RTEMS 5.2
cpuimpl.h
1
7/*
8 * Copyright (c) 1989, 2007 On-Line Applications Research Corporation (OAR)
9 * Copyright (c) 2013, 2016 embedded brains GmbH
10 *
11 * The license and distribution terms for this file may be
12 * found in the file LICENSE in this distribution or at
13 * http://www.rtems.org/license/LICENSE.
14 */
15
16#ifndef _RTEMS_SCORE_CPUIMPL_H
17#define _RTEMS_SCORE_CPUIMPL_H
18
19#include <rtems/score/cpu.h>
20
32#define SPARC_MINIMUM_STACK_FRAME_SIZE 0x60
33
34/*
35 * Offsets of fields with CPU_Interrupt_frame for assembly routines.
36 */
37
39#define ISF_PSR_OFFSET SPARC_MINIMUM_STACK_FRAME_SIZE + 0x00
41#define ISF_PC_OFFSET SPARC_MINIMUM_STACK_FRAME_SIZE + 0x04
43#define ISF_NPC_OFFSET SPARC_MINIMUM_STACK_FRAME_SIZE + 0x08
45#define ISF_G1_OFFSET SPARC_MINIMUM_STACK_FRAME_SIZE + 0x0c
47#define ISF_G2_OFFSET SPARC_MINIMUM_STACK_FRAME_SIZE + 0x10
49#define ISF_G3_OFFSET SPARC_MINIMUM_STACK_FRAME_SIZE + 0x14
51#define ISF_G4_OFFSET SPARC_MINIMUM_STACK_FRAME_SIZE + 0x18
53#define ISF_G5_OFFSET SPARC_MINIMUM_STACK_FRAME_SIZE + 0x1c
55#define ISF_G7_OFFSET SPARC_MINIMUM_STACK_FRAME_SIZE + 0x24
57#define ISF_I0_OFFSET SPARC_MINIMUM_STACK_FRAME_SIZE + 0x28
59#define ISF_I1_OFFSET SPARC_MINIMUM_STACK_FRAME_SIZE + 0x2c
61#define ISF_I2_OFFSET SPARC_MINIMUM_STACK_FRAME_SIZE + 0x30
63#define ISF_I3_OFFSET SPARC_MINIMUM_STACK_FRAME_SIZE + 0x34
65#define ISF_I4_OFFSET SPARC_MINIMUM_STACK_FRAME_SIZE + 0x38
67#define ISF_I5_OFFSET SPARC_MINIMUM_STACK_FRAME_SIZE + 0x3c
69#define ISF_I6_FP_OFFSET SPARC_MINIMUM_STACK_FRAME_SIZE + 0x40
71#define ISF_I7_OFFSET SPARC_MINIMUM_STACK_FRAME_SIZE + 0x44
73#define ISF_Y_OFFSET SPARC_MINIMUM_STACK_FRAME_SIZE + 0x48
75#define ISF_TPC_OFFSET SPARC_MINIMUM_STACK_FRAME_SIZE + 0x4c
76
78#define CPU_INTERRUPT_FRAME_SIZE SPARC_MINIMUM_STACK_FRAME_SIZE + 0x50
79
80#define SPARC_FP_CONTEXT_OFFSET_F0_F1 0
81#define SPARC_FP_CONTEXT_OFFSET_F2_F3 8
82#define SPARC_FP_CONTEXT_OFFSET_F4_F5 16
83#define SPARC_FP_CONTEXT_OFFSET_F6_F7 24
84#define SPARC_FP_CONTEXT_OFFSET_F8_F9 32
85#define SPARC_FP_CONTEXT_OFFSET_F10_F11 40
86#define SPARC_FP_CONTEXT_OFFSET_F12_F13 48
87#define SPARC_FP_CONTEXT_OFFSET_F14_F15 56
88#define SPARC_FP_CONTEXT_OFFSET_F16_F17 64
89#define SPARC_FP_CONTEXT_OFFSET_F18_F19 72
90#define SPARC_FP_CONTEXT_OFFSET_F20_F21 80
91#define SPARC_FP_CONTEXT_OFFSET_F22_F23 88
92#define SPARC_FP_CONTEXT_OFFSET_F24_F25 96
93#define SPARC_FP_CONTEXT_OFFSET_F26_F27 104
94#define SPARC_FP_CONTEXT_OFFSET_F28_F29 112
95#define SPARC_FP_CONTEXT_OFFSET_F30_F31 120
96#define SPARC_FP_CONTEXT_OFFSET_FSR 128
97
98#if ( SPARC_HAS_FPU == 1 )
99 #define CPU_PER_CPU_CONTROL_SIZE 8
100#else
101 #define CPU_PER_CPU_CONTROL_SIZE 0
102#endif
103
104#if ( SPARC_HAS_FPU == 1 )
109 #define SPARC_PER_CPU_FSR_OFFSET 0
110
111 #if defined(SPARC_USE_LAZY_FP_SWITCH)
116 #define SPARC_PER_CPU_FP_OWNER_OFFSET 4
117 #endif
118#endif
119
120#ifndef ASM
121
122#ifdef __cplusplus
123extern "C" {
124#endif
125
126typedef struct {
127#if ( SPARC_HAS_FPU == 1 )
135 uint32_t fsr;
136
137#if defined(SPARC_USE_LAZY_FP_SWITCH)
141 struct _Thread_Control *fp_owner;
142#else
143 /* See Per_CPU_Control::Interrupt_frame */
144 uint32_t reserved_for_alignment_of_interrupt_frame;
145#endif
146#endif
148
153register struct Per_CPU_Control *_SPARC_Per_CPU_current __asm__( "g6" );
154
155#define _CPU_Get_current_per_CPU_control() _SPARC_Per_CPU_current
156
157#define _CPU_Get_thread_executing() ( _SPARC_Per_CPU_current->executing )
158
159void _CPU_Context_volatile_clobber( uintptr_t pattern );
160
161void _CPU_Context_validate( uintptr_t pattern );
162
164{
165 __asm__ volatile ( "unimp 0" );
166}
167
169{
170 __asm__ volatile ( "nop" );
171}
172
173#ifdef __cplusplus
174}
175#endif
176
177#endif /* ASM */
178
181#endif /* _RTEMS_SCORE_CPUIMPL_H */
#define RTEMS_INLINE_ROUTINE
Definition: basedefs.h:66
RTEMS_INLINE_ROUTINE void _CPU_Instruction_illegal(void)
Emits an illegal instruction.
Definition: cpuimpl.h:122
RTEMS_INLINE_ROUTINE void _CPU_Instruction_no_operation(void)
Emits a no operation instruction (nop).
Definition: cpuimpl.h:132
register struct Per_CPU_Control *_SPARC_Per_CPU_current __asm__("g6")
The pointer to the current per-CPU control is available via register g6.
The CPU specific per-CPU control.
Definition: cpuimpl.h:54
Per CPU Core Structure.
Definition: percpu.h:347
Definition: thread.h:732
