5 */
123#define SPARC_PSR_PS_MASK 0x00000040 /* bit 6 */
125#define SPARC_PSR_S_MASK 0x00000080 /* bit 7 */
127#define SPARC_PSR_PIL_MASK 0x00000F00 /* bits 8 - 11 */
129#define SPARC_PSR_EF_MASK 0x00001000 /* bit 12 */
131#define SPARC_PSR_EC_MASK 0x00002000 /* bit 13 */
133#define SPARC_PSR_ICC_MASK 0x00F00000 /* bits 20 - 23 */
135#define SPARC_PSR_VER_MASK 0x0F000000 /* bits 24 - 27 */
137#define SPARC_PSR_IMPL_MASK 0xF0000000 /* bits 28 - 31 */
138
140#define SPARC_PSR_CWP_BIT_POSITION 0 /* bits 0 - 4 */
142#define SPARC_PSR_ET_BIT_POSITION 5 /* bit 5 */
144#define SPARC_PSR_PS_BIT_POSITION 6 /* bit 6 */
146#define SPARC_PSR_S_BIT_POSITION 7 /* bit 7 */
148#define SPARC_PSR_PIL_BIT_POSITION 8 /* bits 8 - 11 */
150#define SPARC_PSR_EF_BIT_POSITION 12 /* bit 12 */
152#define SPARC_PSR_EC_BIT_POSITION 13 /* bit 13 */
154#define SPARC_PSR_ICC_BIT_POSITION 20 /* bits 20 - 23 */
156#define SPARC_PSR_VER_BIT_POSITION 24 /* bits 24 - 27 */
158#define SPARC_PSR_IMPL_BIT_POSITION 28 /* bits 28 - 31 */
159
160#define LEON3_ASR17_PROCESSOR_INDEX_SHIFT 28
161
162/* SPARC Software Trap number definitions */
163#define SPARC_SWTRAP_SYSCALL 0
164#define SPARC_SWTRAP_IRQDIS 9
165#define SPARC_SWTRAP_IRQEN 10
166#if SPARC_HAS_FPU == 1
167#define SPARC_SWTRAP_IRQDIS_FP 11
168#endif
169
170#ifndef ASM
171
175#define nop() \
176 do { \
177 __asm__ volatile ( "nop" ); \
178 } while ( 0 )
179
185#if defined(RTEMS_PARAVIRT)
186
187uint32_t _SPARC_Get_PSR( void );
188
189#define sparc_get_psr( _psr ) \
190 (_psr) = _SPARC_Get_PSR()
191
192#else /* RTEMS_PARAVIRT */
193
194#define sparc_get_psr( _psr ) \
195 do { \
196 (_psr) = 0; \
197 __asm__ volatile( "rd %%psr, %0" : "=r" (_psr) : "0" (_psr) ); \
198 } while ( 0 )
199
200#endif /* RTEMS_PARAVIRT */
201
207#if defined(RTEMS_PARAVIRT)
208
209void _SPARC_Set_PSR( uint32_t new_psr );
210
211#define sparc_set_psr( _psr ) \
212 _SPARC_Set_PSR( _psr )
213
214#else /* RTEMS_PARAVIRT */
215
216#define sparc_set_psr( _psr ) \
217 do { \
218 __asm__ volatile ( "mov %0, %%psr " : "=r" ((_psr)) : "0" ((_psr)) ); \
219 nop(); \
220 nop(); \
221 nop(); \
222 } while ( 0 )
223
224#endif /* RTEMS_PARAVIRT */
225
231#if defined(RTEMS_PARAVIRT)
232
233uint32_t _SPARC_Get_TBR( void );
234
235#define sparc_get_tbr( _tbr ) \
236 (_tbr) = _SPARC_Get_TBR()
237
238#else /* RTEMS_PARAVIRT */
239
240#define sparc_get_tbr( _tbr ) \
241 do { \
242 (_tbr) = 0; /* to avoid unitialized warnings */ \
243 __asm__ volatile( "rd %%tbr, %0" : "=r" (_tbr) : "0" (_tbr) ); \
244 } while ( 0 )
245
246#endif /* RTEMS_PARAVIRT */
247
253#if defined(RTEMS_PARAVIRT)
254
255void _SPARC_Set_TBR( uint32_t new_tbr );
256
257#define sparc_set_tbr( _tbr ) \
258 _SPARC_Set_TBR((_tbr))
259
260#else /* RTEMS_PARAVIRT */
261
262#define sparc_set_tbr( _tbr ) \
263 do { \
264 __asm__ volatile( "wr %0, 0, %%tbr" : "=r" (_tbr) : "0" (_tbr) ); \
265 } while ( 0 )
266
267#endif /* RTEMS_PARAVIRT */
268
274#define sparc_get_wim( _wim ) \
275 do { \
276 __asm__ volatile( "rd %%wim, %0" : "=r" (_wim) : "0" (_wim) ); \
277 } while ( 0 )
278
284#define sparc_set_wim( _wim ) \
285 do { \
286 __asm__ volatile( "wr %0, %%wim" : "=r" (_wim) : "0" (_wim) ); \
287 nop(); \
288 nop(); \
289 nop(); \
290 } while ( 0 )
291
297#define sparc_get_y( _y ) \
298 do { \
299 __asm__ volatile( "rd %%y, %0" : "=r" (_y) : "0" (_y) ); \
300 } while ( 0 )
301
307#define sparc_set_y( _y ) \
308 do { \
309 __asm__ volatile( "wr %0, %%y" : "=r" (_y) : "0" (_y) ); \
310 } while ( 0 )
311
319static inline uint32_t sparc_disable_interrupts(void)
320{
321 register uint32_t psr __asm__("g1"); /* return value of trap handler */
322 __asm__ volatile ( "ta %1\n\t" : "=r" (psr) : "i" (SPARC_SWTRAP_IRQDIS));
323 return psr;
324}
325
333static inline void sparc_enable_interrupts(uint32_t psr)
334{
335 register uint32_t _psr __asm__("g1") = psr; /* input to trap handler */
336
337 /*
338 * The trap instruction has a higher trap priority than the interrupts
339 * according to "The SPARC Architecture Manual: Version 8", Table 7-1
340 * "Exception and Interrupt Request Priority and tt Values". Add a nop to
341 * prevent a trap instruction right after the interrupt enable trap.
342 */
343 __asm__ volatile ( "ta %0\nnop\n" :: "i" (SPARC_SWTRAP_IRQEN), "r" (_psr));
344}
345
368void sparc_syscall_exit(uint32_t exitcode1, uint32_t exitcode2)
370
378#define sparc_flash_interrupts( _psr ) \
379 do { \
380 sparc_enable_interrupts( (_psr) ); \
381 _psr = sparc_disable_interrupts(); \
382 } while ( 0 )
383
391#define sparc_get_interrupt_level( _level ) \
392 do { \
393 uint32_t _psr_level = 0; \
394 \
395 sparc_get_psr( _psr_level ); \
396 (_level) = \
397 (_psr_level & SPARC_PSR_PIL_MASK) >> SPARC_PSR_PIL_BIT_POSITION; \
398 } while ( 0 )
399
400static inline uint32_t _LEON3_Get_current_processor( void )
401{
402 uint32_t asr17;
403
404 __asm__ volatile (
405 "rd %%asr17, %0"
406 : "=&r" (asr17)
407 );
408
409 return asr17 >> LEON3_ASR17_PROCESSOR_INDEX_SHIFT;
410}
411
412#endif
413
414#ifdef __cplusplus
415}
416#endif
417
418#endif /* _RTEMS_SCORE_SPARC_H */
Basic Definitions.
#define RTEMS_NO_RETURN
Definition: basedefs.h:102
register struct Per_CPU_Control *_SPARC_Per_CPU_current __asm__("g6")
The pointer to the current per-CPU control is available via register g6.
void sparc_syscall_exit(uint32_t exitcode1, uint32_t exitcode2) RTEMS_NO_RETURN
SPARC exit through system call 1.
